 Old 01-12-2011, 07:51 PM   #1
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
amoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the world
Groans: 53
Groaned at 31 Times in 22 Posts
Sorry for turning this into my personal "I don't know what the fuck I'm doing" thread... but quick question for you guys.
You can see in logs 13 and 14, the row right before I let off the throttle, the car immediately goes lean. I let off the throttle at different RPMs in the logs, so it's not that. I was thinking it has something to do with a transition back into CL but the lean happens before I let off the throttle according to the log.
Log 12, the only difference was a change OL/WOT command where I changed my command to 11.8:1 to RL... so something changed... not sure what.
Any thoughts would be appreciated.
You know.... Moose stuff
amoosenamedhank is offline
 Old 01-13-2011, 12:35 PM   #2
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
so are you saying that before you made your OL/WOT AF change this wasn't logged?
to me it just looks like resolution in the logging. In relaity the rows that are logged don't meet up in realtime. if you do enough logging you can see these patterns occur. you might log Acel Pos so you can see exactly when you let off.
I don't know if it is the processing within the ECU that gives us the low resolution or the AP processing itself but either way it would be nice to have higher res.
Dano is offline
 Old 01-13-2011, 01:21 PM   #3
Groans: 53
This had crossed my mind... that the refresh rate between the values might not always line up perfectly. Good point about the acceleration pedal... I suppose this could be explained in part by the delay between the time I lift my foot and the time the throttle plate actually closes.
But to answer your first question, no this was not logged this way until I leaned out my OL/WOT to 11.8 to RL, coincidence?
 Old 01-13-2011, 01:50 PM   #4
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
coincidence?
Yes.
If you had a DashDaq which logs very fast you would see clearly that nothing lines up exactly, on the AP stuff can be 1 line off, on the DD stuff can be 10 lines off.
Suspension:
FreeFlyFreak is offline
 Old 01-13-2011, 01:57 PM   #5
Trail of Fail
Dano's Avatar
yes purely coincidence
Dano is offline
 Old 01-13-2011, 08:39 AM   #6
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
i am a dumb ass at tuning.. but how much better or power if felt by boost tuning compared to load tuning ?? Christian did my etune and i guess he did load tuning i guess..
would getting boost tuned be better ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
jracer is offline
 Old 01-13-2011, 09:23 AM   #7
Groans: 53
I don't think there is necessarily more power to be had between them. If your car is correctly tune using either method, I wouldn't expect much difference. I think it more comes down to your preference in how you would like to obtain your results.
For me, it's easier to grasp the concept of targeting a psi number opposed to trying to obtain a numeric value based of some formula in the ECU. So that's why I choose to go after boost based targeting. I'm sure your load based tune from Xtian is just fine.
 Old 01-13-2011, 10:34 AM   #8
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
I understand about 80% of this stuff, the one question I have is...if you plan on tuning by boost, are you supposed to zero out the gear-based load tables?
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline
 Old 01-13-2011, 11:14 AM   #9
Trail of Fail
Dano's Avatar
Nope. The boost toggle defeats the load tbls
A boost tune appears to yield a smoother throttle response than a load tune. Making no other changes, ie APP, DBW etc a boost based tune allows for smoother more controlled application of power for me.
With load tuning power is controlled by RPM only and not directly by throttle input. One could argue this point but I am simplifying it for this discussion. You can hold the throttle in one position and get a tremendous surge of power as RPMs rise. This translates to a hard to control torque curve at times and will blast the front tires off on a FWD car. Also, since it is load based and the ECU is responsible for calculating load, it can be unpredictable and you get very different power applied at times.
Boost tuning on the other hand, is controlled by TPS and RPM so you can more easily control when the power gets laid down by throttle position. Some have described this as a "softer pedal feel", meaning it takes more pedal to make the same power. to me you get more pedal "resolution" this way. We all know how you get 100% power at just over 50% pedal position right? well not with boost tuning along with a little APP tweaking.
For me, I prefer this side effect of boost tuning and now the either on or off feeling of throttle is gone.
I have further refined this effect by tuning my APP per gear to limit power in the lower gears without neutering power like in the TRL xgear tables.
Of course you could spend hours perfecting a load based tune [ or just be smarter than me which wouldn't take much] and perhaps get the same results but for me, boost tuning is a faster way to get those same results.
Dano is offline
 Old 01-13-2011, 11:26 AM   #10
m4tic's Avatar
Posts: 4,928   (View Stats)
also with boost tuning you remove variables like.. which load table A-E is going to be used at any given moment
the only concern is ol/cl transitions
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
m4tic is offline
 Old 01-13-2011, 12:23 PM   #11
Trail of Fail
Dano's Avatar
post 89 updated with more "impressions" of boost vs load tuning.
