E-Tuners / Custom Hardparts
Like Tree12Likes
 Old 08-02-2012, 10:26 AM   #41
Originally Posted by Boosten Ya(josh) View Post
I also moved my AAT sensor. I know it reads about 5-10° higher. But IAT on Mt logs are lower by about that much. I know IAT can't be lower then AAT. I can do some testing on this as well.
AFAIK AAT and looking at the wiring manual is simply for the climate control and dash display. Not used for engine function.
atvfreek (08-03-2012), superskaterxes (08-02-2012)
 Old 08-02-2012, 10:40 AM   #42
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
So moving that sensor won't affect the IAT as stated earlier correct?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 08-02-2012, 10:43 AM   #43
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Why are people thinking the PCM uses the ambient air temperature sensor in it's calculations?
It doesn't. I'd loved to be proved wrong though.
timjs is offline   Reply With Quote
 Old 08-02-2012, 11:50 AM   #44
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
im going to be doing some testing on this to see if i can find any more patterns/correlations
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
Boosted Beluga (08-02-2012), rfinkle2 (08-14-2012)
 Old 08-02-2012, 02:19 PM   #45
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
Default Pre-turbo meth
I do not on the K04 - do you have any data you can share? Airflow? Is your tune setup to drive the turbo as hard as possible near redline? This is an easy way to create a plateau and see if you can bring in more air.
Regretfully, no, I have no data left. I just made a couple or three runs, noted virtually no
difference, and gave up on the thought. This was back in May or so when it just started
to get warmed up.
My tune backs down the boost after 5k or so as well because of the torch like character of
the K04. With the DO5 I'm just keeping even with the BATs on the top end. My impression
has been that I'm plateau'd as is.
 Old 08-02-2012, 10:15 PM   #46
MS309's Avatar
Posts: 673   (View Stats)
MS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the worldMS309 is the leader of the world
I think an efficient Intake setup would be to run a full 3" intake WITH a cold air box, that way you get VE and cooler IAT's.
'11 CWP Speed3
More torque than your right arm.
MS309 is offline   Reply With Quote
 Old 08-02-2012, 10:36 PM   #47
Or a RAM air system like that from Corksport. When moving you have positive pressure against the inlet of the turbo.
 Old 08-03-2012, 10:30 AM   #48
MS309's Avatar
Have you tuned anyone with this kit ?
'11 CWP Speed3
 Old 08-03-2012, 11:12 AM   #49
Yes a bunch of people in the UK have it. It works well if you get the full fmic system.
 Old 08-03-2012, 12:13 PM   #50
SilverDemon's Avatar
Posts: 3,034   (View Stats)
What is the best pressure drop to have across the I/C core?
Too little of a drop and it will not transfer the heat to the aluminum, too much drop and it becomes too much of a restriction. There has to be a a happy median.
Also, on an I/C that has the BPV flange on the hot side (like people are going to for the fifth port), do not recirc the air. Heated air from pre I/C will just heat up the inlet, in turn raising IAT'S
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 2 Users Say Thank You to SilverDemon For This Useful Post:
Dano (08-03-2012), Lex (08-03-2012)
 Old 08-03-2012, 12:16 PM   #51
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I actually liked this kit as well but at the time, had just bought a 300 MSCAI so went with a traditional FMIC.
it was really cool how the air filter was tucked up inside the OE duct work.
I am tuning a guy with a CS intake...not sure that's the same one or do they make more than one...i'll ax him. he has a 2012 so IDK how that setup looks.
 Old 08-03-2012, 12:19 PM   #52
IMASA's Avatar
Posts: 209   (View Stats)
What's better?
The CS full FMIC kit which has the stock size MAF housing built into ther piping, or
running a big 3"+ MAF SRI?
 Old 08-03-2012, 12:49 PM   #53
It doesn't have to be thought this way. A low pressure drop can mean that either the IC is inefficient at cooling OR that it has a great big core and good design for the airflow you are passing through it. Restriction does not solely pass from the positive interaction that removes heat. Remember that friction between a pipe and gas actually ADDS heat (or costs energy).
The higher the flow, the higher the inlet pressure and the higher the pressure drop given the core stays the same. The size and VE of the motor determine how much air will pass through it at x pressure and x RPM so you have to look at where the motor will be operating most of the time.
In summary, you want to have an IC that does not restrict flow unnecessarily through endtank and core design. You also want a core that is large enough for your application in terms of both heat rejection and flow. Most companies quote CFM at x pressure drop. I would shoot for the largest core I can fit on the car since that limitation will come into play first. The placement of the IC is also very important since the amount of heat it can reject from the air passing through it is related to how much heat it can reject TO the air passing over it.
Originally Posted by IMASA View Post
What's better?
That is a tough one. There are many systems in play. How do the intercooler cores compare? What about piping size and routing and pressure drops? Also remember that the RAM air system is most effective at high speeds. Also what about packaging inside the engine bay and cost? So better is hard to quantify unless you look at all variables.
