E-Tuners / Custom Hardparts
Like Tree38Likes
 Old 08-26-2013, 02:25 AM   #241
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
I'm surprised that the very different sized tip, which should influence/restrict the effective flow, as well as the kind of filter used, practically doesn't affect the maf calibration, but thank's for the clarification!
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 08-26-2013, 06:48 AM   #242
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
If it helps, think of it this way-
MAF Diameter means large scale across the entire MAF Curve
Filter, TIP etc means small scale fine tuning commonly referred to simply as MAF Calibration regardless of tweaking LTFT's or making adjustments to bring WOT AFR's to the desired targets.
One is often beyond the scope of the ECU to compensate for and is addressed across the entire MAF curve where the other is typically small chunks that get small tweaks.
340hp / 371tq
 Old 08-26-2013, 04:33 PM   #243
Mistersix's Avatar
Posts: 2,585   (View Stats)
Well i've been trying to get a log of the stumbling start but the car hasn't done it. It still doesn't sound right though. Somethings off.
I did get these two logs. This map has over 300 miles on it and is pretty dialed in as far as CL and OL WOT afr's go. At least until this morning when i noticed a +20 in the second breakpoint. I'm using @Lex; breakpoints of 5.70,12,20,30,40
I also noticed a difference in spark advance during this breakpoint between these two logs.
I've made the adjustment to that break point and will flash tomorrow. I'm betting the car is gonna struggle to stay running during cold start after the new map. Just a hunch.
 Old 09-20-2013, 11:09 AM   #244
tooslowgti's Avatar
Posts: 441   (View Stats)
tooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the worldtooslowgti is the leader of the world
subbed
ATP GTX2867/cobb ap/autotech hpfp/ATP 3" maf with k&n fliter/HTP 3" tip/ atp catless full dp/ sure rmm/jbr 80 duro pm/ jbr 80 tmm/ sure short cut/ sure shifter bushing/resonator delete/Ksport Kontrol coilovers/680g shift knob/ sure tmic/ cp-e safe seals/ jbr tig/jbr coolent bypass/ Oil rig OCC/Stratified EBCS
325hp/352tq on VD FREEK tuned 93oct...E85 in process
soon to be installed: PERm vta occ, PERM pcv plate,
tooslowgti is offline   Reply With Quote
 Old 11-15-2013, 01:32 PM   #245
Just updated the JBR 3" WP MAF cal.
DSIT995 (11-15-2013), LatinKraze (12-08-2013)
 Old 12-02-2013, 06:28 PM   #246
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Any chance of a cal for the SURE Full 3.25?
Full3 Aeros ID325 GT | SURE Motorsports
MattJackson86 is offline   Reply With Quote
 Old 12-05-2013, 09:48 PM   #247
jdeves's Avatar
Posts: 266   (View Stats)
jdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the worldjdeves is the leader of the world
Groaned at 7 Times in 1 Post
@Lex
I'm looking at your HTP 4" cal and I noticed a weird spike between 3.081v and 3.12v you increase here over 2x as much as preceding and following changes. Then between 3.6 and 3.75 the changes are really small so you end up basically lining back up with the trend from before the earlier spike. Is there some reason for this or is it just because of an irregularity in the stock cal getting emphasized by the formula to go to 4"?
2006 Speed6 | GT3071 | VersaTuner | Lots of supporting mods
jdeves is offline   Reply With Quote
 Old 12-05-2013, 10:10 PM   #248
I just added a BETA version of the 3.25" for SURE. Give it a try and post feedback with MAF and WOT logs.
Originally Posted by jdeves View Post
@Lex
The HTP MAF cal had to be massaged piecewise due to the honeycomb and this is the effect you are seeing. Do you have a MAF and WOT log - any issues?
hnda etr (12-06-2013), jdeves (12-06-2013), LatinKraze (12-08-2013), MattJackson86 (12-05-2013), redboat (01-01-2014)
 Old 12-06-2013, 08:00 AM   #249
jdeves's Avatar
I hadn't tried yours yet. I was just looking through the numbers and comparing it to what I currently have set on my own. I'm not very happy with how mine has been running at low rpms though so I'm planning to give yours a try.
