 Old 05-05-2011, 02:14 PM   #401
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
just timing from 5500 up, running around 12*
fmic lowers your G's
hence why u see people with tmic getting 290 - 300 ish. But most of the time there maf cal is off.
if you look ill get 60mph-100mph alot quicker than anyone hitting those g's
860whp/677wtq
2.7 V6 Ecoboost
PapaSmurf is offline
 Old 05-05-2011, 02:15 PM   #402
atvfreek's Avatar
Posts: 7,787   (View Stats)
Originally Posted by MicaBlueMS3 View Post
Couple recent logs I took today, Ambient temp is about 70-75.
Im trying to get a little more boost out from 5800+, well atleast trying to hold 18, i think i might need to raise my WGDC a point or two from that RPM up.
dont mind the knock in the 3rd gear log at the end, accidently hit off rev limiter not paying attention. haha
oh and i think my car is pretty quick, im getting torque steer in 4th gear haha.
Haha, gotta love the torque steer, I was passing a car as I was doing a 4th gear pull and almost ended up in their lane. A little scetchy. Lol
Your car definitely loves life and seems to pull hard.
What is your knock offset table set at? And are you targeting 12:1 tapering to 11.8:1? Thanks
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
atvfreek is offline
 Old 05-05-2011, 02:23 PM   #403
PapaSmurf's Avatar
knock offsets are whatever the OTS maps were at for stage 2 sf fmic, didnt mess with them.
from 2500-5000rpm i target 12.013 and 11.9, 11.8, 11.7, 11.7. Something me and DJ talked about says our cars like that better than mid 11's
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-05-2011, 02:50 PM   #404
atvfreek's Avatar
Cool im gonna give those afr's a try. Right now I target 11.7 across the board but feel like i'm leaving some power on the table. Thanks!
Sent from my MB300 using Tapatalk
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
atvfreek is offline
 Old 05-05-2011, 05:34 PM   #405
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
You are on 93 oct since you are on the east coast right?
wolly6973 is offline
 Old 05-05-2011, 05:36 PM   #406
PapaSmurf's Avatar
me?
yes i am.
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-05-2011, 05:40 PM   #407
wolly6973's Avatar
Groans: 386
What is the consensus on how octane affects tuning practices?
I know you will be more likely to knock so you will usually run less timing, but should we also target lower AFRs to help combat knock?
 Old 05-05-2011, 05:42 PM   #408
atvfreek's Avatar
Right now i'm targeting 11.7 afr and usually hold 11.76. Is it worth doing another maf cal for wot? If so, what would I add to bring it down.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
atvfreek is offline
 Old 05-05-2011, 05:43 PM   #409
atvfreek's Avatar
Yes usually run lower afr's and a little less timing for low octane.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
atvfreek is offline
 Old 05-06-2011, 07:50 AM   #410
Ex_WRX_driver's Avatar
Posts: 719   (View Stats)
Ex_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the world
Just put in my order for 2011 ATR, cant wait.
Ex_WRX_driver is offline
 Old 05-06-2011, 07:56 AM   #411
Hell yeah. Let us know if you need a hand.
rfinkle2 is offline
 Old 05-06-2011, 07:59 AM   #412
indianaryan's Avatar
Posts: 496   (View Stats)
indianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the world
Groans: 39
So the 2011 OTS maps are actually different than the 2010 maps? I figured they would be the same. Are they v100 or v101?
2010 Silver Mazdaspeed3
indianaryan is offline
 Old 05-06-2011, 08:42 AM   #413
FridayGt's Avatar
Posts: 695   (View Stats)
FridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the worldFridayGt is the leader of the world
I could have sworn they were v101 last night when I updated my AP. I was, however, well past a six pack and I'm not home to verify right now.
-- 2010 MazdaSpeed3
- Current Mod(s): Ventus V12's, CP-E RMM, CS SRI, CS TIP, JBR Stage 2 SSP, 35% Tint, COBB AP, COBB XLE BPV
- Planned Mod(s): JBR Knob, JBR Rear Sway, PMM, CS HPFP (Please), CS Catback, CS TMIC, Driver Mod, Cawk Mod
Originally Posted by Dre View Post
if you get an sri, kiss your mpg goodbye cuz you're gonna be balls deep in that throttle whenever you get the chance..
