E-Tuners / Custom Hardparts
 Old 06-17-2014, 11:16 PM   #1
shneeko6's Avatar
Posts: 57   (View Stats)
shneeko6 has much to be proud ofshneeko6 has much to be proud ofshneeko6 has much to be proud ofshneeko6 has much to be proud ofshneeko6 has much to be proud ofshneeko6 has much to be proud ofshneeko6 has much to be proud ofshneeko6 has much to be proud of
Groaned at 6 Times in 2 Posts
Default Thanks Stratified!
I just wanted to say thanks for the awesome work and quick turn around time. I recently order an OTS+ tune from Stratified and accidentally left out my fuel pump on my mod list. Generally they make you buy another tune but they took care of me and sent me the correct tune (within an hour) at no charge. All in all it was $40 well spent and I wouldn't have minded having to pay for the revised tune because it was worth it. Can't wait to do a full tune!
Sent from my LG-G2 using Tapatalk
shneeko6 is offline   Reply With Quote
The Following 4 Users Say Thank You to shneeko6 For This Useful Post:
Lex (06-18-2014), Mike@Stratified (06-18-2014), phahengpro (06-19-2014), trancehead (06-18-2014)
 Old 06-18-2014, 10:25 AM   #2
The door is always open and we want to make sure you enjoy your car and Stratified tune as much as possible. Looking forward to working with you on the full tune!
 Old 06-18-2014, 10:35 AM   #3
torquemaniac's Avatar
Posts: 733   (View Stats)
So much good feedback from Stratified!
Lex, did you ever tune a CX-7 with a turbo upgrade?
I have a hard time getting my tune were I want with the MS6 K04 ive got in the CX-7 (spoolup), guess Id be better off going with a professional tuner with a big turbo and all the hardware...
The ignition timing tables are wicked on the CX-7 : theres the ''normal table'', ''transition table'', lots of tables with ''unknow'' function...
FYI, here is my build thread : Big turbo build CX-7 :P
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
Lex (06-18-2014)
 Old 06-18-2014, 10:38 AM   #4
Jtaylor's Avatar
Posts: 656   (View Stats)
How is the driveability of that tune?
08 MazdaSpeed3
 Old 06-18-2014, 11:57 AM   #5
Have tuned a few CX7s. The good thing is that there is a good amount of resemblance to the MazdaSpeed 3/6 in the control system. Are you tuning it yourself? Did you start from the OEM tune?
 Old 06-18-2014, 06:48 PM   #6
Im doing the tuning, and started from the Versatuner OTS 93 octane base tune...
 Old 06-19-2014, 10:07 AM   #7
phahengpro's Avatar
Posts: 351   (View Stats)
phahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the world
The guys at Stratified are good dudes and always helpful.
MS3 traded in after VVT eruption
2013 WRX - no mods and slower
phahengpro is offline   Reply With Quote
The Following User Says Thank You to phahengpro For This Useful Post:
Lex (06-19-2014)
 Old 06-19-2014, 10:22 AM   #8
Let me know if there's something I can help you with.
 Old 06-20-2014, 08:49 PM   #9
Thanks...I have some questions about ignition timing tuning for an upgraded turbo...should I pm you or start a new thread for other to see?
 Old 06-20-2014, 10:10 PM   #10
Either is fine. Just so you know there is no magic number. You have to blend timing advance with boost and fuel to reach the best mixture and this can differ from one car or setup to another. Keep asking here if you'd like.
 Old 06-21-2014, 07:03 PM   #11
I have so many questions...dont know to start
My biggest concern is the timing in the spoolup zone (particularly the spoolup when lauching from a stop), so I will—start with this...
When you retard timing in the spoolup zone (to improve spoolup)on the OEM tables, do you smooth out (horizontal interpolation) the timing in the nearby cells?
Can the change in timing by abrupt...example : have positive timing values up to the spoolup zone (to increase torque), then the timing drop abruptly to accelerate spoolup?
 Old 06-21-2014, 09:43 PM   #12
I would not focus on the low RPM timing zone but rather look at 3.5k and above. The OEM tables going down in the negative regions are not bad in that area.
 Old 06-22-2014, 08:23 AM   #13
Lex,
I dont want to change the very low rpm zone timing, but rather the timing in the spoolup zone
Look at the attached Excel file for a comparaison between my CX-7 and a buddy MS6 spoolup with the same turbo (you will see that spoolup is not the same and the major difference is the ignition timing)
As a reference, when I changed the stock CX-7 turbo and downpipe (same time) for the MS6 turbo and a catless 3'' downpipe+testpipe, the spoolup went from 2500rpm to 3700rpm with the Versatuner OTS tune
VVT alterations shaved 300rpm on spoolup (3700rpm to 3400rpm)
AS for the timing advance in the pre-spool zone, I was asking to eliminate the plateau in the 2000rpm zone (see attached graph...the plateau is highlighted in blue)
Thanks Stratified muggs Mazdaspeed3/6 General Discussion 4 03-20-2014 02:44 PM
Thanks Lex From Stratified slow_ms3 Stratified Automotive Controls 1 03-19-2014 08:27 PM
Thanks STRATIFIED bwinms Stratified Automotive Controls 0 02-24-2014 07:33 PM
Stratified strukoff Stratified Automotive Controls 5 11-19-2012 01:41 PM
Stratified! 284/326 Midnitehours Stratified Automotive Controls 0 10-05-2012 09:12 AM
Page generated in 0.33872 seconds with 25 queries
