E-Tuners / Custom Hardparts
Like Tree10Likes
 Old 10-28-2015, 12:55 PM   #1
aviator79's Avatar
Posts: 3,934   (View Stats)
Originally Posted by boostedms3 View Post
does it work with synapse bov???
It depends on how the valve is setup. The synapse can be setup in both push and pull type, so yes it would work with it.
The Synapse Diverter valve can be setup as both push/pull but the BOV cannot. So I assume no work with BOV.
And difference between V1 and V2?
This so I don't really need?
At this time this feature is only available when the GA is purchased directly from Stratified** The GA V2 now includes the option to have a 4 bar MAP sensor output at no extra cost! The Guardian Angel's 4 bar MAP sensor can now be integrated into your vehicles harness replacing your OEM MAP sensor. This feature requires simple tuning in order to work properly. This eliminates the need to purchase a costly aftermarket MAP sensor for your turbocharged vehicle!
The Guardian Angel V2 (GA V2) WITH Adjustable Vent to Atmosphere (VTA) Valve Control is designed to protect your turbocharged motor from one of the worst catastrophes: uncontrollable OVERBOOST! This is the best investment you can make in protecting your tuned turbocharged engine from failure.
The GA V2 VTA Adjust Feature allows you to tune the response of your bypass valve! This is a first and unique to market feature not offered anywhere else. You can adjust how quickly your BOV/BPV releases during shifting and how quickly it closes back up. This feature also allows you to run your BPV/BOV in VTA mode without affecting your fuel trims or idle!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/guardian-angel-your-motor-81202/
81202 Aluminum Clutch Shoes This thread Refback 11-19-2012 01:48 PM
MS3: "Guardian Angel" for your motor This thread Refback 05-20-2011 01:30 PM
Angel Eyes? Sparky_86 MazdaSpeed 6 - How-To's 26 05-20-2010 04:58 PM
Angel Eyes TXspeed3 MazdaSpeed 3/6 - Appearance 2 06-28-2009 08:36 PM
Angel Eyes Ballast kingpin748 Mazdaspeed3/6 General Discussion 0 04-20-2009 04:53 PM
Twilight Cars The Mercedes Guardian Haltech Automotive News 0 04-07-2009 08:00 PM
Page generated in 0.33393 seconds with 22 queries
