E-Tuners / Custom Hardparts
 Old 04-01-2014, 02:50 PM   #1
BruhhWill's Avatar
Posts: 104   (View Stats)
BruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond repute
Default S-OTS+ Tune Log
@Lex; as promised, my log is attached for reference with the S-OTS+ tune. 4th gear pull. HPFP, AFR look very healthy.
Thanks for your time.
2008.5 MGM Mazdaspeed3
Engine
Cobb Accessport // Autotech HPFP Internals // Stratified Auto 3 Port Boost Control Solenoid (2-Port Mode) // Injen Cold Air Intake // CorkSport TIP // NGK Spark Plugs // Ultimate Racing Resonated Test Pipe // Stratified Auto S-OTS Stage 2+ Tune //
Transmission
JBR V2 Rear Motor Mount 80a // JBR Heavy Shift Knob // Corksport Shifter Bushings // Corksport Short Shift Plate //
Suspension
Koni Yellow Struts and Shocks with H&R Sport Springs // JBR Rear Sway Bar // 18x8 +45 Enkei Raijins in Black wrapped in Kumho Ecsta 4X All Seasons 235/40/18
Aesthetics
JDM Axela Window Visors // Corksport LED Fog Lights // Corksport LED Interior Lights //
Past:
1999 Crystal Blue Honda Prelude SH
2006 Titanium Grey Mazda 3 Hatchback (R.I.P.)
1995 Hyundai Elantra
BruhhWill is offline   Reply With Quote
 Old 04-01-2014, 04:38 PM   #2
In spite of your few flow modifications your car is flowing very well at these temperatures and not needing much boost to hit the load targets of the Stg1 tune.
Were you planning a full tune soon?
BruhhWill (04-01-2014)
 Old 04-01-2014, 08:26 PM   #3
BruhhWill's Avatar
Thanks for taking the time to look.
I eventually want to get a full tune; my struggle is wondering when it makes sense to do so. The car can always use more power, but I also want to further enhance the handling aside from just a JBR Rear Sway.
My next thought on power would be a 3-inch Intake to replace the Injen Cold Air, catted downpipe (emissions) and upgraded top mount. That takes money that I don't have at the moment lol. So I'm wondering if it makes more sense to go full tune after I dive in further with the flow mods.
Engine
Transmission
Suspension
Aesthetics
Past:
 Old 04-01-2014, 10:13 PM   #4
I would say that a test pipe and a TMIC will get you to 90+% of the power potential of the K04 with a tune.
BruhhWill (04-02-2014)
 Old 04-02-2014, 06:13 AM   #5
rbflurry's Avatar
Posts: 193   (View Stats)
rbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Not to barge in but what percentage would you say he is now? @Lex;
rbflurry is offline   Reply With Quote
The Following User Says Thank You to rbflurry For This Useful Post:
 Old 04-02-2014, 07:10 AM   #6
BruhhWill's Avatar
I'm highly interested in a Top Mount intercooler (particularly the ETS model). As for a test pipe, living in Northern Virginia essentially means I'll have to go the catted downpipe route. We have STRICT emissions testing here.
Thanks for your input and future insight, @Lex;
Engine
Transmission
Suspension
Aesthetics
Past:
 Old 04-02-2014, 09:10 AM   #7
The test pipe just removes the secondary cat in your exhaust. So your primary cat and the OEM downpipe stay. The primary cat is much better for emissions than any aftermarket high flow cat in a downpipe.
The test pipe is 4 bolts to be put in and can be done in under an hour easily. On top of this a test pipe is much cheaper than a full downpipe.
He can certainly get a tune now as well and we can push a good amount further from the S-OTS+. I was just giving suggestions on what a really good cost/benefit combo is for opening up the exhaust and intake at a minimal cost.
Last edited by Lex; 04-02-2014 at 09:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-02-2014, 09:18 AM   #8
BruhhWill's Avatar
Ahh okay, that makes sense then. That's surely something to keep in mind then as I progress further into this build. With the flow of a test pipe added to my stock exhaust system, would that qualify my car for a Stg 2+ tune?
Thanks again, @Lex;
Engine
Transmission
Suspension
Aesthetics
Past:
 Old 04-02-2014, 10:25 AM   #9
Thanks again, @Lex;
Yes sir.
1st tune - pre tune questions ep87 Stratified Automotive Controls 14 01-03-2014 01:21 PM
cobb ap: is safe tune quicker than stage 0 tune? Fusion_MS3 2010 MS3 - ECU Computer Tuning 14 12-16-2012 02:27 AM
Problem. Without meth tune is great. On Meth tune shits the bed. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 16 09-06-2011 06:58 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
Page generated in 0.29314 seconds with 23 queries
