> MSF KB - Mazdaspeed 3/6 - Suspension & Brakes
 Old 07-07-2012, 11:22 AM   #41
mariomspeed's Avatar
Posts: 26   (View Stats)
mariomspeed is a jewel in the roughmariomspeed is a jewel in the roughmariomspeed is a jewel in the rough
i want to get the eibach pro-kit. any problems i should run into?
mariomspeed is offline
The Following User Says Thank You to mariomspeed For This Useful Post:
Revolv0 (06-26-2016)
 Old 08-13-2012, 08:29 PM   #42
KillerSaiyan's Avatar
Posts: 22   (View Stats)
KillerSaiyan will become famous soon enough
I want a good suspension for occasional autoX and drag, but cant see myself putting out more than $1000 for it, seeing that its not my living, just occasional fun... I dont want BC though... possibly Sonic Tuning? def looking for rear sway bar kit to go with it also.
COBB AccessPort | HKS SSQ v4 | INJEN Cold Air Intake | CORKSPORT Turbo Inlet Pipe | EBAY (m2) Catless Long Downpipe | HKS Hi-Power Catback Exhaust | PTP Fuel Pump Internals | Grimmspeed EBCS | TWM Short Shifter | JBR 815 gram knob| SURE Short Shift Plate/Counterweight | STREETUNIT Shifter Bushings | STREETUNIT Rear Motor Mount | CORKSPORT SuperWhite interior LED Kit | HALO Angeleyes 7000k | DDM 6000k 35w (switching to 55w) HID Headlights | DDM 3000k 35w HID Fogs | Flat Black Evil M | Side Door Guard Removal | Evo Mod Grille| Tenzo-R dc-10 wheels| BC COILS| KENWOOD eXcelon Headunit (4v preouts) | ALPINE MRP-M500 Mono Amp (500w RMS) | ALPINE MRP-F300 4-way Amp (75w RMS x4) | ALPINE Type-R 12" Woofer | ALPINE Type-R 6.5 Door Speakersru
KillerSaiyan is offline
 Old 08-13-2012, 09:24 PM   #43
Todd98SE's Avatar
Posts: 1,077   (View Stats)
KW V1
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 08-20-2012, 07:42 PM   #44
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
Question.. Does the OEM Struts off of a Pu fit the Wons..
Reason I ask: Thinking of getting coil-overs in the next month or so, and I have a buddy with his struts going out. If they fit I was just going to give him my OEM ones and save him some money.
Thanks.
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline
 Old 08-20-2012, 08:36 PM   #45
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
I believe the struts are directly interchangeable.
The shocks are not.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Nliiitend1 is offline
 Old 08-20-2012, 08:37 PM   #46
jrdm91's Avatar
Posts: 10   (View Stats)
jrdm91 will become famous soon enoughjrdm91 will become famous soon enough
I'm new to the modding scene, I just want to confirm that the prices on the COBB and hotchkis sway bar is in fact both FSB and RSB.
Seeing that the hotchkis says "kit" that it is in fact F and R.
jrdm91 is offline
 Old 08-21-2012, 02:12 PM   #47
TRex's Avatar
Posts: 3,139   (View Stats)
^if it says kit then yes it is both
but pass on the FSB
TRex is offline
 Old 08-21-2012, 04:32 PM   #48
Groans: 44
The shocks are not.
what makes the shocks not interchangeable?
AWDTuning Tuned
 Old 08-21-2012, 05:55 PM   #49
TRex's Avatar
^the pu's rear end has a slightly different setup from what i remember...but i cant tell how
genone
gen2
TRex is offline
 Old 08-21-2012, 08:48 PM   #50
Groans: 44
hmm i would just assume they would fit cause the springs are matched.
AWDTuning Tuned
 Old 08-22-2012, 07:25 AM   #51
Nliiitend1's Avatar
The rear shock lower attachment point is different on the Pu than on the Won.
I know you need a longer bolt to put Won shocks on a Pu, so you'd probably need some sort of machined spacer or longer shock eye bushing to make a Pu shock work on a Won...
2008 MS3 GT
2016 MX-5 Club
 Old 08-22-2012, 07:44 AM   #52
Groans: 44
hmm.. well if i get the coils i guess it wouldnt hurt to check it out and maybe do a quick write up on the matter. Im sure he wouldn't care.
thanks for the help
AWDTuning Tuned
 Old 08-24-2012, 03:35 AM   #53
jrdm91's Avatar
but pass on the FSB
That what I figured. I'm not sure if I can bass on the FSB it's rattling fucking annoyingly as of now, so I have to make sure it's not anything more than the bushings or end links, I may have to replace it if it's more than that.