 Old 12-13-2013, 11:46 PM   #250
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
Any one using the ATP 3" housing? And any one know the AEM/MS CAI inner diameter at the MAF?
redboat is offline   Reply With Quote
 Old 12-14-2013, 03:14 AM   #251
Ireland's Avatar
Posts: 1,419   (View Stats)
Ireland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the world
Groaned at 119 Times in 22 Posts
Subbing
2013 Tech Package // NVS tuned // 35% e85
DYNOCOM eddy current chassis dyno @ 332hp 400lbft
Ireland is offline   Reply With Quote
 Old 01-01-2014, 11:46 PM   #252
redboat's Avatar
I'm running my own custom made 3.75" MAF housing w/ 3.5" ID using scalar 1.78715. Shown here..
http://www.mazdaspeedforum.org/forum/foru...um-maf-161689/
I have an optional honeycomb that I can add to it, from your experience with HTP larger MAF housings that have the honey comb install. Does the Honey comb make easier isolate lower percentage LFTF's? Or just make it more of a PITA?
 Old 01-02-2014, 12:49 PM   #253
The HTP intake definitely needed more piecewise MAF calibration work. The honeycomb does affect the curve such that you probably have to adjust several areas of the curve independently if you are basing your MAF cal on a pipe with no honeycomb.
redboat (01-02-2014)
 Old 01-12-2014, 02:50 PM   #254
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
Thanks for posting, I cut/pasted the numbers for the 3" JBR silicone intake I installed yesterday. I'll give it a day or so back and forth to work and check the cal.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
 Old 01-12-2014, 07:09 PM   #255
Ireland's Avatar
Here's a first log after the maf cal for the 3' htp. Did the log to soon I think. I'm targeting 12afrs but fluctuating between 12.2-12.4
 Old 01-25-2014, 07:52 PM   #256
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
@Lex; So i used your HTP 3.5" MAF table for my 3.5" intake...
I also scaled my already calibrated MAF table by multiplying it by 1.66.
I tried both maps and am getting some weird results. With both MAF tables i am running very lean at WOT, and also getting some WOT knock retard. Idles at 14.7, it's the WOT that is giving me problems. Boost targets are being hit, so does not seem like a boost leak.
Do you think this is a matter of just taking it easy and not going WOT and letting the LTFT's settle until i can do a MAF cal. Or is my table just way off for some reason?
I have attached a 3rd gear log, and the map that i have scaled using my previous MAF table.
I'd appreciate any help, thanks.
1996 Miata
 Old 01-25-2014, 08:51 PM   #257
Based on just the one log, and presuming that there are no hardware issues like a post-MAF pre-turbo vac leak sucking in a butt chunk of unmetered air, then you just want to do normal WOT AFR calibration. In this case adding at least 10% then testing for effect. Easy-peasy.
340hp / 371tq
 Old 01-25-2014, 09:10 PM   #258
redboat's Avatar
Your scalar is off. My 3.75" MAF has a 3.5" ID. But when you use the HTP 3.5" MAF scalar, you didnt take into account that its ID is less then 3.5" this is why you're running lean.
The Following User Says Thank You to redboat For This Useful Post:
6Y MAZDA (01-26-2014)
 Old 01-25-2014, 10:19 PM   #259
You have to measure the ID of your MAF housing as specified above. The HTP pipe is 3.37x iirc ID.
6Y MAZDA (01-26-2014), redboat (01-25-2014)
 Old 01-26-2014, 06:23 AM   #260
6Y MAZDA's Avatar
@redboat;
So i saw you scaled yours by 1.78. I am going to try that and hopefully that will fix my situation! Thanks guys.
1996 Miata
The Following User Says Thank You to 6Y MAZDA For This Useful Post:
redboat (01-26-2014)
 Old 01-26-2014, 06:37 AM   #261
You're doing an open loop MAF Cal too, right?
not just correcting the LTFT's with the closed loop MAF Cal?
