E-Tuners / Custom Hardparts
Like Tree17Likes
 Old 06-06-2014, 01:16 PM   #241
MechEnix's Avatar
Posts: 186   (View Stats)
MechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond repute
I really had not been seeing any knock until this fill up. I'd like to get close to 300 whp and then be able to save some cash for a bnr down the road. All that's left though is a new TMIC, custom tune, and/or a larger intake. I wish someone would just make a 3inch SRI with an adapted for a stock size TIP.
% Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe
% Next up = Custom Tune
MechEnix is offline   Reply With Quote
 Old 06-06-2014, 01:26 PM   #242
If you want to make sure you exceed 300whp and have E85 around that is the way to go. You wouldn't even need more modifications beyond what you currently have aside from the tune.
 Old 06-06-2014, 01:50 PM   #243
MechEnix's Avatar
I've thought about E85, the closest station is probably 25 to 30 minutes away from me. I've looked into those 14 gallon containers, but it still becomes a nuisance.
 Old 06-06-2014, 04:44 PM   #244
iammike's Avatar
Posts: 1,415   (View Stats)
lol, my car got close to 290whp fast....and now I'm kicking and screaming hoping to get that last little bit before the next time I'm on a dyno.
Mike
 Old 06-06-2014, 04:51 PM   #245
MechEnix's Avatar
Don't know what to tell ya man, I must have a turd for an engine. Are we still using 1.01 on VD and 3 for smoothing?
 Old 06-06-2014, 05:12 PM   #246
iammike's Avatar
Hell if I know. A lot of people will tell you 1.01. Some others will point out that one of the later release notes for VD said that he had corrected this.
I don't use VD to know how much HP I have but to compare vs other logs instead...and I just use the Dynojet preset of 1.09.
Mike
 Old 06-17-2014, 08:29 PM   #247
DocBrown's Avatar
Posts: 167   (View Stats)
DocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the worldDocBrown is the leader of the world
Groaned at 6 Times in 4 Posts
Just got done breaking in my hpfp internals and immediately loaded the Stage 2 93oct map. I feel a noticeable bump in performance from the stage 1 OTS map and the couple brief WOT pulls look good on boost/hpfp press/KR. Will run complete logs this weekend before and after I install my CX FMIC.
Thanks a lot Stratified!
By the way, is there a problem running the OTS stage 2 93oct with the CX FMIC, or is that OTS+ territory? I'm going to do OTS+ anyways to kill some CEL codes but just wondering what to expect.
Thanks guys
Last edited by DocBrown; 06-17-2014 at 08:29 PM. Reason: MSF Database - Automerged Doublepost
DocBrown is offline   Reply With Quote
The Following User Says Thank You to DocBrown For This Useful Post:
Lex (06-17-2014)
 Old 06-17-2014, 10:38 PM   #248
Thanks guys
As long as it is leak free there should be no issues. Post up a log and I will be glad to have a look.
 Old 06-17-2014, 10:52 PM   #249
DocBrown's Avatar
Sounds good, gonna try to do it this weekend
Sent from my SPH-L710 using Tapatalk
06 Speedsex - built engine - JBR Stage 2 intake - Unicorn 2013 K04 - Stratified OTS stage 2 - Autotech internals - Cx FMIC - JBR RMM - Forge V2 - VTCS delete - EGR delete - BSD - JBR OCC - JBR TIGs + coolant bypass
Lex (06-17-2014)
 Old 06-24-2014, 10:16 AM   #250
Ewind's Avatar
Posts: 235   (View Stats)
Ewind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond reputeEwind has a reputation beyond repute
any idea why I am getting a
unable to load base map
Invalid base map file. Please verify vehicle and vendor of map file
5:1208
Ewind is offline   Reply With Quote
 Old 06-24-2014, 11:01 AM   #251
Default Stratified S-OTS maps for the JBR Power Path Intakes
5:1208
Is this for the free sots maps? THis just means there is a mismatch between your vehicle market and year and the map. If you are trying to load these in atr you won't be able to because they are locked down maps.
