E-Tuners / Custom Hardparts
  • 1 Post By Cevaes_64
 Old 06-09-2013, 06:17 PM   #1
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
Default Guardian Angel
After spending all that hard earned money on modifying and tuning you car, buying this product will give you the tranquility and the peace of mind you need, Over-boosting could happen to any of us, either by malfunctioning parts or an improper tune, and the results are pretty bad, So if you still don`t have this, YOU NEED THIS, do the math, engine replacement vs Angel Guardian.... looks pretty simple now doesn't it?
Its a pretty easy and straight forward install and is backed up by Stratified who will stay behind they products 100%.
I`m running a GFB RESPONSE and when running in VTA I use to have LOUD afterfires and in between shifts it was pretty rough and that was only 50/50, sometimes less than that. After installing my GA I turned my BOV 100% VTA just to try this out, and now i don't have any more backfires at all and in between shifts its smooth like butter, Just wanted to thank @Lex; for doing a great job by creating this device that saves our arses from major disasters.
If you have any questions about this, feel free to ask me i will me more than glad to help.
The Following 4 Users Say Thank You to Cevaes_64 For This Useful Post:
cshunter (06-10-2013), kish89 (06-10-2013), Lex (06-09-2013), TiGraySpeed6 (06-09-2013)
 Old 06-09-2013, 06:45 PM   #2
Limeybastard's Avatar
Posts: 578   (View Stats)
Limeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the worldLimeybastard is the leader of the world
Groaned at 68 Times in 30 Posts
Your engine bay is dirty Chico.
British Expat living in the land of the "3"
2013 W/tech
Limeybastard is offline   Reply With Quote
The Following User Says Thank You to Limeybastard For This Useful Post:
Cevaes_64 (06-09-2013)
 Old 06-09-2013, 06:49 PM   #3
Cevaes_64's Avatar
Its been raining a lot Limey, you should know that =)
Limeybastard likes this.
 Old 06-09-2013, 07:01 PM   #4
aldekei's Avatar
Posts: 831   (View Stats)
aldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the world
@Cevaes_64; I'm running the GFB 100% vta with a GA as well, however, I found that using a softer spring further improved drivability.
The spring is pretty cheap and a couple of turns to add a little load seems just right.
tapawhat
HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke
CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust
Beachshoer Intake Manifold P/P /w VTCS Delete
Sure Shortcut | Sure Anchors | Sure 1/8 TIG
Cobb AP | Cobb FMIC | Cobb Sport Springs
ATP GT3071R /w Stratified Boost Dial
Stratified Automotive Guardian Angel
Go Fast Bits Respons (100% VTA)
Autotech Internals
I tune myself, bitches
aldekei is offline   Reply With Quote
The Following 2 Users Say Thank You to aldekei For This Useful Post:
Cevaes_64 (06-09-2013), TiGraySpeed6 (06-09-2013)
 Old 06-09-2013, 07:04 PM   #5
Cevaes_64's Avatar
tapawhat
Thanks, pretty good info, any links to the softer spring?
 Old 06-09-2013, 07:17 PM   #6
aldekei's Avatar
I talked to the guys at Edge and they were able to track one down for me.
tapawhat
Autotech Internals
 Old 06-09-2013, 07:45 PM   #7
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
*afterfires
Mortose (06-09-2013)
Guardian Angel VTA...how? iammike 2010 MS3 - Engine, Transmission & Driveline 21 11-23-2012 12:41 AM
A Guardian Angel Looking Over Me...... Novej Stratified Automotive Controls 3 09-07-2012 05:22 PM
Guardian Angel BPC compatibility. himurax13 Stratified Automotive Controls 25 07-09-2012 06:10 AM
Guardian Angel help? MS6FL Mazdaspeed3/6 General Discussion 2 04-28-2012 07:13 PM
Page generated in 0.28057 seconds with 24 queries
