E-Tuners / Custom Hardparts
Like Tree21Likes
 Old 04-07-2014, 07:10 AM   #121
rbflurry's Avatar
Posts: 193   (View Stats)
rbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond reputerbflurry has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Is there any Dyno or vd numbers for these tunes ? Just curious.
rbflurry is offline   Reply With Quote
The Following User Says Thank You to rbflurry For This Useful Post:
Lex (04-07-2014)
 Old 04-07-2014, 07:56 AM   #122
DO NOT BUY FROM ME!
bigwavedave33's Avatar
Posts: 288   (View Stats)
bigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the worldbigwavedave33 is the leader of the world
Got mine last week, but was super busy all last week. With the original S-OTS Stage 2 93 oct and my combination of mods, car was pushing over 23psi which was not good. I wasn't driving it so much after I saw that. Loaded it up Friday before I went out for a spin in the evening. With the S-OTS+ option car is much smoother when it gets into the boost rather than light switchish. I need to do some logging, but might not happen this week. Thanks again for the OTS+ option. Look forward to getting a full tune in the future.
bigwavedave33 is offline   Reply With Quote
The Following User Says Thank You to bigwavedave33 For This Useful Post:
Lex (04-07-2014)
 Old 04-07-2014, 03:45 PM   #123
lx_diego's Avatar
Posts: 42   (View Stats)
lx_diego is a name known to alllx_diego is a name known to alllx_diego is a name known to alllx_diego is a name known to alllx_diego is a name known to alllx_diego is a name known to all
Groaned at 13 Times in 5 Posts
This is awesome. I bought mine Friday night and got a reply Saturday night. Hopefully will receive it today! Can't wait!
2013 Mazdaspeed3 | Cobb AP, Cobb SRI, Cobb TIP, Ultimate Racing Catless Test Pipe, Autotech HPFP Internals, JBR Rear Motor Mount 88 Duro, Forge BPV, NGK LTR7IX-11, XT-M5-QS, Stratified E85 S-OTS.
lx_diego is offline   Reply With Quote
The Following User Says Thank You to lx_diego For This Useful Post:
Lex (04-07-2014)
 Old 04-07-2014, 04:35 PM   #124
darthxar's Avatar
Posts: 560   (View Stats)
darthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the worlddarthxar is the leader of the world
I have a couple stage one pulls I have done. I will try to load them into vdyno later.
Double tappin' the Moto
2013 VRM MS3
darthxar is offline   Reply With Quote
The Following User Says Thank You to darthxar For This Useful Post:
Lex (04-07-2014)
 Old 04-07-2014, 07:13 PM   #125
New maps are going to be sent out tomorrow guys - sorry but just not enough time in the day!
lx_diego (04-07-2014)
 Old 04-07-2014, 08:32 PM   #126
darthxar's Avatar
Well the pulls I had have some weird peaking. The roads around here are still bad from winter, so probably surface issues. I will see if I can find a smoother spot tomorrow.
2013 VRM MS3
 Old 04-08-2014, 10:23 AM   #127
lx_diego's Avatar
when I get the map, what should I be monitoring on my AP to make sure everything is fine?
 Old 04-08-2014, 01:58 PM   #128
There are some guidelines that come with the maps.
More calibrations went out today. Thanks everyone.
lx_diego (04-08-2014)
 Old 04-08-2014, 02:10 PM   #129
lx_diego's Avatar
that's what I actually wasn't sure of. Just received my map and about to go flash. Thank you so much @Lex; !
Lex (04-08-2014)
 Old 04-08-2014, 02:21 PM   #130
lx_diego's Avatar
So even though I have my fuel pump internals upgraded its still a stage one map correct? until I get my downpipe?
Lex (04-08-2014)
 Old 04-08-2014, 02:35 PM   #131
SpencerC's Avatar
Posts: 2,159   (View Stats)
Just received mine. Thanks a million @Lex; for working so hard and providing such a great option for the community. If you are lucky.... or maybe ... unlucky? Once it's installed and I'm rocking it I'll probably be sending many more people your way.
Lex (04-08-2014)
 Old 04-08-2014, 02:42 PM   #132
There were very few flow parts on the car with the exhaust and intercooler being stock. It is best to not push the turbo too hard until it's able to breathe a little better.
Thanks Spencer - very much appreciated, hope you enjoy the S-OTS+ and hopefully we'll work on a full tune in the future with you!
lx_diego (04-08-2014), SpencerC (04-09-2014)
 Old 04-08-2014, 03:51 PM   #133
darthxar's Avatar
Here is a 3rd gear pull on my Stage 1 SOTS+ map. Keep in mind however that my car has enough flow mods to run stage 2, but I went stage 1 to conservatively feel out Stratified tuning strategies. I have just recently ordered my full tune. This is with CorkSport stage 2 intake, CPE TMIC, and a TP. It was also about 40 degrees F so I have a pretty low boost to get the load numbers. I am also impressed that I have not been seeing any over boost issues with the extra flow mods.
