E-Tuners / Custom Hardparts
 Old 12-19-2013, 08:22 AM   #1
CrawlingMS3's Avatar
Posts: 3,116   (View Stats)
CrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the world
Groans: 31
Groaned at 32 Times in 16 Posts
Default Satisfied with Stratified
Well I finished up my tune yesterday with the one and only @Lex; and let me say, I am very satisfied. Getting tuned was definitely an adventure and I learned some stuff along the way.
I am completely in love with my car now, and this was definitely the best mod I've done to it. Lex was able to pull 54 extra horsies out of the car. Before the tune, I was barely able to break traction in 1st. Now, I'm breaking traction in 3rd. What was great is that Lex spent some extra time with me to make sure I had a safe tune. I was not expecting that and was very pleased that he did that for me.We started to see some kr near the end and had to dial back a little bit. I was able to get to 294/349 before Lex dialed back timing a little bit in the 5k rpm range to reduce knock. My final revision gave me 292/343, my goal had been 285. I'll get on a dyno either next week or the week after to see what numbers are really being put down.
I'll definitely be coming back to Lex when I'm ready for E85 in the Spring or Summer.
Here's some VD graphs for your viewing pleasure. 1st graph is the last revision. 2nd is the first, second, and last. The 3rd is all graphs throughout the tune. The last graph is a datalog taken for the base logs.
EDIT: Dug in my computer and found base logs to begin the tune.
Lex likes this.
Past
2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love
Present
2014 Chevy Silverado Z71
CrawlingMS3 is offline   Reply With Quote
The Following 8 Users Say Thank You to CrawlingMS3 For This Useful Post:
bioevolve (12-19-2013), dale_gribble (12-19-2013), Goodrich27 (12-20-2013), Hush (12-19-2013), Lex (12-19-2013), Mike@Stratified (12-19-2013), omgvance (12-20-2013), Pointless (12-19-2013)
 Old 12-19-2013, 08:29 AM   #2
hatchedspeed3's Avatar
Posts: 1,966   (View Stats)
Very nice. Il getting tuned by lex at the beginning of the year, and can't wait to see what kind of numbers he can make on my slow ass shitbox lol. How long did it take you to finish the tune?
2009 CWP MS3 1-23-2014
 Old 12-19-2013, 08:34 AM   #3
Groans: 31
A little over 2 months after Lex had spent some extra time giving me a safe tune. But keep in mind after the 1 month of actual tuning time ended, the 2 day maximum for receiving a new revision ended. So I wasn't getting revisions as often. A total of 11 revisions
Past
Present
 Old 12-19-2013, 11:09 AM   #4
how often were you sending him logs/requests?
 Old 12-19-2013, 11:13 AM   #5
MICASPEED13's Avatar
Posts: 280   (View Stats)
MICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the world
Can't wait for my tune. These numbers look promising. I have the CNT catless dp awaiting install and I'm going to do a fmic with tr6 core and possible a wide path intake. I wanna break 300whp I think it should be easy. Now I just need more money lol
Tappin
Installed: CORKSPORT:SRI/TIP, IC Piping, Recirc tube, Shifter Bushings, SSP, ULTIMATE RACING CBE, JBR "Dogbone" RMM, COBB AP v2, stage 2 93 OTS map, red Cobb knob, AUTOTECH internals, CNT Catless Downpipe, NGK step colder plugs+ignition coil spring stretch, 5k lows, 3k fogs, LED kit
Wish list: FMIC, HTP full 3in intake, Stratified tune.
MICASPEED13 is offline   Reply With Quote
 Old 12-19-2013, 11:23 AM   #6
dale_gribble's Avatar
Posts: 4,720   (View Stats)
That's a really good pickup there, especially given your mods. You guys must have some decent fuel out there and I'm sure the lower temps helped. What was the outside air temp for that run?
My buddy has a few more mods than that and is sitting around 265-270WHP on a modded OTS which is pretty normal numbers for the gas out here.
Near 300 on pump gas alone is pretty badass!
MINI H1 6.0 - CAR LED TAILS
 Old 12-19-2013, 11:32 AM   #7
Groans: 31
On average probably 4-5 days
Tappin
I would be excited if I was you. Why fmic tho? You have a good possibility of breaking 300. That was my original goal then I started adding things up and realized I probably wouldn't get there. I got closer than I thought tho.
Lex did say he it seemed like I have good fuel in my area. I've been fueling up at the same pump for over 3 months now. The outside temp when I took my final log was 57*F.
