E-Tuners / Custom Hardparts
 Old 12-20-2013, 11:14 AM   #41
manila's Avatar
Posts: 1,767   (View Stats)
Originally Posted by MICASPEED13 View Post
Also going with an htp 3" intake. I'm hoping the tr6 core won't block as much air as the tr8.
Tappin
I'm running the TR6 core
This core should well suit a GT3076 and smaller. It says its rated at 400hp
'12 MS3 Black Mica w/ Tech
 Old 12-20-2013, 11:15 AM   #42
MICASPEED13's Avatar
Posts: 280   (View Stats)
MICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the worldMICASPEED13 is the leader of the world
Originally Posted by swsmailman View Post
Get with Edge on that HTP, that is where I am getting mine from for a great price.
To keep this topic going, the FMIC I am looking at is the CPE DeltaCore, since that is the case, guess I would need to look into improving coolant temps as well...
Yeah edge is what's up. I'm ordering my intercooler through edge too
Tappin
Installed: CORKSPORT:SRI/TIP, IC Piping, Recirc tube, Shifter Bushings, SSP, ULTIMATE RACING CBE, JBR "Dogbone" RMM, COBB AP v2, stage 2 93 OTS map, red Cobb knob, AUTOTECH internals, CNT Catless Downpipe, NGK step colder plugs+ignition coil spring stretch, 5k lows, 3k fogs, LED kit
Wish list: FMIC, HTP full 3in intake, Stratified tune.
MICASPEED13 is offline   Reply With Quote
 Old 12-20-2013, 11:29 AM   #43
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
Actually, a FMIC or any other upgraded IC plays a vital role in additional HP.
When I was running the OEM top mount heatsoak was always an issue.
Once I added a FMIC, BATs stay low and they drop very quickly.
Haven't seen many guys upgrade their radiators unless they are up in the 500+ HP range.
This has been tested and proven that the gains are minimal
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
 Old 12-20-2013, 11:33 AM   #44
Can you say thread jacked?
Tappin
 Old 12-20-2013, 11:34 AM   #45
CrawlingMS3's Avatar
Posts: 3,116   (View Stats)
CrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the worldCrawlingMS3 is the leader of the world
Groans: 31
Groaned at 32 Times in 16 Posts
Tappin
Make yourselves at home
Past
2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love
Present
2014 Chevy Silverado Z71
CrawlingMS3 is offline   Reply With Quote
The Following 2 Users Say Thank You to CrawlingMS3 For This Useful Post:
MICASPEED13 (12-20-2013), swsmailman (12-20-2013)
 Old 12-20-2013, 11:36 AM   #46
Goodrich27's Avatar
3" MAF + Stock TMIC = Win?
No dyno graphs but good info, yea sorry about the thread jack I'm done
 Old 12-20-2013, 11:40 AM   #47
SpencerC's Avatar
Posts: 2,159   (View Stats)
IIRC the freek was running an ETS TMIC on is BNR S3 and broke the 400hp mark
Definitely possible, just not usually the route people take.
Originally Posted by CrawlingMS3 View Post
I'm only shooting for about 315-320 so a TMIC is good with me. I was just comparing the CS and the ETS TMICs. The ETS seems to be favored here on the forum and seem to have better power outputs, but is $600. The CS TMIC is $400 and doesn't seem to be as good of an option as the ETS but is more in my budget.
I'll just have to make a decision this Summer once it warms up
Give me a call if you interested in a TMIC soon, I have a small number of Scratch and Dent TMICs that are all cosmetic damage, I could sell you one for a discount if you wanted.
360-260-2675 ext 105.
And... thread jack FTW!
CrawlingMS3 (12-20-2013), Goodrich27 (12-20-2013)
 Old 12-20-2013, 11:44 AM   #48
Groans: 31
Thanks for the offer but I just have no extra money for anything right now. Motorcycle payments started about a month ago and it's taking up anything extra I have. This is why I'm searching for a second job, I need more money to dump into my hobbies
Past
Present
 Old 12-20-2013, 11:47 AM   #49
Goodrich27's Avatar
+1 I'm one broke ass bitch, @Spencer@CorkSport; any chance this offer would be around next month?
