| LinkBack | Thread Tools | Search this Thread | Display Modes |
12-08-2011, 09:24 PM | #1481 |
Rep Power: 0 Thanks: 11,560
Groans: 50
| Not Ranked : 0 score
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
12-09-2011, 04:23 AM | #1482 |
Rep Power: 0 Thanks: 4,098
Groans: 31
| Not Ranked : 0 score You shouldn't even need a MAF cal with 2 gallons. I didn't.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
12-09-2011, 07:40 AM | #1483 |
Rep Power: 0 Thanks: 40,628
Groans: 386
| Not Ranked : 0 score FWIW - I have been running 3 gallons for a long time, and didn't need to adjust my MAF until they switched to E70, and there was just a tiny spot around 4.9v that needed adjusted. |
12-09-2011, 08:02 AM | #1484 |
Trail of Fail Join Date: Jan 2010 Location: rock city AR
Rep Power: 9906 Thanks: 10,493
(Thread Starter) | Not Ranked : 0 score depending on how accurate your petrol MAF cal is you shouldn't need to change it for 2-2.5 gallons. you will want to add some timing to get the full benefit though.
__________________ 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
12-09-2011, 08:25 AM | #1485 |
Must Have Teh 10's! Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10778 Thanks: 6,334
just tickling the tip of the curve huh?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
12-09-2011, 12:23 PM | #1486 |
Rep Power: 0 Thanks: 541
| Not Ranked : 0 score So closest E85 to me is 25 miles away. Seems E85 is in short supply around here
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) |
12-09-2011, 01:04 PM | #1487 |
Groans: 386
12-09-2011, 01:08 PM | #1488 |
Rep Power: 0 Thanks: 1,323
| Not Ranked : 0 score I drive 18 miles for mine. Just buy a bunch of 5 gallon gas cans and a single 2 gallon can so you can measure correctly. I do it this way and have about 2 months worth of E85 before I have to go back, works great so far.
__________________ www.MOTOIQ.com Beater Titan |
12-09-2011, 03:21 PM | #1489 |
Groans: 50
| Not Ranked : 0 score Did you check out propelfuels.com?
12-09-2011, 03:38 PM | #1490 |
Rep Power: 5339 Thanks: 27,149
| Not Ranked : 0 score I am about 20 miles from the corn pump as well and I couldn't be happier, it's worth the drive. I use a bathroom scale to measure the fuel. 20lbs of the juice and 9 gal of 93. I couldn't find any 3 gallon containers. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
12-09-2011, 04:38 PM | #1491 |
Rep Power: 0 Thanks: 1,457
| Not Ranked : 0 score I have one at the end of my road. I could freakin throw a stone there. Why am I not using it??
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
12-09-2011, 05:06 PM | #1492 |
(Thread Starter) | Not Ranked : 0 score b/c your boost control is all fucked up...that's why....you need a good tuner....I know of a couple...DJ, Lex, Socks....any one of them could help you out.
12-09-2011, 05:11 PM | #1493 |
Rep Power: 0 Thanks: 52,496
| Not Ranked : 0 score I know of a great tuner named Dano, but he is just having a bit of trouble with the comp tables on some cars (as we all are). |
12-09-2011, 05:36 PM | #1494 |
Coughloadtunecough
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning | |
12-09-2011, 05:49 PM | #1495 |
all kidding aside I don't think load tuning will work either...I've sent your BCS test logs to David and we'll see what he thinks but to me it looks like your BCS is laggy at best and can't reach targets at worst. for everyone else we completely neutered the comp tables to test if the BCS would just follow commanded values and to me it failed but I don't know how closely logged DC should match commanded. Here were the commanded DC values from 2500: Code: 40.00 45.00 40.00 45.00 45.00 50.00 60.00 65.00 70.00 70.00 logs attached. edit: imma gonna cut a load map this weekend and have boost_creep give it a try.
__________________ 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
12-09-2011, 06:06 PM | #1496 |
| Not Ranked : 0 score Wgdc like a stegosaurus is the new coolest thing. You guys are all jealous. Who's everyone else? Lol.
12-09-2011, 08:02 PM | #1497 |
(Thread Starter) | Not Ranked : 0 score just guys reading the thread wondering WTF I am talking about.
12-11-2011, 04:48 PM | #1498 |
Rep Power: 0 Thanks: 294
| Not Ranked : 0 score I think my car is doing something similar to boost creeps. Boost is on target but strays off somewhere near 5k and the ecu does not seem to do anything to correct it. Pure boost tune only BEC active. I also have a lean condition during and sometimes after spool in rare cases that can hold close to 5k rpms. I think a bit lean on spool is common on this car? I have no idea why it sometimes holds for the majority of the run and I am out of ideas on how to fix this. Most logs run about .2 or .3 high during initial spool but hit their target right after. This log shows both. intake/tip/dp/fuelpump - sealevel and its 50 degrees outside. 18 psi boost target and 11.1 afr target. |
12-13-2011, 09:21 PM | #1499 |
| Not Ranked : 0 score Im gonna go try and get some E85 shortly and test it out. If it sells me on it then I will work something out on how to store it. Would 100octane race gas be comparable to E85 performance wise? Cost wise its WAY more I know.