Dano is offline
 Old 01-14-2011, 10:55 AM   #12
Trail of Fail
Dano's Avatar
you can remove that variable by setting your CL Max Throttle tbls to 100 and set your CL Max Load D tbl to like 1.1 and you will always transition to OL at 1.1 load. oh for an MS6 I think the table to change is E. I don't think it hurts anything to change all of them to the same. Just set them to 1.1 from 500 to 4.5K. You can leave the lower values there to RL as you will always be above those load points. FYI, you can see that in OEM trim, the ECU tries to stay in CL until 4.5K.
Once you make that change ensure that your fuel tables are changed to match. Meaning start at the 1.1 row in the 3D fuel tables and enter your desired AFR. Make them all match and your are good to go and will have very stable fueling.
Dano is offline
 Old 01-14-2011, 12:16 PM   #13
Groans: 53
I changed my CL Max load/CL max throttle tables the same time I enabled 'boost based tuning'. Because of this, I unfortunately didn't get the chance to feel what each brought to the table independent of each other.... but man, between the two of them, this thing is as smooth as butter.
It has made me completely fall back in love with driving the car.
 Old 01-14-2011, 01:27 PM   #14
Trail of Fail
Dano's Avatar
hahah
well I made my CL changes way back when....almost a year ago while working around the load cap...so I can tell you that both offer great control over what the motor does but the pressure based boost tuning is what really makes the control over power smoother.
keep the comments/ideas coming.
Dano is offline
 Old 01-15-2011, 12:30 PM   #15
SRTie4k's Avatar
From reading earlier posts, it looks like you state the the Boost Dynamics table makes modifications to the WGDC if boost is off. Are you sure BD doesn't actually modify boost targetting? If you look at the subtitles, it says "Boost Compensation" as opposed to something like the Boost Comp IAT in which the subtitle says "WGDC Compensation".
SRTie4k is offline
 Old 01-16-2011, 10:30 AM   #16
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
Dano would you mind posting your fuel tables I'm curious to see how yours looks compared to mine
Are you talking about changing the CL Commanded EQ or OL/Part Throttle Commanded EQ
manelscout4life is offline
 Old 01-16-2011, 10:36 AM   #17
Trail of Fail
Dano's Avatar
my entire map is in post #1 and the only map changes have been with regard to boost tuning so the fuel tables in the map are what I am running now.
now I am exiting CL at 1.25 load so a bit higher than in my 1.1 example...just don't want to confuse anyone. I started out at 1.1 but moved it up to 1.25 which removed some of the touchy throttle response. I think most guys that are forcing CL exit are doing it at 1.1. It probably doesn't really matter as long is you are in that general area. when going WOT you fly through those load points very fast anyway.
Dano is offline
 Old 01-13-2011, 03:32 PM   #18
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
trying out this boost tuning deal (thanks to socks) and, although i havent pushed the car hard enough yet (learning fuel trims), i can DEFINITELY see the difference in pedal feel. not only smoother, but the power is actually delivered gradually, not in an on/off manner.
Ill post more impressions later.
super_pablo_ is offline
 Old 01-13-2011, 03:40 PM   #19
triple_threat's Avatar
Posts: 98   (View Stats)
triple_threat is a splendid one to beholdtriple_threat is a splendid one to beholdtriple_threat is a splendid one to beholdtriple_threat is a splendid one to beholdtriple_threat is a splendid one to beholdtriple_threat is a splendid one to behold
I love the boost based tuning! its way easier, and the car just feels way smoother all around. Not to mention i can actually hold boost now
2009 Mazdaspeed 3
Cobb AP (ATR Tuned by me), HKS Intake, CX Racing FMIC, Cobb TIP, Turbo XS Hybrid BPV, Turbo XS Testpipe, Grimmspeed EBCS (3 port mode), SURE TIG, PnP intake Mani+vtcs delete, coolant bypass, TRZ RMM, JBARONE Stage 2 Short shift kit, Denso itv-22's,MSD Dashhawk, HKS turbo timer, ResonatorDelete, 18x8 Motegi MR116+ Toyo proxes 235/40/18, Prosport Boost Gauge, Blacked out side markers and badges, Tint
triple_threat is offline
 Old 01-13-2011, 04:07 PM   #20
Groans: 53
The overall driving experience has really improved for me since switching. As others have mentioned everything is a lot smoother and a lot more linear. And the ability to actually be able to control boost n00b style, is amazing.
