| Stratified Automotive Controls We offer Vehicle Specific Street, Remote E-tuning, Dyno Services for Mazdaspeed 3 and Mazdaspeed 6 vehicles using the COBB AccessPort and VersaTuner. We specialize in control systems, engine management, instrumentation and turbocharging and offer a variety of products and services, from standalone ECUs to build-consulting services. |
(Thread Starter) | Not Ranked : 0 score As many of you know tuning boost and load on the DISI is one of the challenges to getting the car to perform well in all weather conditions and to have great driveability. The OEM K04 runs in 2 port mode and we can target load or boost and achieve great results fairly easily. When changing the turbocharger, it was a requirement that the boost control valve solenoid (EBCS) be swapped for a 3 port (interrupt style) in order to still electronically control boost and achieve a stable boost curve and response. Sure, manual boost controllers were always an option but often not the best one. Unfortunately when tuning in 3 port mode (interrupt) there was a good amount of work involved in getting the response just right, limit spikes, and oscillations. Tuners became quite good at doing this but in the process we neuter a lot of load dynamics tables and lose some nice features such as load/boost gear per which are so nice in a FWD. On top of this some cars take a long time to fine tune the boost curve on and most importantly some driveability is lost as a 3 port will be much more affected by changes in car setup and weather. At Stratified we have always sided with load tuning and have played a big part in having companies like COBB and VersaTuner enable load based tuning and removing all caps. Load based tuning with a 3 port is challenging at best ... so now we have a better solution. The Stratified Boost Dial ![]() The Stratified Boost Dial allows you to tune ANY turbocharger in 2 port mode (bleed) and do all this with full load (or boost) based tuning. It allows you to keep the OEM 2 port (or get an aftermarket one if it's broken) while tuning your big turbo. Best of all, the load and boost dynamics tables can be left mostly untouched from factory settings! Driveability and boost control are vastly improved, load by gear is back, and you maintain a constant load (torque) curve in all seasons making this type of control much more flexible than 3 port (interrupt) style. The Stratified Boost Dial was used to increase boost on the K04 as well as tune several large turbos including BNRs and GT series with both internal and external wastegates. ![]() This closes the loop on boost control for the MazdaSpeed. You can now choose your tuning weapon and method. Whether it's 3 port, 2 port, boost targeting, or load targeting, we give you the capability to do all this at Stratified. Setting this up is easy with a full set of clear instructions on our website and the full support and engineering behind Stratified products that you've come to know and expect.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 01-30-2013 at 11:06 AM. Reason: MSF Database - Automerged Doublepost |
| The Following 68 Users Say Thank You to Lex For This Useful Post: | -cj- (02-04-2013), 08.5MS3 (01-30-2013), 08cosmic3 (01-30-2013), aggierandy (01-30-2013), Ayaritz (02-01-2013), beachshoer (01-30-2013), BigJimMs3 (01-30-2013), BlueStreak (01-30-2013), bob^3 (05-21-2013), Boosted Beluga (01-30-2013), brandonf (01-31-2013), btstarcher (02-01-2013), Chief_Wiggum (01-30-2013), ckMS3 (01-30-2013), Code Monkey (01-30-2013), cshunter (01-30-2013), daafisch (01-30-2013), Dahouse702 (01-30-2013), dan7225 (01-30-2013), Dano (01-30-2013), Dash08 (01-30-2013), faeker (01-30-2013), Familyguy427 (02-12-2013), Fobio (02-04-2013), Funkster777 (02-14-2013), gsrtype1 (01-30-2013), H3R3TIC (02-01-2013), helmetface (01-30-2013), JBR (01-30-2013), Jh8909 (01-31-2013), Juyoung (01-31-2013), KevMS6 (02-25-2013), kish89 (01-30-2013), kritz (01-30-2013), LatinKraze (01-30-2013), leon78 (01-30-2013), mazdaspeeding (01-30-2013), meelo88 (05-28-2013), Menace1 (02-13-2013), Micha (02-12-2013), Mistersix (02-02-2013), mxlplx71 (01-31-2013), Naaman (02-01-2013), Nliiitend1 (01-30-2013), obijack (05-13-2013), pwned101 (01-31-2013), rfinkle2 (01-31-2013), RichieRichness (03-04-2013), rigor (07-07-2013), robertof (04-03-2014), SarcasticOne (04-03-2014), smoogs12 (01-30-2013), snailD (05-16-2013), SPEED6 KILLAH (01-30-2013), SpeedNess (02-01-2013), SpeedRebirth (02-02-2013), Standsideways (01-30-2013), TheFlash (02-04-2013), TiGraySpeed6 (01-30-2013), Todd98SE (01-31-2013), Tokay444 (01-30-2013), Tomas (01-30-2013), trf5000 (01-30-2013), Whiteboy (02-12-2013), x09MS3GT (01-30-2013), xI Leveler Ix (01-31-2013), Zbrit00x (01-31-2013), zxhoya (05-17-2013) |
(Thread Starter) | Not Ranked : 0 score Here is how simple it is to set this up for a BNR S3 for example. 1. Route the vacuum lines. The first diagram is for the OEM 2 port solenoid This second diagram is if you are using a 3 port solenoid. The port numbers are the same whether you are using a Stratified, GS, COBB solenoid 2. Set your wastegate and dynamics tables. Look they are ALL STOCK except for the WGDC table! 3. Do some driving and set your Boost Dial. 4. Set your load or boost targets and do some logging. You know you have set your boost dial correctly if the logged wastegate duty cycle and boost curves look like this. Notice the quick ramp in boost and little to no oscillations of the boost or WGDC. The oscillations that are less than 1psi are not felt by the driver. Also notice that the WGDC is in the 80-95% range when reaching the maximum desired boost near redline. If you've' turned the boost dial too far in the + direction then you will see oscillations like shown below. If you see this you need to turn the dial in the - direction. If you have a slow boost rise and get to 100% WGDC without reaching your load or boost targets then the boost dial needs to be turned in the + direction more or the turbo is not able to reach those load/boost targets. 5. WIN! It's that easy. Have excellent boost control, great driveability, and no boost spikes with great spool and a tapering curve (as defined by your load targets)!
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 03-04-2013 at 12:40 PM. |
| The Following 29 Users Say Thank You to Lex For This Useful Post: | amoosenamedhank (02-02-2013), ASHMS3 (01-30-2013), atvfreek (01-30-2013), breakfasteatre (01-30-2013), Code Monkey (01-30-2013), daafisch (01-30-2013), Dahouse702 (01-30-2013), dan7225 (03-04-2013), Dmurray06 (01-30-2013), Familyguy427 (02-12-2013), Fobio (02-04-2013), H3R3TIC (02-01-2013), Haltech (01-30-2013), Jh8909 (01-31-2013), Juyoung (01-31-2013), mazdaspeeding (01-30-2013), Pointless (02-12-2013), Rayd (02-12-2013), RichieRichness (03-01-2013), SarcasticOne (02-13-2013), skeurton (01-30-2013), smoogs12 (01-30-2013), Standsideways (01-30-2013), super_pablo_ (04-10-2013), TiGraySpeed6 (01-30-2013), Todd98SE (01-31-2013), Tokay444 (01-30-2013), Vader (01-30-2013), zxhoya (05-17-2013) |
| Not Ranked : 0 score nice lil device lex. When I get my new hotside I may have to give one of these a try.
| The Following User Says Thank You to Dano For This Useful Post: | Lex (01-30-2013) |
| The Following User Says Thank You to Lex For This Useful Post: | Dano (01-30-2013) |
| Not Ranked : 0 score Sorry if this is a stupid question, but what exactly is this doing to allow tuning to be so much easier? Restricting boost to a set pressure?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
| The Following User Says Thank You to sidekick For This Useful Post: | Lex (01-30-2013) |
The solenoid in bleed mode can only bleed so much. It has to bleed enough to drop the pressure at the WG actuator in order to increase boost. So the Boost Dial is a device you can tune to restrict flow into the WG actuator line so that the solenoid can keep up and effectively drop pressure at the wastegate line which then gives you control over boost.
