| LinkBack | Thread Tools | Search this Thread | Display Modes |
05-11-2011, 03:51 PM | #1121 |
Rep Power: 0 Thanks: 52,496
| Not Ranked : 0 score Am I missing something in the ability to spray @ low boost to max? |
05-11-2011, 03:57 PM | #1122 |
Trail of Fail Join Date: Jan 2010 Location: rock city AR
Rep Power: 9906 Thanks: 10,493
(Thread Starter) | Not Ranked : 0 score nah, I was speaking about over spraying meth to cool down a turbo that you are trying to push out of its efficiency range. Doing this with a nozzle that otherwise would be too large may cause some bogging down in the lower RPM/PSI range if you start the spray at the same time as a properly sized nozzle. I am purely speculating here. The progressive controller allows for some flexibility in this regard. I hope you got at least a 4 and 5 nozzle and not the suggested 3 for a K04
__________________ 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
05-11-2011, 03:58 PM | #1123 |
Banned Join Date: Nov 2010 Location: Valley Park, Missouri
Rep Power: 0 Thanks: 26,461
Groans: 126
Only, I'll have four of them | |
05-11-2011, 04:00 PM | #1124 |
Rep Power: 0 Thanks: 11,560
Groans: 50
| Not Ranked : 0 score So for a k04 we should go with a 4 or 5 instead of the 3?
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
05-11-2011, 04:01 PM | #1125 |
(Thread Starter) | Not Ranked : 0 score I think 8-9 would be my current "sweet spot" So to get there would require a 10 and some controller configuration.
05-11-2011, 04:01 PM | #1126 |
I looked @ the chart, and assumed too much I guess. Nozzles are the least of my worries before install. LOL Thanks for the heads up. This will be my first experience with meth, although I've been trying to read as much as possible. I'm not looking to make huge power over my current tune, but I'm @ a loss for a decent front mount (I'm starting to join the CP-E non-fan club), and summer is coming. | |
05-11-2011, 04:02 PM | #1127 |
Groans: 126
05-11-2011, 04:04 PM | #1128 |
(Thread Starter) | Not Ranked : 0 score WMI > IC for many reasons. you need both to be sure but WMI is pure win. in my experience the DO3/M3 nozzle didn't provide me with much afr shift on my K04/ETS TMIC setup. The 4 was the bottom bar for me. If anyone want's a 3 I have one so order your kit with a 4/5 and if you want to nozzle down hit me up.
05-11-2011, 04:06 PM | #1129 |
| Not Ranked : 0 score I would even go as far as to pay up for a Cobb (gen2 is going to be released, but no eta as of now), but I refuse to do any more business with CP-E. I have to admit, we are starting to get decent gen2 support, but I have to be patient (another of my character flaws). I would be down for a turbo XS, and am really only concerned with crash bar modification. I think the job can be done cooling wise without changing the crash bar, but I am no engineer. |
05-11-2011, 04:10 PM | #1130 |
Rep Power: 9902 Thanks: 7,218
| Not Ranked : 0 score For those that care, it appears boost based map has better boost control than a load based one (duh). I'm spiking higher than I want on my tune but hitting just shy of the load numbers I'm requesting in the AP. Couple of load based third gear logs and a 3rd to 4th shift with an old boost based log showing multiple shifts. I guess I need to figure out if I want consistent output or consistent boost. Edit: On the subject of intercoolers, anyone considering an air/water setup?
__________________ |
05-11-2011, 04:18 PM | #1131 |
@Enki, I took the liberty of converting your logs below... | |
05-11-2011, 04:50 PM | #1132 |
| Not Ranked : 0 score Thanks for the conversion, but I think every Excel type app can read CSVs dude.
