E-Tuners / Custom Hardparts
Like Tree10Likes
 Old 05-19-2011, 11:22 PM   #1
Default The Guardian Angel for your motor
Some of you may know this - but I own a small company where we build tuning solutions. Our focus so far has been with older vehicles and Megasquirt - the name is Stratified Automotive Controls. You can check out the site if you like at Stratified Automotive Controls.
When Joe (FORZDA) blew his motor due to a boost spike while tuning, I came up with an idea for a product that I feel can benefit the MS community. We built a prototype and are testing on the MS3 and I want to test the waters before going with a full on production.
The Guardian Angel is an electromechanical device that prevents boost spikes or uncontrolled boost. It attaches to the BOV, has a threshold that you set (up to 44psi) and will release the BOV if you go above that threshold. It resets itself automatically once the boost has left the "danger zone."
There are several nice things about this:
- This will save your butt from all kinds of boost spikes and uncontrolled boost - saving your motor in the process. We know boost spikes cause detonation and detonation pops motors.
- Wastegate mechanical failures such as popped off lines are averted
- Boost controller failure
- Tuning failures or distractions
- Perfect for tuning with the AP where changes are not in real time or when E-tuning
- Cold temps causing boost spikes etc
- This will work with stock and aftermarket valves
- If you're running a recirculating valve, the cut will be a soft one compared to the stock spark/fuel cut. So it won't be like hitting a wall which is nice if you're in the middle of passing or merging.
- There will be an LED that lets you know the system has been tripped so you don't sit there over-spinning the turbo.
- The valve will react very quickly - much quicker than our OEM cut does - especially since most of us set load cut much too high to help in the event of a spike
Essentially, I can pull the wastegate line off my super fast spooling K04, floor it, and this will save my butt and motor. Video of this coming up ... for now here's a short log showing how the car won't make more than 8psi at 80% wastegate duty cycle when the Guardian Angel is set to 8psi.
EDIT: Here's a short and not so exciting video
Don't mind the wires, that's just temporary for testing purposes.
The log above is from one of these pulls. I hit the threshold, it holds the limit (you can hear the turbo spooling), and I get off the throttle so the device is reset (LED goes off).
Notice how smoothly the car limits boost, my camera guy in the back moves around more because of the bumps in the road. No backfires or harsh cuts.
** I realize you don't see the boost gauge this is why I included the log **
#x202aGuardian Angel Prototype Road Test 2&#x202c‏" target="_blank">YouTube - &#x202aGuardian Angel Prototype Road Test 2&#x202c‏
Who is interested in a "save my ass, I fucked up, but at least it won't be a fail" device like this? Comments welcome and appreciated. If we go into production and offer it here, we'll setup vendorship as needed.
p057 likes this.
The Following 99 Users Say Thank You to Lex For This Useful Post:
-cj- (05-20-2011), 4G63 (05-20-2011), 802MS3 (05-20-2011), AJ713 (05-21-2011), ak_spray (05-20-2011), Alpha (05-20-2011), amoosenamedhank (05-20-2011), AZSPEED3 (05-20-2011), Blackspeed (07-19-2011), BlueStreak (05-21-2011), BLURSPORTS (05-26-2011), BobtailedSnail (01-30-2012), Cataphract_40 (05-20-2011), charlesfist (07-21-2011), ChidoriSpeed (09-12-2011), Ckmazdaspeed3 (05-20-2011), daafisch (05-20-2011), DaleNixon (05-20-2011), Dano (06-15-2011), Dash08 (05-20-2011), dereeek (01-29-2012), dizzydtrain (06-15-2011), djthom (07-19-2011), djuosnteisn (05-20-2011), doubleflusher (07-25-2011), dougefresh_ (07-24-2011), dphm (07-23-2011), drknyte (09-12-2011), DuBz (01-30-2012), eppopipe (05-21-2011), essejkcamraw (05-21-2011), Ferg (09-09-2011), Fobio (05-20-2011), FORZDA 1 (05-20-2011), FridayGt (05-20-2011), frivolous_rob (09-09-2011), fywdyl (05-20-2011), gtlaw (06-15-2011), Haltech (05-20-2011), Hamilton69 (09-12-2011), helmetface (08-27-2012), i8urgti (07-24-2011), JacksonMS30 (05-20-2011), jracer (05-20-2011), kgb (05-20-2011), kmac (05-20-2011), KusteLokal (05-22-2011), kylec_2003 (08-19-2011), LakeSTLMS3 (01-05-2012), laxplayermjd (05-22-2011), LiEast (05-24-2011), lifeownedme (07-23-2011), m4tic (05-20-2011), manelscout4life (05-20-2011), mason (06-24-2011), maxed_out_saloon (05-20-2011), MGM_GT3 (12-15-2011), Monotonous ONE (05-20-2011), MPSdriver (05-20-2011), MS6FL (02-28-2012), myt_tuf1 (05-21-2011), mzr0818 (05-20-2011), Nazarite (05-20-2011), neofandango (11-26-2011), nighthawk358 (05-22-2011), Nitr0EngiE (05-20-2011), NJSPEED3 (05-20-2011), Nliiitend1 (09-09-2011), Novej (01-05-2012), nycMS3 (05-19-2011), p057 (01-30-2012), phantom3 (08-13-2011), predapio (05-20-2011), PunjabiPlaya (05-20-2011), Realgib3 (07-20-2011), redneckrecon (05-20-2011), rfinkle2 (05-20-2011), ridenfish39 (05-20-2011), rigor (05-20-2011), Sacrilicious (01-31-2012), spnkr21 (05-20-2011), superskaterxes (05-20-2011), taf0422 (06-29-2011), Teethkikr (05-20-2011), TenaciousBoost (05-20-2011), TexasSpeed3 (05-21-2011), the_caruch (05-25-2011), TRex (05-20-2011), trf5000 (05-20-2011), triplejumper18 (05-20-2011), turd burglar (05-22-2011), urbansurfer (05-20-2011), vdgmcool (05-20-2011), wette460 (05-22-2011), Whiteboy (05-21-2011), wolly6973 (05-20-2011), xdm88 (09-12-2011), Zdraveca (01-29-2012), zpele (06-24-2011)
 Old 05-19-2011, 11:23 PM   #2
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
subbed. looks really interesting. I'll come back when in a better state of mind.
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
The Following User Says Thank You to PunjabiPlaya For This Useful Post:
Lex (05-20-2011)
 Old 05-19-2011, 11:26 PM   #3
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Subbed, very interested.
I'd also like something that cuts throttle when you see over 2* of knock for more than a few seconds.
edit: but that could be achieved via tuning much more easily.
The Following User Says Thank You to Speed3eak For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 05:58 AM   #4
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
Attaches to which BOV? A lot of them have different designs, so would it only work on a specific model?
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
The Following User Says Thank You to SRTie4k For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 06:07 AM   #5
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
obviously it is probably inline on the vacuum line that attaches to the bypass valve so it can be used with any.
The Following User Says Thank You to bova For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 06:12 AM   #6
TRex's Avatar
Posts: 3,139   (View Stats)
very intereseted
glad you thought about recirc for those that have the stock system or are still using recirc with an aftermarket system
i see it as just bpv to dump more when your current one cant react fast enough or cant dump enough
The Following User Says Thank You to TRex For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 06:14 AM   #7
kmac's Avatar
Posts: 1,792   (View Stats)
U sir are an innovator
The Following User Says Thank You to kmac For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 06:22 AM   #8
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
well done lex, cant wait to see more results!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
Lex (05-20-2011)
 Old 05-20-2011, 06:34 AM   #9
Subbed for pricing...
