E-Tuners / Custom Hardparts
Like Tree10Likes
 Old 05-20-2011, 02:21 PM   #41
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
So even with stock maf (or is it map?) you could set this above where it stops reading accurately, and it would still work? So, i could tune for 22psi (on a 2871) and set this to go off at 24psi, even with the stock sensor which does not read above 22psi ish?
The Following 7 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
-cj- (05-20-2011), charlesfist (07-21-2011), dougefresh_ (07-24-2011), Lex (05-20-2011), manelscout4life (05-20-2011), rfinkle2 (05-20-2011), Speed3eak (05-20-2011)
 Old 05-20-2011, 02:30 PM   #42
It doesn't use the stock map at all There's no messing with the car's OEM wiring.
The Following 7 Users Say Thank You to Lex For This Useful Post:
-cj- (05-20-2011), charlesfist (07-21-2011), Ckmazdaspeed3 (05-20-2011), manelscout4life (05-20-2011), rfinkle2 (05-20-2011), Speed3eak (05-20-2011), wolly6973 (05-20-2011)
 Old 05-20-2011, 02:48 PM   #43
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Ingenuity, yet another reason why I'm on this forum.
You guys that help advance this platform, are all fucking geniuses...well done.
What a lovable bunch we are!!
The Following 7 Users Say Thank You to predapio For This Useful Post:
charlesfist (07-21-2011), Ckmazdaspeed3 (05-20-2011), dougefresh_ (07-24-2011), kmac (05-20-2011), Lex (05-20-2011), nindoja (06-15-2011), rfinkle2 (05-20-2011)
 Old 05-20-2011, 02:54 PM   #44
mzr0818's Avatar
Groans: 221
Awesome idea. As stated before always good for piece of mind. I think def needed for initial tuning BT.
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
The Following User Says Thank You to mzr0818 For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 03:17 PM   #45
magicka's Avatar
Posts: 520   (View Stats)
This is a great idea. I'm always in for peace of mind.
2009 CWP MS3 GT
The Following 2 Users Say Thank You to magicka For This Useful Post:
 Old 05-20-2011, 03:53 PM   #46
Ziggo's Avatar
Posts: 3,843   (View Stats)
This is what I may do with it.
Ask Me About My:
Ckmazdaspeed3 (05-20-2011), Lex (05-20-2011)
 Old 05-20-2011, 05:24 PM   #47
starscream's Avatar
Posts: 630   (View Stats)
Groans: 44
This...is...BALLIN'
Do want x2!
The Following User Says Thank You to starscream For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 06:28 PM   #48
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
has no one heard of a pop off valve? its like a blow off valve but also like what lex is doing but it's a bypass valve that is set to let off at a certain pressure. hks used to make one can't find it on their site now though.
lex's seems more versatile and easy to apply to all platforms.
The Following User Says Thank You to bova For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 07:08 PM   #49
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
the only downside I see to this is that it may potentially mask a unsafe, unfinished, or half-assed tune, but I guess the light going off should indicate that there's something wrong.
make the light really bright...and in a colour that really stands out in our car.
-- Mario Andretti --
The Following User Says Thank You to Fobio For This Useful Post:
Lex (05-20-2011)
 Old 05-20-2011, 08:02 PM   #50
That super bright red will light up the whole car so it can't be missed.
The idea here is that you notice the problem and do something about it. Although it can act like a boost controller you don't want to use it as such. The turbo would just be overspun for no reason and extended periods of time.
dougefresh_ (07-24-2011), manelscout4life (05-21-2011), rfinkle2 (05-20-2011), zpele (06-24-2011)
 Old 05-20-2011, 08:28 PM   #51
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
When are you planning on taking this product to market?? I'm definitely in for 1... If you need a tester, PM...
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
The Following User Says Thank You to -cj- For This Useful Post:
 Old 05-20-2011, 08:43 PM   #52
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
Very cool idea. Boost spikes are what scare me away from a downpipe. Looks like there may be a safeguard soon!
Great work!