I'm giving the previous owner (JohnnyT) shit because the car feels 10x better than he's ever had it.
 Old 01-13-2011, 06:04 PM   #21
SRTie4k's Avatar
I just made a 17psi map real quick and boost tuning is definitely way easier and more predictable.
SRTie4k is offline
 Old 01-16-2011, 11:04 AM   #22
m4tic's Avatar
i cant read your ATR map... can you post up your 3d fuel tables... i want to make sure i understand what you're saying about making them match
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 01-16-2011, 11:18 AM   #23
Trail of Fail
Dano's Avatar
Well this guide is for MS3s we don't like MS6 guys...move along, nothing to see here...LOL
Fuel tables I have changed the "unused" and throttle closed are OTS
after making the changes at the load point you choose, you will want to IP, interpolate from your new AFR value up about 6 rowes to smooth the transition out.
And I think it goes witout saying but I'll say it anyway, when you make fueling changes please log log log and make sure things are responding correctly.
Dano is offline
 Old 01-16-2011, 04:01 PM   #24
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Confirm you're running a meth system? My fuel tables mirror yours except I'm targeting 11.6 at WOT without meth. It keeps me a little more warm and fuzzy.
Frequentflyer is offline
 Old 01-16-2011, 04:08 PM   #25
Trail of Fail
Dano's Avatar
yes I typically spray 100% meth on a 7 nozzle but my local shop is out for the season so I am running 5050 water/heet for now. 7 nozzle isn't big enough to change my AFR so I need to step up to a 10 and tweak my trigger points to end up with gph flow of something like an 8 or 9 nozzle size.
FF you could go up to 11.8 and just fatten up the 5.5k and up range where the K04 starts to heat up. may give you a bit more kick IDK probably have to have it on a dyno to see any difference LOL.
Dano is offline
 Old 01-16-2011, 12:32 PM   #26
m4tic's Avatar
ahh i see.. guess i caught the gist of it, thats what i laid out.
we dont have a fuel OL commanded base table
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 01-16-2011, 12:46 PM   #27
Trail of Fail
Dano's Avatar
do you know which table on a 6 is for CL Max Load? IIRC it is E but I don't know for sure.
Dano is offline
 Old 01-16-2011, 02:26 PM   #28
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I got my Grimspeed installed in intercept mode.
I capped off the turbo boost source line with the pill in it. I also capped off the top (smaller) wastegate actuator port.
Configuration:
Port 3 to boost source (I tapped into my silicone hose coupler on the discharge of my turbo).
Port 2 to wastegate actuator (using lower, larger port).
Port 1 is vent to atmosphere (will probably eventually connect to the turbo inlet pipe).
The way it works in this configuration is that with 0% WGDC (solenoid not energized), the path is always open from boost source to wastegate actuator (will run spring pressure).
As WGDC is increased it restricts the boost source to the wastegate actuator (increases boost).
This is flipped from the recommended setup for bleed, which is:
Port 1 = Top port on wastegate actuator
Port 2 = Turbo Inlet Pipe
In this configuration 0% WGDC means no flow (bleed), which will result in just running spring pressure.
Increased WGDC will increase the amount of pressure bled from the wastegate actuator, which will increase boost.
Hope this clarifies things...
cld12pk2go is offline
 Old 01-16-2011, 02:30 PM   #29
Trail of Fail
Dano's Avatar
That's how my Grimm EBC is routed. intetested to see how you setup your DC tables and are you going to use the OTS BD table? it seemed way to reactive for EBC 3 port.
Dano is offline
 Old 01-16-2011, 03:06 PM   #30
m4tic's Avatar
we have CL max load a-d .. C i the prime table we believe
@cld12pk2go
it doesnt matter what port on the wga you use since its straight through... just capping the bottom is harder to reach if the cap splits and starts bleeding boost away from the wastegate
2017 Daytona 392
2007 MS6 w/ Cheez
m4tic is offline
 Old 01-16-2011, 03:52 PM   #31
Eth/Meth Junkie
cld12pk2go's Avatar
I started with my WGDC table at 10 from 2000-7000 RPMs and aiming for 17 PSI in boost targeting mode.
I know that I experience boost creep with my stock K04 when it is cold out. Typically, I creep to ~18-19 PSI when it is 20°F around 4000 RPMs when just running spring pressure. As the compressor efficiency falls off up top my pressure falls to ~15 PSI (again on spring pressure).