Ewind (06-25-2014)
 Old 06-25-2014, 10:35 AM   #252
Ewind's Avatar
Ahh I see that makes sense. I wanted to look at some of the data on your maps.
Makes sense.
The Following User Says Thank You to Ewind For This Useful Post:
Lex (06-25-2014)
 Old 09-28-2014, 12:20 AM   #253
googlebutt's Avatar
Posts: 44   (View Stats)
googlebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to behold
Is there any issue with running the stage 2 91 map with both cats intact? I have internals, but I'm in California so my only option is gutting my midpipe.. which I do not have time to do for a while.
googlebutt is offline   Reply With Quote
 Old 09-28-2014, 04:16 AM   #254
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Yes, Noob.
You should lose at least 1 cat if you want to run a Stage 2 map.
Pickles Tune in progress
googlebutt (09-28-2014)
 Old 05-23-2015, 05:10 PM   #255
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
Just read the entire thread, and it wasn't asked. Can the stock MAF/airbox be used with the S-OTS tune with the JBR intake elbow and TIH?
It's my understanding both the JBR and stock MAF are 68mm.
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
 Old 05-23-2015, 06:18 PM   #256
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Nope... If it can't be used on different intakes, it can't be used on stock air box
The Following User Says Thank You to SarcasticOne For This Useful Post:
texasboy21 (05-23-2015)
 Old 05-23-2015, 06:29 PM   #257
texasboy21's Avatar
It can't be used on different intakes due to a different MAF diameter; JBR is 68mm. Stock is also 68mm. Assume the correct TIH and intake elbow are used (JBR), can the S-OTS be run safely?
2003 A4 1.8TQ
 Old 05-23-2015, 08:07 PM   #258
It's been said before, can't even use this on a COBB/corksport/whatever else other "stock sized" intake is available...
 Old 05-23-2015, 08:12 PM   #259
texasboy21's Avatar
It's been said it can't be run without a JBR intake bc of MAF diameter. Cobb and Corksport are 70mm and 66mm respectively, not the stock diameter.
2003 A4 1.8TQ
 Old 05-23-2015, 10:05 PM   #260
The MAF calibration for the JBR intake is indeed different from the OEM MAF calibration. So this will throw off the load calculations in the ECU.
texasboy21 likes this.
 Old 05-31-2015, 02:00 PM   #261
texasissouth's Avatar
Posts: 31   (View Stats)
texasissouth has a spectacular aura abouttexasissouth has a spectacular aura about
I just loaded these maps up yesterday and have been driving around on them. They feel wonderful, but I've been having weird large LTFT problems. The map started out with good trims, but got worse as I drove it along. I just double-checked everything and all the hoses on the intake seem tight, does anyone have any ideas or do I just need to give it more time? I've driven about 80 miles or so.
2011 Silver Speed3
JBR RMM | JBR OCC | JBR SRI | JBR Rear Sway Bar | Moog Endlinks
Corksport HPFP internals | AP | UR Catted Test Pipe | CBE
texasissouth is offline   Reply With Quote
 Old 05-31-2015, 05:07 PM   #262
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
What intake do you have on the car?
The Following User Says Thank You to Mike@Stratified For This Useful Post:
texasissouth (06-01-2015)
 Old 05-31-2015, 05:28 PM   #263
Hi Mike,
Right now I have the jbr intake and the stock TIP
2011 Silver Speed3
 Old 05-31-2015, 06:37 PM   #264
Check to make sure the o-ring on the MAF sensor isn't broken or torn. +10 isn't ideal, but it isn't going to hurt anything either.
Sent while Stratified.
 Old 05-31-2015, 06:56 PM   #265
I just checked the maf, the o-ring is good, it sits in there nice and snug and it's tightened down pretty good. I had an issue originally where one of the hoses to the BPV got crimped and it would actuate at 9 psi, but I fixed that and reflashed the map to make sure it wouldn't affect anything, so it shouldn't be that right?
