E-Tuners / Custom Hardparts
Like Tree38Likes
 Old 03-20-2013, 10:14 AM   #161
If we find someone with no surge ports and the HTP 4" intake then we will get an answer surrounding the surge ports vs the intake design itself.
 Old 03-20-2013, 10:40 AM   #162
Voltwings's Avatar
Posts: 3,713   (View Stats)
I'm installing one next weekend if no one gets around to it first, My old gt3071r, no surge porting and HTP 4". @rfinkle2; that actually seems to make some sense ...
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
rfinkle2 (03-20-2013)
 Old 03-20-2013, 10:54 AM   #163
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Indeed i do, and no substantial issues on the 6. My BW s300sx has surge ports too, but they are very very minimal. I'm currently installing a 35r on the 6 now, so we'll see if anything changes.
No rich spikes at all?
You are not running a MAF screen right? Might have to try taking mine out see if it helps.
Oh and apropos nothing at all why change terboh? If you do a TS manifold for the 35 I hope you jig it. I wantz TS for long time meow.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
Deldran (03-20-2013), djuosnteisn (03-20-2013), rfinkle2 (03-20-2013), Voltwings (03-20-2013)
 Old 03-20-2013, 12:12 PM   #164
Alex, the bucking is only during very light load conditions. During WOT pulls everything is fine. Unless you disagree I'd say this is not BPV related. Besides, the BPV reciird tube into the intake is about 10" to 12" downstream from the MAF sensor.
Attached two logs. One with fairly horrible bucking and other less pronounced due to slower throttle modulation. Unfortunately I don't have LTFTs on it. Forgot to add that back on to the log list but will take another log with it today.
Attachment 98934
Attachment 98935
Tomas, what are your closed loop exit delays set to?
Also, what size throttle body are you running in your car?
Tomas (03-20-2013)
 Old 03-20-2013, 12:12 PM   #165
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
I surged the BW a couple times really good, and the bearings started to fail. I pulled it off a couple weeks ago to take measurements, and there is quite a bit of shaft play. I've had a 35r on the shelf for almost a year now, and want to play with something that spools a bit faster. I'll run it as a standard 35r and then get the HTA treatment to compare.
I'll replace the bearings on the BW and probably sell it with my manifold, a down pipe (new) and dump tubes at some point. Then build a new long tube mani after relocating the alternator. Probably months til all that shit is done though, so, i'll just enjoy the 35r for now.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
breakfstincluded (10-09-2013), rfinkle2 (03-20-2013), Tomas (03-20-2013)
 Old 03-20-2013, 12:35 PM   #166
Ziggo's Avatar
Posts: 3,843   (View Stats)
Default Re: MAF calibrations for bigger intakes
Did somebody say TS T3 gtx3576?
I thought I smelled win.
Zigatapatalka
Ask Me About My:
 Old 03-20-2013, 02:32 PM   #167
Bob Ross Fanclub
Tomas's Avatar
Rob,
Fuck now you gave me something else to wonder about. You instigator you.
They are set to A 15 and B and C to 30
Stock TB right now. That god damn bigger TB was another fail project I was never really able to get to work smoothly. I must have adjusted the throtle blade screws on both ends over 80 times and it never really ran like stock. I am not one to give up easily however so that fucker will go back in some day. Shit, I can only imagine how the car would run with the 4" intake and the bigger TB. It would probably literally ram my dentures into the steering wheel on every gear change.
The Following 3 Users Say Thank You to Tomas For This Useful Post:
BlueStreak (03-20-2013), djuosnteisn (03-21-2013), rfinkle2 (03-20-2013)
 Old 03-20-2013, 02:38 PM   #168
Rob,
LOL. You crack me up Tomas. Always make me have a good laugh.
I don't think it is your issue, but setting your A, B and C tables to 10 may help.
I'm interested to see how this finally gets worked out.
Tomas (03-20-2013)
 Old 03-20-2013, 02:43 PM   #169
Bob Ross Fanclub
Tomas's Avatar
I am ready for teh buttseckz when you are.
BlueStreak (03-20-2013), rfinkle2 (03-21-2013)
 Old 03-20-2013, 02:45 PM   #170
BlueStreak's Avatar
Posts: 1,467   (View Stats)
I am ready for the buttseckz when you are.
