E-Tuners / Custom Hardparts
Like Tree21Likes
 Old 03-17-2014, 08:17 PM   #41
carfreakMS3's Avatar
Posts: 30   (View Stats)
carfreakMS3 is a name known to allcarfreakMS3 is a name known to allcarfreakMS3 is a name known to allcarfreakMS3 is a name known to allcarfreakMS3 is a name known to allcarfreakMS3 is a name known to all
Just purchased look forward to the map
2009 True Red Mazdaspeed 3
Cobb Intake/TIP
Res. Delete
cp-e stage 2 RMM
Tein S-tech Springs
Cobb AP V.3
carfreakMS3 is offline   Reply With Quote
The Following User Says Thank You to carfreakMS3 For This Useful Post:
Lex (03-17-2014)
 Old 03-17-2014, 11:00 PM   #42
All orders received prior to today should have a map!
Mauro_Penguin likes this.
Asianspeed3 (03-17-2014), Axela_EN (03-18-2014), Mauro_Penguin (03-24-2014), natieb (03-18-2014)
 Old 03-18-2014, 02:49 AM   #43
tbcota25's Avatar
Posts: 1,542   (View Stats)
tbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the world
Just put my catless dp on yesterday... Waiting to see what cels are gonna pop before I order mine I can't wait
Sent from my SAMSUNG GALAXY NOTE 3 using Tapatalk
2012 Black Mica
Mods
CS catless DP, CS RP
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
CS Short Shit Kit and Shifter Bushings
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
JBR Reticulation Tube
Cobb AP v2
H&R springs
JBR Rear Sway Bar
Self Built 3 Port EBCS
maisonvi Shift Knob
Tuned on 93 and corn
tbcota25 is offline   Reply With Quote
The Following User Says Thank You to tbcota25 For This Useful Post:
Lex (03-18-2014)
 Old 03-18-2014, 08:00 PM   #44
darthxar's Avatar
Posts: 560   (View Stats)
darthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the world
Can't wait for my fuel trims to settle in so I can see what this OTS has really got.
Double tappin' the Moto
2013 VRM MS3
darthxar is offline   Reply With Quote
The Following User Says Thank You to darthxar For This Useful Post:
Lex (03-19-2014)
 Old 03-18-2014, 08:02 PM   #45
Fuel trims are not active at WOT. You don't have to let the car "learn" before going WOT.
 Old 03-18-2014, 08:19 PM   #46
darthxar's Avatar
I thought the gen pu did some adjusting at WOT. I guess I am just in the habit of letting things settle before beating on a new set up.
2013 VRM MS3
Lex (03-19-2014)
 Old 03-18-2014, 08:56 PM   #47
msp2709's Avatar
Posts: 104   (View Stats)
msp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond reputemsp2709 has a reputation beyond repute
Submitted my mod form and am anxiously waiting. Can't wait to see the difference over my Cobb ots map
sent while blasting a dookie
msp2709 is offline   Reply With Quote
The Following User Says Thank You to msp2709 For This Useful Post:
Lex (03-19-2014)
 Old 03-18-2014, 09:11 PM   #48
kolosok17's Avatar
Posts: 1,104   (View Stats)
Just saw this thread and made a purchase. Thanks for making this offer!
2012 CWP Non-Tech MS3
The Following User Says Thank You to kolosok17 For This Useful Post:
Lex (03-19-2014)
 Old 03-18-2014, 10:21 PM   #49
Axela_EN's Avatar
Posts: 498   (View Stats)
Axela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the worldAxela_EN is the leader of the world
Should change from closed loop to open loop at WOT
tapa-da-gas
Jakeypoo likes this.
Custom Tuned, Bolted and on Meth......
Still slower than my dad's Impala
Now featuring: Turblow Smoke Screen Mod
Axela_EN is offline   Reply With Quote
The Following User Says Thank You to Axela_EN For This Useful Post:
Lex (03-19-2014)
 Old 03-19-2014, 03:01 AM   #50
tbcota25's Avatar
Ahhh all sold out
Sent from my SAMSUNG-SM-N900A using Tapatalk
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
Lex (03-19-2014)
 Old 03-19-2014, 08:12 AM   #51
BruhhWill's Avatar
BruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond reputeBruhhWill has a reputation beyond repute
I've been running my S-OTS Plus map since yesterday. I was previously running a Cobb OTS Stage 1+ map. Some comparisons between the two:
I feel that this S-OTS Plus tune is a more healthier tune. My AFR is in a much better range under WOT (lowest I dip is 11.8), and with the Cobb I was dipping into the low 10s. This alone is awesome.
