| Stratified Automotive Controls We offer Vehicle Specific Street, Remote E-tuning, Dyno Services for Mazdaspeed 3 and Mazdaspeed 6 vehicles using the COBB AccessPort and VersaTuner. We specialize in control systems, engine management, instrumentation and turbocharging and offer a variety of products and services, from standalone ECUs to build-consulting services. |
http://www.mazdaspeedforum.org/forum/foru...servoir-25050/
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score
![]() Thanks again lex!
__________________ 05 MPS 6 - Self Tuned Borg Warner EFR T4 Twin Scrolled, Forged Block, Snow Performance S3 WMI, 5th/6th Port Injection, CPe: Ex Mani, Custom intake 3.75" MAF, CPe HPFP, Injector Seals, REM, SURE: Rear Diff Front mount & Brace, TIG's; Tial EWG, HDI FMIC, Custom 3" TBE, 3.5-Bar MAP sensor, AWR SEM, SouthBend S4 Clutch, Custom Head Unit, Car-LED Tails, 6000K HIDs, Auto Head-light Kit, Mugen Visors, LED conv., BC Coilovers, SPC Ball Joints, Brembo BBK Last edited by Rayd; 02-04-2013 at 12:16 AM. | |
| The Following User Says Thank You to Rayd For This Useful Post: | Lex (02-04-2013) |
(Thread Starter) | Not Ranked : 0 score All Boost Dial orders shipped out!
| The Following 2 Users Say Thank You to Lex For This Useful Post: | amoosenamedhank (02-04-2013), Zbrit00x (02-04-2013) |
__________________ 05 MPS 6 - Self Tuned Borg Warner EFR T4 Twin Scrolled, Forged Block, Snow Performance S3 WMI, 5th/6th Port Injection, CPe: Ex Mani, Custom intake 3.75" MAF, CPe HPFP, Injector Seals, REM, SURE: Rear Diff Front mount & Brace, TIG's; Tial EWG, HDI FMIC, Custom 3" TBE, 3.5-Bar MAP sensor, AWR SEM, SouthBend S4 Clutch, Custom Head Unit, Car-LED Tails, 6000K HIDs, Auto Head-light Kit, Mugen Visors, LED conv., BC Coilovers, SPC Ball Joints, Brembo BBK |
| The Following User Says Thank You to Rayd For This Useful Post: | Lex (02-12-2013) |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Just wanted to double check I've done this right.... uploadfromtaptalk1360698858281.jpg Ms paint ftw ![]() Is port 3 supposed to be vta? Couldn't find anything on GS instructions about blocking it off... @Rayd; has reported great success, but mine seems much less so... Also, should the boost source house be 4 or 6mm? Had all sorts of issues getting the 4 mm on there...
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
| The Following User Says Thank You to SarcasticOne For This Useful Post: | Lex (02-12-2013) |
(Thread Starter) | Not Ranked : 0 score Cap off the 3rd port on the GS solenoid. Use hoses that fit snugly and don't leak - the diameter doesn't matter in terms of response as long as they don't slip off or leak. For initial setting (not sure how your setup is) but I would try a Blue 9 or there abouts (almost in the orange zone) and work your way towards the + if needed. Remember that the tune has to be calling for the correct values and I recommend having stock or very close to stock LEC and BEC values with correct boost and load targets (depending on if it's a boost targeting or load targeting tune). Post up a log.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | SarcasticOne (02-12-2013), TiGraySpeed6 (02-12-2013) |
| Not Ranked : 0 score Took till nearly 4k rpm for full spool on a 3071 ![]() @atvfreek; has logs, I'm on phone, but am sure he'll look after me Just wanted to check to see if install fail on my part :pSent from my Galaxy Nexus using Tapatalk 2
But guessing I should cap off port 3 before commenting too much further... Sent from my Galaxy Nexus using Tapatalk 2
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP | |
| Not Ranked : 0 score @SarcasticOne, i think i hooked mine up abit differently... not sure how the GS EBCS is compared to my perrin, but what i did was, the line that originally came from the turbo compressor housing to the EBCS i took out and put the boost dial vacuum line into that port, i then removed the vacuum line that use to come from the EBCS the WG actuator and capped it off, and i left the line that originally went from the EBCS to the intake as it was. have huge oscillations though so maybe i did it wrong aswell! lol @Lex might be able to confirm?
(Thread Starter) | Not Ranked : 0 score Ray, I need to send you a proper map Give me a bit of time.
| Not Ranked : 0 score lol thanks mate ![]() I've been checking my emails with constant refreshing! im just worried that me or sam have "swapped" our EBCS from 3 port interrupt to bleed type incorrectly
(Thread Starter) | Not Ranked : 0 score Did the diagrams on my site help? Let me know if anything is unclear. I will be getting to your e-mail this evening.
