E-Tuners / Custom Hardparts
 Old 08-23-2014, 01:51 PM   #1
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
Default Tried your OTS stage 2 map
@Lex;
All I can say is wow! What a difference between load based/boost base (cobb) maps.
I think everything looks good for what it is. Here is a log (I let off ~5800 (traffic))
The only thing I'm concerned about is boost. In this log it only peaks and holds around 16.5 (3rd gear WOT). It looks like it surged a tad too, although I didn't notice it.
Heading the other way on the e-way I peaked at 20 and held around 17-18. Just the ECU settling in?? I don't have a log with that because I wasn't expecting it. Almost as if I had a spike.
I also noticed this with the cobb CS stg 2 map too, although this map pulls way different, and I'm closer to target.. I'm new to the tuning world. So here is my log. Thanks for looking and I'm looking forward to a full tune very soon!
The Following User Says Thank You to ALPINEST4RS For This Useful Post:
Lex (08-24-2014)
 Old 08-24-2014, 12:38 AM   #2
Hey and thanks for the feedback. It looks like in the log you posted you eased into the throttle and then went WOT around 4000 RPM. You will get much better boost response if you don't ease into the throttle and this is likely what happened in the second pull.
Everything looks good otherwise.
ALPINEST4RS (08-24-2014)
 Old 08-24-2014, 05:57 AM   #3
Got ya, if everything looks good I'm going to take a few more logs and compare. It's about 65 out right now too. Yesterday was 86 when I was logging. Kinda pumped to see the outcome.
Lex (08-25-2014)
Switch from stage 1 to stage 0 and pushing more boost ??? frankc730 MazdaSpeed 3/6 - ECU Computer Tuning 4 07-11-2014 08:36 PM
First dyno pulls on Stage 1 and Stage 2 Cobb Maps PSmurf78 2010 MS3 - ECU Computer Tuning 11 05-14-2013 05:44 PM
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.25266 seconds with 22 queries