The pleasure was mine. Sometimes tunes take a little longer than expected either because we get bogged down or issues come up; but the Stratified philosophy is that we never have a car leave without being properly sorted out and the owner at ease and hopefully happy.
Thanks so much Lex, it was all greatly appreciated. I'm deeply in love with my car since we started the tune.
Past
Present
The Following User Says Thank You to CrawlingMS3 For This Useful Post:
Lex (12-19-2013)
 Old 12-19-2013, 12:06 PM   #8
SpencerC's Avatar
Posts: 2,159   (View Stats)
Are you thinking of doing a TMIC yourself in the future? Or just planning on sticking with the Stock.
@Lex; What are your thoughts on a TMIC on his build? How much benefit would he be getting. Just curious since you tuned him.
 Old 12-19-2013, 12:16 PM   #9
A TMIC helps in two ways:
1. In terms of flow and pressure drop across the IC. Flow is increased due to the lower pressure drop across a bigger core
2. In terms of cooling. An FMIC is obviously better since it doesn't get heatsoaked but a larger core does cool better once air is moving across it.
As for "how much" it will help, it is hard to speculate because there are lots of variables to consider and they are related and each car reacts differently. I would venture to say that if all was kept constant and just a TMIC changed on his car he should be over the 300 mark.
CrawlingMS3 (12-20-2013), hatchedspeed3 (12-19-2013)
 Old 12-19-2013, 03:01 PM   #10
SpencerC's Avatar
Thanks. Just curious what you were thinking specifically in relation to his setup. Seems like he might be limiting himself a little by not running a TMIC, the FMIC obviously has more power potential but has some drawbacks such as install time, cost and the larger piping means it isn't a as direct passage for moving the cool air.
 Old 12-19-2013, 11:29 AM   #11
CrawlingMS3 (12-19-2013), hatchedspeed3 (12-19-2013), manila (12-20-2013), SpeedRebirth (12-19-2013), wankular (12-19-2013)
 Old 12-19-2013, 11:35 AM   #12
@CrawlingMS3; fmic because I live in Texas and it's hot year round. Car is always heat soaked and I just like fmic more lol. And e85 is no option for me because there's e85 stations near me. But meth is still on the table
Tappin
 Old 12-19-2013, 11:40 AM   #13
^^^^^Texas heat blows, and I haz no hoodscoops. We have 2 e85 stations around here, none in Austin????
 Old 12-19-2013, 11:41 AM   #14
There's one way south of me and one way north of me.
Tappin
 Old 12-19-2013, 11:48 AM   #15
Tappin
that sucks bro. I have 2 within 5 miles of me. I figured Austin would be full of them.
 Old 12-19-2013, 11:49 AM   #16
If I had a plug in hybrid id be good.
Tappin
 Old 12-19-2013, 11:51 AM   #17
Tappin
figures...fuckin hybrids. Why not get a drum and keep that shit at your house. I know there's a few guys on here that do that
 Old 12-19-2013, 11:50 AM   #18
Groans: 31
That must be really nice. The closest one to me is 19 miles one way
Past
Present
 Old 12-19-2013, 11:52 AM   #19
@CrawlingMS3 my bad, not trying to jack your thread lol
 Old 12-19-2013, 11:53 AM   #20
Lol yeah glad you are happy with your tune. Makes me excited to get started on mine!
Tappin
 Old 12-19-2013, 11:55 AM   #21
@MICASPEED13 are you going with a stratified tune as well?
 Old 12-19-2013, 11:56 AM   #22
Yes sir.
Tappin
 Old 12-19-2013, 11:57 AM   #23
Word! Pm sent
 Old 12-19-2013, 09:32 PM   #24
@Lex, have you seen many, if any cars making 400+who on tmic? Seems like most, if not all, the guys with high #s are fmic
 Old 12-20-2013, 06:26 AM   #25
Groans: 31
The main reason I'm going for a TMIC is cost. A FMIC is just not anywhere in my budget. I'm thinking either ETS or Corksport
Past
Present
 Old 12-20-2013, 09:50 AM   #26
SpencerC's Avatar
I wouldn't recommend a TMIC for that high of numbers, but if you are shooting for sub 350 you are probably good with a TMIC.
 Old 12-20-2013, 10:03 AM   #27
manila's Avatar
Posts: 1,767   (View Stats)
IIRC the freek was running an ETS TMIC on is BNR S3 and broke the 400hp mark
'12 MS3 Black Mica w/ Tech
 Old 12-20-2013, 10:08 AM   #28
Groans: 31
I'm only shooting for about 315-320 so a TMIC is good with me. I was just comparing the CS and the ETS TMICs. The ETS seems to be favored here on the forum and seem to have better power outputs, but is $600. The CS TMIC is $400 and doesn't seem to be as good of an option as the ETS but is more in my budget.