Is there room for one more?
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
rfinkle2 (03-21-2013), Tomas (03-20-2013)
 Old 03-20-2013, 02:47 PM   #171
I doubt exit delays are going to help here. Anyone with the htp 4 run smoothly?
 Old 03-20-2013, 02:49 PM   #172
Bob Ross Fanclub
Tomas's Avatar
We can triangulate you in.
 Old 03-21-2013, 06:40 AM   #173
Geez Lex, it was just a thought. Sorry to interrupt your teaching session.
Yes to someone running the 4" intake smoothly and we were talking about it in his thread until you asked the discussion be moved here.
Smoogs' car is running well with the 4" intake.
GODspeed7 likes this.
GODspeed7 (03-21-2013), Lex (03-21-2013), smoogs12 (03-21-2013)
 Old 03-21-2013, 09:55 AM   #174
So was mine.
@smoogs12; what's your car setup in terms of intake, turbo housing (surge ports, no surge ports) BPV, and how it runs when shifting and letting off the throttle? Any surging or bucking? Do you have a log of shifting at low loads?
 Old 03-21-2013, 11:39 AM   #175
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
I'm experiencing bucking at low loads/rpms with the 3.5" htp intake and stock turbo. I think it's cuz I have a exhaustl eak at the mani tho.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 03-21-2013, 12:29 PM   #176
It's possible. The WBO2 can be fooled into thinking you are running lean and then cause the car to run richer. That being said it should not buck. Also when you have throttle transitions such as during shifting the ECU does not use the WBO2 and this points more to MAF sensor turbulence. Post up a log.
 Old 03-21-2013, 01:16 PM   #177
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Just an FYI.
Due to all this new discussion I decided I would watch my afrs when I let off the throttle and when I push the clutch in. In both instances AFR goes to about 13.5 then drops down to the normal 29.
I am curious if this is part of the reason I feel a slight hesitation between shifts.
Sent from my Nexus 4 using Tapatalk 2
Damond Built Speed 6
Lex (03-21-2013)
 Old 03-21-2013, 02:17 PM   #178
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
So was mine.
Intake-HTP 4"
Turbo housing- No surge ports
Still running stock bpv
No surging or bucking. I'm not sure if I have a log, but I could take one if you were interested.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
Lex (03-21-2013)
 Old 03-21-2013, 02:21 PM   #179
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Htp 4" here with surge ports and synapse dv. No bucking or surging whatsoever. I'll try to get some logs as well.
The Following 3 Users Say Thank You to Etipp98 For This Useful Post:
Lex (03-21-2013), smoogs12 (03-21-2013), Voltwings (03-22-2013)
 Old 03-21-2013, 02:33 PM   #180
The guys that have no issues, get a log just normal everyday shifting. Doesn't have to be WOT but use the WOT parameters:
Accel. Pedal Pos.
Actual AFR
Boost
Boosted Air Temp
Calculated Load
Coolant Temp
Engine Speed (RPM)
HPFP Actual Pressure
Injector Duty Cycle
Intake Temp
Intake Valve Adv.
Knock Retard
Long Term FT (LTFT)
MAF Voltage
Mass Airflow
Spark Advance
Throttle Position
Vehicle Speed
Wastegate Duty Cycle
@Etipp98; @smoogs12; @Tomas; get a picture of your honey comb looking straight into the intake if possible. Also post an engine bay shot.
Last edited by Lex; 03-21-2013 at 03:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-21-2013, 03:00 PM   #181
Ziggo's Avatar
Might be helpful to post an engine bay shot too. Air movement within the bay could impact this as well.
Zigatapatalka
Ask Me About My:
BlueStreak (03-22-2013), Lex (03-21-2013)
 Old 03-21-2013, 03:36 PM   #182
Groans: 50
@Lex; here is my intake. I can get a different shot if needed. I just have this one in my phone.
08 Mazdaspeed 3
The Following 2 Users Say Thank You to Boosted Beluga For This Useful Post:
Lex (03-21-2013), Tomas (03-22-2013)
 Old 03-21-2013, 09:51 PM   #183
Groans: 50
Here are some logs from the other day.