FridayGt is offline
 Old 05-06-2011, 01:07 PM   #414
I believe there is now a firmware update and this:
new version of ATR (1760)
Firmware and AccessTUNER Updates for MAZDASPEEDs Available Now!
http://www.cobbforums.com/forums/sho...PEED-Vehicles!
rfinkle2 is offline
 Old 05-06-2011, 01:47 PM   #415
PapaSmurf's Avatar
believe its only to support 2011's and fix a couple bugs.
Still waiting on LC/FFS and to actually have the idle tables work.
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-06-2011, 03:23 PM   #416
goodfella16's Avatar
Posts: 70   (View Stats)
goodfella16 has much to be proud ofgoodfella16 has much to be proud ofgoodfella16 has much to be proud ofgoodfella16 has much to be proud ofgoodfella16 has much to be proud ofgoodfella16 has much to be proud ofgoodfella16 has much to be proud ofgoodfella16 has much to be proud ofgoodfella16 has much to be proud of
you guys might want to look into adding a few degrees of timing (to start off with) in your VVT...check my log and you can see as the RPM's increase (and VVT/crankshaft degree decreases) my WGDC skyrockets from 5k-5.5k..im using a more aggressive VVT map (its from a stage 2+ SF + TIH + TMIC, while im using a Stage 2 + SF map) and it really helped ALOT!..i just remade a map and added 2.5degrees at 6k to help this, and added 1 degree to 5.5k to see how it helps
edit: thanks to fink for the conversion below, didnt realize what format it was in
COBB AP SURE SRI Turbosmart Dualport BPV JBARONE SSP + Bushings
TRZ RMM & Tranny Mount CP-E Downpipe CP-E HPFP Ultimate Racing CBE Denso itv22's
goodfella16 is offline
 Old 05-06-2011, 03:49 PM   #417
I took the liberty of converting your file.
BTW, that log looks great.
rfinkle2 is offline
 Old 05-06-2011, 04:58 PM   #418
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
I haven't read much about vvt manipulation. Is it a parameter that is fairly safe and straightforward to work with? I can't even remember reading much about it in gen 1 threads.
Ckmazdaspeed3 is offline
 Old 05-06-2011, 05:18 PM   #419
from what i understand, its pretty important to have these set accordingly for optimum performance..you can read up on it
"for twin cam or DOHC engines, VCT(variable cam timing) was used on either the intake or exhaust camshaft. (Engines that have VCT on both camshafts are now designated as Ti-VCT.) The use of variable camshaft timing on the exhaust camshaft is for improved emissions, and vehicles with VCT on the exhaust camshaft do not require exhaust gas recirculation (EGR) as retarding the exhaust cam timing achieves the same result.[1] VCT on the intake camshaft is used primarily for increasing engine power and torque as the PCM is able to optimize the opening of the intake valves to match the engine conditions"
 Old 05-06-2011, 05:23 PM   #420
id suggest starting off with an OTS map that matches what your current MODS are (because this limits the degree the VVT can help as it depends on ur mods) you can tweak the timing a few degrees and log and see the difference
 Old 05-07-2011, 02:52 PM   #421
Groans: 134
Ok, so I've been working on tuning my 2871 with my 3.5"inlet/intake (no more crappy corksport "ramair" ftw!!!!) and I am finally getting stuff dialed in. I do have sluggish spool time, but I've read that leaning out and timing will help (have to wait for help to do timing).
So, my AFRS are fairly stable, but I'm not sureif they're quite stable enough to start tweaking, which I guess means another maf cal. My question is, do I have to reset the ecu and drive around town for 50 miles without getting into boost, like the first time, or is that initially just done so your car doesn't go boom?
Or, do you think my AFRs are stable enough to start a bit of leanige? BTW, I am targeting 11.4.
Oh, and I will increase boost a bit soon, and I know that my boost curve isn't perfect yet, but it's very much under control and I just need to tweak WGDC a bit.
One more thing, my maf cal has a slight dip in g/s around 120g/s. Because there is no breaking points near this value, do you think it may have been a copy and paste error? Because, I based this calibration off of Joel's, and his has no dip... We were working on this on my laptop in bright sunlight during the columbia MO meat last week so it is quite possible.
