E-Tuners / Custom Hardparts
Like Tree4Likes
 Old 12-07-2012, 02:09 PM   #1
Default Product Release: Mazda 3 Port EBCV/EBCS
This is a 3 port boost control valve that is plug and play with the OEM harness and comes with some nice as well as some unique features compared to what's already out there:
To name a few:
- It plugs into the OEM harness. No splicing of wires, not CELs
- It allows you to control boost in both 3 port and 2 port modes.
- Allows for faster spool, better response, and improved boost control when tuned.
- Allows boost control on all turbochargers including bigger turbos and OEM.
- Fully compatible with COBB AP, VersaTuner.
- Attaches cleanly to the engine bay in seconds without drilling, cutting, messy brackets.
- Includes reusable hose clamps that can be removed and installed without tools.
- The wiring harness is 18" long and braided for durability and mounting versatility.
- 1/4" diameter barbs that are automotive grade match those on most turbochargers.
- Bracket free, solid mounting solution. No more drilling holes in the engine bay!
- Discounted price if purchased along with our tuning packages
This is designed with ease of installation in mind. I have created very clear instructions and diagrams on how to install this valve in either 3 port (interrupt) or 2 port (bleed) mode. the diagrams are below.
Any questions - you know how to get a hold of me!
TiGraySpeed6, kritz and Hoyoman like this.
The Following 39 Users Say Thank You to Lex For This Useful Post:
atvfreek (12-10-2012), BigjohnB20 (12-07-2012), BlueStreak (12-07-2012), Boost Addict (12-07-2012), breakfstincluded (12-07-2012), BrianB6 (12-07-2012), Code Monkey (12-07-2012), daafisch (12-07-2012), DamagedGoods (12-07-2012), Dano (12-10-2012), djuosnteisn (12-07-2012), Dmurray06 (12-10-2012), jdub0802 (12-07-2012), jreiden1 (03-16-2013), JTMS3 (01-27-2013), kritz (12-10-2012), lilred (12-07-2012), manila (12-07-2012), meelo88 (05-25-2013), Mike@Stratified (12-07-2012), mituc (12-08-2012), moomooz12 (01-15-2013), ms3blackmica (01-16-2013), msantana101 (12-12-2012), NCZ13 (12-10-2012), Nliiitend1 (12-07-2012), Pointless (12-07-2012), psychophyr (01-05-2013), Realgib3 (01-26-2013), Rich990 (01-23-2013), Sig_Nasty (12-07-2012), SLOWHATCH (01-11-2013), thanox2 (12-07-2012), thepatient77 (06-13-2014), TiGraySpeed6 (12-07-2012), Todd98SE (12-07-2012), UnknownSuperhero (12-07-2012), Vader (12-07-2012), Zdraveca (12-07-2012)
The Following User Says NO Thank You to Lex For This Un-useful Post:
jracer (12-26-2012)
 Old 12-07-2012, 02:22 PM   #2
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
puh puh please for group buy (:
I'll have my bnib COBB EBCS up for sale soon I think now (:
Lex (12-07-2012)
 Old 12-07-2012, 02:27 PM   #3
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Do you have a good picture of the pneumatic diagram on the solenoid @Lex;? I'm guessing you don't really need to cap port 3 in bleed mode, just like it's not needed with the MAC solenoids sold under the COBB and GrimmSpeed brand names. Not that it hurts to block it off anyways.
Lex (12-07-2012)
 Old 12-07-2012, 02:28 PM   #4
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Those black boost tube clips are the shit! They work Great!
Lex (12-07-2012)
 Old 12-07-2012, 02:31 PM   #5
You actually do need to cap port 3 in this one as well as COBB and the GS solenoids.
When not actuated P2 and P3 are connected. P1 is blocked.
When actuated P1 and P2 are connected. P3 is blocked.
If you leave P3 uncapped you will be drawing in unmetered air via the TIP.
 Old 12-07-2012, 02:34 PM   #6
bstover17's Avatar
Posts: 586   (View Stats)
Groans: 228
I like your whale penis drawing
Might have to order one of these. I wonder how much $85.00CAD is in 'Merican money.