EDIT: put in a better log with 3rd and 4th.
Last edited by darthxar; 04-08-2014 at 06:45 PM. Reason: put cleaner couple pulls includes 4th gear
Lex (04-08-2014)
 Old 04-08-2014, 05:23 PM   #134
Attachment 154793
Thanks for posting!
The graph looks a little funny because throttle position is low at the beginning of the log. You can manually set it to 100 when you actually go WOT in the log and resave for virtual dyno purposes.
 Old 04-08-2014, 05:44 PM   #135
darthxar's Avatar
Thanks for posting!
Thanks for the tip. I'm pretty new to VD. Just did a new pull to send to you for full tune. I will try with that one.
2013 VRM MS3
 Old 04-08-2014, 06:47 PM   #136
darthxar's Avatar
Edited first post with a different log. Got much smoother results and more realistic numbers.
 Old 04-08-2014, 07:01 PM   #137
knocturnal's Avatar
Posts: 266   (View Stats)
Got mine Today also. Just took the car out for a spin and it feel alot smoother. while doing a pull in third the it felt like the tires wanted to break loose the higher the rpm got. I am very happy with this new tune and you just might hear from me again about getting a proper tune after i get a TMIC or FMIC installed.
Thank you LEX!!
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
The Following User Says Thank You to knocturnal For This Useful Post:
Lex (04-08-2014)
 Old 04-08-2014, 09:47 PM   #138
lx_diego's Avatar
Thank you @Lex; I did some runs today and wow did they amaze me. I'm going to be posting some logs in a few. Be much appreciated if you gave them a quick check for me!
Lex (04-08-2014)
 Old 04-09-2014, 09:38 AM   #139
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
Ordered mine last night. Thought I'd try this out... I mean it should be better than the self tune I have that after fires every other shift .... Plus for $25 it really is an amazing deal.
2012 Mazdaspeed3 Black Mica
The Following User Says Thank You to Cujo For This Useful Post:
Lex (04-09-2014)
 Old 04-09-2014, 02:10 PM   #140
rbflurry's Avatar
@Lex;
Was going to send this as a PM but figured it might help someone else out.
I have a sure intake, Cobb TIP, Streetuint TMIC, Synapse BPV and AT internals.
Would the tune that you send out differ if I added a test pipe to the mix?
I'm not sure if I should buy now or when I install the Testpipe.
Thanks
 Old 04-09-2014, 02:52 PM   #141
@Lex;
Thanks
Since you do have the flow of a TMIC I can send you a stg2 map which will then work well with your test pipe when you install it.
 Old 04-09-2014, 07:33 PM   #142
SpencerC's Avatar
Run number 1 was probably not on level ground. Lol. Wish those were my numbers.
 Old 04-09-2014, 07:40 PM   #143
Had a look at one of the logs and it looks clean. Try a 4th gear run and adjust the throttle position in the log to be at 100 when you start the run. That will smooth the Vdyno plot out a lot.
 Old 04-09-2014, 07:43 PM   #144
SpencerC's Avatar
I'll get back out and do more. I really shouldn't have been doing runs 15 minutes ago, to many people on the road. The logs look great! Everything looks within spec, no problems (one spot of knock for 1.4 in the third log, but it does't seem to be concerning) Otherwise super happy.
Lex (04-09-2014)
 Old 04-10-2014, 02:48 PM   #145
Cujo's Avatar
I know it takes up to 48 business hours before being contacted but the wait is killing me
edit: 2 seconds after Iwrote this I got the email. I was going to respond to it but stupid gmail is stupid and replied before I could type anything. Im glad I attached the form before typing the body.
V/R
Lex (04-10-2014)
 Old 04-10-2014, 03:12 PM   #146
A bunch of e-mails just went out and the maps are following right now for those that submitted the forms.
Cujo (04-10-2014)
 Old 04-10-2014, 04:24 PM   #147
Everyone, our S-OTS+ tunes currently have 10 more slots open. Once these sell out it will be 75 happy S-OTS+ customers and it will also mark the end of the introductory price period.
The prices are going to go up very mildly to cover some of the fees and development time involved. The price once these last 10 are sold will be $40 CAD.
This will ensure the sustainability, research, development and improvement of our tunes, products, and service.
The great news is that we will continue to honour a 100% refund of the S-OTS+ price if you purchase the full Stratified tune within 3 months.
Cujo (04-10-2014)
 Old 04-10-2014, 05:40 PM   #148
Cujo's Avatar
wow that was a fast turn around time!!! going to try it out now
Lex (04-10-2014)
 Old 04-10-2014, 05:44 PM   #149
All that maps have gone out for the customers that have sent in their forms!
 Old 04-10-2014, 07:50 PM   #150
Cujo's Avatar
Well just got home from driving around town and I have to say that this was the best $25 I have ever spent on my car. It's so much smoother now. I still get a tiny pop when I give it some gas but it's nonexistent during normal driving. Changing gears feels a lot smoother now too. I plan on getting a custom tune from you guys here in the near future.