05-11-2011, 04:54 PM | #1133 |
Your welcome for the trl - x gear tip btw. | |
05-11-2011, 05:32 PM | #1134 |
Rep Power: 0 Thanks: 294
05-11-2011, 06:06 PM | #1135 |
Eth/Meth Junkie Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 Thanks: 1,846
Have you tried the M10 yet? Worst case if you have a bit of a rich blip if you get into boost at lower RPM (and thus lower massflow), but this is very quickly diluted as RPMs rise. I like triggering off of the MAF signal better, because it is looking at the actual process variable of interest with respect to impact on fueling. Thus, it can much more effectively tune around the rich spot, but there are limits. I have had no issues with the M7 nozzle turning on as low as 3.1v on the MAF (~80g/s), and could easily increase to ~110 g/s if I upsized to the M10 without impacting the fueling at the turnon. I am currently doing the ~25% ethanol in gas tank + 100% meth with an M7...My car is officially an alcoholic... LOL
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
05-11-2011, 06:35 PM | #1136 |
(Thread Starter) | Not Ranked : 0 score Word!! Haven't tried the 10 yet but will need it for summer I'll get off my ass and order one tomorrow. Been threatening to do it for months now LOL.
05-12-2011, 06:44 PM | #1137 |
Looks like 16° up top.
05-13-2011, 06:11 PM | #1138 |
(Thread Starter) | Not Ranked : 0 score I think everyone would agree that 12pk has pushed the K04 and his setup to the limits. Squeezed every ounce of HP out of it and makes it look pretty to boot
05-13-2011, 07:05 PM | #1139 |
Rep Power: 0 Thanks: 625
| Not Ranked : 0 score Now that it's getting hotter, I'm trying to figure out how I can lower boost at higher BAT's like we could load tuning using the High BAT and Norm BAT requested load tables. With boost tuning, it doesn't seem like there are equivalent tables to do the same thing.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
05-13-2011, 08:23 PM | #1140 |
| Not Ranked : 0 score Actually, they still kick in; at least in my gen 1 they do.
05-14-2011, 02:45 PM | #1141 |
Rep Power: 1352 Thanks: 813
| Not Ranked : 0 score Yeah high BAT tables should still neuter your boost, when/if Cobb successfully separates the load/boost logic that may not be the case though. Has anyone tried playing with the 'WG Duty - IAT Comp'? If any of the ambient values line up with what you would consider hot that may apply, or possibly it only applies to the initial duty cycle before the boost dynamic logic kicks in..
__________________ Some things. |
05-14-2011, 08:37 PM | #1142 |
| Not Ranked : 0 score I see that table being used to compensate for higher intake temps allowing you to increase WGDC's when it gets hotter to maintain boost, but I guess it can be used the opposite way. That's not how it's used from factory though.
05-14-2011, 08:53 PM | #1143 |
Rep Power: 1310 Thanks: 4,310
Groans: 134
| Not Ranked : 0 score Not Ranked—:—0—score———— So, is it safe to conservatively manipulate the vvt table? It was suggested by Christian that this could bs the reason that my 2871 is spoiling slowly. I read atr andthey don't seem to causation against this as much as the manipulation of some other tables. As such, I obtained a genpoo 2871 IWG map tuned by Christian (thx bwallace) which was less modded than me and applied his vvt table Which at most was ten degrees more aggresivethan mine. Do u guys feel that it is safe to continue to adjust these slightly, or could I mess something up big time? I also added a touch of fuel as it mentioned that its affect on other parameters was what I had to watch out for... KR did not increase and the engine is supposed to have a pretty effective safe guard against adding too much vvt. On a side note (now it's raining today so logging is tougher), it seems that these adjustments have already shaved 200+rpm off of spool up!!! So I wonder if an additional 5-10° would continue to help? |
05-16-2011, 03:04 PM | #1144 |
[MSF STIG] Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 Thanks: 1,476
Basically if the turbo fully spooled, you really don't need or want any intake cam advance as the DI setup puts the fuel inside the CC unlike a port injected or carbed car where you need the fuel/air mixture to flow in, so the highly pressurized manifold air is all thats needed to fill the CC. Note that the 30 values are the OEM settings, so you could advance a bit more if you wanted, but be careful of popping the injector seals with too much CC pressure... Code: 0.00 30.00 30.00 30.00 30.00 30.00 15.00 15.00 15.00 5.00 0.00 0.00 0.00 0.00
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy | |
05-16-2011, 03:37 PM | #1145 |
Groans: 134
| Not Ranked : 0 score Jesus! ^^^ i guess that is why u are orange. Thanks a ton for not only giving me the values but adding the detailed explanation of why to do it |
05-16-2011, 03:40 PM | #1146 |
(Thread Starter) | Not Ranked : 0 score hahaha there are deff different shades of orange....Forzda's is one of the brightest shades....