Autotech Internals are responding very well to the tune; hitting about 1800 under WOT.
Boost is around 14-15psi, depending on the gear I'm in.
Feels like a smoother, healthier tune that's just as powerful as how my car responded to the Cobb OTS tune, if not a little more powerful. I'm still seeing how the car moves in certain situations.
Money well spent, absolutely. Hoping to purchase a full E-Tune down the road. I'm sure there's a lot of potential to be unlocked.
2008.5 MGM Mazdaspeed3
Engine
Cobb Accessport // Autotech HPFP Internals // Stratified Auto 3 Port Boost Control Solenoid (2-Port Mode) // Injen Cold Air Intake // CorkSport TIP // NGK Spark Plugs // Ultimate Racing Resonated Test Pipe // Stratified Auto S-OTS Stage 2+ Tune //
Transmission
JBR V2 Rear Motor Mount 80a // JBR Heavy Shift Knob // Corksport Shifter Bushings // Corksport Short Shift Plate //
Suspension
Koni Yellow Struts and Shocks with H&R Sport Springs // JBR Rear Sway Bar // 18x8 +45 Enkei Raijins in Black wrapped in Kumho Ecsta 4X All Seasons 235/40/18
Aesthetics
JDM Axela Window Visors // Corksport LED Fog Lights // Corksport LED Interior Lights //
Past:
1999 Crystal Blue Honda Prelude SH
2006 Titanium Grey Mazda 3 Hatchback (R.I.P.)
1995 Hyundai Elantra
BruhhWill is offline   Reply With Quote
The Following 2 Users Say Thank You to BruhhWill For This Useful Post:
kolosok17 (03-19-2014), Lex (03-19-2014)
 Old 03-19-2014, 08:26 AM   #52
tbcota25's Avatar
So I just installed my catless dp last weekend so now I have a complete catless the... I noticed I'm over boosting to 23ish psi... Would this s-ots map fix that? My AFR also dropped as low as 9.3 at wot...
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
Lex (03-19-2014)
 Old 03-19-2014, 08:29 AM   #53
Axela_EN's Avatar
What are your fuel trims like? Are you running a stage 2 OTS map now that you have a DP? Sounds like a boost leak or maybe SWAS.
tapa-da-gas
Lex (03-19-2014)
 Old 03-19-2014, 08:30 AM   #54
tbcota25's Avatar
Yeah Cobb stage 2 93
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
Lex (03-19-2014)
 Old 03-19-2014, 09:19 AM   #55
mzrtrooper's Avatar
Posts: 72   (View Stats)
mzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond reputemzrtrooper has a reputation beyond repute
Groaned at 5 Times in 2 Posts
@lex I saw that it is currently "Sold Out" any idea when we will see this back up?
mzrtrooper is offline   Reply With Quote
The Following User Says Thank You to mzrtrooper For This Useful Post:
Lex (03-19-2014)
 Old 03-19-2014, 12:55 PM   #56
Thanks for the review and glad you're enjoying the tune. This sounds exactly correct for a Stg1. There is still a good amount of potential to unlock from where you currently are.
More tunes were just added to the site and a batch of maps are going out today to those that have submitted their forms.
Both gen1 and gen2 do but they are not the same trims that are at play. It is not a bad idea to get a feel for the car slowly however.
The S-OTS+ maps are MUCH more resilient to mods and overboosting. So chances are you won't overboost. If you do still overboost, it's time for a full tune and you can always use the amount paid for the S-OTS+ towards the full tune.