I had logs up there, but if you think it's fine LTFTing along at like +8 (idle) to +11 (throttle) I won't worry about it.
2011 Silver Speed3
 Old 06-01-2015, 04:27 AM   #266
Like I said, it isn't ideal, but also not a big deal. Just ensure no leaks pre-compressor. If you are certain of that, I wouldn't worry about the trims.
 Old 06-10-2015, 06:14 PM   #267
AnubisFSU's Avatar
Posts: 117   (View Stats)
AnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond reputeAnubisFSU has a reputation beyond repute
Just to confirm, These maps do not have the EGR delete code disabled? Right now im running the S-OTS stage 1 91oct and would like to delete the EGR valve.
2010 Mazdaspeed3 Tech
JBR Power Path Stage II / Double Adjustable Short Shifter / Solid Shifter Bushings
Cobb Accessport v3 / XLE BPV / Cobb Knob
Damond Motorsports License Plate Tow Mount / EGR Delete
Ultimate Racing Test Pipe
Autotech Fuel Pump Internals
CP-E XFlex Stage2 RMM
Stratified Stage 3 93oct OTS+
AnubisFSU is offline   Reply With Quote
 Old 06-10-2015, 06:15 PM   #268
This is correct for the free JBR maps. Our flash tunes you can spec to have any codes disabled.
JBR (06-10-2015)
The Following User Says NO Thank You to Lex For This Un-useful Post:
jdspeed (06-21-2015)
 Old 06-19-2015, 10:27 PM   #269
AnubisFSU's Avatar
Since these maps are locked is it still possible to disable SWAS and set launch control?
 Old 06-20-2015, 11:20 AM   #270
iammike's Avatar
Disable SWAS...no.
Setting LC and FFS will depend on if the OTS maps have been updated to the later ATR version and you AP is on the later firmware. Cobb no longer provides a website to adjust LC and FFS on locked maps but instead made it part of the flashing process on your AP.....but if the OTS file is too old, it will not be compatible and will only flash as a normal file with no LC or FFS.
Mike
 Old 06-20-2015, 09:12 PM   #271
Snapple415's Avatar
Posts: 38   (View Stats)
Snapple415 has a spectacular aura aboutSnapple415 has a spectacular aura about
It's too bad I can't use this with my intake.. I had loaded the map just to see how it felt and it felt absolutely amazing. My FP and knock was pretty close to perfect. I'm going to assume i have to go the custom route in other to be able to get map similar to this that will work best for my vehicle?
Snapple415 is offline   Reply With Quote
 Old 06-21-2015, 04:23 AM   #272
You can get one of our Flash tunes for as little as $50 which will account for all of your modifications, CELs and SWAS preferences.
 Old 07-25-2015, 02:00 PM   #273
tfusch4's Avatar
Posts: 23   (View Stats)
tfusch4 has much to be proud oftfusch4 has much to be proud oftfusch4 has much to be proud oftfusch4 has much to be proud oftfusch4 has much to be proud oftfusch4 has much to be proud oftfusch4 has much to be proud oftfusch4 has much to be proud of
@Lex; I'm looking to optimize my current set-up. I've been on the fence with the CS turbo and thinking about just biting the bullet and putting the new CS turbo on and having it tuned. However, from what I've seen thus far, the turbo torque curve is quite linear with the HP curve. I like the sudden burst of torque with the K04 and love the E85 Flash Tune. I would like some input on what I can do next. I'm leaning towards a JBR 3" or 3.5" WP intake and a pnp intake manifold and custom tune with my mods. If I were to add a catless downpipe to the mix, is it possible/safe to run 25psi spike and taper to 20 psi at redline on the k04. I know it would really be pushing it beyond it's design, but can it be done? I'm just looking for a little advice on which direction to go for the next 25hp.