08 Mazdaspeed 3
Tomas (03-22-2013)
 Old 03-22-2013, 07:45 AM   #184
Bob Ross Fanclub
Tomas's Avatar
^^ The datalog 5 does show dips into 10.9 AFR at some points after throtle lift and leaning out to 16.5 aft when back in gear. Could be that's not enough variance to cause bucking.
The 4" HTP intakes come with honey comb correct?
Boosted Beluga (03-22-2013), Lex (03-22-2013)
 Old 03-22-2013, 07:54 AM   #185
Etipp98's Avatar
Yes HTP has honeycomb
Tomas (03-22-2013)
 Old 03-22-2013, 09:38 AM   #186
Voltwings's Avatar
Am i the only 4" with no honey comb?
Past:
-Sold-
-Sold-
Current:
 Old 03-22-2013, 01:59 PM   #187
@Tomas; that's not an HTP intake - is that your engine bay?
 Old 03-22-2013, 02:50 PM   #188
Bob Ross Fanclub
Tomas's Avatar
No. DJ also not haz
Not it's not. It's DIY
And yes it is.
 Old 03-22-2013, 03:01 PM   #189
So did you just install the honeycomb or was it there during the bucking logs?
 Old 03-22-2013, 03:10 PM   #190
Bob Ross Fanclub
Tomas's Avatar
I've had the honeycomb from the start.
Once I am done doing the ongoing shift control table tests I'll take it off and see what happens. First I want to understand a bit more how the motor reacts to changes in the shift control tables. There are quite a few different variations and changes in the tables don't always have the effect I would think they should have so I am still in trial and error phase.
 Old 03-22-2013, 04:26 PM   #191
Voltwings's Avatar
Where did you pick up that nifty little hose for your BPV?
Past:
-Sold-
-Sold-
Current:
Tomas (03-22-2013)
 Old 03-22-2013, 06:43 PM   #192
Bob Ross Fanclub
Tomas's Avatar
Home depot. Lol. That was only temporary till I ordered and cut the correct silicone hose to size. That flex hose is plastic and not very good for engine bay temps.
Voltwings (03-23-2013)
 Old 03-22-2013, 11:25 PM   #193
So many variables here. Are you able to put a honeycomb behind the maf sensor as well?
 Old 03-23-2013, 12:24 AM   #194
Voltwings's Avatar
Damn haha was kinda liking where that was goin
Past:
-Sold-
-Sold-
Current:
 Old 03-23-2013, 06:26 AM   #195
Bob Ross Fanclub
Tomas's Avatar
Yeah. I can do that.
 Old 03-27-2013, 06:48 PM   #196
Ziggo's Avatar
I took some shifting logs, but apparently the logging rate on my old AP is too low with all the requested parameters to get a good look. Only one or two datapoints in a shift.
I also did a couple light throttle offs, and the AFRs do go slightly rich but the MAF V seems stable. Also did some extended engine braking and idling, looking for the MAF voltage to spike or behave oddly, but no dice, its all very clean and stable, at least at the low logging rate I saw.
Zoomed in on shifting
Ask Me About My:
 Old 03-27-2013, 07:07 PM   #197
Bob Ross Fanclub
Tomas's Avatar
Ziggo you hais a 4"?
 Old 03-27-2013, 07:33 PM   #198
Ziggo's Avatar
I only haz 3.5" but wanted to get some data up showing the curve of a car NOT having issues for comparison
Ask Me About My:
 Old 03-27-2013, 09:13 PM   #199
Bob Ross Fanclub
Tomas's Avatar
Observations over the last 2 weeks playing around with the shift control tables:
Load based fuel compensation clutch in seems to be a sort of fueling decay rate by which the ECU gradually cuts fuel on throtle lift while the clutch is depressed. So if you decrease the null type adjustment you will notice the AFR dropping to zero, or 29.3 display, at a faster rate. In my case a decrease of 50% or more leads to a very notchy feel when you press in the clutch. I.e the car will rock more and RPMS will drop faster. On the other hand it somewhat decreases the rich spikes right after throtle lift.
