E-Tuners / Custom Hardparts
Like Tree38Likes
 Old 06-02-2016, 05:22 PM   #1
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Here are the other screens, tinypic is being annoying at the moment.
 Old 06-02-2016, 05:29 PM   #2
g00s3y's Avatar
Groans: 438
Here's a folder with the 2010 & 2011-2013 MS3 version of ATR. I can't guarantee anything, but it's worked with everyone else so far.
https://drive.google.com/open?id=0Bw...ExfZXVyaWQ5WDQ
 Old 06-02-2016, 05:37 PM   #3
nell's Avatar
Posts: 6   (View Stats)
nell is an unknown quantity at this point
I have an ms6, is the softare any different??
nell is offline   Reply With Quote
 Old 06-03-2016, 05:07 AM   #4
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Yes. There are different ATR's for 2010 MS3, 2011-2013 MS3, 2007-2009 MS3, and MS6.
2007 Mazdaspeed3 GT
 Old 06-14-2016, 03:27 PM   #5
aackthpt's Avatar
Posts: 1,450   (View Stats)
If you don't connect the ap, you have to x out the window, it gives an error, and you can click on ATR as much as you want, it won't run.
Jon did you ever test my or g00s3y's versions of ATR that we linked here? I'm still interested to know if the installer really is keyed to a serial number.
2013 'speed3, silver
Stage Bro
 Old 06-15-2016, 05:10 AM   #6
MD1032's Avatar
Groans: 143
Not yet...I'm moving to Jersey in like 3 weeks and things are gonna be pretty busy until then...I will try it when I have time...sorry.
2007 Mazdaspeed3 GT
 Old 06-02-2016, 05:38 PM   #7
aackthpt's Avatar
That's one byte different in size from mine, interestingly.
Here's mine if you want to try it. I have a 2013 so it's probably the 11-13 edition.
https://drive.google.com/open?id=0B2...zJaTTZDc3FPcUE
Stage Bro
 Old 07-07-2016, 01:46 PM   #8
f15ms6's Avatar
Posts: 1,546   (View Stats)
f15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the world
Hey guys I need help, which one of this two JBR 3" Wide Path maf cal is designed for the Full aluminum intake ?
This is the intake I have, which I stalled yesterday. I used the first one into a 93 Stage 1 map, and after 40+ miles the car is running lean with LFT around 20.
I am trying to get the afr and fuel trims to become some what normal so I can get a Maf cal done.
2006 MS6 GT - Titanium Silver - #05750 -Cobb AP V2 - AT HPFP - 3" JBR Full Intake-
FidanzdaFlywheel - AWR Trilogy - Techna-Fit Brakes & Clutch SSL - Turbo XS Test Pipe - Maganaflow Catback
99 Civic Dx 5spd - DD/Backup Car
f15ms6 is offline   Reply With Quote
 Old 07-07-2016, 01:57 PM   #9
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
I have the same intake and used the top maf cal(tru) and was within 4% without making any changes. If your ft's are off that bad I'd say go check for leaks, somethings not tight.
f15ms6 likes this.
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
The Following 2 Users Say Thank You to voodoo2crue For This Useful Post:
f15ms6 (07-07-2016), Vansquish (07-07-2016)
 Old 07-07-2016, 02:00 PM   #10
f15ms6's Avatar
Great thank for the answer, now that I know thats the correct one I need go find the leak..
Sent from my SM-N900T using Tapatalk
 Old 07-07-2016, 01:58 PM   #11
Police - Grammarhead
Vansquish's Avatar
Well...if you look at the MAF g/s values in those two tables you highlighted, you'll note that the one with the 3.0"ID has nearly 500g/s at the top end, while the other one is closer to 430g/s. That's a difference of about 14-16%.
If you are running lean, you should probably run the table with the higher values in it, as the ECU is attempting to add a bunch of fuel to the mixture because the WBO2 has determined that too much air is in the mixture. Ergo, you need to tell the ECU that it's getting more air than it currently thinks it is. That is, for each MAF voltage value, the g/s should be registering as something greater than it currently does.
f15ms6 (07-07-2016)
 Old 07-07-2016, 02:06 PM   #12
f15ms6's Avatar
I am using the first one which is the one with the value of 497. This is how how the numbers look.. This is at idle while driving some times the AFR stays a 14.7 but it fluctuates all over 13-15-20
 Old 07-07-2016, 02:16 PM   #13
Vansquish's Avatar
See if you can find a leak. It should be between the MAF and the turbo, if I had to guess.
It is also possible that you've got a failing purge valve and/or WBO2 sensor, but those would be awfully coincidental timing.
f15ms6 (07-07-2016), voodoo2crue (07-07-2016)
 Old 07-07-2016, 02:38 PM   #14
f15ms6's Avatar
I will check for leaks, once I get a chance. But now that you mention purge valve, I will take a look to make sure everything is connected properly.. The car started running a little lean or rich a few days with my previous intake and I thought it was due to a cracked recirc tube and thats why I decided to just install the whole new intake yesterday.
Since I got the Lean code last night might just follow this and make sure the things in the list are good.. But to keep things simple I am going to first check for a vac leak.
 Old 07-07-2016, 10:00 PM   #15
f15ms6's Avatar
Thank you guys, I figured it out! The problem was that the coupler that goes to the Turbo inlet wasn't seating properly.. I end up having to remove it and added the coupler from the stock tip into the jbr intake to -turbo coupler and it worked.