12-13-2011, 10:26 PM | #1500 |
E85 > all other fuels. 105 octane at the lowest and has a very high endothermic reaction in the cylinders that can't be matched.
12-14-2011, 02:29 PM | #1501 |
I haven't heard back from David so I cut a load based tune and sent it over to @Boost_creep and as I suspected, the same issue was there. Plus, his WGDC actually dropped into the single digits during the middle of a WOT run. This proves to me we have some underlying issue since the ECU is dropping DC like that. We are gonna remove the AP and see what DC looks like on an OE tune via DH and go from there. so the bottom line, his issues are not directly related to any boost targeting logic and his car just wants to be difficult
12-14-2011, 04:01 PM | #1502 |
Whether it be the ots comp values, the grimmspeed, or the combo of the 2, something is crushing the wgdc table down to nothing when load values are being approached (sometimes) or exceeded. (in a way you'd expect a protective table to act vs. a compensation table) | |
12-14-2011, 05:25 PM | #1503 |
TRL from 2.5K 2.00 2.30 2.30 2.25 2.15 2.10 2.00 1.75 1.55 1.50 logs attached. BTW his WGDC sometimes shoots up to 99 while in vacuum/cruise as well. And lets not forget the "shark fin" effect which I have never seen before. Edit: so you have seen DC cut this much when a target is exceeded?
12-14-2011, 07:53 PM | #1504 |
| Not Ranked : 0 score Ive been thinking about this. When I log, I usually pull over to the side, cause I have bad connection issues. So I start a log, then pull out onto the highway and usually try to get to 4th pretty quick. Lol. If you look at the OTS wgdc table at anything over 25% TP and under 2250 rpm's, I am targeting 100% wgdc. Could this just be my ecu hitting the target, but then a compensation table knocks it down?
12-14-2011, 08:38 PM | #1505 |
(Thread Starter) | Not Ranked : 0 score I suppose that is possible however I just looked back thru some of your logs and see 90 and 75DC @ 16TPS which doesn't approach higher TPS in any surrounding cells so its isn't a resolution issue....but do see quite a bit of 99 at over 20TPS. I forgot you had one of the APs that has trouble logging. is yours a v2b? [dongless] so lets chalk up the PT DC as BS and move on. the drop from 50 to 2 DC at WOT is unexplainable to me and couple that with issues with a BT tune and Load tune right at about the same RPM/DC of 5K/50+ I'd like to hear back from finkle and anyone else that has seen this happen. me your ECU
12-14-2011, 08:40 PM | #1506 |
12-14-2011, 08:50 PM | #1507 |
| Not Ranked : 0 score I think I was able to find 2 similar situations here: 1) speed6 not hitting boost targets 2) Boost Tune Woes |
12-14-2011, 08:58 PM | #1508 |
| Not Ranked : 0 score Afr was set low while I am working on my lean issue. I've seen 12.7 when targeting 11.1. I'd hate to see what a higher afr looks like... I can't say I notice any power increase going from low to high 11's. If there us one I doubt it's much. This car doesn't seem to make much power off running leaner. |
12-14-2011, 09:10 PM | #1509 |
| Not Ranked : 0 score I have the V2b dongless AP. I still feel a load table is getting in the way here. Or possibly a table yet to be discovered by Cobb.
12-15-2011, 08:06 AM | #1510 |
01-13-2012, 11:30 AM | #1511 |
Engineered Tuning Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 12034 Thanks: 6,485
| Not Ranked : 0 score Been a while since this has been touched. Alas, I have documented this WGDC "issue" with several customers that is present in both boost and load based tunes. In the upper RPM the ECU just doesn't follow load or boost targets and drops WGDC. This will be worse in cold weather, E85 cars, BT cars. Stay tuned, I will do a write-up ... and then COBB will have to be doing some work I should say that I really like how we're getting more and more control of the ECU and COBB have been awesome and very responsive at catering to our requests.
__________________ We Engineer, and that's better than just tuning! www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
02-16-2012, 03:14 PM | #1512 |
Rep Power: 0 Thanks: 10
| Not Ranked : 0 score subd |
09-20-2012, 06:47 AM | #1513 |
hidin in yo bushes Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 Thanks: 10,956
Groans: 122
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/dano-s-boost-tuning-101-cool-stuff-125193/ | ||||
Posted By | For | Type | Date | |
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 08-02-2014 06:32 PM |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Dano's Boost Tuning 101 + Cool Stuff | Dano | MazdaSpeed 3/6 - ECU Computer Tuning | 1518 | 02-25-2014 07:30 PM |
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS | Cobb Tuning | 2010 MS3 - ECU Computer Tuning | 0 | 08-31-2011 07:32 PM |
Cool Cobb Tuning Video | Haltech | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 06-24-2008 12:22 AM |