 Old 05-07-2011, 04:26 PM   #422
CK, It is only my opinion, but given you have a good deal of new hardware on your cal (I would be tempted to mash the throttle if I went BT too), I would take it easy for 50 or so miles, let your trims settle, and do a complete maf calibration.
Again, if you need a hand, I would be more than happy to help.
Congratulations on a successful install, and inching closer to your goals.
rfinkle2 is offline
 Old 05-07-2011, 04:34 PM   #423
Groans: 134
Ok, another boring 50 fucking miles, here I come.
And to clarify, my vacillating AFRs are a result of a non perfect calibration, correct?
What about that dip in the maf cal table? Does that seem like a mistake to you? Think about it. If Joel's original maf numbers showed a linear progression, and there is no break point near that value, and everything in each section is multiplied by the same number, then doesn't that have to be an error?
Lastly, I can't stand my forge bpv. With the ram air it was so muffled that you couldn't hear it make that horrible clinking sound. Now, every time I let off or switch gears it sounds like Mario hitting a question mark and getting acoin. It's fucking atrocious!.. just sayin.
 Old 05-07-2011, 04:38 PM   #424
Your afr's could be a result of your tables, and / or the maf.
I'm not sure if there is an error or not. I'm pretty sure that if you can get a decent maf log, we can get that bitch spot on though.
On a different note, I installed my Grimmspeed, and it seems to make quite a bit difference in the ability of the car to maintain a nice smooth boost curve.
I'm really close to dialing it in, and will post logs and the tables when I get it to where I want it.
rfinkle2 is offline
 Old 05-07-2011, 09:45 PM   #425
bewsted's Avatar
Posts: 2,456   (View Stats)
I'd like to contribute to this.....
So after doing what appeared to be a proper maf cal.......-8 to 2.3 LTFT after 40 ish miles...I finally thought i had nabbed the MAF cal....then what do you know CEL...system too lean.....Soooooooo.....Back to my original setup until i can become a expert.....I am fine with -5 ltft LOL.....
And your BOV sounds real similar to mine...i feel your pain....hows the beast running though
EWG K04...GETSUM!
bewsted is offline
 Old 05-07-2011, 10:28 PM   #426
Groans: 134
Someone correct me if I'm wrong, but I dont think that those trims should cause a CEL... And did u do three calibrations? Usually it takes around three to get it dialed in.
And no Jason, the car is not running well enough yet IMO. I was spiking at first, but once I tightened my new 14psi WGA I have perfect control over boost, but spool up is very slow. I can't get third to hit 19 much earlier than 3.9krpm... Looking at all the rest of the data in my logs and doing some reading leads me to believe that the problem is that I am too rich w not enough timing because my timing down low was based off a ko4, not a 2871. So Joel and I are going to work on it Monday.
I am going to do one more maf revision tomorrow as well and see if that gets my afrs a bit more consistent. They aren't bad now, but they could be better, and if they were I'd feel a lot more comfortable leaning the car out.
 Old 05-08-2011, 12:45 AM   #427
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
One of the members is helping out with tuning. I don't know if I'm allow to say who he is, so I won't say it, but he's awesome! We are into 2nd revision.
Here are the datalogs for the original map and the 2nd revision map.
Both 3rd gear WOT.
My stock fp is holding it alright.. thankfully..
I've already placed an order of Autotech internal, and it is expected to be shipped out in 2 weeks. So.. I'm taking it easy on my car right now. Only went WOT to do the datalog.
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline
 Old 05-08-2011, 04:24 PM   #428
bewsted's Avatar
I hear you Keith,
I have my AFR's back at a level of normality again and my LTFT is -8 at idle and -.3 and -.5 at part throttle....Im content with the car pulling some fuel.... Now I'm working on some timing ...and trying to get rid of another boost spike that I ended up creating....Having to really drop the WGDC from 2500-3500....Starting to wonder if I am over working the stock solenoid...