The Following 4 Users Say Thank You to f15ms6 For This Useful Post:
ericrapp0507@gmail.com (07-14-2016), TiGraySpeed6 (07-08-2016), Vansquish (07-07-2016), voodoo2crue (07-07-2016)
 Old 08-18-2016, 02:46 PM   #16
armyman's Avatar
Posts: 30   (View Stats)
armyman has a spectacular aura aboutarmyman has a spectacular aura about
does this article also apply to Versa tune? The scale of the voltage seems to be different
CPe HPFP, Corksport Mazdaspeed 6 power series catted downpipe, Corksport TMIC, Corksport MZR Bypass valve, Cooling Mist W/M injection with cmgs, JBR Tru-3.5 Wide Path Full aluminum Intake System, Denso ITV-22, intank 265 L fuel pump, rear engine mount, EGR block off plate, XS stainless steel exhaust manifold ceramic coating, BNR stage 3 turbo, Stratified Mazda 3 Port Electronic Boost Control Valve, Stratified tune, HKS Twin Power
armyman is offline   Reply With Quote
 Old 08-18-2016, 03:17 PM   #17
Ozynigma's Avatar
Posts: 743   (View Stats)
Yes. I have cut and paste these values straight into VersaTune.
I have a CX7 with the JBR 3.5" WPI.
 Old 09-03-2016, 03:45 PM   #18
11ms3lowe's Avatar
Posts: 38   (View Stats)
11ms3lowe is a splendid one to behold11ms3lowe is a splendid one to behold11ms3lowe is a splendid one to behold11ms3lowe is a splendid one to behold11ms3lowe is a splendid one to behold11ms3lowe is a splendid one to behold11ms3lowe is a splendid one to behold11ms3lowe is a splendid one to behold
Is there one for the Cobb intake? I did not see one or am i blind?
11ms3lowe is offline   Reply With Quote
 Old 09-03-2016, 03:57 PM   #19
Bruh, cobb intake isn't bigger, it's still stock sized.
sent from my Nexus 6P
11ms3lowe likes this.
KiwiFlavor (09-03-2016)
 Old 09-03-2016, 10:25 PM   #20
COBB intake is actually bigger than OEM - It's one of the biggest intakes that I would say could pass as stock sized. If you are doing a MAF cal you will be able to scale accordingly.
AwAfrican, mikey27 and 11ms3lowe like this.
MD1032 (09-03-2016)
 Old 09-03-2016, 10:29 PM   #21
MD1032's Avatar
Groans: 143
The Cobb intake MAF cal is contained in the Cobb OTS maps that specify "+SF"
AwAfrican and 11ms3lowe like this.
2007 Mazdaspeed3 GT
 Old 03-04-2017, 10:48 PM   #22
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Installed JBR Tru-3.5 Silicone intake today.
Copy/Pasted the values from OP.
Only took 3 revisions. In the end, had to add 15% to all values 1.755v and below, and added 13% to all values above 1.755volts. LTFT's are now within 1% and WOT AFRs are within .005 lambda, slightly to the rich side of desired.
JBR likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
JBR (03-05-2017)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/maf-calibrations-bigger-intakes-124734/
VersaTune - View topic - DTC P2178, P2188 This thread Refback 12-19-2015 07:06 PM
VersaTune - View topic - Share your MAF Calibration This thread Refback 11-23-2015 12:53 AM
VersaTune - View topic - Hello This thread Refback 11-17-2015 02:20 AM
VersaTune - View topic - New to Versatuner/Tuning This thread Refback 06-29-2015 07:49 PM
Sorry gents, MAF CAL ? Mazda MPS Owners Club This thread Refback 12-24-2014 06:37 AM
For Sale: JBR 3" Intake, JBR Heavy Knob, Other assorted parts This thread Refback 07-26-2014 07:51 PM
4th Gear WOT log This thread Pingback 07-05-2014 04:12 AM
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune This thread Pingback 06-04-2014 11:50 PM
Cobb ap logs help This thread Refback 05-21-2014 04:56 PM
Emew's Tune - Page 23 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-18-2014 08:40 AM
Newbie COBB User This thread Refback 01-17-2014 01:58 PM
New custom made 3.75" Aluminum MAF Housings - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2013 07:09 PM
cobb sure map thats been maf corrected ? Mazda MPS Owners Club This thread Refback 12-08-2013 02:17 PM
Intake Tuning Question? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-03-2013 10:37 AM
Cobb Ap and dash hawk ? Mazda MPS Owners Club This thread Refback 10-04-2013 08:24 AM
Sure Full3 Aeros ID300 Mazdaspeed3 - Mazda 3 Quebec This thread Refback 09-15-2013 08:06 PM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 09-09-2013 10:10 AM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 08-29-2013 05:03 AM
Mrdouble99 Part out :( - Mazda 3 Quebec This thread Refback 07-28-2013 03:27 AM
Mrdouble99 Part out :( This thread Refback 07-27-2013 05:52 PM
HELP! Advice requested please on SRI and TIP with CobbAP - Page 2 This thread Pingback 05-16-2013 07:07 PM
Solid 14.2 AFR killing my vibe man! - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-22-2013 09:45 AM
Nouveauté : HTP 3" Intake Kit - Mazda 3 Quebec This thread Refback 01-28-2013 05:37 PM
HTP 3" full intake - top quality ? Mazda MPS Owners Club This thread Refback 01-27-2013 02:22 PM
HTP 3" Intake - Page 2 This thread Refback 01-24-2013 11:19 PM
AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3! Travis@Cobb 2010 MS3 - ECU Computer Tuning 173 03-25-2011 08:31 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Copying MAF calibrations between maps smakdown61
Cobb ATR Support
3 04-21-2009 02:52 PM
V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 5 01-09-2009 05:54 PM
Spy Shots: Next Pagani Zonda packing big engine, bigger intakes Haltech Automotive News 1 05-14-2008 05:02 PM
Page generated in 0.61832 seconds with 33 queries
