Stratified S-OTS maps for the JBR Power Path Intakes We are proud to announce that we've teamed up with James Barone Racing to offer Stage1 and Stage2 Off the shelf (S-OTS) maps for the MazdaSpeed and Mazda MPS vehicles worldwide. As a COBB Pro Tuner and with thousands of hours of tuning experience on the Mazda platform we are able to offer these maps that can be paired with JBR's top-quality Power Path Intakes to achieve excellent performance, driveability, and reliability from your vehicle. If you're looking to unleash the full potential of your MazdaSpeed, we are of course happy to offer our Custom Tuning packages where we can tune your vehicle to achieve the most from your exact modifications, setup, and driving environment. |
I just installed the JBR stage2 intake and flashed the stage1 S-OTS 93 octane map; wow. After I get my internals installed I'll flash the stage2 S-OTS map...which should hold me over for a short time until I get on your list for a full on custom tune(s)...(easy access to E-85). Thanks to you both for great products! |
I read the big thread! Couldn't have been a better match. Stratified = Experienced Soldier! James Baron Racing = Weapon Of Choice! |
Quote:
Finally got my HPFP internals installed and after verifying solid fuel pressure, flashed the S-OTS stage 2 93 oct map; great, great stuff! This will hold me over for a little while...maybe. |
Finally got my accessport and flashed in the stage 1 map yesterday and plan on going to the stage 2 map when my internals get here (autotech backorder fail). Anyway i like the option of being able to use the FFS and LC options with the Cobb maps is there any way to add this into the stratified maps as they are locked? |
Quote:
I will consider the FFS option BUT ... I am not a fan of it. I still see cars run lean in the next gear (randomly) when FFS is used and I don't like that. It's still a bug COBB hasn't addressed yet and it makes me a bit nervous having it in the S-OTS maps. |
FFS also leads to overboost in next gear:( |
ahh good to know wasnt aware of the issues with the FFS, kind of unfortunate as i like the feature. |
I installed my stage2 jbr intake and flashed the Statified OTS stage1 map. I'm seeing 1700-1800+ HPFP and 14psi during WOT runs. Is this normal? I'm coming from stock everything with the stock stage1 cobb OTS. With that I was seeing around 1600-1650 HPFP readings and 17psi during WOT runs. |
Quote:
Once you have an HPFP installed, try the stage2 maps. |
@Lex; Do the S-OTS maps only work with the JBR? It would be awesome to be able to purchase the S-OTS maps as a substitute for the Cobb OTS maps. This would work for new AP customers as well. A lot of people are still running Cobb OTS maps. I think this would be a nice option. |
Quote:
I have an HKS intake and flashed a Stage 2 Stratified OTS and my LTFT are between 2.8 and -1.6. Went from a modified by me Cobb OTS to this map and I have to say the difference is AMAZING. I will suggest anyone with a Cobb OTS to give these a try and keep and eye on the LTFTs to see if you are good |
Alex, I am using your stage 1 OTS with my JBR Stage 2 on a 06 MS6. How many miles do you suggest of driving before the trims settle and what should the min and max LT%'s should I expect. Thanks! |
Quote:
The trims will generally settle after 40 miles. |
Quote:
I'm saving the more detailed eval after I hopefully get a slot on the dyno at MNM this Sat. |
Quote:
Quote:
Quote:
Remember thought that the S-OTS maps are meant to be safe and fairly mild so that they can be used in a variety of climates and with varying fuel quality and parts installed. |
Quote:
I'm certainly open to the possibility I'm wrong but I've seen my belief posted many times by other users as well. Don't want to toss a fresh tune on the car that doesn't have the MAF curves calibrated and run a bad AF ratio WOT on the dyno. |
Quote:
You are wrong. No need to settle fuel trims for WOT. |
Quote:
2 Attachment(s) Alrighty, here's what we've got. Keep in mind, my car does NOT have the JBR intake system these tunes are advertised for although my LTFT's were all within 5%. Run 1: 275hp/325tq Run 2: 284hp/324tq I then flashed a franken-map where I worked with the WGDC tables of a Cobb v231 OTS map to get the car to stop over boosting...I then did some drivability tweaks and brought over the all the required load values from a v210 map into the v231. Run 3: 287hp/314tq Now here's the thing, I had all 3 runs logged plus by looking at the AFR on the dyno printout, you can tell between the two of them I hit enough KR in both S-OTS runs to trigger significant richening of the AFR. Run 1 was the worst and it reflects in the dyno'd HP. Unfortunately I'm no guru and can't diagnose what caused the knock nor can I see in the S-OTS maps to tweak anything. I much prefer how the S-OTS maps drive but KR scares me. Last thing to mention, I noticed that the Trottle Position % on the S-OTS pulls gradually increases as the RPM's increase while the Cobb based map pegs immediately and stays there. I'm sure there is a logic behind that but I found it curious. Anyway, here are the media goodies. Runs 1, 2, and 3 on Google Docs for your browsing pleasure. I highlighted the 4k RPM range where the KR kicked in and highlighted in orange the moment knock jumped. Run 1 - S-OTS https://docs.google.com/spreadsheet/...1E&usp=sharing Run 2 - S-OTS https://docs.google.com/spreadsheet/...nc&usp=sharing Run 3 - Franken-tune mix of Cobb v231, Cobb v210, and me. https://docs.google.com/spreadsheet/...VE&usp=sharing Attached are copies of the dyno printout and the franken-tune I was running. |
Quote:
Finally, if you want a custom map for your particular car ... then get in touch. |
Quote:
https://docs.google.com/spreadsheet/...lE&usp=sharing https://docs.google.com/spreadsheet/...2c&usp=sharing Here is one log where I didn't experience any knock but the car had only just gotten close to operating temp. https://docs.google.com/spreadsheet/...2c&usp=sharing |
Quote:
Quote:
Quote:
http://www.mazdaspeedforum.org/forum/foru...octane-142289/ |
Quote:
Good Morning Alex Right now my only mods are the JBR stage 2 on my MS6 and I am running your stage 1 map. Would adding a test pipe result in me needing a custom tune or will the stage 1 map be ok? Right now I am within 10% long term trim. Thanks, |
Quote:
thanks for the quick reply. why does a test pipe effect the Fuel Pressure, I trust your expectise I just wonder why that could happen so I understand. I am going to use the stock DP, but I thought about replacing the second cat with a test pipe. Is there significant gains by doing so? |
Removing restrictions from the exhaust generally leads to higher boost that may overwhelm a stock HPFP. It is unlikely that just a test pipe will do this with a stage1 map but it's something to keep an eye on. |
If you plan on doing anything beyond a couple of mods to your car, just do yourself and your engine a favor...upgrade your HPFP. Your wallet will thank you later when you don't ruin your ride. |
Purchased a Cobb AP this week and got it today. Installed the Stage1 S-OTS 93Octane and took the car out and did a data log while testing it out. I'm assuming I need to get used to the boost since it seems like its dependent on pedal/throttle position? I dunno if I am sounding nuts but in stock form if i give 50%, boost would slowly build up but after mapping boost stops so it works different. I'm sure thats normal just wanted to throw that out there. Also, what a difference. This is how the speed 3 SHOULD feel. Holy torque batman. I kept getting traction warnings in 2nd gear, I never got that before - :hypnotized: Great product. I was debating if I should ever try out the stage 1 cobb maps but from the looks of it, stay away. |
Quote:
Quote:
Oh ok good to know, I thought I forgot how to drive for a second there... when boost stops I was like uhhhhhh but then I floor it and my face lit up like north korea being nuked :P |
1 Attachment(s) here are datalogs from today. I'm a little concerned, should I try the 91 map to compare? Looking for a second pair of eyes. This is stage 1 Thanks |
| All times are GMT -7. The time now is 02:32 AM. |
