E-Tuners / Custom Hardparts
 Old 05-30-2013, 08:31 AM   #1
spd6demon's Avatar
Posts: 164   (View Stats)
spd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the world
Default Stratified Tuned by Mike
First off, I want to thank @RacerMike; for my tune. Mike was very patient with me and my car. He was quick to respond to my emails and new maps were sent within 24 hrs. Went through several iterations due to false knock readings, turned out to be poor gas quality in my area.
Even with bad fuel, Mike pulled through and made great numbers. I'm pleased with how the tune came out, definitely will be coming back to Stratified for another tune when I go BT.
06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP
CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC
HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress
305/364 (K04) // 367/387 (2871r)
454/417 (PTE6262 R.I.P)
spd6demon is offline   Reply With Quote
The Following 3 Users Say Thank You to spd6demon For This Useful Post:
crazyspeed6 (05-30-2013), Lex (05-30-2013), Mike@Stratified (05-30-2013)
 Old 05-30-2013, 08:34 AM   #2
manila's Avatar
Posts: 1,767   (View Stats)
Good to hear! What were your numbers?
'12 MS3 Black Mica w/ Tech
The Following 3 Users Say Thank You to manila For This Useful Post:
bstover17 (05-30-2013), Lex (05-30-2013), Pointless (05-30-2013)
 Old 05-30-2013, 09:17 AM   #3
Pointless's Avatar
Posts: 171   (View Stats)
Pointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the world
Groans: 104
numbers please !!
MS3 2012 CWP
• Cobb AP • HTP 3" INTAKE • CorkSport RP - TMIC - TMM • Autotech HPFP • GFB BPV • CP-E RMM • MishiMoto OCC
• Denso ITV22 • Devil's Own WMI DVC-30 Stage 2
Pointless is offline   Reply With Quote
The Following User Says Thank You to Pointless For This Useful Post:
Lex (05-30-2013)
 Old 05-30-2013, 09:18 AM   #4
spd6demon's Avatar
I got to 304HP/354TQ at 55ish degrees
I'll post my VD later today, at work right now
Lex (05-30-2013), Mike@Stratified (05-30-2013), Pointless (05-30-2013)
 Old 05-30-2013, 09:21 AM   #5
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Was that with E?
Lex (05-30-2013)
 Old 05-30-2013, 09:23 AM   #6
spd6demon's Avatar
Was that with E?
Yea, 4 gal mix
The Following User Says Thank You to spd6demon For This Useful Post:
Lex (05-30-2013)
 Old 05-30-2013, 12:01 PM   #7
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
My pleasure and thanks for the kind words!
The Following User Says Thank You to Mike@Stratified For This Useful Post:
Lex (05-30-2013)
 Old 06-13-2013, 02:00 PM   #8
crazyspeed6's Avatar
Posts: 74   (View Stats)
crazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud of
I wish we were back at 55 degrees, this 95 degree shit is killing my car....
2006 Speed 6 - GTX3071, Cobb AP, CPE HPFP, CPE DP, HTP 3" Turbo Inlet, HTP 3" MAF Housing, CX FMIC, Greddy BOV, 3 Port EBC, JBR IM TIG, 3 Bar MAP, Corksport OCC, Stratified Tuned by Lex
STOCKING OUT
crazyspeed6 is offline   Reply With Quote
The Following 2 Users Say Thank You to crazyspeed6 For This Useful Post:
galens47 (06-13-2013), Lex (06-13-2013)
 Old 06-13-2013, 02:54 PM   #9
spd6demon's Avatar
No kidding! I'm running a bit rich when it's hot like it is now. Can't wait to do FMIC setup....
 Old 06-13-2013, 03:07 PM   #10
jdmage_mx5's Avatar
I was looking at your signature. You are running the stock TMIC arent you? What are your BATS in this 90 degree weather?
 Old 06-13-2013, 04:14 PM   #11
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
I feel you on that. My car's temp gauge said 94 today. I never wished for winter weather at the beginning of summer until I got this car.
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
 Old 06-13-2013, 04:49 PM   #12
spd6demon's Avatar
I did a log today and the lowest BAT I saw was 124..lol. Went all the way up to 142 @ redline -_-
Stratified - 363/413 with K04 v8killer Stratified Automotive Controls 0 10-24-2012 02:33 PM
363/413 on K04 - Stratified Tuned v8killer MazdaSpeed 3/6 - Dyno Sheets/Discussions 12 10-24-2012 01:25 PM
Stratified! 284/326 Midnitehours Stratified Automotive Controls 0 10-05-2012 09:12 AM
Stratified Tuned by Alex and Brad Polish_Eagle Stratified Automotive Controls 10 06-23-2012 01:01 PM
Stratified Tuned also. "Stratituned" 08cosmic3 Stratified Automotive Controls 5 01-16-2012 04:09 PM
Page generated in 0.32882 seconds with 26 queries