Lex (05-20-2011), nindoja (06-15-2011)
 Old 05-20-2011, 06:43 AM   #10
retrobmx63's Avatar
Posts: 436   (View Stats)
retrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the worldretrobmx63 is the leader of the world
A clarification question Lex. So let's say for example you only run 15-18psi, but you constantly spike to 21 psi after shifts. I install a Guardian Angel and set the threshold to idk, 20psi. So as I shift and approach 21psi, the Guardian Angel triggers my BPV to release pressure.
Does this mean I effectively cannot accelerate with boost anymore? Or is that once enough pressure is lost my BPV closes again and I resume rebuild pressure pretty quickly/seamlessly?
Is this example too minor? Or is this device really for devastating boost spikes that we should lift our foot and stop accelerating altogether?
Hey, do my fingers smell like your mother?
retrobmx63 is offline   Reply With Quote
The Following 3 Users Say Thank You to retrobmx63 For This Useful Post:
cbusby (05-20-2011), Lex (05-20-2011), Realgib3 (07-20-2011)
 Old 05-20-2011, 06:46 AM   #11
5.000000yeah
ridenfish39's Avatar
Posts: 1,269   (View Stats)
ridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the world
Groans: 44
Groaned at 30 Times in 18 Posts
Great idea!
Subbed for pricing also......
2012 MUSTANG 5.0 // BBK X_PIPE//FLOWMASTER HUSHPOWER //3.73 REAR//SVE DRIFTS//JLT OIL SEPARATOR//BMR LCAS//J+M PANHARD BAR//STEEDA PANHARD BRACE//AIR RAID//BAMA//CAT DELETES// LOUD AS HELL
ridenfish39 is offline   Reply With Quote
The Following User Says Thank You to ridenfish39 For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 06:50 AM   #12
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
Very interested in this. Are you gonna market it to other platforms as well?
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
The Following 3 Users Say Thank You to JacksonMS30 For This Useful Post:
djuosnteisn (05-20-2011), Lex (05-20-2011), rfinkle2 (05-20-2011)
 Old 05-20-2011, 07:22 AM   #13
Z-Indy's Avatar
Posts: 1,815   (View Stats)
Z-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the world
Groans: 35
My car would have throttle cut all the time while I'm cruising around in 3rd or 4th gear if I had something like that.
Now if it only cut throttle if throttle was wide open... that would potentially be useful.
2008.5 Black Mica MS3
Cobb AP and 30% E85 Dizzy Tune - Cobb SRI - CP-e RMM - JBR SSP & Solid Shifter Bushings - E4 heavy shift knob - Denso ITV22 plugs - 6000K HID lows - 3500k HID fogs - Ford XT-M5-QS Tranny fluid - RX8's (PC'd Anthracite) - Rubber hatch tray
It's not my fault I'm this way, I was homeschooled.
Z-Indy is offline   Reply With Quote
The Following 2 Users Say Thank You to Z-Indy For This Useful Post:
Lex (05-20-2011), Speed3eak (05-20-2011)
 Old 05-20-2011, 07:25 AM   #14
Blue 2 shims
Nazarite's Avatar
Posts: 2,254   (View Stats)
Groans: 66
So Lex, BT application question here. Will this prevent boost creep running BT's IWG? Because that could be a huge answer to prayer for a lot of guys here, and would definitely nudge me towards that route again.
Nazarite is offline   Reply With Quote
The Following User Says Thank You to Nazarite For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 07:30 AM   #15
bova's Avatar
Groans: 45
i dont think it will prevent the boost creep but it will prevent it from going over what ever psi level you don't want it to creep over
Lex (05-20-2011)
 Old 05-20-2011, 07:32 AM   #16
Ziggo's Avatar
Posts: 3,843   (View Stats)
Great idea/product. Subbing.
Ask Me About My:
Lex (05-20-2011)
 Old 05-20-2011, 07:39 AM   #17
trf5000's Avatar
Subbed, as I want this!
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following User Says Thank You to trf5000 For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 07:44 AM   #18
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
Man if I still had my MS3 I'd be all over this!