Don't expect just the multiplier to bring the entire MAF Curve on target. You were just told the same thing three times in different language- 12%. If you're using 11.6 as your WOT AFR target- then 13/11.6 = m@1.120, or adding 12%, or conservatively 10% then tweak.
340hp / 371tq
 Old 01-26-2014, 06:56 AM   #262
6Y MAZDA's Avatar
Ok so i scaled using 1.78 and flashed it. Of course the LTFT's havent settled, but i am still seeing WOT AFRs of 12-13:1. not sure why it's doing this
No i haven't done any MAF cal yet, as i just flashed the map and havent driven 50 miles. So you're saying to get my AFR where it should be i should add 10-12% to the entire curve? (multiply the cells by 1.1)
1996 Miata
Last edited by 6Y MAZDA; 01-26-2014 at 06:57 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-26-2014, 07:12 AM   #263
Basic MAF Cal 101 Hector!
You can set initial fuel trims in as little as 5ish miles by just spending time in each of the ranges. You can look at the STFT's as well, and take them into account if needed. This is the process Cobb talks about in the help file.
30-50 miles just gives more time to let things settle & trims to trend with more stability.
As for the entire curve, I'd grab the MAF Curve from an OTS map, multiply that whole curve by the known multiplier of 1.78 noted above & test for effect, rather than modifying what you were running on your old intake setup. In general tho, bumping your multiplier from the 1.66 you used the first time and then doing it by 1.78 is no different than taking the 1.66 curve result and doing a m@1.12 or conservatively 1.1 (12 or 10%)
If you can make a 10% change to your fueling and not see a resulting change to the monitored results, I'd double check hardware to be sure you're not pulling in unmetered air.
340hp / 371tq
 Old 01-26-2014, 07:37 AM   #264
6Y MAZDA's Avatar
Lol OK @TiGraySpeed6;
I feel ALOT better now...i took my 1.78 scale and multiplied it by 1.1. Now its almost dead on 11.6. Thank you! haha. Now i just have to scale my WGDC down by 15% as i am overboosting and hitting boost cut. (hitting up to 23 psi!).
1996 Miata
TiGraySpeed6 (01-26-2014)
 Old 01-26-2014, 04:50 PM   #265
redboat's Avatar
Did you multiple the scalar to the stock map or an OTS map?
If an OTS Map, what intake set up was it set to?
I made this same mistake, I reverted back to a stock map, and then used my 1.78 scalar.
 Old 01-26-2014, 05:05 PM   #266
6Y MAZDA's Avatar
I was using a calibrated CS SRI/TIP maf table (from my etune).
Multiplied that by 1.78 and was still off AFR by like 12%...too lean. So then i multiplied again by 1.11 and that got me where i was supposed to be. Then i was overboosting because the hose to the wg actuator was split! But now everything is working as it is supposed to.
1996 Miata
 Old 01-26-2014, 07:43 PM   #267
Also don't overlook doing a boost leak test when installing new parts. You don't want to calibrate a MAF around a present leak.
 Old 02-11-2014, 05:22 PM   #268
Added the Corksport (CS) 3" MAF calibration to the OP so that we have a common resource on the forums. The CS calibration is straight from the CS website.