2010 MAZDASPEED 3
The Following User Says Thank You to bstover17 For This Useful Post:
Lex (12-07-2012)
 Old 12-07-2012, 02:34 PM   #7
Stratified busting out the high quality electronics.
If I didn't have my bcs already, I'd be all over this.
Lex (12-07-2012)
 Old 12-07-2012, 02:36 PM   #8
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Those are the best vaccum line connectors I've ever seen on an EBCS. Definitely assuring that the lines won't pop off.
Beauty.
'07 CWP MS3
Forged.
The Following 3 Users Say Thank You to BlueStreak For This Useful Post:
Dano (12-10-2012), Lex (12-07-2012), rfinkle2 (12-07-2012)
 Old 12-07-2012, 02:37 PM   #9
silvapain's Avatar
Groans: 136
I have never capped port 3 on my GS EBCS and I have no leaks.
I posted this in Dustin's EBCS + MBC thread:
The MAC three-port solenoid that is used in the COBB and GS EBCS has check valves, and couldn't care less about the boost source being under vacuum.
Solenoids have pneumatic symbols on them that outline how the valve functions. For example, the MAC solenoid diagram is shown here:
If you look up how to read the diagram, you'll see something like this:
So, you can see that the MAC 3-port solenoid is NOT actuated, airflow is allowed from port 2 to port 3 (in that direction ONLY), and port 1 is blocked. When the solenoid is actuated, airflow is allowed from port 1 to port 2 ONLY, and port 3 is blocked.
This means that if you run the EBCS in 2-port mode, with port 1 going to boost source and port 2 going to inlet (bleed), if the boost source is under more vacuum than the inlet there will be no airflow.
P.S. also, you will notice that in 2-port mode you don't need to block port 3, as the inlet will always be under vacuum with respect to ambient pressure when the engine is running, so there will never be airflow into the intake when the solenoid isn't energized. If port 3 isn't capped, though, it will show up as a 'leak' when doing a boost test.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
BrianB6 (12-07-2012), Dano (12-10-2012), Easter Bunny (12-10-2012), Lex (12-07-2012), ms3blackmica (01-16-2013), rfinkle2 (12-07-2012), TiGraySpeed6 (02-19-2013)
 Old 12-07-2012, 02:38 PM   #10
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
If only these were allowed in my autox and time trial class....
Lex (12-07-2012)
 Old 12-07-2012, 02:45 PM   #11
manila's Avatar
Posts: 1,767   (View Stats)
@Lex; I noticed in the engine bay pic that the nipples seem to be brass and in the second pic they are black. Can you confirm if these are plastic like the OEM or are they metal like the COBB's/Grimmspeed.
'12 MS3 Black Mica w/ Tech
Lex (12-07-2012)
 Old 12-07-2012, 02:45 PM   #12
@silvapain; here's the diagram for the valve. I as you, thought the same. However I can tell you that the cap is needed on this one. I literally blew and sucked through them to verify. I have not done the same on the MAC solenoids however.
silvapain likes this.
Easter Bunny (12-10-2012), silvapain (12-07-2012)
 Old 12-07-2012, 02:47 PM   #13
They are black nylon to be exact which is excellent in this environment. Metal in this case adds weight is harder to seal. That picture is one of the prototype units.
manila (12-07-2012)
 Old 12-07-2012, 02:50 PM   #14
manila's Avatar
Thank you for clarifying sir. How is the durability on the nylon fittings? Hoping better than the flimsy OEM
Lex (12-07-2012)
 Old 12-07-2012, 02:52 PM   #15
Yes much more so. The OEM nipples are a hard plastic that easily snaps. Black nylon is quite flexible so they don't snap or crack like the OEM when they are tugged on.
manila (12-07-2012)
 Old 12-07-2012, 05:48 PM   #16
Vader's Avatar
Posts: 1,651   (View Stats)
Groans: 45
Finally!
Ordered
The Following User Says Thank You to Vader For This Useful Post:
Lex (12-07-2012)
 Old 12-10-2012, 10:43 AM   #17
hum I didn't see the discount for buying this with tuning for a MS3
Also there's extra cost to tune with an EBCS right?
