E-Tuners / Custom Hardparts
 Old 07-11-2014, 07:13 AM   #1
untitledav's Avatar
Posts: 189   (View Stats)
untitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond reputeuntitledav has a reputation beyond repute
Default Strange LTFT posible boost leak?
Hello,
Lex can you please take a look at the post:
Strange LTFT possibly boost leak?
Im having strange LTFT behavior, Please shine some of your awesome knowledge and hopefully we can figure out what is the deal with it.
Thanks for your help!
::UaV:: 2013 Mazdaspeed3 VRM
Mods: JBR StageII Intake, AutoTech HPFP, CorkSport TestPipe, Resonator Delete, ETS TMIC,
Step Colder NGK, JBR 88a RMM, JBR Short Shift Plate, JBR Shifter Bushings, AccessPortV3,
S-OTS+ Stage2 93, Damond OCC, Forge BPV V1.
untitledav is offline   Reply With Quote
 Old 07-11-2014, 12:03 PM   #2
Your tune is perfectly safe based on the logs you sent in via e-mail. We are working via e-mail to touch up the MAF calibration if it needs it but there is nothing to worry about safety wise.
 Old 07-11-2014, 12:20 PM   #3
untitledav's Avatar
Thank you Lex!!!!!
The Following User Says Thank You to untitledav For This Useful Post:
Lex (07-11-2014)
 Old 07-11-2014, 12:29 PM   #4
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Definitely a boost leak. @Lex; is trying to make you feel better. I would recommend pulling the turbo off altogether and just capping the turbo flange immediately. NA = Way Okay.
MINI H1 6.0 - CAR LED TAILS
 Old 07-11-2014, 01:16 PM   #5
untitledav's Avatar
hahaha i might as well pull the engine off and use a donkey instead
Strange LTFT possibly boost leak? untitledav 2010 MS3 - ECU Computer Tuning 11 07-11-2014 12:20 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
Strange noise under boost - MS6 cocoanton MazdaSpeed 3/6 - Turbo Induction 14 04-03-2011 02:51 PM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Page generated in 0.27402 seconds with 22 queries