6Y MAZDA (02-11-2014), DevilSpeed (02-11-2014), MZRSPEED (02-11-2014), SpencerC (02-21-2014)
 Old 02-12-2014, 05:12 AM   #269
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Wow the cs flows only 50g's less then the htp 3.5"
Patty-Wack (02-12-2014)
 Old 02-22-2014, 07:52 PM   #270
Chron's Avatar
Posts: 800   (View Stats)
Chron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the world
@Lex; you are awesome! Just helped a local install his HTP 3" and I was able to use your MAF tables to get a temporary tune running for him (he's still waiting for his tuner to get back to him). The tables worked great and brought his AFR's back down to normal. :-)
2012 Mazdaspeed 3 CWP
CorkSport: 3" Power Series Intake, TP, CBE, RMM, TMM Insert, RSB, Front Control Arm Bar, ECU Relocation Box, Short Shifter, Leather Shift Knob, Hood Struts, Exhaust Hangers, LED Fog Lights, Interior LEDs
Other: AutoTech HPFP, ETS TMIC, Cobb AP, Morimoto 3five 4500k HIDs
CorkSport Whore
Stratified Tuned
Chron is offline   Reply With Quote
The Following 2 Users Say Thank You to Chron For This Useful Post:
Lex (02-22-2014), XerocX (03-21-2014)
 Old 05-20-2014, 12:04 AM   #271
PapaBruno's Avatar
Posts: 942   (View Stats)
Thank you so much for creating this thread, @Lex. I just bought the CS Power Series 3" intake and have it right here waiting for me to get some free time to install it. I'm very new to car mods, especially to this degree, but thanks to your videos I just performed my first closed-loop MAF Cal. log this evening...at least I think I did it right (attached). @Agent_Orange and a few other members from a thread I created, here: RMM, APV3, and Internals. Guidance/Next Steps have been super helpful, and brought this thread to my attention earlier today.
Admittedly I've only read through about three pages of this thread so far, but with my genpu do I paste the CS log into the bottom field or the top field of MAF Table A in Access TUNER?
EDIT: I'm hoping this will hold me over until I can get an e-tune.
Also, for those AP users out there, an update just went live today.
Post #100 Now, back to reading the rest of this thread.
 Old 05-20-2014, 11:00 AM   #272
Copy all the values from the calibration and then select the first cell in the MAF calibration table and paste. All the values in the MAF calibration table should be updated to match what you copied from here.
Remember to save the map and flash it to your car.
PapaBruno (05-20-2014)
 Old 08-13-2014, 11:37 AM   #273
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
Hi,
didn't read all the thread, but, curious - why such BIG g/s difference between different 3" intakes?
mrQQ is offline   Reply With Quote
 Old 09-02-2014, 06:02 PM   #274
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Added the JBR Tru-3.0 calibration to the OP. This calibration was dialed in on my car and confirmed on the JBR Gen2. Tru-3.5 coming soon.
Originally Posted by mrQQ View Post
Hi,
Actual inner diameter (ID) for the various 3" MAF housings are not the same. Also, for the most part the OL areas of the MAF calibrations are best guesses since the ECU has the ability to adjust trims there that we can't see. As long as the calibrations are within about +/- 15% the ECU will keep AFRs in check. The only time this isn't true is when you exceed 2.50 load and then these hidden trims appear to no longer be in play.
Last edited by Mike@Stratified; 09-02-2014 at 06:02 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to Mike@Stratified For This Useful Post:
Lex (09-02-2014), SarcasticOne (09-02-2014), [R]usty (09-02-2014)
 Old 09-02-2014, 06:20 PM   #275
[R]usty's Avatar
Posts: 2,204   (View Stats)
I was going to ask you guys about this but you beat me to it. Thanks!
2010 Mazdaspeed3 w/tech
Lex (09-02-2014)
 Old 09-02-2014, 06:32 PM   #276
Ozynigma's Avatar
Posts: 743   (View Stats)
Subbed for the 3.5. Mine arrived Monday and needs to be installed before my Stratified tuning experience starts.
The Following 2 Users Say Thank You to Ozynigma For This Useful Post:
Lex (09-02-2014), Mike@Stratified (09-02-2014)
 Old 09-02-2014, 07:05 PM   #277
We have one that should be close we can use whenever you are ready to get started. Just waiting on Jaime to install one on their gen2 and get me some logs to confirm.
The Following User Says Thank You to Mike@Stratified For This Useful Post:
Lex (09-02-2014)
 Old 09-03-2014, 01:05 AM   #278
Ozynigma's Avatar
@Lex you have an email. My last mods will be installed 22nd September.
The Following User Says Thank You to Ozynigma For This Useful Post:
Lex (09-03-2014)
 Old 09-10-2014, 07:06 PM   #279
Updated OP with calibration for JBR Tru-3.5 intake.
