MazdaSpeed Synapse DV Valve at Stratified As we are growing we are starting to carry more of the common parts that a lot our customers need for their builds and that we have ran and stand by their performance. Today, we added the Synapse DV valve for the MazdaSpeed. It is the fastest valve on the market and anyone with a MazdaSpeed running above 20psi of boost should consider this upgrade. More at the link below. Price includes shipping! Synapse DV Bypass/Blow Off Valve [MazdaSpeed Synapse DV] - $260.00USD : Stratified Automotive Controls |
How do these compare to a forge or corksport bpv? |
Quote:
Lol, from what I've heard, the Synapse is suppose to be a pretty damn nice DV, but I don't have any personal experience. |
I like pssh pssh. Not sure if I can justify $260 worth of pssh pssh. It certainly looks fancier. |
It's faster, isn't it? |
It's one of the best around. It uses a sealing piston and orings instead of a diaphragm, so less maintenance and also very fast. And it doesn't make that grotesque dying tweety bird noise that everyone seems to think is cool. I got it because I wanted quality. I've seen too many issues with others, even the well known brands (maybe with hks as an exception), not to justify doing it right the first time and just spending an extra $60 to $100 on a bpv. My 2 pence. |
I have this bypass valve as well. I like it a lot. Very quick. I don't have any other experience other valves so I honestly can't say how it compares, but I am very satisfied with this one. |
This valve won't make fancy noises (it is fairly quiet) since the opening is fairly large but it is very fast and that's what makes it special. This means that transient on/off boost is excellent as is gear shifting and this is why I recommend the valve. When we developed the GA I had the opportunity to try a lot of different valves on the market and this one stood out for me. |
Hands down the best there is. I want to run it with a GA so I can go VTA and see what the sound diff is. I have one on my turbo rx8 and I have zero complaints. I love that recirc'd no one can hear it but me. Really puts my car into sleeper mode :) |
Quote:
I plan to order this after I order my new intake. Everything I have read about the Synapse DV has been awesome and I really don't care what it sounds like just that it does its job and does it well. |
@Lex; Are you currently running this valve with the Guardian Angel? If so, how did you connect the smaller diameter hose supplied with the valve to the larger diameter hose required for the BOV OUT nipple on the GA? |
Quote:
I purchased this valve while tuning with Stratified per Lex's suggestion and I love it. As stated above the on/off throttle response is very impressive. I find that the turbine doesn't lose much speed between quick shifts which means full boost much sooner in the following gear when compared to the factory bpv. I hooked mine up using a fancy 90° barbed brass fitting that I purchased from a local hydraulics shop along with a small brass fitting with a screen in it for the unused port. I was able to reuse the stock BPV hose in the factory orientation and location with this arrangement. |
Same deal, got this valve per Mike at stratified suggestion since my stocker was leaking under boost. Works great, slightly louder than stock and extremely responsive. I ordered a corksport bpv hose at the same time, luckily. The stock wouldn't fit properly. |
@Lex; Just got my synapse bpv in from you guys this afternoon. What are your recommendations as far as setup?: 1.) port combinations (A, B, or A+B), 2.) spring pre-load, 3.) and push vs pull. Based off of what I have gathered so far, I would guess the answers would be A+B, minimum pre-load, and push mode. I have read some say pull mode is better for high boost operation, but I imagine this may not be an issue for our application. Would that be correct to assume? I'm currently running a factory K04, plan to upgrade to the BNR stage3 eventually. Thank you in advance. |
Found the following handy information posted by Synapse on an Evo forum and I subsequently switched from ports A+B to port B only, with the result of smoother actuation and less flutter/bucking: link: Post your Synapse DV config and results - Page 14 - evolutionm.net "What I've found in road racing applications is especially true in this scenario: Long straight that goes into heavy braking, with a tight exit that requires slow throttle input. If you're setup with A+B, you'll find that the vacuum is too strong and it opens the BOV/DV. So, for anyone road racing, I really recommend using Port B. The solution by other manufacturers is more spring pre-load, which translates into the DV/BOV not working in other critical areas. Pneumatically, with only Port B the DV/BOV won't self relieve pressure until well over 60 psi anyhow, so, you'll be just fine." |