Thanks for the heads up of not needing to change it though. Much appreciated.
jrdm91 is offline
 Old 08-24-2012, 11:07 AM   #54
Todd98SE's Avatar
but pass on the FSB
That isn't necessarily true. It all depends on how you like to setup your suspension. Most people skip the front bar because its a huge PITA to install not because its not needed. Again it depends on the type of driving you do and your preference for setup.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 08-24-2012, 11:11 AM   #55
I have had both for years. The handling is better with both than just the rear, as I had the rear for a month until I did the front. Well worth it imo. Front just sucks to install.
Raider is offline
Familyguy427 (01-19-2013)
 Old 08-24-2012, 11:34 AM   #56
TRex's Avatar
while im sure there are benefits in steering response
you cant argue the fact that sway bars reduce traction in the area they are installed
rsb lifts the inside wheel decreasing the traction in the rear inducing oversteer
fsb again attempts left that inside wheel...decreasing front traction and inducing understeer
personally in auto cross my biggest issues came from understeer and general lack of front traction through turns
heavy rsb and disconnecting my fsb during runs solved this
im not saying that this is the end all be all setup and of course you need to decide what is best for what kind events you run, but my personal opinion is to run no or a lighter fsb....im actually looking to source a regular 3 fsb to run always
TRex is offline
 Old 08-24-2012, 11:43 AM   #57
Todd98SE's Avatar
For AutoX i'm sure a MZ3 or no bar is the hot ticket. For a track like Big Willow or Buttonwillow no front bar is the quick way to sliding backwards off track.
A large front bar can also reduce camber loss under roll which increases traction, all I'm getting at is a larger front bar is a preference depending on your preferred style and setup. In a heavy FWD camber limited Macpherson strut car a larger FSB can actually increase lateral front grip.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 08-24-2012, 11:57 AM   #58
Todd98SE's Avatar
Let me add that the bar you choose plays a big role as well, not all are created equal. The OEM MS3 FSB size is 26mm solid IIRC. I have ran the 28.5mm solid Racing Beat FSB and currently run the 27mm solid Whiteline FSB. The Racing Beat was a bit to stiff and the Whiteline on the soft setting is a perfect match with the Tripoint rear bar on full stiff.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
The Following 2 Users Say Thank You to Todd98SE For This Useful Post:
Familyguy427 (01-19-2013), license2ill (02-05-2015)
 Old 09-07-2012, 08:39 AM   #59
BierbaumC's Avatar
Posts: 5   (View Stats)
BierbaumC is an unknown quantity at this point
I couldn't find anything in this thread that was related to this..
Does anyone know if the KW V3 front c/o has an adjustment for the camber?
BierbaumC is offline
 Old 09-07-2012, 11:38 AM   #60
Nliiitend1's Avatar
None of the KW setups for the MS3 include any type of camber adjustment, but they can be used with Corksport's camber plates.
2008 MS3 GT
2016 MX-5 Club
 Old 09-07-2012, 12:38 PM   #61
BierbaumC's Avatar
I was leaning toward KW but now that I see the BCs include this camber plate, I'm leaning that way.
Does anyone have those on their MS3?
If so, did it require modifying the strut tower itself?
 Old 09-07-2012, 03:18 PM   #62
Nliiitend1's Avatar
KW >>>>>>> BC
All day, every day.
The option of included camber plates isn't worth choosing BC over KW.
2008 MS3 GT
2016 MX-5 Club
SKiZ0TT (10-30-2012)
 Old 09-07-2012, 03:28 PM   #63
Todd98SE's Avatar
KW >>>>>>> BC
All day, every day.
I found KW V1 for under $1k online and after adding the Corksport camber plates still came close to the BC price. As @Nliiitend1 said dont waste your time with BC.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline
 Old 09-10-2012, 11:40 AM   #64
LLIo6oH's Avatar
Posts: 17   (View Stats)
LLIo6oH has a spectacular aura aboutLLIo6oH has a spectacular aura aboutLLIo6oH has a spectacular aura about
I think it's time to add CorkSport coilovers
CorkSport Mazdaspeed 3 Coilovers
LLIo6oH is offline
 Old 09-19-2012, 01:34 PM   #65
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: The Official MS3 Suspension Thread
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f627/official-mazdaspeed-3-suspension-thread-125063/
Top 5 coilover ??? - Mazda 3 Quebec This thread Refback 12-31-2013 12:33 PM
The Official MS6 Suspension Thread RhoadBlock MazdaSpeed 3/6 - Suspension & Brakes 182 07-24-2018 11:38 AM
The Official MS3 Suspension Thread RhoadBlock MazdaSpeed 3/6 - Suspension & Brakes 199 07-02-2018 11:27 AM
Official: Mercedes-Benz offers new Ride Control suspension on SLS AMG Haltech Automotive News 1 04-13-2012 09:28 PM
Another.. is my suspension shot thread amc5 MazdaSpeed 3/6 - Suspension & Brakes 14 01-20-2012 08:16 AM
Another suspension noise/sound thread-Strut Bearing? Raider MazdaSpeed 3/6 - Suspension & Brakes 8 12-07-2011 09:57 PM
Page generated in 0.45057 seconds with 31 queries