My current BD table is as follows:
0.08 0.05 0.03 0.02 0.00 0.00 -0.01 -0.06 -0.12 -0.30 -0.70
@cld12pk2go
Correct. I used the bottom b/c I was running 1/4'' hose.
 Old 01-16-2011, 03:56 PM   #32
Trail of Fail
Dano's Avatar
I have now worked my way back up to Christain's BD table from the neutered version I was running.
Code:
0.04	0.02	0.01	0.01	0.00	0.00	-0.00	-0.01	-0.02	-0.04	-0.09
I see you are allowing the BD table quite a bit of authority to reduce WGDC but keeping things tight in the under run area. I did find that if I allowed BD any compensation for 1PSI over or under the EBC was way too reactive so I'll be interested to see how yours turns out with the -0.01 in your 1psi over run cell.
with not allowing any compensation in the 1PSI area I have found that having your WGDC table spot on actually is a bad thing as BD will let you "Hang" out in a 1PSI error state until the next RPM range. Does that seem possible to you 12pk?
Dano is offline
 Old 01-16-2011, 09:56 PM   #33
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
dano, thanks very much for all the great info in this thread. I've been quietly following along and am now successfully running an 18psi tune using boost based tuning.
My AFRs are the most stable they've ever been...11.76 all day long, solid as a rock. You kick ass man!!
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
Cataphract_40 is offline
 Old 01-16-2011, 10:24 PM   #34
Groans: 661
Can you post up your map so I can compare to mine
 Old 01-16-2011, 10:42 PM   #35
Groans: 30
Sure here you go. It's still a work in progress of course. Note that I have tweaked this map for my deleted EGR system. It's cold here right now so that's probably why I'm seeing just shy of 18psi
1995 Miata
 Old 01-17-2011, 06:38 AM   #36
SRTie4k's Avatar
I finally got my map fully sorted out as a baseline, now just need to add BD back into the equation. Right now my car spikes to 17psi at 3000RPM and holds 16.5-17psi to 5500RPM on WGDC alone. I can't go much higher with the 10-20* weather and my stock pump, but I'm thinking the Boost Comp IAT will push that up to about 17-17.5psi in the summer automatically anyways.
But so far, this is easily the most stable and easiest to modify map I've created yet; the car pulls like a freight train in 4th now, and doesn't hesitate constantly like it did on my load-based maps.
Thanks for the help Dano!
SRTie4k is offline
 Old 01-17-2011, 08:19 AM   #37
Trail of Fail
Dano's Avatar
Glad to help where I can guys. This is certainly a work in progress for me as well. One thing about the IAT comp table Christian modified is that its only set to reduce dc below 32* and above 140* so keep that in mind.
I actually negated my table as well [1.00 in the 32.00 cell] until I get the WGDC table finialized to remove that variable.
Dano is offline
 Old 01-17-2011, 10:35 AM   #38
DSIT995's Avatar
Posts: 1,768   (View Stats)
This is a great guide to get a solid understanding on how to tune with boost.......
I just started making my own winter map for 16.5psi & Ill also make a summer map (or slight changes to the winter map) targeting 18psi
Dano for gearhead?
99 Miata NB - Stock for now
DSIT995 is offline
 Old 01-17-2011, 01:23 PM   #39
Eth/Meth Junkie
cld12pk2go's Avatar
I love the idea of limiting power in 1st/2nd gear via APP trans tables.
That should work brilliantly.
Just remember that Cobb did some work where beyond (~50% IIRC) very little additional power was obtained when playing with the throttle blade, so you might need to restrict further.
 Old 01-17-2011, 01:40 PM   #40
Trail of Fail
Dano's Avatar
yes actually my 3rd gear is a bit too limited.....this weekend it got up into the 50s and I couldn't break 3rd gear lose at WOT so it is very temp dependent. My APP setup for 3rd was done at ~40 and I could just barely get it to spin...that's the sweet spot.
The other good thing about using APP is that it will work for MBC as well. Albeit the curve might have to be a bit different but it should still work.
on-the-fly/partial flash tuning would shine here to flash some pre-defined APP tweaks for temp changes.
Dano is offline
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f628/dano-s-boost-tuning-101-cool-stuff-125193/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-02-2014 06:32 PM
Dano's Boost Tuning 101 + Cool Stuff Dano MazdaSpeed 3/6 - ECU Computer Tuning 1518 02-25-2014 07:30 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 08-31-2011 07:32 PM
Cool Cobb Tuning Video Haltech MazdaSpeed 3/6 - ECU Computer Tuning 1 06-24-2008 12:22 AM
Page generated in 1.18908 seconds with 33 queries