2008 Mazdaspeed 3 64k Miles
AP, AT Internals, JBR TRU 3" Silicone Intake, CS TMIC CS Race Pipe, Autolite Iridiums 1 step colder & gapped at .026 Stratified E85 Flash Tune, CP-E Stage 2 RMM
tfusch4 is offline   Reply With Quote
 Old 07-25-2015, 10:46 PM   #274
All very good questions. Take a WOT datalog of the current map and setup. Send it along with your power goals and complete mod list and budget to feedback at stratifiedauto.com
From there one of us will be able to give you a direction quite clearly based on the datalog and information.
 Old 09-05-2016, 05:56 AM   #275
GreenieMS3's Avatar
Posts: 2   (View Stats)
GreenieMS3 is an unknown quantity at this point
i see everyone on here talking intakes and such on stage 1, i just got my genpu ms3 about 6 weeks ago and my AP will be here wednesday. Can i safely flash the S-OTS stage 1 map on a bone stock vehicle? after reading about cobbs maps its safe to say ill stay away from those to avoid a little ZZB possibility.
GreenieMS3 is offline   Reply With Quote
 Old 09-05-2016, 06:11 AM   #276
El Tolete's Avatar
Posts: 1   (View Stats)
El Tolete has a little shameless behaviour in the past
Can someone recommend good tires for a mazdacx7.
El Tolete is offline   Reply With Quote
The Following 2 Users Say NO Thank You to El Tolete For This Un-useful Post:
JSmith (09-05-2016), Vansquish (09-05-2016)
 Old 09-05-2016, 07:24 AM   #277
Need a JBR intake for this tune. There are also OTS tunes which Stratified sells on their website where you can put in your vehicle configuration and then the cost to update them I believe is lower than a brand new one. I'd suggest that route, or buying a JBR intake soon and using the provided S-OTS tune.
2011 Silver Speed3
The Following 2 Users Say Thank You to texasissouth For This Useful Post:
GreenieMS3 (09-05-2016), Lex (09-05-2016)
 Old 09-05-2016, 07:39 AM   #278
GreenieMS3's Avatar
will the s-ots maps work with the jbr full 3" intake or are they specific to just the power path sram?
'12 MS3
-Cobb AP
 Old 09-05-2016, 11:38 AM   #279
BoostedHatch's Avatar
Posts: 7   (View Stats)
BoostedHatch will become famous soon enoughBoostedHatch will become famous soon enough
Default JBR intake
Installing anything larger than stock sized intake (i.e. 3" or bigger) will not work with the S-OTS. You will get a lot of stuttering as the ECU mis-calculates the intake (thinking it is a stock intake but actually pulling in more air with a 3" or larger intake)
The S-OTS maps are for the JBR short ram intakes (stage 1 or 2) or the cold air intake (stage 3).
Note that Stratified calls the stages differently - stage 1 = JBR intake + stock HPFP; stage 2 = JBR intake + upgraded HPFP
see Stratified MazdaSpeed / Mazda MPS Off The Shelf (S-OTS) Maps [Stratified Mazda S-OTS Maps] - It's Free! : Stratified Automotive Controls
BoostedHatch is offline   Reply With Quote
The Following User Says Thank You to BoostedHatch For This Useful Post:
Lex (09-05-2016)
 Old 09-05-2016, 10:06 PM   #280
You definitely don't want to run a larger intake on the free SOTS+ tunes because the car will run lean. We do have flash tunes that we cater to any intake or modification combination you have (short of a bigger turbo)
Stratified MazdaSpeed / Mazda MPS Flash Tune [Stratified Mazda Flash Tune] - $50.00USD : Stratified Automotive Controls
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/stratified-s-ots-maps-jbr-power-path-135125/
Flat foot shift - Mazda 3 Quebec This thread Refback 07-28-2013 06:23 PM
Forum Mazda Performance Series - Zobacz temat - Stratified OTS Maps This thread Refback 03-23-2013 05:44 AM
Intakes Now Available! HTP HTP (Hi-Tuned Performance) 354 10-14-2014 08:21 AM
Mod path for me eksces Mazdaspeed3/6 General Discussion 19 07-31-2012 03:26 PM
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 11:03 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
Page generated in 0.58213 seconds with 37 queries