Load based compensation clutch out is the same but it applies when you just lift off the throttle without touching the throttle. A lower number will make the engine drop fueling faster and also makes for a somewhat rougher feel. It feels like the throttle plate closes more with more violence.
The ignition timing limit throtle closed min all tables set to -3 does help a little compared to -13.50 but it's not a huge difference.
The best compromise I was able to get was 30% lower on both load based fuel comp clutch in and out and -3 deg min ignition timing limit.
I have to note however that my car is a probably a bit more modified than most. The head is massively ported as is the IM with VTCs removed. I did that mostly for the injector I am running pre TB from DJ so the fuel wouldn't pool too much before getting to the combustion chamber. Add to that the web cams and lighter eagle rods which make the engine a lot more rev happy, and things can quickly get too overwhelming for the ECU. On a fairly stock engine I don't believe the drawbacks of a 4" would be so noticeable if at all.
The Following 5 Users Say Thank You to Tomas For This Useful Post:
BlueStreak (03-27-2013), Boosted Beluga (03-27-2013), djuosnteisn (03-28-2013), phate (03-27-2013), Voltwings (04-01-2013)
 Old 03-27-2013, 09:32 PM   #200
Groans: 50
So what if we increase the clutch in/out tables? To slow down the rpm drop. My car only likes when I shift quickly. If I don't, the car will buck.
08 Mazdaspeed 3
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/maf-calibrations-bigger-intakes-124734/
VersaTune - View topic - DTC P2178, P2188 This thread Refback 12-19-2015 07:06 PM
VersaTune - View topic - Share your MAF Calibration This thread Refback 11-23-2015 12:53 AM
VersaTune - View topic - Hello This thread Refback 11-17-2015 02:20 AM
VersaTune - View topic - New to Versatuner/Tuning This thread Refback 06-29-2015 07:49 PM
Sorry gents, MAF CAL ? Mazda MPS Owners Club This thread Refback 12-24-2014 06:37 AM
For Sale: JBR 3" Intake, JBR Heavy Knob, Other assorted parts This thread Refback 07-26-2014 07:51 PM
4th Gear WOT log This thread Pingback 07-05-2014 04:12 AM
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune This thread Pingback 06-04-2014 11:50 PM
Cobb ap logs help This thread Refback 05-21-2014 04:56 PM
Emew's Tune - Page 23 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-18-2014 08:40 AM
Newbie COBB User This thread Refback 01-17-2014 01:58 PM
New custom made 3.75" Aluminum MAF Housings - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2013 07:09 PM
cobb sure map thats been maf corrected ? Mazda MPS Owners Club This thread Refback 12-08-2013 02:17 PM
Intake Tuning Question? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-03-2013 10:37 AM
Cobb Ap and dash hawk ? Mazda MPS Owners Club This thread Refback 10-04-2013 08:24 AM
Sure Full3 Aeros ID300 Mazdaspeed3 - Mazda 3 Quebec This thread Refback 09-15-2013 08:06 PM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 09-09-2013 10:10 AM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 08-29-2013 05:03 AM
Mrdouble99 Part out :( - Mazda 3 Quebec This thread Refback 07-28-2013 03:27 AM
Mrdouble99 Part out :( This thread Refback 07-27-2013 05:52 PM
HELP! Advice requested please on SRI and TIP with CobbAP - Page 2 This thread Pingback 05-16-2013 07:07 PM
Solid 14.2 AFR killing my vibe man! - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-22-2013 09:45 AM
Nouveauté : HTP 3" Intake Kit - Mazda 3 Quebec This thread Refback 01-28-2013 05:37 PM
HTP 3" full intake - top quality ? Mazda MPS Owners Club This thread Refback 01-27-2013 02:22 PM
HTP 3" Intake - Page 2 This thread Refback 01-24-2013 11:19 PM
AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3! Travis@Cobb 2010 MS3 - ECU Computer Tuning 173 03-25-2011 08:31 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Copying MAF calibrations between maps smakdown61
Cobb ATR Support
3 04-21-2009 02:52 PM
V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 5 01-09-2009 05:54 PM
Spy Shots: Next Pagani Zonda packing big engine, bigger intakes Haltech Automotive News 1 05-14-2008 05:02 PM
Page generated in 0.62392 seconds with 31 queries