| The Following 9 Users Say Thank You to Lex For This Useful Post: | Easter Bunny (02-01-2013), Familyguy427 (02-12-2013), Juyoung (02-23-2013), Nliiitend1 (01-30-2013), Pointless (06-25-2013), sidekick (01-30-2013), TiGraySpeed6 (01-30-2013), xI Leveler Ix (01-31-2013), zxhoya (05-17-2013) |
| Not Ranked : 0 score This seems similar to what DJ had mentioned a while back, about running a MBC + the Factory EBC to maintain a flat torque curve. Not trying to call you guys out for "stealing ideas" just trying to understand what exactly it is im looking at. Thanks.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following 2 Users Say Thank You to Voltwings For This Useful Post: | 86AmishMs3 (01-30-2013), Lex (01-30-2013) |
| Not Ranked : 0 score Ok, i was mistaking your "dial" for an MBC, the routing seemed similar to DJ's but a few people Ninja'd replys while i was making my first post and it makes more sense now. Thanks.
| The Following User Says Thank You to Voltwings For This Useful Post: | Lex (01-30-2013) |
(Thread Starter) | Not Ranked : 0 score This will definitely not work as an MBC - internally it is completely different and serves a different purpose. It has to be paired to a bleed source (solenoid) for it to control boost. Also, this is using full closed loop load control when set correctly. This means load by gear works and airflow can be targeted, not boost. You can turn the boost toggle on of course and target boost should you choose.
![]() Join Date: Sep 2011 Location: Croatia (Europe)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 265
| Not Ranked : 0 score Forgot to say that we also tried that solution EBCS+MBC (hybrid mode), but it was no good, oscillations were still there and we couldn't get flat boost curve as we wanted.
__________________ 06 MS6, Versatuner, Stratified Tuned BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter Autotech HPFP internals, Forge V1 BPV Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP NGK Iridium IX one step colder plugs, CPE SafeSeals & studs Custom FMIC with 2.5" piping and Treadstone TR8 IC SnowPerfomance WMI, Stratified Guardian Angel Eibach pro kit lowering springs |
| Not Ranked : 0 score Yeah i tried that before the load caps were eliminated to hold boost up top lol and its almost more trouble than its worth. Glad to see this spiffy little thing is working though. Most big turbos (at least EWG that i know of) run in 2 port mode anyways, so this kinda saves money over a grimmspeed... small amount, but saved nonetheless.
| The Following User Says Thank You to Lex For This Useful Post: | Voltwings (01-30-2013) |
| Not Ranked : 0 score Yet another darn spiffy tool there Lex!
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Lex (01-30-2013) |
| Nice, how much are these retailing for Alex?
| The Following User Says Thank You to Haltech For This Useful Post: | Lex (01-30-2013) |
(Thread Starter) | Not Ranked : 0 score Listed on my site for $70.
| The Following 5 Users Say Thank You to Haltech For This Useful Post: | atvfreek (01-31-2013), Lex (01-30-2013), LumberJack (01-30-2013), rfinkle2 (01-31-2013), xI Leveler Ix (01-31-2013) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score I got my BNR S3 turbo 7 months ago, and since I was very satisfied with Stratified tune on stock turbo my choice for BNR was of course again Stratified. Everything was ready to go, I got 3BAR MAP sensor and Grimmspeed EBCS. Car felt great on first two tune iterations when we were at low boost (~17PSI), but as soon as Lex started to raise load targets, we ran into some issues. Car was hitting ~21-22PSI at whole RPM range as intended, but boost was oscillating badly. It was something like 22-19-22-18-22-20PSI-etc and believe me it was no fun to drive car like that. Lex was trying to tune out that issue, but it seems that my speed didn't like any solution. Next step was to try only with Grimmspeed MBC. Oscillations were gone, but my boost curve was like on K04, at ~3k RPM we got 22PSI boost, and at redline it was ~18PSI. So again, we didn't get what we were asking. We were out of options, either I have boost or exhaust leak, or my speed just likes to be stubborn. I did leak test, and nothing, everything was just fine. Lex told me that he is developing some kind of valve(boost dial), which should solve this issues. After few weeks of waiting, boost dial finally arrived. I installed it right away with new tune iteration which Lex sent me, and WOW what a difference. Car felt as completely different car, so smooth acceleration, way better throttle response, load targets were spot on and no more oscillations! I just can't believe what that little valve did to my car. I don't know how many guys have this issue, but I can tell you from my personal experience that this is working great. Valve itself is very sturdy and bullet proof. Installed pic:
| The Following 17 Users Say Thank You to kish89 For This Useful Post: | Alpha (03-04-2013), amoosenamedhank (02-02-2013), Chief_Wiggum (01-30-2013), ckMS3 (01-30-2013), Code Monkey (01-30-2013), Dahouse702 (01-30-2013), Dano (01-30-2013), Easter Bunny (02-01-2013), faeker (01-30-2013), Familyguy427 (02-12-2013), Fobio (02-04-2013), Koke382 (01-31-2013), Lex (01-30-2013), Nliiitend1 (01-30-2013), TiGraySpeed6 (01-30-2013), Voltwings (01-30-2013), zxhoya (05-17-2013) |
![]() | | #20 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score Great Work Lex
__________________ www.tunedbynishan.com |
![]() | | #21 | ![]() |
![]() Join Date: Nov 2009 Location: Pensacola FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 659
| Not Ranked : 0 score As a tuning retard (my oil soaked hands don't mix well with the keyboard) I have one question. Will this help you tune my car? And will this benefit my setup? Im assuming you're going to say yes Alex. So expect some money heading your way. Again. Nice work
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII |
| The Following User Says Thank You to beachshoer For This Useful Post: | Lex (01-30-2013) |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score We are using a 3 port strategy on your car and it is running well. I will write you a reply that is overdue regarding this. If you like how the car drives with the 3 port we can continue with that strategy. If you want to go to load based tuning then the Boost Dial is the way to go.
![]() | | #23 | ![]() |
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII | |
| The Following 2 Users Say Thank You to beachshoer For This Useful Post: | Lex (01-30-2013), TiGraySpeed6 (01-31-2013) |
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
![]() Join Date: Jan 2012 Location: Pensacola, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score The description says that boost can be increased on OEM turbos. Does this include the K04, and what kind of boost are we talking about? tapawhat
__________________ HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust Beachshoer Intake Manifold P/P /w VTCS Delete Sure Shortcut | Sure Anchors | Sure 1/8 TIG Cobb AP | Cobb FMIC | Cobb Sport Springs ATP GT3071R /w Stratified Boost Dial Stratified Automotive Guardian Angel Go Fast Bits Respons (100% VTA) Autotech Internals I tune myself, bitches |
| The Following User Says Thank You to aldekei For This Useful Post: | Lex (01-30-2013) |
![]() | | #26 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score Sooo how is this different then a MBC and why can't a MBC function the same....more specifics. Also do you need a pill for a turbo that does not have one to be able to tune with this?
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following User Says Thank You to 86AmishMs3 For This Useful Post: | Lex (01-30-2013) |
![]() | | #27 | ![]() |
No pill needed. The lines to and from the Boost Dial are completely unrestricted.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. | ||
| The Following User Says Thank You to Lex For This Useful Post: | 86AmishMs3 (01-30-2013) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Also @SleeperHatch; was tuned on his GT turbo and EWG using the Boost Dial and the OEM 2 port when I was down in San Diego in October. He can chime in with is results as well.
| The Following User Says Thank You to Lex For This Useful Post: | SleeperHatch (01-31-2013) |
![]() | | #29 | ![]() |
![]() Join Date: Feb 2011 Location: Aurora, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,094
Groans: 39
| Not Ranked : 0 score Question i have for you @Lex; would this be a benefit for me at this stage?
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" |
| The Following User Says Thank You to Mortose For This Useful Post: | Lex (01-30-2013) |
![]() | | #30 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | Mortose (01-30-2013) |
![]() | | #31 | ![]() |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Believe @atvfreek; has spoken to you about the issues on my car with boost being an absolute pain to get right... Looks like I'm getting one of these... Will pick up a GA as well whilst I'm at it... Currently have a grimmspeed ebc installed, what changes do I need to make? Also, doesn't this product directly compete with your ebc?
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
![]() | | #32 | ![]() |
| Not Ranked : 0 score you would just switch your GS from 3 port to 2 port mode.