SilverDemon (08-03-2012)
 Old 08-03-2012, 01:01 PM   #54
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
Yes CS makes an SRI and TIP as well. The ram air is built in as part of the FMIC system and sits where the OEM TMIC sits.
For what it is worth, this thread finally made me pull the trigger on the CS cold air box for thier SRI. I have been on the fence about this thing for a long time but it doesn't get a lot of love from the MS3 guys. I think you guys have much cooler underhood/IATs to begin with, and peopel always say that the turbo just heats the air anyway so it is pointless. I always thought a little differently and this thread helped to confirm some of those thoughts.
As an aside, last night coming home late from the new Batman it was about 70 out and low humidity. The car felt fucking fantastic compared to driving on the way there at about 90 ambient and sunny. I still had IAT and BATs well into the 100's on the way home but could absolutely tell the difference in power at night.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
 Old 08-03-2012, 01:04 PM   #55
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
I actually just switched to a dry flow aem over an oiled kn and did feel a different SOT dyno looks like a made a good choice. Also I use a fujita CAI and If i were to just cut the last say foot off and use a reducer coupling to then mate my current 2.75 size to a maybe 3.5 dia size pipe to run a larger diameter filter would that help or hinder cooling and flow? I dont want to scrap the intake, but if more air is needed i need to figure out a way to get it there without going BT and wasting the TIP, and CAI i already have. thanks!
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
 Old 08-08-2012, 07:34 AM   #56
jamesr242's Avatar
Posts: 725   (View Stats)
jamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the world
I just switched from a CP-E CAI to a CP-E Nano SRI and the initial findings are somewhat interesting.
Temps are in relation to ambient.
CAI:
+4-5 Degrees IAT cruising
+20 degrees IAT city
+40 degrees IAT traffic
+18-22 degrees BAT cruising
+30 degrees BAT city
+35-40 BAT traffic
SRI:
+10-14 IAT Cruising
+18-22 BAT Cruising
These are just my initial observations since I just put it on last night. It seems like that even though the intake temps are higher with the SRI that the BATs have stayed the same, which surprises me.
Does intake temp matter if my BATs are staying the same?
2011 MS3 - SOLD
2000 Miata LS, Flyin Miata Turbo'd (GT2560R), 3" TBE, Megasquirt EMS, 650cc injectors
jamesr242 is offline   Reply With Quote
 Old 08-08-2012, 07:45 AM   #57
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
I was just looking at the differences of my logs with varied temps.
Maybe the 2nd, blue run should be omitted though, I must've done something funky, or.. humidity maybe
 Old 08-08-2012, 08:14 AM   #58
CAI:
+35-40 BAT traffic
SRI:
+10-14 IAT Cruising
+18-22 BAT Cruising
Even though the bats are the same due to the small amount of AIT temp difference the turbo should still be seeing the benefits of colder AIT temps I would think. thank you for the post though. Im actually trying to shorten and widen my CAI just a bit to still infact be a CAI but see if i can pull some better throttle response and keep the cooler AITs. By eliminating the last bend in the CAi system and widening the end and filter i should be able to accomplish this. data to follow in the future!
 Old 08-08-2012, 11:23 AM   #59
Must Have Teh 10's!
so i put a heat gun right on the AAT sensor and the dash display was super slow to change but it did.
the AAT value on the DH did not change however so im not sure what that is referenced by.
 Old 08-08-2012, 12:27 PM   #60
This is what I was getting at when we talked. The AAT in the DH may be referencing something else altogether - we need to know what PID it is looking at.
The AAT on the dash is very slow to respond because it is very dampened since large fluctuations are unlikely to happen in contrast to IAT in the MAF.
superskaterxes (08-08-2012)
 Old 08-09-2012, 12:05 PM   #61
nukepilot's Avatar
Posts: 333   (View Stats)
nukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the worldnukepilot is the leader of the world
Groaned at 32 Times in 12 Posts
CAI:
+35-40 BAT traffic
SRI:
+10-14 IAT Cruising
+18-22 BAT Cruising
damn. With my cobb sri i get +2-4 IAT while cruising though my BATs are similar to yours. I have the stock tmic
nukepilot is offline   Reply With Quote
 Old 08-12-2012, 07:25 AM   #62
painfulpillow's Avatar
Posts: 103   (View Stats)
painfulpillow is a splendid one to beholdpainfulpillow is a splendid one to beholdpainfulpillow is a splendid one to beholdpainfulpillow is a splendid one to beholdpainfulpillow is a splendid one to beholdpainfulpillow is a splendid one to beholdpainfulpillow is a splendid one to behold
Groaned at 6 Times in 2 Posts
Here is my thought on the intake temps:
When running the stock intercooler with intake, the intake is all by itself with no heat source nearby. That would explain the similar IAT and ambient temps.
With the FMIC, the cold side pipe (well colder pipe) runs directly below the intake. You are now introducing a heat source that heats up the intake. That would also explain why basically all FMIC guys have a much higher difference from ambient and IAT.