DaleNixon is offline   Reply With Quote
The Following User Says Thank You to DaleNixon For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 07:54 AM   #19
speedypollard's Avatar
Posts: 92   (View Stats)
speedypollard has much to be proud ofspeedypollard has much to be proud ofspeedypollard has much to be proud ofspeedypollard has much to be proud ofspeedypollard has much to be proud ofspeedypollard has much to be proud ofspeedypollard has much to be proud ofspeedypollard has much to be proud ofspeedypollard has much to be proud of
Great idea...wish I woulda had this on my last Evo which blew up cause the tuner let the boost spike to 36psi on the dyno!
speedypollard is offline   Reply With Quote
The Following User Says Thank You to speedypollard For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 07:56 AM   #20
Blue 2 shims
Nazarite's Avatar
Groans: 66
That's what I meant, thanks for clarifying.
Lex (05-20-2011)
 Old 05-20-2011, 08:00 AM   #21
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
Interested as well. Subd
The Following User Says Thank You to dizzydtrain For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 08:02 AM   #22
I can haz fast?
vdgmcool's Avatar
Posts: 467   (View Stats)
vdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the worldvdgmcool is the leader of the world
Very Interested!! Subbed
2012 Mazdaspeed 3 CWP - Cobb AP Stage 2+ OTS/Cobb SRI+TIP/Autotech HPFP Internals/JBR 80 duro RMM/JBR SSP/JBR Sway Bar/UR Race Pipe and Catback Exhaust//Corksport TMIC/Denso ITV22/15% Window Tint/Super Race Weighted Neo Chrome Shift Knob/Morimoto 5K HIDs/Cobb BPV XLE/Corksport Lowering Springs. 18 x 8 MB Battles wrapped in 235/40/18 Nitto NT 555 Extreme Performance Tires.
2008 Mazdaspeed 3 SSM - Sold
Mods: Cobb AP Stage 2 Base Map by Phate/Forge BPV(Blue 2 Shims)/JBR RMM/Stealth Black Cobb SRI/JBR SSP & Heavy Shift Knob/15% Window Tint/DDM 6k HIDs in Lows and Fogs/Hardwired Escort 9500i/Autotech Fuel Pump Internals/CNT Catless DP/CNT Catback Exhaust
vdgmcool is offline   Reply With Quote
The Following User Says Thank You to vdgmcool For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 08:56 AM   #23
Woah, lots of responses - thanks for this guys. Here's some clarification.
This *can* be used to control boost but you wouldn't want to use it as a boost controller in the long term since the turbo will work harder than it has to. It is a safety device, a safety net that will guard against mechanical, electrical and tuning issues should they get out of hand.
I will be posting a short video here in a few minutes in my MS3. You will see that once ~10psi (it was actually 8) is hit in any gear, boost won't go beyond this. Because my BOV is recirculating to the intake, the transition will be smooth and as you can see in the graph above the AFRs are maintained and safe. No harsh fuel and spark cuts.
If your BOV vents to atmosphere, it will still work but it will be more abrupt as the AFRs get richer since already metered air is escaping. This is what happens when you shift with an atm BOV anyways.
When setting this you want to experiment a little and set it above any "normal spikes" you're likely to see. So if you spike to 21psi, set it to around 23, or just a notch above your normal spike level. You can just do a few pulls and set this via the LED.
I want to set this up that once it's tripped, it will reset itself once the car is in vacuum once again.
Depending on how much air your turbo can push, once its tripped, you may see a drecrease in boost or boost staying the same. In any case, that boost spike will be stopped dead.
We plan to make this available for other platforms as well but want to start on the MS3 first because it is a prime example where fast turbo spool and spikes has caused the Boom Boom.