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Lex (01-30-2013), SarcasticOne (01-30-2013) |
![]() | | #33 | ![]() |
![]() Join Date: Aug 2012 Location: Benton,AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 486
| Not Ranked : 0 score So, pretty much, what you are doing is fooling the wastegate by installing a flow/ pressure regulator in the sensing line? |
| The Following User Says Thank You to nojjy For This Useful Post: | Lex (01-30-2013) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score It's like running a variable restrictor pill. Instead of swapping pills to get boost control right, you simply turn the dial. Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 Last edited by atvfreek; 01-30-2013 at 06:40 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 4 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #35 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score Nifty, so its basically a variable sized pill. I am not clear on how it impacts load vs boost tuning though. Just that you can dampen the hyperactivity of the load tune a bit using it?
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following User Says Thank You to Ziggo For This Useful Post: | Lex (01-30-2013) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score yeah IDK...I would think a boost targeting tune would benefit more since the ECU load logic is extremely rapid to take action whereas boost targeting logic is a bit lazy...
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Great replies guys. You can use load targeting as well as boost targeting logic (flick the boost toggle on). The nice thing here is that you can use the Boost Dial to move the operating window of your 2 port EBCS up and down and maintain the wastegate dynamics and load dynamics in play without neutering those tables. Yes you can even run a 3 port as a 2 port. The 3 ports can be a pain to tune sometimes due to oscillation and spiking - they are a lot more sensitive to changes in setup and weather and this is an alternative to that. Downside? You will have to adjust the dial to get the 2 port to be active in your desired boost window (say spring pressure to 22psi for the K04). Once you've set it, you forget it and tune electronically. Some of you will still choose a 3 port. Others will go this route. They both allow you to control boost, it's just that this is closer to the OEM logic and a bleed (2 port) system in general is more forgiving. I have made a big diagram summary to help shed more light on how to set this: ![]()
| The Following 16 Users Say Thank You to Lex For This Useful Post: | anavrinIV (02-03-2013), atvfreek (01-31-2013), beachshoer (01-31-2013), BigRedSpecial (02-01-2013), Dahouse702 (01-31-2013), Dimenus (02-04-2013), Haltech (01-30-2013), ms3blackmica (01-30-2013), Nliiitend1 (01-31-2013), Rayd (02-03-2013), RichieRichness (03-04-2013), rigor (07-07-2013), SarcasticOne (01-31-2013), TiGraySpeed6 (01-31-2013), Tokay444 (01-31-2013), xI Leveler Ix (01-31-2013) |
![]() | | #38 | ![]() |
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
| Not Ranked : 0 score Will be installing this baby very soon. I got my OEM Boost Solenoid the other day and the Boost dial came in yesterday so I'll be hooking everything up shortly. When @Lex tuned me with this thing I fell in love! Being load tuned again is amazing and my car really took to this very well. I gotta say if you buy anything from Stratified be ready to be blown away by the item as well as the customer service!!
__________________ 2009 CWP Speed3 |
| The Following 5 Users Say Thank You to SleeperHatch For This Useful Post: | atvfreek (01-31-2013), beachshoer (01-31-2013), Lex (01-31-2013), Todd98SE (01-31-2013), xI Leveler Ix (01-31-2013) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Color coded and everything. Son of a bitch. Can't get much more simple than that. Genius.
![]() | | #40 | ![]() |
![]() Join Date: Feb 2011 Location: Irvine,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
| Not Ranked : 0 score Il be needing one to replace my slow response mbc setup!
__________________ 2010 ms3-sold ww evo x -385/360 |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/product-release-stratified-boost-dial-136768/ | ||||
| Limestone Street Scene - View topic - My Speed3 is faster than yours....lol | This thread | Refback | 02-08-2013 12:10 PM | |
| Instead of a 3 port boost solenoid.... ? Mazda MPS Owners Club | This thread | Refback | 02-01-2013 03:19 AM | |
| Display Modes | |
| Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up | CorkSport | CorkSport | 47 | 04-22-2014 11:53 PM |
| Product Release! CorkSport Oil Catch Can Development and Release Notes | CorkSport | CorkSport | 118 | 03-25-2014 05:20 PM |
| Product Release! CorkSport LED Underhood Lighting Kit | CorkSport | CorkSport | 12 | 11-30-2013 04:29 AM |
| New Product release. Speed 6 rear mount | medieval | MazdaSpeed 6 - Engine, Transmission & Driveline | 22 | 04-24-2009 09:12 PM |
