| Stratified Automotive Controls We offer Vehicle Specific Street, Remote E-tuning, Dyno Services for Mazdaspeed 3 and Mazdaspeed 6 vehicles using the COBB AccessPort and VersaTuner. We specialize in control systems, engine management, instrumentation and turbocharging and offer a variety of products and services, from standalone ECUs to build-consulting services. |
![]() | | #161 | ![]() |
![]() Join Date: Feb 2012 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
| Not Ranked : 0 score
__________________ Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat |
![]() | | #162 | ![]() |
(Thread Starter) | Not Ranked : 0 score This may also have to do with the tune. At high temperatures loads will be lower - are you targeting load or boost?
![]() | | #163 | ![]() |
| Not Ranked : 0 score I'm targeting boost, all correction tables are stock (except for the load comp tables, which are zero'd out) and wgdc is chosen a little bit lower (max 80) than observed. I know that the tune is not yet perfect, since I use much more oem (correction/adjustment) tables than before. Concerning the low load values, I just wanted to demonstrate how hot it was ;-) BTW: I guess one reason for the quite stable boost curve is that in 2-port mode the boost system is not so sensitive to little changes in wgdc, which is why boost fluctuations during the correction process are also smaller.
![]() | | #164 | ![]() |
![]() | | #165 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score Wow, why did I not know this existed? I'm going to order one for my BNR install.
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
| The Following User Says Thank You to m4tic For This Useful Post: | Lex (08-10-2013) |
![]() | | #166 | ![]() |
![]() Join Date: Apr 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
| Not Ranked : 0 score Lex I recently installed a Cobb FMIC and ported my intake which has made dialing in boost a bit tricky. So I just purchased a boost dial which hopefully will help, I was just wondering when its comes to switching maps from say a 20psi map to a RT 26psi map am i going to have to adjust the boost dial or do you think i'll be able to find a happy medium which will work in both scenarios?
__________________ 2012 Black Mazda 3 MPS ![]() CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC 2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks Versus Eurolace 19 x 8 +45 - Hankook RS3 Built & Tuned by Rob Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18 DBA T3 Rotors - Carbotech XP10 Brake Pads |
![]() | | #167 | ![]() |
On a related note I haven't seen an order for a dial come in. Make sure it was submitted.
| The Following User Says Thank You to Lex For This Useful Post: | ledfootrob (04-04-2014) |
![]() | | #168 | ![]() |
| Not Ranked : 0 score Awesome thanks Sent from my GT-I9300 using Tapatalk
![]() | | #169 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's hard to beat the smoothness of 2 port boost control using the Boost Dial. This is a GTX3076 internally gated turbo. EWG setups work even better with the boost dial.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 05-06-2014 at 10:20 AM. |
| The Following User Says Thank You to Lex For This Useful Post: | SpeedRebirth (05-13-2014) |
![]() | | #170 | ![]() |
(Thread Starter) | Not Ranked : 0 score The killer combo with the boost dial is an external wastegate setup. It is just so easy to get picture perfect boost control.
| The Following User Says Thank You to Lex For This Useful Post: | SpeedRebirth (08-31-2014) |
![]() | | #171 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score So you recommend ditching 3 port gs, and use the boost dial with the gs in 2 port/ewg on the 3076?
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | Lex (09-01-2014) |
![]() | | #172 | ![]() |
You can achieve good boost control with the 3 port as well. The boost dial allows you to build a tune that is very flexible however when coupled with an ewg. The shortcoming of the boost dial is being able to drive the last pound of boost from a turbo and that is inherent to two port control. However with an ewg this is not an issue and you get to keep the flexibility and higher resolution of the two port/boost dial setup.
![]() | | #173 | ![]() |
| Not Ranked : 0 score Hmmm. I have your boost dial sitting in a box. I have a GS in 3 port currently. I have a GTX3076 with a tial hotside on the car. Current boost control is great...but im only running 16psi. Game plan is to NOT run over 23-24psi...and this turbo can go at least 30 psi....so I won't be at the point where I need to extract the last pound of boost, I'm well below that threshold. Perhaps I should give this at try. I'm just not fully understanding why I would want to do this vs my current 3 port.
![]() | | #174 | ![]() |
Try both methods!
| The Following User Says Thank You to Lex For This Useful Post: | mrmonk7663 (09-01-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/product-release-stratified-boost-dial-136768/ | ||||
| Limestone Street Scene - View topic - My Speed3 is faster than yours....lol | This thread | Refback | 02-08-2013 12:10 PM | |
| Instead of a 3 port boost solenoid.... ? Mazda MPS Owners Club | This thread | Refback | 02-01-2013 03:19 AM | |
| Display Modes | |
| Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up | CorkSport | CorkSport | 47 | 04-22-2014 11:53 PM |
| Product Release! CorkSport Oil Catch Can Development and Release Notes | CorkSport | CorkSport | 118 | 03-25-2014 05:20 PM |
| Product Release! CorkSport LED Underhood Lighting Kit | CorkSport | CorkSport | 12 | 11-30-2013 04:29 AM |
| New Product release. Speed 6 rear mount | medieval | MazdaSpeed 6 - Engine, Transmission & Driveline | 22 | 04-24-2009 09:12 PM |