05-18-2011, 01:09 PM | #1147 |
05-18-2011, 01:38 PM | #1148 |
Rep Power: 877 Thanks: 200
| Not Ranked : 0 score At last!!!!!!!!!!!! It appears my KR is GONE! I spent some time yesterday under the hood. Pulled the TMIC off, stretched all the coil springs, tightened everything I could find (nothing seemed loose though..), switched my map over to 91 Oct Ign tables, and removed the ECU cover and battery box cover, both of which were missing a clip so they were all loose and whatnot. Granted, I did a lot of things at once but from this morning and this afternoon's logs, it appears my KR is finally gone. I'd gone to 91 Oct map before and it didn't change anything so I think I can rule that out. I'm using the same gas as I have been the last month (except when i thought I was getting bad gas), so that isn't it. I'm not sure if the ECU box and battery cover being lose could actually show up as KR or not...but who knows. My data logs... Question is. In the afternoon, in 84*, it looks like I'm pegging out my WGDC starting at 5200-5300 RPM and up. Is this the stock TMIC restricting me at this point? Thoughts?
__________________ 2009 CWP MS3 Sport Built Motor and Twinscroll T3 35r - 415WHP/400WTQ - 93 Pump Gas, No Meth - Mustang Dyno Custom Tubular Manifold - HTP 3.5" Intake - 3" V-Band TBE - Custom COBB FMIC - COBB EBCS - COBB 44mm WG - KW V2 Coilovers SOLD! 2008 Toyota Tacoma TRD Sport 4x4 |
05-18-2011, 02:10 PM | #1149 |
Rep Power: 5339 Thanks: 27,149
| Not Ranked : 0 score Yes. The stock tmic has a massive pressure drop across it at high flowrates. You would lower WGDC significantly by swapping it out and not upping your boost targets.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
05-18-2011, 03:39 PM | #1150 |
05-18-2011, 06:35 PM | #1151 |
Rep Power: 0 Thanks: 3,452
Groans: 82
| Not Ranked : 0 score Unless you have my car. I swapped the stocker out for a corksport TMIC, and either I had a freakishly good stock TMIC, or I don't know what. I don't see any extra boost at max wgdc, and it doesn't look like my observed wgdc has changed at all from pre- to post- install. Bah humbug. |
05-18-2011, 06:41 PM | #1152 |
(Thread Starter) | Not Ranked : 0 score aren't OE ICs all fin type....fin type < bar/plate. IIRC my OE was fin but its been a few years LOL.
05-18-2011, 06:57 PM | #1153 |
What this means is that the OEM TMIC is very good at cooling the air because it slows it down (a LOT of drag) to maintain contact longer HOWEVER the ETS is just as good at cooling the air, only much more efficient with less "drag". The change in WGDC will not be drastic, it will be subtle, but measurable.
05-18-2011, 07:10 PM | #1154 |
| Not Ranked : 0 score Man my stock intercooler can't see 4th gear from a launch without climbing up to 140 degrees (from a standing 100). I've even cut out the mesh on the stock cover. The last time I tried to run it up in 6th, it fell on its face because the BAT got so high it switched load targets.