The Following 28 Users Say Thank You to Lex For This Useful Post:
-cj- (05-20-2011), AZSPEED3 (05-20-2011), charlesfist (07-21-2011), djuosnteisn (05-20-2011), dougefresh_ (07-24-2011), essejkcamraw (05-21-2011), Fobio (05-20-2011), fywdyl (05-20-2011), i8urgti (07-24-2011), JacksonMS30 (05-25-2011), jracer (05-21-2011), kgb (05-21-2011), LiEast (05-24-2011), manelscout4life (05-20-2011), mason (06-24-2011), MSMS3 (05-20-2011), predapio (05-20-2011), Realgib3 (07-20-2011), retrobmx63 (05-20-2011), rfinkle2 (05-20-2011), Speed3eak (05-20-2011), TenaciousBoost (05-20-2011), trf5000 (05-20-2011), turd burglar (05-22-2011), wette460 (05-22-2011), wolly6973 (05-20-2011), xdm88 (06-14-2011), zpele (06-24-2011)
 Old 05-20-2011, 09:22 AM   #24
fywdyl's Avatar
Posts: 370   (View Stats)
fywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the worldfywdyl is the leader of the world
This is awesome, def interested.
2010 Black Mica MS3
Mods to date:
Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071
Mods to come:
Driver Mod || Snow Performance Meth Kit
fywdyl is offline   Reply With Quote
The Following User Says Thank You to fywdyl For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 09:28 AM   #25
Ok here's a short video of this in action. Don't mind the wires, that's just temporary for testing purposes.
The log in the OP is from one of these pulls. I hit the threshold, it holds the limit (you can hear the turbo spooling), and I get off the throttle so the device is reset (LED goes off).
The Following 10 Users Say Thank You to Lex For This Useful Post:
802MS3 (05-20-2011), BlackMS6 (05-22-2011), charlesfist (07-21-2011), djuosnteisn (05-20-2011), dougefresh_ (07-24-2011), jracer (05-21-2011), kgb (05-21-2011), PunjabiPlaya (05-20-2011), rfinkle2 (05-20-2011), zpele (06-24-2011)
 Old 05-20-2011, 10:05 AM   #26
DaleNixon's Avatar
Groans: 91
Wow I finally get to see what Lex looks like!
The Following 2 Users Say Thank You to DaleNixon For This Useful Post:
kgb (05-21-2011), Lex (05-20-2011)
 Old 05-20-2011, 10:24 AM   #27
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
wow such an awesome idea and sounds really simplistic should not cost very much at all.
are you guys gonna test this with actual higher psi levels like upwards to 30 psi and see if all the different BOV can vent enough to be safe with all turbo setups, and if someone has a SSQV BOV aren't those much more restrictive and flow less ?
Lex (05-20-2011)
 Old 05-20-2011, 10:41 AM   #28
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
great idea, esp for guys who are going to BT and dealing with boost control issues...I'd like to help distribute this in Eastern Canada!
-- Mario Andretti --
The Following 3 Users Say Thank You to Fobio For This Useful Post:
-cj- (05-20-2011), Lex (05-20-2011), rfinkle2 (05-20-2011)
 Old 05-20-2011, 10:43 AM   #29
Well there's certainly enough support from what I can see here that we'll go ahead, finalize testing and development, and get a product out the door. I will update here with progress.
Fobio, I'll be in touch once we've got some units on hand. At that point we'll set up vendorship here as well. I've got another couple of ideas for the MS market
charlesfist (07-21-2011), Ckmazdaspeed3 (05-20-2011), djuosnteisn (05-20-2011), dougefresh_ (07-24-2011), JacksonMS30 (05-25-2011), kgb (05-21-2011), LiEast (05-24-2011), rfinkle2 (05-20-2011), wolly6973 (05-20-2011), zpele (06-24-2011)
 Old 05-20-2011, 10:48 AM   #30
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Is there a way to modify/add to this unit to cut boost if meth stops spraying? A simple voltage checker at the pump, perhaps?
That would be awesome.
'07 CWP MS3
Forged.