 Old 12-20-2013, 11:48 AM   #50
austin102085's Avatar
Posts: 1,195   (View Stats)
HUMM..... i still need a tune... saving moneyz still
2008.5 Mazdaspeed 3
513whp MS3<-- for now (sold)
The Following User Says Thank You to austin102085 For This Useful Post:
Lex (12-21-2013)
 Old 12-20-2013, 12:27 PM   #51
SpencerC's Avatar
Just give me a call. We do have just a few around, just stuff we don't think is perfect so we set aside. Those fins bend pretty easy so it doesn't take much to have us reject it. Let me know when you are interested though, I'll look around.
Back on Track....
STRATIFIED TUNING ROCKS!
PM me if you guys have more questions so we quit thread jacking.
Lex (12-21-2013)
 Old 12-20-2013, 08:40 PM   #52
pnltncms3's Avatar
Posts: 17   (View Stats)
pnltncms3 is a jewel in the roughpnltncms3 is a jewel in the roughpnltncms3 is a jewel in the rough
How much shipped to Maryland?
pnltncms3 is offline   Reply With Quote
 Old 12-20-2013, 08:55 PM   #53
Goodrich27's Avatar
Neutral  :  -1 score
Because I was apart of this thread jack I'll be nice........ read the post above yours this part of the thread is done and donate brownie
Sent from my phone whilst bojanglen.
 Old 12-20-2013, 09:06 PM   #54
pnltncms3's Avatar
Get a life
The Following User Says NO Thank You to pnltncms3 For This Un-useful Post:
 Old 12-20-2013, 09:09 PM   #55
Originally Posted by pnltncms3 View Post
Get a life
Dude fucking pm him Atleast. If you are gonna milk this thread don't let us know about it.
Tappin
The Following User Says Thank You to MICASPEED13 For This Useful Post:
 Old 12-20-2013, 09:10 PM   #56
pnltncms3's Avatar
Ok thanks
 Old 12-21-2013, 06:19 AM   #57
Groans: 31
Back on Track....
Past
Present
Lex (12-21-2013), MICASPEED13 (12-21-2013)
 Old 12-21-2013, 06:02 PM   #58
I can't wait to get more parts and start working on getting a tune made for me. I am going FMIC since I am in Texas and the heat is a bitch during the summer.
@Lex; since I thought of this. Would it be better to do a tune say when the temps are starting to go up? Like around the 70s-80s? To have a tune that would work well for both Texas summers and winters? I would like to be over 300whp once I am fully bolted as that is my goal on my ko4...
Being able to capture hot and cold temperatures during logs is always something we ask for and work into the tuning process. So tuning when temperatures are mild makes it easy to capture cooler and hotter logs but even tuning in the colder months we can usually create a heatsoaked environment for the motor.
@Lex, have you seen many, if any cars making 400+who on tmic? Seems like most, if not all, the guys with high #s are fmic
Seen in e-tuning and on the dyno, FMIC setups are better at BAT consistency and power output consistency. They are a lot more money. Yes, you can run a TMIC for those power numbers but I would bundle this with some methanol and have a very nice cooling setup.
hatchedspeed3 (12-21-2013), MICASPEED13 (12-23-2013)
 Old 12-23-2013, 06:49 AM   #59
Groans: 31
That was the somewhat annoying part of the tune, haha. Having to sit for minutes at a time to get my BAT's up, and as soon as I hit the throttle they shot down
Past
Present
Another satisfied customer Mikesp3 Stratified Automotive Controls 23 07-20-2013 09:25 AM
Satisfied by Stratified mazdaspeeding Stratified Automotive Controls 28 08-21-2012 03:07 PM
another satisfied STRATIFIED customer ruthless013 Stratified Automotive Controls 0 04-26-2012 09:05 AM
Another satisfied JBR SSP Customer mazdaspeeding MazdaSpeed 3 - Engine, Transmission & Driveline 7 07-14-2010 10:51 AM
Another satisfied customer. MS6 SSP fhaze JAMES BARONE RACING 1 05-03-2010 10:04 AM
Page generated in 0.41533 seconds with 27 queries