Lex (04-10-2014)
 Old 04-10-2014, 08:16 PM   #151
Glad you enjoy it and thanks for the review! The driveability is what we spent a lot of time refining.
Cujo (04-10-2014)
 Old 04-10-2014, 08:53 PM   #152
punkk77's Avatar
Posts: 813   (View Stats)
punkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the worldpunkk77 is the leader of the world
Make that 9 more left. :-)
2012 Black Mica Mazdaspeed 3 w/tech
CS SRI w/TIP - CS ABE - SU Test Pipe - JBR 88 RMM
Cobb AP V2 - Autotech Internals - Stratified OTS+ Stage 2 Tune
Maisonvi Stainless Dessert Beagle Knob - Custom Mud Flaps - Lovely, lovely Rice - CS BPV - JBR BPV Hose - Damond OCC
SOON...
CS 3" Intake - CS TMIC - Cobb Springs w/Koni Yellows
punkk77 is offline   Reply With Quote
The Following User Says Thank You to punkk77 For This Useful Post:
Lex (04-10-2014)
 Old 04-10-2014, 09:21 PM   #153
distortion's Avatar
Posts: 66   (View Stats)
distortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud of
Sorry if this has been asked already but are the S-OTS+ mapes load based?
2011 Black Mica W/Tech Package
Cobb AP|CP-E HPFP|Corksport SRI/TIP|Corksport TMIC|UR Test Pipe|Corksport Cold Air Box|Corksport Rear Sway Bar|JBR Shifter Bushings|Corksport RMM|Techna Fit Stainless Brake Lines|Ultraguage|Stratified E85
distortion is offline   Reply With Quote
 Old 04-10-2014, 10:21 PM   #154
Yes they do use a load based strategy.
distortion (04-13-2014)
 Old 04-11-2014, 06:42 PM   #155
distortion's Avatar
Thanks @Lex; purchased!
The Following User Says Thank You to distortion For This Useful Post:
Lex (04-12-2014)
 Old 04-12-2014, 06:26 PM   #156
lx_diego's Avatar
I have one step colder plugs that i recently bought. Should I put these in with this ots map?
Lex (04-12-2014)
 Old 04-12-2014, 08:20 PM   #157
acuracy's Avatar
Posts: 1   (View Stats)
acuracy will become famous soon enough
@Lex; need some help. Purchased a S-OTS map and received it within minutes of submitting my form. Issue I have is that the serial number registered on the AP is different then the label on the back and the box. It's just one number different. Because of this I can't load the map. Should of checked the serial number on the AP to make sure it matched the label. Would like to experience the hype around your tunes. Can you help?
I hate that is my first post on this forum.
acuracy is offline   Reply With Quote
The Following User Says Thank You to acuracy For This Useful Post:
Lex (04-12-2014)
 Old 04-12-2014, 08:39 PM   #158
Make sure they are gapped to 0.026" and go ahead.
Just reply to the e-mail with the ACTUAL serial number of the AP. I will resend you the map. You are the second person to not have matching labels.
Welcome to the forums and don't be sorry! We'll get you sorted out to enjoy the map you purchased.
lx_diego (04-12-2014)
 Old 04-13-2014, 02:17 PM   #159
mrtheandrew's Avatar
Posts: 468   (View Stats)
@Lex; Purchased!! I will be getting the full tune when I get home in a few weeks and get my mountain of parts installed.
2007 True Red MS3
Koni Yellows || H&R Springs || JBR RSB || JBR Dogbone RMM || Centric Blanks || CS Pads || Goodridge SS Brake Lines || CS SSP || Hella Supertones || 55w 5000k HIDs/35w 3000k fogs || eonon D5151 HU/Nav/PS2 || 17x8 RPF1s || 235/45 DW || CS BPV || CS Intake/TIP || CXRacing/Godspeed FMIC || Ultimate Racing TP || Autotech Internals || AP v3
The Following User Says Thank You to mrtheandrew For This Useful Post:
Lex (04-13-2014)
 Old 04-13-2014, 02:20 PM   #160
Thank you! Maps and e-mails are going out tomorrow - Monday.
How To: Stratified Tune Lex Stratified Automotive Controls 1 07-24-2014 12:22 PM
First Stratified S-OTS+ Tune Jadcock 2010 MS3 - ECU Computer Tuning 45 07-09-2014 08:57 AM
Stratified Tune phahengpro MazdaSpeed 3/6 - ECU Computer Tuning 42 03-07-2014 03:29 PM
Stratified Tune? ape_ck Stratified Automotive Controls 7 08-04-2013 08:21 AM
Stratified tune done. MS309 Stratified Automotive Controls 57 08-04-2012 05:39 PM
Page generated in 0.59500 seconds with 32 queries