Groans: 33
| Not Ranked : 0 score GA and BD shipping email recieved ![]() ETA: Feb 19 Thanks Lex
![]() The diagrams did indeed help a lot, but since they were for a two port EBCS (stock looking) and I have a 3 port Perrin EBCS, it was abit difficult to correspond the appropriate vacuum lines. to explain further: I wasn't sure about how to convert the 3 port EBCS to the bleed style 2 port correctly. Unsure which port had to be routed to where And wasn't 100% certain of which one to cap. As I mentioned in the earlier post, I ended up capping off the port that previously went to the WG, and put the vacuum line that is coming from the boost dial to the port on the EBCS that was previously tapped to directly to the boost source (turbo compressor housing) Oh and I let the 3rd port from the EBCS to the intake as it was. Is that correct?
__________________ 05 MPS 6 - Self Tuned Borg Warner EFR T4 Twin Scrolled, Forged Block, Snow Performance S3 WMI, 5th/6th Port Injection, CPe: Ex Mani, Custom intake 3.75" MAF, CPe HPFP, Injector Seals, REM, SURE: Rear Diff Front mount & Brace, TIG's; Tial EWG, HDI FMIC, Custom 3" TBE, 3.5-Bar MAP sensor, AWR SEM, SouthBend S4 Clutch, Custom Head Unit, Car-LED Tails, 6000K HIDs, Auto Head-light Kit, Mugen Visors, LED conv., BC Coilovers, SPC Ball Joints, Brembo BBK | |
| The Following 2 Users Say Thank You to Rayd For This Useful Post: | Lex (02-13-2013), SarcasticOne (02-13-2013) |
Sent from your couch
I would study some compressor maps. Keeping the compressor efficient will keep the turbo happy for lots of miles and also make the best power. Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 Last edited by atvfreek; 02-13-2013 at 08:26 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following 4 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #19 | ![]() |
| Banned ![]() Join Date: Sep 2012 Location: Arlington, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 271
Thanks for reaffirming what I was pretty sure of... | |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lots of people are confused about vacuum routing for the Boost Dial if they have a 3 port solenoid installed. I updated the OP with a diagram on how to do this.
| The Following 5 Users Say Thank You to Lex For This Useful Post: | amoosenamedhank (02-13-2013), atvfreek (02-13-2013), magicka (02-13-2013), Rayd (02-13-2013), TiGraySpeed6 (02-13-2013) |
![]() | | #21 | ![]() |
![]() Join Date: May 2011 Location: Johannesburg, South Africa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 783
| Not Ranked : 0 score ^ at 5500 ft of altitude, it self limits itself to max 15 psi anywhere after 5500 rpm :/
__________________ 2007 Velocity Red MS6 Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads Parts stockpile... Wiseco 88mm's / Manley H beams Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04 Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth) Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust 5500 ft altitude FTL MSF in South Africa |
![]() | | #22 | ![]() |
| Not Ranked : 0 score lil turbo can't be expected to pump air that isn't there...lol
![]() | | #23 | ![]() |
![]() Join Date: Feb 2011 Location: Irvine,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
| Not Ranked : 0 score My boost dial is working amazingly, getting 19/20 psi by 32/3400 rpm, and the car is so much more responsive on the load based tune.
__________________ 2010 ms3-sold ww evo x -385/360 |
| The Following User Says Thank You to Zbrit00x For This Useful Post: | Lex (02-14-2013) |
![]() | | #24 | ![]() |
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
__________________ 2009 CWP Speed3 | |
| The Following User Says Thank You to SleeperHatch For This Useful Post: | Lex (02-15-2013) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score It varies on temp, additional load In the car etc. soonest ive seen is 3200, average is about 34/3500 I'd say
| The Following User Says Thank You to Zbrit00x For This Useful Post: | Lex (02-15-2013) |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cale don't you have a bigger turbo? I know your setup is flowing more g/s than Zayn. Targeting load means that you may need less boost to get to the same load if your setup flows very well.
![]() | | #27 | ![]() |
| Not Ranked : 0 score Boost dial is working great for me too! Improved spool and responsiveness and only on my 1st stratified revision! 20/21PSI by 3250-3350 ![]() And that's with the dial set to orange 4.5 (about midway)
__________________ 05 MPS 6 - Self Tuned Borg Warner EFR T4 Twin Scrolled, Forged Block, Snow Performance S3 WMI, 5th/6th Port Injection, CPe: Ex Mani, Custom intake 3.75" MAF, CPe HPFP, Injector Seals, REM, SURE: Rear Diff Front mount & Brace, TIG's; Tial EWG, HDI FMIC, Custom 3" TBE, 3.5-Bar MAP sensor, AWR SEM, SouthBend S4 Clutch, Custom Head Unit, Car-LED Tails, 6000K HIDs, Auto Head-light Kit, Mugen Visors, LED conv., BC Coilovers, SPC Ball Joints, Brembo BBK Last edited by Rayd; 02-15-2013 at 04:59 AM. |
| The Following User Says Thank You to Rayd For This Useful Post: | Lex (02-15-2013) |
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Correct, the gtx is supposed to flow better mid to up top I thought so you should be good
![]() | | #30 | ![]() |
Groans: 33
| Not Ranked : 0 score Thank you @Lex;!! Recieved my Guardian Angel and Boost Dial today, looks awesome ![]() GA will be installed as soon as possible
| The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post: | Lex (02-19-2013), Mike@Stratified (02-20-2013) |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Glad it made it safely! Thanks for posting sir!
