E-Tuners / Custom Hardparts
 Old 12-19-2013, 06:51 AM   #1
jucca's Avatar
Posts: 159   (View Stats)
jucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond reputejucca has a reputation beyond repute
Default Oredered tune, just few question in mean time
Hi guys.
Just ordered Stratified tune for mine speed6. Confused with some things.
My speed 6 is getting right now catless DP. Was sure that S-OTS stg2 map are designed for catlless dp. wen't to download it, and found in description that ots map is for dp with at least one cat.
In mean time that custom map is done, can I run that S-stg2 map on catlees dp without problems?
My other mods ar in sig.
Cobb AP V3
Stratified tune
Autotech HPFP internals
M2 DP
JBR PowerPath stg II
Sure RMM
Sure Rear Diff Mount
TurboXS 50/50
Grimspeed EBCS
NGK Iridium step colder
Ebay OCC
EGR delete
3BAR MAP w/ Harness
3" CBE w/ high flow mufflers
Eibach -35mm
18x9 JapanRacing JR3 w/ 235/40/18 Kumho KU39
jucca is offline   Reply With Quote
The Following User Says Thank You to jucca For This Useful Post:
Lex (12-19-2013)
 Old 12-19-2013, 07:44 AM   #2
CrawlingMS3's Avatar
Posts: 3,116   (View Stats)
CrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the world
Groans: 31
Groaned at 32 Times in 16 Posts
I ran my OTS stage 2 map with a catless downpipe with no problems. Just monitor your boost and watch for overboosting.
Past
2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love
Present
2014 Chevy Silverado Z71
CrawlingMS3 is offline   Reply With Quote
The Following User Says Thank You to CrawlingMS3 For This Useful Post:
Lex (12-19-2013)
 Old 12-19-2013, 10:32 AM   #3
Our maps are designed to adapt to the modifications you have installed. Very seldomly will you have overboosting conditions even with a catless downpipe with the S-OTS maps.
You won't be running the S-OTS for long however as we'll be starting the tuning process shortly here.
 Old 12-20-2013, 01:25 AM   #4
jucca's Avatar
Thanks Lex. Received mail, will send it shortly. DP install will be done in few days. Discovered than no one in my town can bend 3" pipe, so need to wait that come from other town.
What boost cut do you recomend to match my tune?
Cobb AP V3
Stratified tune
M2 DP
Sure RMM
TurboXS 50/50
Grimspeed EBCS
Ebay OCC
EGR delete
3BAR MAP w/ Harness
Eibach -35mm
 Old 12-21-2013, 05:54 PM   #5
Not quite sure what you mean by what boost cut I recommend ...
Send me a more details response when you reply to my e-mail.
jucca (01-29-2014)
tune time? momovllj MazdaSpeed 3/6 - Turbo Induction 14 07-18-2013 08:23 AM
New MS6..... Tune time? ivory lovin MazdaSpeed 3/6 - ECU Computer Tuning 6 11-22-2011 08:14 AM
Is it time for the dreaded tune up? dajuice27 CX-7 > Issues & Troubleshooting 12 05-12-2011 08:12 AM
When is it time for a pro-tune? Roguevice 2010 MS3 - ECU Computer Tuning 11 04-30-2011 10:25 PM
Tune up time. Orphen Mazdaspeed3/6 General Discussion 2 01-27-2011 12:53 PM
Page generated in 0.25778 seconds with 22 queries
