(Thread Starter) | Not Ranked : 0 score I think the following criteria should be included; Turbo type: [GT30xx or ATP GT30xx, GTX30xx, etc] Restrictor used: [no restrictor, .035, .040 etc] Failure Mode: [CHRA bearing falure, hotside cracking, etc.] Oil feed line used: [OE, ATP, other] Oil return line used and if modified for length. Vendor Purchased from: Answer/resolution from vendor or manufacturer: Symptoms: [cloud of smoke out of the back + no boost, etc.] Turbo mileage: Turbo failure after blown motor: [yes/no] I think that's about it unless anyone has other ideas of what would be useful. @chimmike @BlueStreak @crazyp and any others
![]() Join Date: Dec 2010 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,614
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score Here is my wall of frustration... Turbo type: GTX3076 Restrictor used: Told by ATP that no restrictor was needed on new GTX series. Failure Mode: Two time Seal failure. First time had metal bur left inside CHRA housing that caused rubbing and excessive heat. Defective Oil Return line sent from ATP. Oil feed line used: OE Feed line. Oil return line used and if modified for length. Original install had Oil Feed line used supplied by ATP. Now running custom line supplied by ATP that is 1in shorter in length. Vendor Purchased from: Edge AutoSports Answer/resolution from vendor or manufacturer: First time ATP rebuilt entire CHRA housing. Still waiting on resolution for second issue. Symptoms: Oil blow back through Compressor housing. Oil in Intercooler, Intake and Throttle Body. Massive "Spy Hunter" smokescreen from tail pipe. Turbo mileage: About 5k on original install, 1.5k on second failure. Turbo failure after blown motor: No Blown Motor Here are some pics of the bur in the CHRA housing and of the defective Oil Return line sent to me by ATP.
__________________ 2009 MazdaSpeed 3 Spy Hunter Smoke Screen Mod Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760. |
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
| Not Ranked : 0 score Turbo type: T3 GT3071 Restrictor used: .035 Failure Mode: CHRA bearing failure Oil feed line used: custom ATP steel braided line Oil return line used : Custom ATP steel Braided line Vendor Purchased from: bought used forum user Answer/resolution from vendor or manufacturer: Symptoms: no boost , mileage unknown and boosted up to 24 psi Turbo type: T3 GTX3076 Restrictor used: .035, Failure Mode: no failure as of yet Oil feed line used: custom ATP steel braided line Oil return line used : Custom ATP steel Braided line. Vendor Purchased from: Edgeautosport Answer/resolution from vendor or manufacturer: Symptoms:working fine so far, bought november 2011 boosted up to 27 psi
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score Turbo type: GT3071R /w ATP IWG Mileage: 30K KMs Restrictor used: None Failure Mode: Bearing failure. Shaft play in all directions. Damaged compressor wheel. Oil feed line used: OEM Oil return line used and if modified for length: ATP oil return line. Not modified. Vendor Purchased from: StreetUnit Answer/resolution from vendor or manufacturer: Haven't sent it out yet. Symptoms: Zero positive manifold pressure. Smokescreen out the exhaust. I added mileage in there. Figured it would be a good parameter to list.
__________________ '07 CWP MS3 Forged. |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score did your turbos blow after a blown motor, or just all by themselves? |
(Thread Starter) | Not Ranked : 0 score From rayray pending more details
Tappin
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| Not Ranked : 0 score Updated my post with all important details!!
Groans: 433
| Not Ranked : 0 score Turbo type: GTX3076R Restrictor used: No, stock oil line via ATP fittings Failure Mode: 'clog' in oil feed inside turbo, bearings failed. Oil feed line used: OE via ATP fittings Oil return line used and if modified for length: ATP, not modified Vendor Purchased from: StreetUnit Answer/resolution from vendor or manufacturer: "user-induced error" Symptoms: No boost, metallic whirring Turbo mileage: 15k Turbo failure after blown motor: NO
| Not Ranked : 0 score @SPEED6 KILLAH.. You made mention of seeing this more than once. Could you tag the owners of the turbos in this thread when you have a chance? |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
Ms3ko he owned an t3 gt3071 turbo blew post zzb Twoptslow atp gt 3076 turbo blew post zzb If you blow you're motor there is a big change for the contaminated oil to take out your turbo, this is why he recommended the oil feed filter. | |
(Thread Starter) | Not Ranked : 0 score now we're startin to get somewhere. Ziggo made an interesting observation in chimmike's thread about the in-line filter, in that it can be a blessing or a curse. if you don't monitor it and keep it clean of debris it will be the cause of your failure. It will likely never get anything in there unless you do lose a motor but as Pablo said you have to check it religiously. From your data it would seem that if you do blow the motor you WILL blow the turbo as well..