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
The Following User Says Thank You to Hectik1 For This Useful Post:
Lex (05-21-2011)
 Old 05-20-2011, 08:48 PM   #53
ualeks's Avatar
Posts: 60   (View Stats)
ualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant futureualeks has a brilliant future
Would this gizmo work on a "pull style" BOV such as the HKS SSQV where boost pressure in the i/c tube hits the back of the BOV piston and effectively helps to keep the piston sealed?
I think I know how it will work on the typical OEM style valve, but I'm not sure how you can get the HKS style valve to dump boost pressure without somehow creating vaccum in the "signal" hose from the manifold.
ualeks is offline   Reply With Quote
The Following User Says Thank You to ualeks For This Useful Post:
Lex (05-21-2011)
 Old 05-20-2011, 09:06 PM   #54
JumpingJackson's Avatar
Posts: 967   (View Stats)
What if the tube on your failsafe pops off
2006 Titanium Gray MS6 Mods:
DCR - Built Longblock with Pauter Rods , Wiseco 8.9:1 Pistons, Stiffer Valvesprings, P&P Head Upgraded VVT Actuator
Cobb AccessPort + 3 Bar Map Sensor
CP-E TIP , RMM
Aquamist HFS-4 WMI Injection System
Bullseye - T3 .55AR S259 Turbo
Synapse - BOV
Custom - Ceramic Coated T3 Exhaust Manifold , 3" T3 Downpipe, 3"-2.5" Dual Catback Exhaust, 3" MAF SRI, FMIC
PT-P CDFP + Walbro 255 Intank Pump + Fuelabs Adj. FPR + -6 AN Feed/Return
Turbine Tech / Street Unit - Front & Rear Diff Mount
eDesign Audio - NINe.2x 760W AMP , 2x 11Kv.2 10" Subwoofers
The Following User Says Thank You to JumpingJackson For This Useful Post:
Lex (05-21-2011)
 Old 05-20-2011, 09:18 PM   #55
-cj-'s Avatar
You run another one of Lex's failsafe valves to watch the first... They're stackable. Your bank account is your limit!
The Following 4 Users Say Thank You to -cj- For This Useful Post:
JacksonMS30 (05-25-2011), Lex (05-21-2011), p057 (06-03-2012), predapio (05-21-2011)
 Old 05-20-2011, 09:44 PM   #56
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
mee too lol
at 104000 2 bent rods
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
Lex (05-21-2011)
 Old 05-21-2011, 01:09 AM   #57
Thanks for the offer - will be finalizing the design and doing testing and we will probably send out some beta versions - as you guys know I won't have anything leave my hands before it's passed through the ringer. I won't say 2 weeks Will keep this thread updated.
Yes, the solution will work with poppet type valves.
Well that depends on which tube "pops off." But if the tune, the wastegate, and the failsafe fail, sometimes it's safe to say fail was just meant to be Up to you on how you want to layer the safety nets and how many you want.
-cj- (05-21-2011), dougefresh_ (07-24-2011), kgb (05-21-2011)
 Old 05-21-2011, 03:33 AM   #58
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
Anything that gives me some more piece of mind...I am in! Will test it for you 2!
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
The Following User Says Thank You to Whiteboy For This Useful Post:
Lex (05-21-2011)
 Old 05-21-2011, 04:05 AM   #59
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
subbed great product idea and can and will be used on a shit ton of projects. good work
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline   Reply With Quote
The Following User Says Thank You to TexasSpeed3 For This Useful Post:
Lex (05-21-2011)
 Old 05-22-2011, 10:17 AM   #60
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
subbed .good work
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
The Following User Says Thank You to laxplayermjd For This Useful Post:
Lex (05-24-2011)
 Old 05-22-2011, 08:19 PM   #61
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
The Following User Says Thank You to wette460 For This Useful Post:
Lex (05-24-2011)
 Old 05-22-2011, 08:30 PM   #62
KusteLokal's Avatar
Posts: 2,664   (View Stats)
Groans: 124
subbed... i want it
1995 Miata 1.8
2006 MS6 Sold
The Following User Says Thank You to KusteLokal For This Useful Post:
Lex (05-24-2011)
 Old 05-22-2011, 08:36 PM   #63
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
I fucking love this forum. I can finally run a simple IWG setup, catless, in the cold. Thanks for the hard work and research. I can't wait to see the final product!