05-18-2011, 08:49 PM | #1155 |
Groans: 134
| Not Ranked : 0 score Ok, so I keep thinking that I am getting this under control, and then I hit another wall. I have improved spool time (especially with the vvt table) and in 4th gear it is fine. I spool just after 3200... cool. 3rd, still sucks and I'm spooling at 3600 if I start at 2800 and 4000+ if I start at 3200!!! So I started comparing the map that bwallace sent me (2871, dp, ebcs, stock boost control and stock tmic) and I got to an ignition table that I didn't recognize. Apparently it is not in the gen 1 atr and it is not listed in the gen2 online tuning guide. Has anyone heard of the IGNITION TABLES: IGN TBLS (UNK)? I would have just skipped over it, but mine is drastically different than his. I want to copy and paste his values to see if it helps me but I don't want to blow my car up... imagine that. I can't think of why it could hurt (since his car is less modded than mine), but I know it's not always that simple. Here are photos of his and mine: EDIT: I have a 2871 too, but I started my tuning from an ots stage 2 map with fmic, dp, intake tih and hpfp |
05-18-2011, 09:03 PM | #1156 |
| Not Ranked : 0 score I would have to look at the timing tables in ATR to figure out which is which, but the "donated" table is significantly more retarded than the one you are using, so I think its safe. If you want to figure out which table its following, log the spark advance and compare it to the tables. If you are above a 2.0 load its pretty simple. Remember, retarding timing is a good way to get spool time decreased.
05-18-2011, 09:53 PM | #1157 |
Groans: 134
| Not Ranked : 0 score I don't want to go out to do a full pull at night, so I'll do more research tomorrow to see how it affects the rest of the pull, but the effect on spool up is as follows Earlier today 3rd gear: spool up took 823rpm measured by: -.58psi at 3268 to 18.85psi at 4091. Tonight after changes 3rd gear: spool up took 642rpm measured by: -1.31psi at 3138 to 19.72 at 3780... It was actually a bit less than that but that was the best point to get a good measurement... the next value was 2.9psi for a starting point. Implementing the above table was the only difference between these two runs... The difference in final boost is due to my BD table I believe. I have it a bit too aggressive for ebcs, but earlier today while doing logs, I noticed more over boost with it, but quicker spool time. So, it appears that this table is affecting spool time on my car... especially because the range is bigger on tonight's pull, yet the rpms are still less by 181! I don't want to jump to conclusions yet, as every time that I do, they end up being wrong, so I will look into this tomorrow... Is this table used for spool up only or something on gen2s? IDK if that is completely absurd, but judging by those conservative values in the table, I would think that there is no way that this could be used for the whole pull... shit, I really should have said fuck it, and gotten a whole pull. Unfortunately, if this is one key to my problem, I have no idea how to fine tune it I'm sure no one does, but let me know if you want to see the logs. |
05-18-2011, 10:03 PM | #1158 |
Groans: 134
| Not Ranked : 0 score Ok, I will post the log from tonight, as I just went back and noticed that my afr's are a bit weird... My afrs are set at 11.8. They peak at 12.05 and dip to 11.47, but w/o kr, I never see 10s or 12.35+. Note that this log has two spool ups on it, but I was not doing a whole pull. |
05-18-2011, 10:11 PM | #1159 |
| Not Ranked : 0 score Your WGDC is way low. You are nowhere near maxing it out. Up the WGDC in the spool area. I know you said it doesn't seem to help and you are using the 3 port, but thats where I would go first. Keep that WG slammed shut.
05-18-2011, 10:19 PM | #1160 |
Groans: 134
| Not Ranked : 0 score What do you think about everything else? Could the afrs be because I just flashed the map... I was scanning the gen2 atr section the other day, and i thought that I remembered someone saying it takes a few minutes for that shit to settle. Anyway, my wgdc is deceiving because my WGA is really tight and my wg is ported (I can hold 20+psi at 6000rpm with 13wgdc in atr). I can try to do that for like 2500 or so, but if I do it at 3000+ I end up with abig spike because the values in atr drop from 26 to 16 at 3500. I also feel like I've tried it a bunch, but maybe I've changed enough since last time so maybe it will have a different effect... I'll give it a try. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/dano-s-boost-tuning-101-cool-stuff-125193/ | ||||
Posted By | For | Type | Date | |
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 08-02-2014 06:32 PM |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread | Thread Starter | Forum | Replies | Last Post |
Dano's Boost Tuning 101 + Cool Stuff | Dano | MazdaSpeed 3/6 - ECU Computer Tuning | 1518 | 02-25-2014 07:30 PM |
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS | Cobb Tuning | 2010 MS3 - ECU Computer Tuning | 0 | 08-31-2011 07:32 PM |
Cool Cobb Tuning Video | Haltech | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 06-24-2008 12:22 AM |
