E-Tuners / Custom Hardparts
  • 1 Post By MS3-a(sore)ASS-rex
  • 1 Post By Lex
 Old 06-27-2013, 07:22 AM   #1
ajberhorst's Avatar
Posts: 242   (View Stats)
ajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond reputeajberhorst has a reputation beyond repute
Default HELP ME LEX
Lex,
I contacted Stratified Automotive Controls for information about a custom tune. I am more than happy to pay for services but I wanted to get into contact with you and see what you will need from me. I can't start for another few weeks until my spark plugs get back and HKS sends me a new BOV because of their faulty BOV.
My car is throwing some lean codes and I am replacing the O2 sensor tonight, but I have a feeling most of my problem with idle and stutter is coming from not having a good custom tune done with how many after market modifications I have had done.
Let me know by pm'ing me or responding to the contact request I did through Stratified Automotive Controls. I am highly interested in getting this tune done as quickly as humanly possible.
I've read all of your reviews on Stratified and the many posts on here that rave about you and your customer service and knowledge. I would be grateful to have a customer tuner like you help me out in getting my Speed6 back up to par!
CorkSport TMIC, Stage II Short Ram Intake w/ Cold Air Conversion Box, Boost Tubes, Rear Motor Mount, and Turbo-Back Exhaust. Auto Tech HPFP Internals. H&R Lowering Springs. OEM Replaced Transmission, Clutch, Front/Rear O2 Sensors. Street Unit Iridium Spark Plugs.Custom Powder Coated Satin Black Rims. Replaced OEM Front Bumper.
VVT Actuator replaced at 101K Miles. w/ help from Rokusek & 15driley15
Stratified Tuned by Lex
ajberhorst is offline   Reply With Quote
 Old 06-27-2013, 07:28 AM   #2
Oalmon's Avatar
Posts: 999   (View Stats)
Oalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the worldOalmon is the leader of the world
Groaned at 37 Times in 28 Posts
Probably shoulda tagged @Lex;
Oalmon is offline   Reply With Quote
The Following 2 Users Say Thank You to Oalmon For This Useful Post:
3starmagnum (06-27-2013), btstarcher (06-27-2013)
 Old 06-27-2013, 07:33 AM   #3
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
OP you has an AP, right?
 Old 06-27-2013, 07:53 AM   #4
btstarcher's Avatar
Posts: 4,852   (View Stats)
LMFAO! I sure hope so...
SnailTune in progress
MazdaBoy2.3 (06-27-2013)
 Old 06-27-2013, 08:11 AM   #5
ajberhorst's Avatar
I have the Cobb AP . I read all the requirements on Stratified and I have a general feel for the process I just wanted to get in touch with Lex and see if he has any ideas on what my CEL's for to lean could be if replacing the O2 sensor doesn't work. Only idea after that is a faulty MAF. But I know that Lex can't tune the car properly until all of the modified parts are on that I am wanting the custom tune for so I have to wait either way for HKS to send me back my BOV from the warranty claim I made.
The Following User Says Thank You to ajberhorst For This Useful Post:
 Old 06-27-2013, 08:15 AM   #6
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
It sounds more like a boost leak than need for a tune. Are you catless? What's the gap on your plugs?
These are most likely mechanical issues that NEED to be addressed before tuning.
ajberhorst likes this.
NATOR PA
 Old 06-27-2013, 08:19 AM   #7
I saw the email and will be in touch this morning. We'll get you sorted whether it's a hardware or tune issue.
 Old 06-27-2013, 08:25 AM   #8
ajberhorst's Avatar
Thanks Lex!
As for the gaps on the plug I think they are stock from the factory :/. my bet is original owner never changed (some 60 year old man). I ordered the iridium spark plugs but they are on global back order according to street unit so I won't have them for at least three weeks :/. As for boost leaks I have checked and talked with CorkSport about it and done every test possible including completely disassembling then putting it back together. I am currently in the process of having CorkSport replace the entire unit under my warranty because I have eliminated everything else out I believe.
Besides that I have gone a step farther I think and replaced the lower O2 sensor when replacing my turbo back exhaust. I have a high flow cat option when I purchased the turbo back exhaust from CorkSport so I don't think it is an issue with that.
I've recently been reading a lot on the forums about the "open loop" exhaust system that occurs with the two O2 sensors (I hope I am saying this right), and I really believe that in my haste to put on the down pipe that I may have slightly damaged the upper O2 port.
Either way, I think that replacing and upgrading the spark plugs and replacing the upper O2 sensor should solve the issue and if not it will at least rule out what the hell is going on.
Once again, Thank you Lex for being so damn active on these Forums and apparently a great tuner. Can't wait to hear from you and set up what I need to in order to avoid joinging the zoom zoom boom club .
thanks guys,
Andrew J. Berhorst
 Old 06-27-2013, 08:31 AM   #9
Groans: 51
He ordered from Street Unit....
The Following 2 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
Mauro_Penguin (06-27-2013), trancehead (06-27-2013)
 Old 06-27-2013, 08:31 AM   #10
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
Originally Posted by ajberhorst View Post
Thanks Lex!
I picked up a set of Autolite one step colder iridium plugs from Advance Auto and they're working just fine. Might be able to get yourself a set to use in the interim.
Stealth01
2006 Mazdaspeed6 GT
 Old 06-27-2013, 08:38 AM   #11
ajberhorst's Avatar
It isn't a huge deal for me to wait. I haven't been using the Speed6 for my daily driver because it's been having a few issues and I don't want to run it into the ground so to speak.
I think swapping the 02 tonight should tell me a lot about whats going on and I'm sure that after showing Lex my data logs he will be able to pick up on it. In general the spark plugs should help smooth out my idle and keep the power band stronger correct?
Page generated in 0.34183 seconds with 25 queries