Can you add a audible alarm similar to this along with a blinding light?
AtTheDriveIn is offline   Reply With Quote
The Following User Says Thank You to AtTheDriveIn For This Useful Post:
Lex (05-24-2011)
 Old 05-22-2011, 08:41 PM   #64
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Hmmm, now should i wire up my 3 bar map, oooooor just wait for this
NO! No way am I havin a dick made outta hamburger!
stocking out, buy my big turbo shit here, http://www.mazdaspeedforum.org/forum/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives
The Following User Says Thank You to turd burglar For This Useful Post:
Lex (05-24-2011)
 Old 05-22-2011, 09:04 PM   #65
event's Avatar
Posts: 521   (View Stats)
event is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the world
Will it work with the MS6 as well? if so, I'd be interested if it's not too expensive...
event is offline   Reply With Quote
The Following User Says Thank You to event For This Useful Post:
Lex (05-24-2011)
 Old 05-23-2011, 05:43 AM   #66
bova's Avatar
Groans: 45
it will work on whatever car you want to put it on
Lex (05-24-2011)
 Old 05-24-2011, 05:35 PM   #67
ryno077's Avatar
Posts: 58   (View Stats)
ryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond repute
Subbed for a awesome idea
07 MS3 GT
CPE catted DP & CBE // CPE HPFP // Corksport interior LEDs // Cobb AP // JBR Trilogy 88 Mounts // JBR OCC // Sensen Shocks // Centric Rotors // EBC Red Pads // JBR Intake // JBR Battery Tray
ryno077 is offline   Reply With Quote
The Following User Says Thank You to ryno077 For This Useful Post:
Lex (05-24-2011)
 Old 05-24-2011, 05:53 PM   #68
LiEast's Avatar
Posts: 582   (View Stats)
LiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the world
im so getting one! this will really keep my worrying at a low... deff interested for a combo fail safe for meth!
lex your going to make millions lol well done
2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor
PERM!
LiEast is offline   Reply With Quote
The Following User Says Thank You to LiEast For This Useful Post:
Lex (05-24-2011)
 Old 05-24-2011, 11:16 PM   #69
The brain will be in the engine bay - the hassle of bringing a buzzer into the cabin is probably not worth it.
Thanks for the replies everyone. This will work with all turbo cars.
djuosnteisn (05-25-2011), dougefresh_ (07-24-2011), kgb (05-26-2011), rfinkle2 (05-25-2011), turd burglar (05-24-2011), zpele (06-24-2011)
 Old 06-15-2011, 02:24 PM   #70
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
as usual I am late to the game but this is a very interesting concept and an absolutely GREAT idea. What better way to control runaway boost than to dump it from the intake tract.
again absolute pure genius!
P.S. I want to try one and see just how tunable and how fast reacting it will be.
Lex (06-15-2011)
 Old 06-15-2011, 02:34 PM   #71
Updates @Lex?
Lex (06-15-2011)
 Old 06-15-2011, 02:37 PM   #72
Just working out the details to finalize the product. It takes a little while to get something that works well and looks good ready for the market. Everything from final design to supply chain setup takes a little while ...
The Following 12 Users Say Thank You to Lex For This Useful Post:
BlueStreak (06-16-2011), Broxer (06-15-2011), charlesfist (07-21-2011), Ckmazdaspeed3 (06-15-2011), Dano (06-15-2011), djuosnteisn (06-15-2011), jmhinkle (06-21-2011), rfinkle2 (06-15-2011), rigor (06-27-2011), sick_role (06-16-2011), wolly6973 (06-15-2011), zpele (06-24-2011)
 Old 06-15-2011, 02:44 PM   #73
I'm just glad to hear that you are still working on it.
