Synapse DV mazdaspeed flange o-ring Hi, I lost mine. Any ideas where I could get a replacement? |
I don't think these are the ones.. i need the one which goes between the flange and the TMIC, eg this one: https://frsport.com/images/product_i...FS01-02@2x.jpg |
Quote:
Email them. They sent me one for $2 awhile back after I tore mine. |
Quote:
or go to a hardware store and get a 2x31mm o-ring... (I think I have gotten them from ACE in Vitan) |
Quote:
As far as my post goes, all I did was quote another post. Didn't actually have a pic or link attached. |
Quote:
I've created an issue in their support system with no response yet :/ |
Quote:
When I purchased mine used I had to replace it (the old one was rotted) I took it to the hardware store and literally sized one up... no leaks, 3 years later.. :) and I believe you are correct, the 2x31mm are the diverter air seals, not the flange o-ring (sorry about that). |
Awesome! can you please measure internal diameter for me? As it seems that the ID is being used when sizing o-rings. Also, 2mm seems kinda slim, the groove in the flange is kinda deep, i'm not sure if 2mm is gonna seal it.. |
https://uploads.tapatalk-cdn.com/201...02bfe71ed8.jpghttps://uploads.tapatalk-cdn.com/201...dada3e8012.jpg Best I could do, sorry :) Sent from my iPhone using Tapatalk so... here is the thing... after taking it off (the engine was warm) the o-ring expanded and I was not able to get it back into the flange.. it is in the freezer now but I think my initial 40mm is correct (it was cold and went back in just fine). |
after sitting in the freezer.. it was back down to 40mm and it fit (is installed once more)... |
You are awesome! Thanks. |
| All times are GMT -7. The time now is 02:33 AM. |
