| Stratified Automotive Controls We offer Vehicle Specific Street, Remote E-tuning, Dyno Services for Mazdaspeed 3 and Mazdaspeed 6 vehicles using the COBB AccessPort and VersaTuner. We specialize in control systems, engine management, instrumentation and turbocharging and offer a variety of products and services, from standalone ECUs to build-consulting services. |
![]() Join Date: Jan 2016 Location: Dallas, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
(Thread Starter) | Not Ranked : 0 score I was looking through the Stratified dyno results page and found a 2010 MS3 that made 307whp/357wtq with only an SRI+Test Pipe+E85? That seems like very good numbers. Obviously it has internals but I was wondering since I have a very similar set up if I could expect some numbers close to this if I got a custom tune through you guys. Was this a very aggressive tune or was it mild? Thanks in advance for answering my question. Tax return is coming and I want to make sure I have everything lined up before then.
__________________ 2010 Mica Blue MS3- Go Fast Stuff-AP V3, CS Internals, CS 3" SRI+TIP, CS BPV, H&R Springs/Koni Oranges, JBR Rear Sway, JBR RMM, CS Race Pipe w/res delete. Stratisfied Pro Tune on 93. Working on E85 now. Pretty Stuff-CS LED fogs and headlights, CS LED interior lights, JBR shifter knob, Eonon head unit, Alpine 12" Type S, MB Quart Amp 2006 Mazda 3-170k mile beater that runs strong. |
![]() Join Date: Jun 2014 Location: Chatsworth, CA
Rep Power: 122 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score Here are my results in V dyno with a stratified flash E-tune, CS SRI/TIP, Test pipe, and front mount. This is for a Gen 1 so Gen 2 might vary but it's just a ball park reference. |
(Thread Starter) | Not Ranked : 0 score Good numbers for sure. I wonder how much of your gains are actually from the E85. My other idea was getting a good 93 tune but not if im going to lose 30-40whp.
![]() Join Date: Jan 2015 Location: Holden Louisiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 182
blue is ots tune before the tmic,green was the same ots with tmic added without proper tune (lost power) yellow was 93 retune with the new tmic and red is etune after the tmic.
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ | |
![]() Join Date: Jun 2015 Location: Belgium
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 4
Question, what is you're E85 mix ? 50/50 ?
__________________ 2007 Mazda 3 MPS Cobb accesport v3 Freektuned Corksport SRI - TIP - HPFP internals - Racepipe FMIC Downpipe Shortshifter H&R -4cm springs | |
| Not Ranked : 0 score Running a 33-35% mix 2/1 ratio.
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| E85 is lyfe
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| Not Ranked : 0 score E85 definitely allows for more power. Of course it depends from what fuel you are starting from but as a ballpark idea it is worth 20-40whp (again depending on what fuel you start from). E85 can also offset to some degree some cooling inefficiencies such as an OEM TMIC by not being as knock prone and allowing more timing in spite of higher charge temps that would otherwise result in knock. Have a quick look at this article as well: Blog : E85 Blends in the Mazda DISI and Ford EcoBoost : Stratified Automotive Controls
| The Following User Says Thank You to Lex For This Useful Post: | WetzMS3 (01-20-2016) |
| The Official Downpipe/Test Pipe/Race Pipe Thread | MS3-a(sore)ASS-rex | Mazdaspeed3/6 General Discussion | 415 | 02-06-2020 08:55 PM |
| Brand name test pipe vs. custom muffle shop test pipe | Huligan | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 10-05-2009 07:52 AM |