EWG K04...GETSUM!
bewsted is offline
 Old 05-08-2011, 04:46 PM   #429
Originally Posted by bewsted View Post
I hear you Keith,
I have found the following to work well, and keep spikes @ bay.
in the trl - x gear tables:
2500 rpm = 2.12 load
3000 rpm = 2.12 load
3500 rpm = 2.25 load
4000 rpm - redline = 2.3 load
rfinkle2 is offline
 Old 05-08-2011, 05:02 PM   #430
bewsted's Avatar
I will have to take a peak at my last log and see where my TRL was ending up on them....Still curious to as if there is any corrolation to have the TRL being set "much" higher than the load your achieving? Or is it just the "roof" for load you can achieve?
EWG K04...GETSUM!
bewsted is offline
 Old 05-08-2011, 05:22 PM   #431
I have been experimenting with the comment Braden made as to those tables, and if you look @ some of the guys' logs, it is possible to go over the limits.
In my experience, the higher you set that value, the more likely you are to get spikes, especially in the spool region (much like Braden was referring to).
rfinkle2 is offline
 Old 05-08-2011, 05:26 PM   #432
PapaSmurf's Avatar
I have my req x gear load set to 3.00 in every gear but 1st.
I only see spikes of .5, if you would call that a spike. But i think if you dial in your boost dynamics than you wont have a problem with spiking.
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-08-2011, 05:38 PM   #433
Agreed. It is getting the right combination of all of the tables for your particular mods that is the key, @ least imo.
rfinkle2 is offline
 Old 05-08-2011, 05:52 PM   #434
ya, ive noticed ive set mine trl to 2.25 up to about 2.3 and ive noticed anything over 2.5 i get some boost spikes, load gets outa wack sometimes, afr leans out sometimes, and ultimately some knock..ive set my trl to 2.24 from 3k to 4k and alota that went away
 Old 05-08-2011, 08:12 PM   #435
bewsted's Avatar
I was back reading a little on this thread....
I'm feeling pretty sure that you had a copy and paste error or something.
Think about it this way. Your MAF VOLTAGE increases with the amount of air coming in (Or the amount of air that the meter senses I guess is the correct way to say it.) So the higher the voltage reading the higher the air coming in. So it should really do nothing but go up as you go into higher voltage.
I ran into this the other day when I was doing my MAF cal. Had the same sort of scenario. Trims were reading different at 2 breakpoints. Applied the proper multiplier and then had this type of scaling that you did. So i did 2 more logs and tried the CAL again and this time the LTFT fell into the breakpoints. Otherwise slight improvision can solve it LOL.
EWG K04...GETSUM!
bewsted is offline
 Old 05-08-2011, 08:32 PM   #436
Groans: 134
Thanks Jason! While people have been super helpful with answering my Qs, that one seems to have been skipped over more than once.
I figured the same thing, but wanted to make sure since I am still learning this stuff!
I am about 35 miles in to a 50 mile light throttle period to adjust maf. I will look into this when I make the adjustment tomorrow.
I am also going to tune with Joel tomorrow, so hopefully we can get some quicker spoolage action too!..
I have found the following to work well. 3000+ = 3 load
 Old 05-08-2011, 08:41 PM   #437
bewsted's Avatar
Me and joel did some tweaking on what i was running yesterday.....I had go back and redo some shit but it seems to be pulling fairly hard again.....a good sign to me is breaking the tires lose at the top of 2nd lol
EWG K04...GETSUM!
bewsted is offline
 Old 05-09-2011, 06:42 AM   #438
If everyone in the thread had a big turbo, I would imagine that would work well for them too.
rfinkle2 is offline
 Old 05-09-2011, 07:04 AM   #439
Groans: 134
Actually finkle, I set it like that long before I went BT.
 Old 05-09-2011, 07:08 AM   #440
Without tweaks to the wgdc or boost dynamics table, I believe many cars would spike @ those trl levels.
rfinkle2 is offline
Gen 2 Cobb ATR discussion Nataphen 2010 MS3 - ECU Computer Tuning 2261 05-12-2015 12:09 PM
Cobb Tuning Inlet Review Discussion Haltech Review Discussion 62 06-03-2011 06:16 AM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Cobb AP Dyno Graph/Discussion NYpest MazdaSpeed 3/6 - ECU Computer Tuning 212 05-13-2008 02:13 PM
Page generated in 0.60234 seconds with 31 queries