Last edited by Lex; 03-19-2014 at 12:55 PM. Reason: MSF Database - Automerged Doublepost
BruhhWill (03-19-2014), Pointless (03-19-2014), tbcota25 (03-19-2014)
 Old 03-19-2014, 01:11 PM   #57
therapist510's Avatar
Posts: 83   (View Stats)
therapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond reputetherapist510 has a reputation beyond repute
I got the the stage 2 map. It runs rich: 9.8-10.2 AFR under WOT. Pulls way harder than my stage 1 map and I'm averaging 26mpg with 70% freeway driving. I'm noticing much better throttle response probably due to the new spark plugs. Overall, happy with it. Expect a full tune order soon Lex. Debating if I should get a test pipe or not.
Corksport SRI/TIH, Treadstone TR8/CXracing kit, Corksport Testpipe, Autotech HPFP, CPE Safe seals, Cobb Ap. Freektuned.
ISC N1 Street Sport coilovers. Enkei RPF1 17x9 35/45 front and rear offsets. Bridgestone Potenza RE-71R 235 45 17.
therapist510 is offline   Reply With Quote
The Following User Says Thank You to therapist510 For This Useful Post:
Lex (03-19-2014)
 Old 03-19-2014, 01:48 PM   #58
tbcota25's Avatar
Do you have a dp?
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
 Old 03-19-2014, 01:57 PM   #59
Do you have a dp?
Nope. According to Lex, I have enough flow mods for stage 2.
 Old 03-19-2014, 02:08 PM   #60
tbcota25's Avatar
You should so get a race pipe... Do you have a cbe???
Just ordered my s-ots map
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
Last edited by tbcota25; 03-19-2014 at 02:08 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-19-2014, 02:25 PM   #61
I do recommend getting a test pipe. Also check for boost leaks. The map commands leaner AFRs than this and AFRs should only dip to 11 by redline if there is no KR and there are no leaks.
The throttle response is all in the tune
therapist510 (03-19-2014)
 Old 03-19-2014, 06:55 PM   #62
All maps sent to those who submitted their information.
 Old 03-19-2014, 08:20 PM   #63
King Scumbag's Avatar
Posts: 2,384   (View Stats)
IM sure many of these peeps running OTS+ will be immediately hooked on getting a full strat tune!
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
Lex (03-19-2014)
 Old 03-19-2014, 08:27 PM   #64
msp2709's Avatar
Oh my god. This tune vs my ots Cobb stage 2 is incredible. The power comes on hard and the car pulls very smooth to Redline. This is the best 25$ I have ever spent. Also cemented my decision to get a full tune from stratified.
The Following 4 Users Say Thank You to msp2709 For This Useful Post:
King Scumbag (03-19-2014), Lex (03-19-2014), Mike@Stratified (03-20-2014), tbcota25 (03-19-2014)
 Old 03-19-2014, 08:47 PM   #65
kolosok17's Avatar
Just did a couple of log runs in 3rd gear for a Stage 1 S-OTS+ map. Wow - what a difference! I used to have minor KR (under 1) all over the place with the COBB map in all of my logs and now that's all gone. Acceleration feels much smoother. AFR's around 11.5 or so.
Lex (03-19-2014)
 Old 03-20-2014, 07:21 AM   #66
darthxar's Avatar
Well I have about 100 miles on my S-OTS+ stage 1 now, and it is really nice. It feels like power levels are about on par with the previous stage 1 I was running with, but the power delivery and throttle response are much smoother and more linear. It feels like I have much better control over the car now
Fuel trims are little wider than I would really like, but still within +/- 8% so I am not to concerned with that.
I am definitely sold on getting a full tune from Stratified. Now I just need to decide if I am going to put a test pipe on and go for stage two levels of power, or just stay were I'm at and get it dialed in as is.
Lex (03-20-2014)
 Old 03-20-2014, 07:35 AM   #67
tbcota25's Avatar
Test pipe... Dooooo it!!!
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
Lex (03-20-2014)
 Old 03-20-2014, 03:26 PM   #68
Suzysube's Avatar
Posts: 32   (View Stats)
Suzysube is just really niceSuzysube is just really niceSuzysube is just really niceSuzysube is just really nice
Just ordered. Can't wait to try it.