I'll just have to make a decision this Summer once it warms up
Past
Present
 Old 12-20-2013, 11:40 AM   #29
SpencerC's Avatar
Definitely possible, just not usually the route people take.
Give me a call if you interested in a TMIC soon, I have a small number of Scratch and Dent TMICs that are all cosmetic damage, I could sell you one for a discount if you wanted.
360-260-2675 ext 105.
And... thread jack FTW!
CrawlingMS3 (12-20-2013), Goodrich27 (12-20-2013)
 Old 12-20-2013, 11:44 AM   #30
Groans: 31
Thanks for the offer but I just have no extra money for anything right now. Motorcycle payments started about a month ago and it's taking up anything extra I have. This is why I'm searching for a second job, I need more money to dump into my hobbies
Past
Present
 Old 12-20-2013, 07:20 AM   #31
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
Great numbers man, I was very happy with my stratified tune as well
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
 Old 12-20-2013, 10:46 AM   #32
The fmic set up I am doing is about 600. Will support over 400whp. Just FYI. You can do it too.
Tappin
 Old 12-20-2013, 10:53 AM   #33
swsmailman's Avatar
Posts: 1,118   (View Stats)
I can't wait to get more parts and start working on getting a tune made for me. I am going FMIC since I am in Texas and the heat is a bitch during the summer.
@Lex; since I thought of this. Would it be better to do a tune say when the temps are starting to go up? Like around the 70s-80s? To have a tune that would work well for both Texas summers and winters? I would like to be over 300whp once I am fully bolted as that is my goal on my ko4...
2013 Liquid Silver MazdaSpeed
MICASPEED13 (12-20-2013)
 Old 12-20-2013, 11:02 AM   #34
Goodrich27's Avatar
Thought I would chime in here since I was going to do the same thing. On a stock k04 your gains will be minimal and a lot of money for a few horsepower. I would spend that money on a bigger intake. Also having a fmic will increase your coolant temps in the summer. you can stay out of boost with high BATs but having hot coolant temps in no bueno. If your end goal is 300 range stick with a tmic. If they are more then go with a fmic but also consider getting a better radiator at some point. Just my opinion
 Old 12-20-2013, 11:06 AM   #35
swsmailman's Avatar
Already ahead of you, I am picking up an HTP 3" intake after Christmas and will be selling the CorkSport one. I plan on going BT in the next couple of years or so, so I am thinking FMIC for that anyways.
 Old 12-20-2013, 11:08 AM   #36
Also going with an htp 3" intake. I'm hoping the tr6 core won't block as much air as the tr8.
Tappin
 Old 12-20-2013, 11:13 AM   #37
swsmailman's Avatar
Tappin
Get with Edge on that HTP, that is where I am getting mine from for a great price.
To keep this topic going, the FMIC I am looking at is the CPE DeltaCore, since that is the case, guess I would need to look into improving coolant temps as well...
 Old 12-20-2013, 11:14 AM   #38
manila's Avatar
Tappin
I'm running the TR6 core
This core should well suit a GT3076 and smaller. It says its rated at 400hp
 Old 12-20-2013, 11:12 AM   #39
manila's Avatar
Actually, a FMIC or any other upgraded IC plays a vital role in additional HP.
When I was running the OEM top mount heatsoak was always an issue.
Once I added a FMIC, BATs stay low and they drop very quickly.
Haven't seen many guys upgrade their radiators unless they are up in the 500+ HP range.
 Old 12-20-2013, 11:29 AM   #40
Goodrich27's Avatar
This has been tested and proven that the gains are minimal
Another satisfied customer Mikesp3 Stratified Automotive Controls 23 07-20-2013 09:25 AM
Satisfied by Stratified mazdaspeeding Stratified Automotive Controls 28 08-21-2012 03:07 PM
another satisfied STRATIFIED customer ruthless013 Stratified Automotive Controls 0 04-26-2012 09:05 AM
Another satisfied JBR SSP Customer mazdaspeeding MazdaSpeed 3 - Engine, Transmission & Driveline 7 07-14-2010 10:51 AM
Another satisfied customer. MS6 SSP fhaze JAMES BARONE RACING 1 05-03-2010 10:04 AM
Page generated in 0.63971 seconds with 28 queries