The Following 5 Users Say Thank You to BlueStreak For This Useful Post:
JacksonMS30 (05-25-2011), Lex (05-20-2011), LiEast (05-24-2011), wette460 (05-22-2011), wolly6973 (05-20-2011)
 Old 05-20-2011, 10:49 AM   #31
Already working on an integration with a WMI or NOS system that has a failsafe output.
The Following 17 Users Say Thank You to Lex For This Useful Post:
BlueStreak (05-20-2011), charlesfist (07-21-2011), Ckmazdaspeed3 (05-20-2011), Dano (06-15-2011), djuosnteisn (05-20-2011), dougefresh_ (07-24-2011), essejkcamraw (05-21-2011), Fobio (05-20-2011), JacksonMS30 (05-25-2011), LiEast (05-24-2011), p057 (01-30-2012), Realgib3 (07-20-2011), rfinkle2 (05-20-2011), wette460 (05-22-2011), Whiteboy (05-21-2011), wolly6973 (05-20-2011), zpele (07-25-2011)
 Old 05-20-2011, 11:30 AM   #32
TRex's Avatar
pics of implementation?
or worried about thieves?
patten this shit yo....
The Following 2 Users Say Thank You to TRex For This Useful Post:
dougefresh_ (07-24-2011), Lex (05-20-2011)
 Old 05-20-2011, 11:32 AM   #33
Nah, not too worried about thieves, it's just messy and strapped on with a bungy cord inside the engine bay. Not much to look at for now.
TRex (05-20-2011)
 Old 05-20-2011, 12:07 PM   #34
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
Would buy this combo in a heart beat!
2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune
1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked*
2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph
2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph
dsmluck is offline   Reply With Quote
The Following User Says Thank You to dsmluck For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 12:10 PM   #35
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
Groans: 65
Awesome news, thanks Lex. Can't wait to see more development and the final product.
The Following User Says Thank You to AZSPEED3 For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 12:16 PM   #36
wankular's Avatar
Posts: 4,343   (View Stats)
Great idea.
Is it going to come with a red beret?
2009 MS3 sport MGM
The Following 2 Users Say Thank You to wankular For This Useful Post:
Lex (05-20-2011), predapio (05-20-2011)
 Old 05-20-2011, 12:23 PM   #37
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
Groans: 38
subbed for pricing, I want it
25%E85FREEKPERMED
The Following User Says Thank You to themytb For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 12:58 PM   #38
maxed_out_saloon's Avatar
Posts: 689   (View Stats)
maxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the world
this is an awesome idea. cant wait for the final product to be out
maxed_out_saloon is offline   Reply With Quote
The Following User Says Thank You to maxed_out_saloon For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 01:05 PM   #39
xxdjfate76xx's Avatar
Posts: 1,446   (View Stats)
xxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the world
Groans: 31
this is awesome... Going cat less in the cold areas won't be such a gamble anymore
Project Gen1 MS3 coming thoon
xxdjfate76xx is offline   Reply With Quote
The Following User Says Thank You to xxdjfate76xx For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 01:13 PM   #40
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
good work son
The Following User Says Thank You to forcedinduktion For This Useful Post:
Lex (05-20-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/guardian-angel-your-motor-81202/
81202 Aluminum Clutch Shoes This thread Refback 11-19-2012 01:48 PM
MS3: "Guardian Angel" for your motor This thread Refback 05-20-2011 01:30 PM
Angel Eyes? Sparky_86 MazdaSpeed 6 - How-To's 26 05-20-2010 04:58 PM
Angel Eyes TXspeed3 MazdaSpeed 3/6 - Appearance 2 06-28-2009 08:36 PM
Angel Eyes Ballast kingpin748 Mazdaspeed3/6 General Discussion 0 04-20-2009 04:53 PM
Twilight Cars The Mercedes Guardian Haltech Automotive News 0 04-07-2009 08:00 PM
Page generated in 0.63404 seconds with 51 queries