Lex (12-10-2012)
 Old 12-10-2012, 11:11 AM   #18
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
I want those clamps!
Lex (12-10-2012)
 Old 12-10-2012, 11:42 AM   #19
Still working on bundling these together with the tunes on the store - it's not playing nice. If you want these with a tune just PM me and I will send an invoice that includes the discount until I update the store.
3 Port setups do a have a $25 tuning fee IF they are in 3 port mode. This extends tuning by a week as well so overall it's not a bad deal.
breakfstincluded (12-10-2012), Dano (12-10-2012), Dmurray06 (12-10-2012), stuntz89 (01-11-2013), Vader (12-10-2012)
 Old 12-10-2012, 12:26 PM   #20
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Little late to the party...but hell yeah!
Lex (12-10-2012)
 Old 12-10-2012, 12:42 PM   #21
Never too late to join this party
 Old 12-10-2012, 01:09 PM   #22
Dmurray06's Avatar
Ill join in once I get off work. Haha
Lex (12-10-2012)
 Old 12-10-2012, 01:12 PM   #23
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Badass!
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
The Following User Says Thank You to TRSpeed For This Useful Post:
Lex (12-10-2012)
 Old 12-10-2012, 05:44 PM   #24
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
DAMNIT! I ordered a Grimmspeed last week!
Needed: Driver mod
The Following 2 Users Say Thank You to BigRedSpecial For This Useful Post:
Dmurray06 (12-10-2012), Lex (12-10-2012)
 Old 12-10-2012, 07:36 PM   #25
Dmurray06's Avatar
I have a BINB Grimmspeed in my basement. Just bought Stratifieds version. I am a bit of a fan boy. It's all about the support you gain when buying a product, and @Lex; has top drawer support for his products.
And as for the Grimmspeed, that's what the for sale sections for.
The Following 2 Users Say Thank You to Dmurray06 For This Useful Post:
Lex (12-10-2012), Vader (12-11-2012)
 Old 12-10-2012, 08:01 PM   #26
Groans: 56
Logic. You haz it.
Needed: Driver mod
The Following 3 Users Say Thank You to BigRedSpecial For This Useful Post:
Dmurray06 (12-10-2012), Lex (12-10-2012), Vader (12-11-2012)
 Old 12-14-2012, 05:32 PM   #27
Thanks everyone - just 3 left of this first batch. Already got the wheels in motion for the next batch but it will be a couple of weeks. So if you're in need of an EBCV this is a good time to jump in.
 Old 01-10-2013, 11:21 PM   #28
stuntz89's Avatar
Posts: 169   (View Stats)
stuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the world
loll with my recent problem im lucky i found this thread... that next batch ready yet??
#3527. On genpus for winter >=)
5zigen Hyper 5ZR for summer
Magnaflow CBE, CPE Catted DP, Corksport stage 2 SRI w/Corksport TIP, Turbosmart Dual Port BOV, 8000k HID Foglights,Block8head Vent pod w/52mm Prosport Boost Gauge, AWR RMM, AWR Passenger Side MM, JBR TMM, Bilstein HD Shocks Rear, Koni Sport Shocks Front, H&R Sport Springs, STI front lip, 35%Tint all around, Cobb AP, ACT 6 Puck Disc w/ ACT prolite Flywheel, Motul M300 Trans Fluid,PTP CDFP internals, Whiteline RSB, Corksport Rear Diff Mount, JDMGOODIE OEM Vent Visors, Mirimoto Mini HD Bixenon Projectors, ETS TMIC, Tuned by boost_creep ...
Tune in progress 8)
im on my way
h
stuntz89 is offline   Reply With Quote
 Old 01-11-2013, 12:40 PM   #29
Batch is ready to ship sir!
 Old 01-11-2013, 02:29 PM   #30
stuntz89's Avatar
As soon as I get paid.... That's gonna be mine
Tune in progress 8)
im on my way
h
The Following User Says Thank You to stuntz89 For This Useful Post:
Lex (01-12-2013)
 Old 01-16-2013, 07:41 AM   #31
Ordered!