Lex (06-21-2011)
 Old 06-15-2011, 02:45 PM   #74
Trail of Fail
Dano's Avatar
Already working on an integration with a WMI or NOS system that has a failsafe output.
I actually quit using my actual FS boost cut sol due to the fact it slowed spoolup to much. I now simply rely on the FS controller to power my lights in the dash. Big red light comes on = lift bitch! hahah
This would be a great integration option for the guardian!
There are actually at least two types of output on FS controllers. One provides a 12v signal at fault and the other [mine] provides a 12v signal UNTIL there is a fault.
You would need to have inputs for both types or just use an SPDT relay, which is what I do to trigger my red light when 12v signal is lost. I am sure there are other more elegant solutions to this.
The Following 4 Users Say Thank You to Dano For This Useful Post:
djuosnteisn (06-15-2011), dougefresh_ (07-24-2011), Lex (06-21-2011), rfinkle2 (06-15-2011)
 Old 06-15-2011, 02:48 PM   #75
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
I'd definately be interested in this, be doing my TBE in a few months!
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following User Says Thank You to Broxer For This Useful Post:
Lex (06-21-2011)
 Old 06-15-2011, 07:16 PM   #76
nindoja's Avatar
Posts: 2,395   (View Stats)
I'm interested if the price is right. I'm already seeing boost spikes and I'm not even running a DP, so this will be great for me as I work out my tune issues.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
Lex (06-21-2011)
 Old 06-21-2011, 03:40 AM   #77
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Would like for those instances when I exceed 3 bar map.
The Following 5 Users Say Thank You to jmhinkle For This Useful Post:
djuosnteisn (06-24-2011), dougefresh_ (07-24-2011), Lex (06-21-2011), rfinkle2 (06-21-2011), superskaterxes (06-21-2011)
 Old 06-21-2011, 08:27 AM   #78
Still hard at work on these boys and girls. The end result will be worth it.
Broxer (06-21-2011), charlesfist (07-21-2011), Ckmazdaspeed3 (06-21-2011), dougefresh_ (07-24-2011), fywdyl (06-24-2011), rfinkle2 (06-21-2011), rigor (06-27-2011)
 Old 06-24-2011, 01:15 PM   #79
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Still hard at work on these boys and girls....
Those poor children
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 6 Users Say Thank You to djuosnteisn For This Useful Post:
charlesfist (07-21-2011), dougefresh_ (07-24-2011), i8urgti (07-24-2011), jmhinkle (06-25-2011), Lex (06-24-2011), wolly6973 (06-24-2011)
 Old 06-24-2011, 01:55 PM   #80
volodya84's Avatar
Posts: 1,552   (View Stats)
volodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the world
Groans: 42
Subbed, will definitely get!
Sent from my SPH-D700 using Tapatalk
Corksport TMIC // Denso ITV22s .028" // COBB SRI // Corksport TIP // Forge V1 BPV // COBB AP // JBR SSP // TWM Bushings // Prosport Boost Gauge // CS Interior LED kit
"ban post whoring brownies"
Forge v1
volodya84 is offline   Reply With Quote
The Following User Says Thank You to volodya84 For This Useful Post:
Lex (06-24-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/guardian-angel-your-motor-81202/
81202 Aluminum Clutch Shoes This thread Refback 11-19-2012 01:48 PM
MS3: "Guardian Angel" for your motor This thread Refback 05-20-2011 01:30 PM
Angel Eyes? Sparky_86 MazdaSpeed 6 - How-To's 26 05-20-2010 04:58 PM
Angel Eyes TXspeed3 MazdaSpeed 3/6 - Appearance 2 06-28-2009 08:36 PM
Angel Eyes Ballast kingpin748 Mazdaspeed3/6 General Discussion 0 04-20-2009 04:53 PM
Twilight Cars The Mercedes Guardian Haltech Automotive News 0 04-07-2009 08:00 PM
Page generated in 0.61588 seconds with 51 queries
