| Stratified Automotive Controls We offer Vehicle Specific Street, Remote E-tuning, Dyno Services for Mazdaspeed 3 and Mazdaspeed 6 vehicles using the COBB AccessPort and VersaTuner. We specialize in control systems, engine management, instrumentation and turbocharging and offer a variety of products and services, from standalone ECUs to build-consulting services. |
![]() Join Date: Nov 2010 Location: Smiths Station, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 816
Groaned at 46 Times in 21 Posts
(Thread Starter) | Not Ranked : 0 score Startup issue after winter Hibernation I got the same codes when I used engine bar and my car would not start. Just installed a gt2871r and would like to use the added protection asap. Can anyone tell me another fuse spot to use. Documentation does not give any options other than to use an add a fuse. Thanks |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score isn't it just a 15a fuse? use one of the other ones....
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
| Not Ranked : 0 score A good fuse location for the GA is the ENG BAR location. This location shuts off when the car turns off and it turns on at startup. The GA uses very little current - well under 1 Amp so a 5A fuse for the GA is more than enough.
| The Following User Says Thank You to Lex For This Useful Post: | ms6mil (07-16-2014) |
Groans: 307
May be coincidental.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() | |
The Add a fuse in engine bar is a no go. I got 4 crazy codes and couldn't even start my car. Please see the link I posted. Are there any other similar fuses one can use? | |
| The Following User Says Thank You to bigspender For This Useful Post: | jtday (07-17-2014) |
(Thread Starter) | Not Ranked : 0 score Just got a reply from @SpeedRebirth I followed his pics to help with my GA install. I PM'ed him and he gave me the following answer.
Groans: 307
| Not Ranked : 0 score derr!
| Not Ranked : 0 score You do need 2 fuses. The top fuse is the one the GA uses. The bottom one is the one that the car will continue using.
| The Following User Says Thank You to Lex For This Useful Post: | bigspender (07-17-2014) |
(Thread Starter) | Not Ranked : 0 score Thanks @Lex it worked. maybe this info will help other noobs like me lol. |
| The Following User Says Thank You to bigspender For This Useful Post: | Lex (07-17-2014) |
| Not Ranked : 0 score Glad you got it sorted!
| Guardian Angel | Cevaes_64 | Stratified Automotive Controls | 6 | 06-09-2013 07:45 PM |
| Guardian Angel help? | MS6FL | Mazdaspeed3/6 General Discussion | 2 | 04-28-2012 07:13 PM |