Groans: 113
Groans: 433
| Not Ranked : 0 score Yeah, definitely did NOT pop the motor on this end, lol. OEM pistons/rods completely intact, hg intact, etc.
(Thread Starter) | Not Ranked : 0 score My immediate plan is to not change my setup. Namely no restrictor or filter until some data can be gathered. IMO a guy should install a pressure gauge in the feed line and measure actual pressure at higher RPMs then compare to Garrett's recommended pressure and install the correct size restrictor if needed. It could very well be that we are over oiling the GTs but really have no idea by how much. So ATP is erring on the side of caution and so will I. Maybe when I install my GTX I'll throw a gauge on there and see what's what. Tappin
(Thread Starter) | Not Ranked : 0 score pertinent info from the other thread
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | ||
Groans: 433
| Not Ranked : 0 score ATP told me specific to the MZR disi a restrictor is not needed. This is why they use the OEM feed without a restrictor. ATP also tells me you cannot "over oil" a turbo, but oil can leak by the seals, at which point a properly sized restrictor will stop the leaking. They say the seals are not rubber and do not "go out", that it's usually another problem. Just repeating what I'm told, that's all. I would be willing to believe we're not over-oiling them if we're not getting smoke/oil leak past the seals, though.
(Thread Starter) | Not Ranked : 0 score I understand completely and am in the "no restrictor" camp. I was putting that information up for the restrictor guys. a blanket statement like "all BB turbos on all platforms need a restrictor" is BS until proven otherwise IMO. not hating on the guys that are running them but perhaps ATP knows something we don't in that our motor runs 45PSI in the feed line..enough to feed the bearings. it sounds like Garrett only wants a restrictor to get you to the 40-45PSI oil pressure in the CHRA...but I can't say that for sure...just going off the statement on their site. so if pressure is higher a smaller orifice will only make it more right? so perhaps they are indicating they want a restrictor in there to INCREASE pressure if you don't have enough.
Groans: 433
They apparently tested the oil pressure in the feed line to determine this data. Doesn't change the fact that these failures are "mysterious" at best, and I'm not sure exactly who is at fault the most; ATP or Garrett or both
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score right. we are covering two different topics here...lol I don't think your failure mode has anything to do with running or not running a restrictor. the other thing I am trying to put to rest is do we need one or not? lol it may always be a matter of opinion. If I put a gauge on mine and wide open it reads 40-45PSE I will feel confident no restrictor is needed. but if you are flowing too much oil IDK how to solve that...if you put in a restrictor you up the pressure correct? Then you are beyond spec for pressure but running correct volume. catch 22 and prob why ATP says leave it alone unless you blow out smoke/seals. edit: I am wrong according to @Lex so there you have it. restrictor apparently does not increase pressure...I was thinking of the gargen hose analogy...put finger over part of it and the pressrue goes up and volume decreases...still don't understand why that is not the case but it doesn't matter...lol
![]() | | #20 | ![]() |
Groans: 433
| Not Ranked : 0 score Your question was answered in my other thread as you know. restrictor reduces pressure/flow.
| The Following User Says Thank You to Chimmike For This Useful Post: | redboat (04-07-2014) |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score haha I love being wrong...I am getting dizzy and must take a break from MSF for awhile....
![]() | | #22 | ![]() |
![]() | | #23 | ![]() |
![]() Join Date: May 2011 Location: Virginia Beach, Virginia
Rep Power: 3957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,694
| Not Ranked : 0 score sub'd for future reference
__________________ I'm not back... But help me find SOMETHING Daily: Evelyn (Eve), 04 4Motion 6Speed VW Passat W8 Sold to @yourstruly; : Isabella (Izzy), 06 MS6 GT with Navigation #1271 Sold to @downmented; : Audrey, 95 Miata Totaled: Vivian (Viv), 07 MS3 bolted and built, brutally murdered by a texting driver ![]() |
![]() | | #24 | ![]() |
| Police ![]() Join Date: Dec 2009 Location: Guadalajara MX
Rep Power: 3113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,737
Groaned at 9 Times in 9 Posts
| Subbed, I'll probably join the list eventually
__________________ SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQSOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW! MS3 vs Focus ST vs Camaro LS1 ---> Click here TEH MEXICAN'T PERM! Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Discuss Here: Failed ATP/Garrett Turbo Thread
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| Failed ATP/Garrett Turbo Thread | Dano | MazdaSpeed 3/6 - Turbo Induction | 47 | 08-13-2015 02:59 PM |
| Garrett m33 turbo | skiptowncat | MazdaSpeed 3/6 - Turbo Induction | 9 | 08-14-2012 03:41 PM |
| Who DOESN'T run a Garrett turbo | Ezekiel81923 | 2010 MS3 - Turbo Induction | 138 | 08-02-2012 05:20 PM |
| Failed Thread | essejkcamraw | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 57 | 11-17-2010 11:16 AM |
