E-Tuners / Custom Hardparts
 Old 04-04-2014, 09:52 PM   #1
ThePatient's Avatar
Posts: 128   (View Stats)
ThePatient has much to be proud ofThePatient has much to be proud ofThePatient has much to be proud ofThePatient has much to be proud ofThePatient has much to be proud ofThePatient has much to be proud ofThePatient has much to be proud ofThePatient has much to be proud ofThePatient has much to be proud ofThePatient has much to be proud of
Default Stage 2 S-OTS+ Map logs
this is a 3rd and 4th gear log from tonight. I have had a suspicion that i may have a boost leak.... it seems that i hit a little over 19psi at onset, then fade off to around 16... am i holding correctly and does everything else seem normal?
Corksport: Stage 2 SRI w/TIP, Test Pipe, RMM, SSP, Shifter Bushings, Hood Shocks, LED Fogs Autotech: HPFP Internals Cobb: APV3 Other: JDM Vent Visors, Resonator Delete
ThePatient is offline   Reply With Quote
The Following User Says Thank You to ThePatient For This Useful Post:
Lex (04-05-2014)
 Old 04-04-2014, 10:02 PM   #2
a143gsxr's Avatar
Posts: 42   (View Stats)
a143gsxr is just really nicea143gsxr is just really nicea143gsxr is just really nicea143gsxr is just really nice
You almost always see the boost drop like this. The turbo can't hang at 19psi at the higher rpm. Your logs look pretty good. No knock and good A/F's.
a143gsxr is offline   Reply With Quote
 Old 04-04-2014, 11:52 PM   #3
jtday's Avatar
Posts: 650   (View Stats)
I can hang at 19psi in the upper rev range no problem. This heat these last few days have played a role in that as I've noticed recently. I have similar mods as you albeit the test pipe and also see an increased boost level usually after spoolup that settles out. I only see max loads around 2 at that point however. Maybe your 2.1+ is normal with your mods. Everything else looks great. @Lex; ?
2009 MS3 GT
 Old 04-05-2014, 02:29 AM   #4
a143gsxr's Avatar
Yeah good point, I'm down a couple psi going from 40 F to these last two days of 80F weather. That could add to it.
Sent from my DROID RAZR HD using Tapatalk
 Old 04-05-2014, 09:48 AM   #5
Everything is in check here. AFRs indicate there is no boost leak. The car is flowing well as well. It will only use as much boost as needed to reach the target flow/load. Since flow is what generates power these maps target a consistent torque output. In well flowing cars the boost will be lower and in colder weather the boost will be lower as well due to the air density being higher.
The maps are not meant to take you to the edge of performance as they are meant to keep a good safety margin with great driveability. The next step is the custom tune to dial in the setup very specifically.
Agent_Orange (04-05-2014), Axela_EN (04-08-2014), jtday (04-05-2014), ThePatient (04-05-2014)
S-OTS Stage 1 Logs bheath3 2010 MS3 - ECU Computer Tuning 0 08-24-2013 10:13 AM
Stage II Logs Awesomesauce 2010 MS3 - Dyno Sheets/Discussions 9 03-09-2013 04:26 PM
Stage 1 First Logs Tyhackman15 MazdaSpeed 3/6 - ECU Computer Tuning 1 12-15-2012 01:43 AM
Stage 2 Logs iammike 2010 MS3 - ECU Computer Tuning 51 10-11-2012 03:57 PM
New Logs since going stage 2 bwspeed MazdaSpeed 3/6 - ECU Computer Tuning 4 06-10-2011 11:45 AM
Page generated in 0.27338 seconds with 24 queries