Interesting that you found it smoothest in that configuration. I run it as A+B in a push type configuration on our vehicle with great results. However this is very much something that you can setup to your liking. One more thing to watch for - when inserting the tubing into the Y connector don't push the tubess too far into the connector. This can cause them to butt against the end and actually prevent the valve from seeing the correct vacuum and opening reliably. |
I run B in pull mode with the minimum pre-load. I have not played around with different configurations because I didn't encounter any unfavorable characteristics after the install. The only real issue is I wouldn't be able to use a fail safe device like the Guardian Angel with this configuration. Otherwise I believe it's the best of all worlds from what I've read and from the Synchronic Tuning Manual and my butt dyno agrees. |
I just picked on up from a buddy of mine that had it on his speed3...but this will be going on a CX-7. So trying to see what would be the best route to start with. Obviously it's an auto 6-speed, and currently installed on the 7 is TIP, CS intake, EGR delete. Was thinking of A+B part in push and see how it does...suggestions? |
Quote:
Cool, just need to get 90 degree fittings since the dv on the 7 sits more straight up and the TMI cover won't go back on |
Quote:
Does this valve need to be serviced/lubed periodically? |
Quote:
With that said, they do sell rebuild kits for them. |
Quote:
@Lex; do you have any experience with the weaker / "street" spring? Synapse Engineering Help Desk They say it's included with "many of our popular DV kits" ... is it in the ones from Stratified? Also wondered if you'd seen the actual data on actuation vacuum, since I hadn't seen it discussed or posted anywhere: Synapse Engineering Help Desk |
I’ve been using one of these for a while, I think its important for most to understand, not only is it fast, it is a bi-directional bypass; throttle open (partial to full, pre-boost), vacuum present in manifold? open; (bypass turbo and intercooler from TIP to IC cold pipe). throttle open, boost present in manifold? closed throttle closed, vacuum post plate, boost pre plate? open (boost bypass) I’ve always wondered if the synapse could create an issue for tuning in that it plays with TIP volume and length, but the throttle response is considerably better with it versus stock, turbosmart or greddy type-r bpv.... (all used previous to it on my pu). |
Quote:
Quote:
We Test Synapse Engineering's Synchronic Blow Off Valve and DV Diverter Valve Essentially having the valve open under vacuum creates a bypass for the compressor which does create some pressure against the throttle plate. This reduces backpressure on the turbine side and increases efficiency when under vacuum. |
Quote:
Some manufacturers (Hyundai for example) are now controlling their stock BPV’s in a similar fashion, though its electronically modulated... |
Any one run in pull mode? I have mine in A+B in pull mode. Is push better? Also do you guys valve rotate even with the clamp tightened? |
Quote:
http://synapseengineering.pinnacleca...001a.002-2.jpg |
So I should losen the clamp a tiny bit then? Also I am running it in pull since it seals better under boost. I couldn't really find any info on which is better and why. Anyone care to enlighten me? So far in pull mode I have no bucking and loose next to no spool when shifting. Wayyyy better then my Cobb bpv and cost less as well! |
Quote:
Read the FAQs for a little more info, especially the first one and the push vs. pull one, not that it'll necessarily what you're looking for. Synapse Engineering Help Desk I'm gathering more information but once I get an intake (so it will fit) I currently expect to first try it in pull B-only... obviously that might change. |
All the info I got was from evo forums but on there platform everyone says run pull mode with a+b for daily and run b port only if on the track. The reason for that is a few guys were getting bad flutter/bucking on the track. I am going to do some logging next track day and see what I find. |
Quote:
Since installing the TR6 intercooler and reflashing on the AP from stage 2 to stage 3, I switched from push B-only, to push A+B. I did a run on the dragon, and don't really have any complaints. Kinda wish I had done one more pass though with it in B-only to compare. As for the tail of the dragon, what an amazing piece of roadway!… Can't wait to go back and run it again after getting a custom tune with @Lex; . Sure beats the hell out of the straight flat roads here in Florida. :684: Perhaps someday I'll move up to the mountains :drive::scool: |
I run the synapse dv. And was told by synapse you can use a mbc with it to bleed off boost as overboost protection |
Quote:
| All times are GMT -7. The time now is 02:30 AM. |