Anyone think this would seem logical?
2010 MS3 + Tech
Power Mods: Cobb FMIC | Cobb Exhaust | Ultimate Racing TP | Cobb SRI | Cobb TIP | Cobb AP | CP-E Fuel Pump | JBR RMM | Dizzytuned
Appearance Mods: Powdercoated stock wheels | 35W 6000k HID | LED Foglights | LED Interior
painfulpillow is offline   Reply With Quote
 Old 08-12-2012, 08:34 AM   #63
Cool new gauges I came across on Prosports website on the subject of intercooler efficiency and charge density, bat sensor accuracy:
Prosport Gauges dual intercooler air temperature gauges with in and out digital display
 Old 08-12-2012, 08:56 AM   #64
Nice find but once you have a core chosen the efficiency won't change much unless it gets really coated with oil on the inside or dirt on the outside. The gauges would be most useful if you are trying different intercooler cores.
Sent from Stratified Mobile Headquarters
rfinkle2 (08-12-2012)
 Old 08-13-2012, 03:04 AM   #65
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
this thread needs more pre turbo meth
The Following User Says Thank You to dooderek For This Useful Post:
Lex (08-13-2012)
 Old 08-13-2012, 04:13 AM   #66
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
Just thinking out loud here, but me and a few guys were discussing this over the weekend. First off where is the iat measured from? We all assumed the maf sensor.
If that's the case, this is my thought on cai vs Sri. Say a cai has about 2 feet worth of piping to go through, and a Sri is say half that (not sure of real measurements, just for reference). The Sri will obviously have higher iat's. But what about the iat by the time it actually gets to the turbo. If the piping takes the same route, its gonna get hot. The air travels through the hot piping, heating the air.
So if a cai starts out with colder air, how much is it heated by traveling a longer distance through the intake? The same goes for the Sri. It starts out slightly hotter, but has less distance to get heated before reaching the turbo.
I'm sure the difference isn't really that much? I could sound completely retarded (and probably do) but its a thought.
Lex (08-13-2012)
 Old 08-13-2012, 10:42 PM   #67
^ Good thoughts there. The silicone or plastic TIPs are pretty good at preventing the "air" from getting heatsoaked as it travels towards the turbo.
However the CAI and SRI will suffer from the same amount of "air heating" from the TIP. The difference here is that the CAI is able to pull in air that is much cooler to begin with compared to the SRI. So let's say for example the air is going to be heated up by 15* by the TIP. By using the SRI you start with 90* and with the CAI you start with 80* then with the SRI you end up with 105* at the turbo and the CAI with 95*.
You're still ahead by 10* with the CAI when you get to the turbo.
However the design and flow through the intake also has an importance and this is where things get more complicated. CAIs are limited to stock size whereas with SRIs we see them as large as 3.5" which outweighs the temperature difference between the CAI and SRI.
aromig (06-12-2014), Boosted Beluga (08-13-2012), exentix (08-14-2012)
 Old 08-14-2012, 01:53 AM   #68
I don't know how the sensor mounts but this seems to be the best bet @ looking @ intake temps and the effects of changes.
Prosport Intake air temperature gauge, instant read air temperature gauge.
@Lex, check this out:
http://www.designengineering.com/cat...yo2-air-intake
Lex (08-20-2012)
 Old 08-20-2012, 02:18 PM   #69
Lol, that bulb sitting in the intake stream restricts flow. If you're going to go that far might as well spray N2O and call it a day.
rfinkle2 (08-20-2012)
 Old 08-31-2012, 01:11 PM   #70
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Is there any repeated observations of intake air actually heating up do to SRI/CAI length and/or material? I remember reading some data years ago from some highly regarded engineers in the industry that basically debunked this belief. Basically the premise was that the intake tract has such minimal surface area in which to transfer heat plus the massive amounts of CFM flowing through the pipe showed little to no additional heating regardless of the temp of the actual tube. The boundary layer inside the pipe helped to insulate the intake air from absorbing any heat from the tube.
When I see people wrapping their intake and I/C cooler pipes I always figured that was a worthless mod.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following User Says Thank You to Todd98SE For This Useful Post:
Enki (08-31-2012)
 Old 08-31-2012, 01:26 PM   #71
I tend to agree that a pipe has as much effect on heating the air as it does at cooling it when it acts as an intercooler if you get what I mean.
CosmicArkie (08-31-2012), Enki (08-31-2012), fortressofcomfort (09-18-2012), Todd98SE (08-31-2012)
2010+ Mazdaspeed 3 performance air intake discussion Nataphen 2010 MS3 - Turbo Induction 467 12-30-2017 11:09 AM
Mod Discussion Beach bum Mazdaspeed3/6 General Discussion 30 03-26-2012 04:59 AM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Boost Air Temps/Intake Air Temp Stan-O
Cobb Access Port/Maps
20 05-03-2009 12:55 PM
Page generated in 0.52815 seconds with 39 queries