Lex (01-16-2013)
 Old 01-23-2013, 12:42 AM   #32
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
Ordered! Thanks Lex
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
The Following User Says Thank You to Rich990 For This Useful Post:
Lex (01-23-2013)
 Old 01-23-2013, 08:17 AM   #33
Originally Posted by Rich990 View Post
Ordered! Thanks Lex
Thank you! Will be going out today.
Rich990 (01-24-2013)
 Old 01-26-2013, 07:43 AM   #34
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Except for the clips what is the actual difference between the offered solenoid and GS or Cobb products?
Do all these work well?
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
 Old 01-27-2013, 02:08 PM   #35
Aside from the clips, mounting solution, barbs, and offering a threaded plug for 2 port operation here are some other differences:
- Braided loom for protection and appearance
- The valve is not a MAC valve that those other guys use. It actually offers a more linear response with better resolution especially past 70%wgdc in 3 port where other valves make boost control erratic.
No CELs and it plugs right in just like the other valves.
The Following 7 Users Say Thank You to Lex For This Useful Post:
Code Monkey (01-27-2013), Dmurray06 (01-27-2013), magicka (01-28-2013), Nliiitend1 (01-29-2013), paveltol (01-28-2013), Rich990 (02-06-2013), TiGraySpeed6 (02-19-2013)
 Old 03-16-2013, 04:22 PM   #36
PreyStayShun's Avatar
Posts: 433   (View Stats)
PreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the world
I know that this thread is a bit older, and don't mean to bump it for no reason. But I forgot to share my love and respect for Lex.
Everything arrived, install was as easy as expected...instructions were perfect, etc.
Thank you again sir!
Car- 06' MS6
Mods:
***Some
Tune:
skiTOON in progress.
Car- 08' MS3 SOLD
Mods:
***Nothing Special
Tune:
***Ski85 Toon'd 50/50 Mix- VD @316/369- W/OUT Timing , 1st Map (My DD Map)
PreyStayShun is offline   Reply With Quote
The Following 2 Users Say Thank You to PreyStayShun For This Useful Post:
Code Monkey (03-16-2013), Lex (03-16-2013)
 Old 03-16-2013, 04:29 PM   #37
Dmurray06's Avatar
Question, if I hook it up in 2 port mode. What is this "restrictor"?
Lex (03-16-2013)
 Old 03-16-2013, 10:22 PM   #38
Thank you sir your review is very much appreciated and I am glad it's working well for you.
The restrictor is either the oem pill or the adjustable boost dial.
Dmurray06 (03-16-2013), PreyStayShun (03-16-2013), redboat (02-17-2014)
 Old 03-16-2013, 11:15 PM   #39
sidekick's Avatar
Posts: 3,093   (View Stats)
Now THAT is quality... It looks awesome @Lex;
Lex (03-17-2013)
 Old 03-27-2013, 04:18 PM   #40
Although a little bit more challenging than using a boost dial, a full LOAD based tune with tapered boost curve can be done using the 3Port EBCV alone. Here's the WGDC and boost curve of a 2-3-4 pull of a BNR S3 we are tuning purely load tuned with a 3 port (interrupt) setup. Note that not all cars respond the same and boost setups that tend to oscillate are much better off being tuned using the Boost Dial.
Dmurray06 (03-27-2013)
Product Release! CorkSport Mazda 2 Cold Air Duct CorkSport CorkSport 4 09-17-2012 11:53 AM
Product Release! CorkSport Mazda CX-7 Airbox CorkSport CorkSport 0 08-28-2012 11:00 AM
Product Release! CorkSport Coilovers for Mazdaspeed 3 and Mazda 3 CorkSport CorkSport 35 08-04-2012 02:14 PM
Product Release! CorkSport Mazda CX-5 LED Lighting Kit CorkSport CorkSport 0 05-23-2012 12:00 PM
Product Release! CorkSport Mazda 2 Skid Tray CorkSport CorkSport 7 05-19-2012 07:08 PM
Page generated in 0.58840 seconds with 40 queries