The Following 4 Users Say Thank You to Mike@Stratified For This Useful Post:
aromig (12-19-2014), JBR (09-11-2014), Lex (09-11-2014), Ozynigma (09-10-2014)
 Old 09-29-2014, 01:40 PM   #280
SnailSpeed3's Avatar
Posts: 278   (View Stats)
SnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond repute
Just wanted to say thanks alot for this info... Made it much easier to just slap in some predetermined values for the Mafcal than to have to figure out a scalar and multiply it through and hope it's close enough... Plus the fact that the values I used for my HTP 3" that I installed this weekend have me at ~ +- 5% LTFT so that's a very nice starting point if you ask me.
2013 Liquid Silver MS3
Mods so far:
FUNCTIONAL-
Cobb AP
HTP 3" Intake
C(u)NT 3" Catless Downpipe
JBR OCC, EGR delete, Under Engine Piping
Treadstone TR6 FMIC and brackets
Damond RMM, PMM, TMM
JBR SSP & BUSHINGS
Autotech HPFP Internals
AESTHETIC-
DIY Mudflaps, DDM 55W HL/35W FL
SnailSpeed3 is offline   Reply With Quote
The Following User Says Thank You to SnailSpeed3 For This Useful Post:
Lex (09-29-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/maf-calibrations-bigger-intakes-124734/
VersaTune - View topic - DTC P2178, P2188 This thread Refback 12-19-2015 07:06 PM
VersaTune - View topic - Share your MAF Calibration This thread Refback 11-23-2015 12:53 AM
VersaTune - View topic - Hello This thread Refback 11-17-2015 02:20 AM
VersaTune - View topic - New to Versatuner/Tuning This thread Refback 06-29-2015 07:49 PM
Sorry gents, MAF CAL ? Mazda MPS Owners Club This thread Refback 12-24-2014 06:37 AM
For Sale: JBR 3" Intake, JBR Heavy Knob, Other assorted parts This thread Refback 07-26-2014 07:51 PM
4th Gear WOT log This thread Pingback 07-05-2014 04:12 AM
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune This thread Pingback 06-04-2014 11:50 PM
Cobb ap logs help This thread Refback 05-21-2014 04:56 PM
Emew's Tune - Page 23 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-18-2014 08:40 AM
Newbie COBB User This thread Refback 01-17-2014 01:58 PM
New custom made 3.75" Aluminum MAF Housings - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2013 07:09 PM
cobb sure map thats been maf corrected ? Mazda MPS Owners Club This thread Refback 12-08-2013 02:17 PM
Intake Tuning Question? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-03-2013 10:37 AM
Cobb Ap and dash hawk ? Mazda MPS Owners Club This thread Refback 10-04-2013 08:24 AM
Sure Full3 Aeros ID300 Mazdaspeed3 - Mazda 3 Quebec This thread Refback 09-15-2013 08:06 PM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 09-09-2013 10:10 AM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 08-29-2013 05:03 AM
Mrdouble99 Part out :( - Mazda 3 Quebec This thread Refback 07-28-2013 03:27 AM
Mrdouble99 Part out :( This thread Refback 07-27-2013 05:52 PM
HELP! Advice requested please on SRI and TIP with CobbAP - Page 2 This thread Pingback 05-16-2013 07:07 PM
Solid 14.2 AFR killing my vibe man! - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-22-2013 09:45 AM
Nouveauté : HTP 3" Intake Kit - Mazda 3 Quebec This thread Refback 01-28-2013 05:37 PM
HTP 3" full intake - top quality ? Mazda MPS Owners Club This thread Refback 01-27-2013 02:22 PM
HTP 3" Intake - Page 2 This thread Refback 01-24-2013 11:19 PM
AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3! Travis@Cobb 2010 MS3 - ECU Computer Tuning 173 03-25-2011 08:31 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Copying MAF calibrations between maps smakdown61
Cobb ATR Support
3 04-21-2009 02:52 PM
V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 5 01-09-2009 05:54 PM
Spy Shots: Next Pagani Zonda packing big engine, bigger intakes Haltech Automotive News 1 05-14-2008 05:02 PM
Page generated in 0.63812 seconds with 39 queries
