E-Tuners / Custom Hardparts
 Old 08-19-2014, 10:15 PM   #1
dltpjr's Avatar
Posts: 6   (View Stats)
dltpjr is an unknown quantity at this point
Question Stage1 S-OTS 93 Octane log
Can someone tell me whats going on in this log please?
datazap.me | dltpjr | MS6
Seems like it runs rich, lots of knock. I'm new to this so any help from more experienced members is appreciated.
2007 Mazdaspeed 6
JBR PowerPath Stage II, Stage1 S-OTS 93 Octane map
Everything else is stock
Thanks!
dltpjr is offline   Reply With Quote
 Old 08-20-2014, 01:06 AM   #2
It is indeed running much richer than what the map is calling for and this is causing your fuel pressure to drop.
Please perform the following:
1. A boost leak test
2. Make sure the MAF o-ring is not damaged and it is sealing
3. Clean the MAF while in there
Let me know what you find and if you find any leaks take a 3rd gear log after you've fixed them.
chaser27 (08-20-2014), SarcasticOne (08-20-2014)
 Old 08-20-2014, 02:32 AM   #3
dltpjr's Avatar
Ok will do asap
Is this safe to drive on? I use the car as my DD.
 Old 08-20-2014, 02:58 AM   #4
Snip's Avatar
Posts: 329   (View Stats)
With those knock numbers and low fuel pressure, i would stay away from wot until you find and fix the problem.
MazdaSpeed3 GT '07
AccessPort V2 Self tuned
 Old 08-20-2014, 04:33 AM   #5
dltpjr's Avatar
OK will do. Gonna have my friend help me leak test it tomorrow.
Appreciate the help!
 Old 08-20-2014, 09:01 AM   #6
Default Stage1 S-OTS 93 Octane log
As snip mentioned above don't beat on it until the hardware issues are resolved and logs look clean. You can certainly drive it to work.
93 Octane losing ... octane? Lex MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 04-09-2013 05:32 PM
Pros/ Cons for running 85 octane reg. unleaded instead of 91 octane premium ZoomZoom06 Mazdaspeed3/6 General Discussion 7 07-24-2012 11:44 PM
No 93 octane in NM..what octane booster to use shifter48 Gen2 MS3 General Discussion 18 06-10-2012 10:54 AM
Stage1+SF+TIH+CDFP 93 Octane BT Logs PapaSmurf 2010 MS3 - ECU Computer Tuning 12 06-02-2011 06:24 PM
93 octane safe for a v102 91 octane map? SLOMS3
Cobb Access Port/Maps
2 12-20-2008 04:26 PM
Page generated in 0.25675 seconds with 22 queries