| The Following User Says Thank You to Lex For This Useful Post: | SpeedRebirth (02-19-2013) |
![]() | | #32 | ![]() |
![]() Join Date: Jan 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score hi alex,ive just ordered one of these from you due to pesky ossilations,correction table is well chopped down and its still a pain,im hoping this cures the problem,mods are in my sig,and log for you to see whats happening ,any tips on what setting to put in will be great,ill also be fitting the stock ebcs and not the gs thanks lex
__________________ mps6,cs tmic,versatuner,one step cooler plugs ngk,jetex 3"cbe,3" catless long pipe,kmd hpfp internals.coolant bypass.bnr3 turbo.3.25 sure maf.egr delete,mani flap delete.injector seals.devils own meth,htp 3" tip,stratified boost dial,cs cab,ported intake,h&r springs,floor braces all round,soon to be forged to get the most out of the turbo |
| The Following User Says Thank You to mps6dave For This Useful Post: | Lex (02-21-2013) |
![]() | | #33 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | mps6dave (02-22-2013) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score hi lex,i had a boost dial delivered for a customers car thats coming for work next month so i fitted it to mine,couldnt wait for mine to arrive. anyway we set the correction tables 75% of the stock values,reflashed the car and this was the outcome,not reached the load targets and the wgdc is high so adjust the valve untill the load is reached . much much smoother
| The Following User Says Thank You to mps6dave For This Useful Post: | Lex (02-23-2013) |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score @mps6dave; post the log in csv format (not sure what the axes are there) here and the setting on the boost dial. What turbo is the car running? Also I would set the correction table to stock values (this can change from turbo to turbo slightly) and perhaps adjust the WGDC base table a bit and the boost dial. The curve looks much smoother and you guys are getting a lot of these in the UK - thanks for that
![]() | | #36 | ![]() |
| Not Ranked : 0 score its running the bnr3 turbo,the valve is preety damn good,wish it was out 21 map revisions earlier.
![]() | | #37 | ![]() |
Nice to see the Boost Dial is working as it should. It is a game changer once people use it and realize how easy it is to have smooth and responsive boost control with no oscillations or hassle. A tip on the tune if I may. Try and target no less than 10* advance at redline even if you have to lower the load/boost. Dropping timing that low is costing more than dropping some load.
| The Following User Says Thank You to Lex For This Useful Post: | mps6dave (02-23-2013) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score i did some messing today and think i need to raise the correction factors back to stock in the load tables as in crease the wgdc a little,i run 50% from 3-7k also my idc is running 99%,so need to run meth or increase the fuel pressure with a better valve
![]() | | #39 | ![]() |
(Thread Starter) | Neutral : +1 score Also don't use an aftermarket relief valve for the fuel rail. You will hit a cut as the sensor maxes out at around 2100psi and it's annoying. It's fine to have IDC even a bit above 100 but adding meth always helps and it will help with your timing.
![]() | | #40 | ![]() |
| Not Ranked : 0 score its becoming hesitant/juddery up top when fueling gets to about 95%idc,im usually running 265kpa,9.5-10* up top , i can can run 2.38load up to 5k then tapers down to 2.15at 6900rpm if fueling allows it. i may get a better in tank pump to help with fuel demand
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/product-release-stratified-boost-dial-136768/ | ||||
| Limestone Street Scene - View topic - My Speed3 is faster than yours....lol | This thread | Refback | 02-08-2013 12:10 PM | |
| Instead of a 3 port boost solenoid.... ? Mazda MPS Owners Club | This thread | Refback | 02-01-2013 03:19 AM | |
| Display Modes | |
| Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up | CorkSport | CorkSport | 47 | 04-22-2014 11:53 PM |
| Product Release! CorkSport Oil Catch Can Development and Release Notes | CorkSport | CorkSport | 118 | 03-25-2014 05:20 PM |
| Product Release! CorkSport LED Underhood Lighting Kit | CorkSport | CorkSport | 12 | 11-30-2013 04:29 AM |
| New Product release. Speed 6 rear mount | medieval | MazdaSpeed 6 - Engine, Transmission & Driveline | 22 | 04-24-2009 09:12 PM |