Suzysube is offline   Reply With Quote
The Following User Says Thank You to Suzysube For This Useful Post:
Lex (03-20-2014)
 Old 03-20-2014, 06:18 PM   #69
tbcota25's Avatar
Ordered mine yesterday... Can't wait to be contacted
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
Lex (03-20-2014)
 Old 03-20-2014, 06:59 PM   #70
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
This S-OTS+ work is keeping @Lex; busier than a one-armed wallpaper hanger
The Following 4 Users Say Thank You to Mike@Stratified For This Useful Post:
Axela_EN (03-20-2014), King Scumbag (03-20-2014), Lex (03-20-2014), tbcota25 (03-21-2014)
 Old 03-20-2014, 07:05 PM   #71
I knew a 1 armed roofer...Dude was a boss!
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
The Following 2 Users Say Thank You to King Scumbag For This Useful Post:
Lex (03-20-2014), Mike@Stratified (03-21-2014)
 Old 03-20-2014, 11:39 PM   #72
Suzysube's Avatar
Got the email back tonight. That was fast. Great customer service.
 Old 03-21-2014, 03:09 AM   #73
cciepunk's Avatar
Posts: 181   (View Stats)
cciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the world
Groaned at 43 Times in 42 Posts
Will the S-OTS Plus maps support an Ebcs in interrupt mode or does it still require a custom etune?
cciepunk is offline   Reply With Quote
 Old 03-21-2014, 11:17 AM   #74
This requires a custom tune. You can run the EBCS in 2 port mode by blocking the 3rd port until you're ready for the a custom tune.
cciepunk (03-21-2014)
 Old 03-21-2014, 11:41 AM   #75
Yatta's Avatar
Posts: 1,862   (View Stats)
Just paid, have been using S-OTS stage 2 for a while with my set up, will be interested to see what changes but even if nothing does I'm happy to throw some cash your way.
Lex (03-21-2014)
 Old 03-21-2014, 02:07 PM   #76
cciepunk's Avatar
I have configured in 2-port mode already. Thanks for the clarification.
The Following User Says Thank You to cciepunk For This Useful Post:
Lex (03-21-2014)
 Old 03-21-2014, 05:24 PM   #77
justinsane87's Avatar
Posts: 877   (View Stats)
justinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the worldjustinsane87 is the leader of the world
Just loaded up the map, feels really good, power definitely comes on earlier.
I'm hitting -20.31 ltft though, is that going to be a problem?
Sent from the flux capacitor
2013 Mazdaspeed 3 - GTX3076R EWG
Autotechs - FreekBuilt 3.5" - UR Catless Turbo-back - AP V3 - ETS TMIC
JBR 80D Trilogy/SSP/Bushings/Heavy Knob/TIGs/0.250 RSB - GFB BOV
FreekTune'd - DO DVC-30 - Ground Control w/Koni Yellows - DM OCC
Enkei RPF1 17x9 w/ PSS 235/45/17 - Full Race Exhaust Mani
justinsane87 is offline   Reply With Quote
 Old 03-21-2014, 05:40 PM   #78
This means you likely have a leak between the turbo and throttle body. Check the intercooler connections for any boost leaks.
justinsane87 (03-21-2014)
 Old 03-23-2014, 04:55 PM   #79
tbcota25's Avatar
Just received my s-ots+ map via email... I can't wait to get it installed... Ps thanks for the great customer service
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
 Old 03-23-2014, 05:04 PM   #80
Suzysube's Avatar
Just received the map and installed it. Boost is more smoother compared to cobbs ots map. But only drove for 20 min. So far so good.
tbcota25 (03-23-2014)
How To: Stratified Tune Lex Stratified Automotive Controls 1 07-24-2014 12:22 PM
First Stratified S-OTS+ Tune Jadcock 2010 MS3 - ECU Computer Tuning 45 07-09-2014 08:57 AM
Stratified Tune phahengpro MazdaSpeed 3/6 - ECU Computer Tuning 42 03-07-2014 03:29 PM
Stratified Tune? ape_ck Stratified Automotive Controls 7 08-04-2013 08:21 AM
Stratified tune done. MS309 Stratified Automotive Controls 57 08-04-2012 05:39 PM
Page generated in 0.60243 seconds with 36 queries
