![]() | | #1361 | ![]() |
| Not Ranked : 0 score
![]() | | #1362 | ![]() |
![]() Join Date: Jan 2011 Location: Wildomar, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 375
Wont work without the corresponding AP unit. Already tried this.
__________________ 2011 Liquid Silver Corksport SRI/TIP/AIRBOX Ultimate Racing catback JBR stage 2 shift kit SURE RMM | |
![]() | | #1363 | ![]() |
![]() Join Date: Nov 2010 Location: Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 187
| Not Ranked : 0 score Cobb should release some viewer software so you can load and inspect other maps
__________________ -2010 Mazdaspeed 3 - DD CorkSport Intake/TIH - CobbAP - JBR RSB + Brackets, Endlinks - Weinerdog Co-Driver -Acura Integra Track Whore Mods: Driver Mod, Teal -SCCA F-Production Triumph Spitfire #46 - Race Kah |
![]() | | #1364 | ![]() |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
| Not Ranked : 0 score screen shots of "IMPORTANT TABLES" from tune.
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. |
![]() | | #1365 | ![]() |
![]() Join Date: Apr 2011 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,478
| Not Ranked : 0 score Will got some screencaps of some tables up once I get off of work. I'll screencap the following: - WG Duty Cycle - Boost Targets (not used in open loop in load-targeting) - Load Dynamics - Throttle Req. Load 1st-6th gear - WG Duty Boost Error Comp - WG Duty Load Error Comp Any other tables I should include?
There's something up with the Load Dynamics and/or WG Duty Load Error Comp tables, and how they interact with the TRL 4th gear table. Logged WGDC and calc. load is consistently lower than the 3rd gear logs.
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // | |
![]() | | #1366 | ![]() |
Post your ramp limiter tables if you get the chance also (please). The ramp limiter tables are added into the final wgdc calculation IF certain conditions are met (as is the wgdc boost error comp table if not 0'd). See the flow charts here: http://www.mazdaspeedforum.org/forum/foru...tml#post941139 | |
![]() | | #1367 | ![]() |
![]() | | #1368 | ![]() |
| Not Ranked : 0 score I give you one guess as to what my WG dut boost error comp table looks like,,,,I bet finkle knows,
![]() | | #1369 | ![]() |
| Not Ranked : 0 score OK, here are the key tables from my map. I've scoured my map over and over, but I can't find anything that would be preventing the ECU from hitting 4th gear load targets. Have at it guys, let me know if I need to post up another table screenshot.
![]() | | #1370 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score CS DP ordered! Will post results, etc. I dont know if I should expect much from it though seeing as my K04 is pretty much maxed as is. CS TMIC, Racepipe, intake, and upgraded HPFP are on it already.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() | | #1371 | ![]() |
1) Give the ecu a bit more authority in under achieved load positions close to 0 in the wgdc load error comp table 2) Raise the load limiter ramp to something a bit higher than 20 (e.g. 30). | |
![]() | | #1372 | ![]() |
| Not Ranked : 0 score The following were provided by member @bmorrisj, and David @ Cobb... I wanted to post them here so we don't have to continue to flip back and forth between threads. http://postimage.org/image/1xpls8kqs/ - main wastegate duty controller http://postimage.org/image/1xqph4wlg/ - with load error comp 0'd http://postimage.org/image/1xqufqy2s/ - with boost error comp 0'd http://postimage.org/image/1xqzeczk4/ - when rpm switch triggers (overboost) |
![]() | | #1373 | ![]() |
The reason I had the high-ramp limit at 20% is because my highest commanded WGDC is 80%, so I've been reluctant to raise it past that. I will consider it though, if my logged values where I'm commanding 80% aren't exceeding 95%
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // | ||
![]() | | #1374 | ![]() |
| Not Ranked : 0 score You could possibly try raising the boost targets, to see if they are limiting you for some reason. Just stick like 18 or 19psi across the board (in the high throttle range, that is) and give it hell |
![]() | | #1375 | ![]() |
![]() I may raise the 68%+ TPS Boost Targets to 17-18psi to give part-throttle/closed loop acceleration a nice kick, though.
![]() | | #1376 | ![]() |
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
![]() | | #1377 | ![]() |
Groans: 451
![]() | | #1378 | ![]() |
![]() Join Date: Jun 2010 Location: Toronto, Ontario, Canada
Rep Power: 297 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 899
| Not Ranked : 0 score Just wondering if there's more room for improvement. Here are a couple of logs, one in 3rd and one in 4th. Amb temp is about 86F. I'm targeting 19 psi from 3K to 5.5K and taper to 18 by RL. AFRs are 11.47 taper to 11.02 by RL. This is on 91 oct. I don't have e85, but I could go to 94 oct. Do you think I can raise the AFRs to 11.6 on 91? Also, the AFRs kinda move around a bit, but might be due to the higher resolution of the new firmware? Is this a cause for concern? Mods in sig. Thanks.
__________________ 2010 Black Mica MS3 Mods to date: Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071 Mods to come: Driver Mod || Snow Performance Meth Kit |
![]() | | #1379 | ![]() |
![]() | | #1380 | ![]() |
| Not Ranked : 0 score Did you have to significantly reduce timing to get rid of knock though to compensate for the higher AFRs?
![]() | | #1381 | ![]() |
Groans: 451
![]() | | #1382 | ![]() |
I had to pull 1 degree of timing, but Im running the stock plugs still.
![]() | | #1383 | ![]() |
Gotcha. Gonna try to increase the AFR this weekend. Will post results.
__________________ 2010 Black Mica MS3 Mods to date: Corksport TMIC || cp-e HPFP || COBB Accessport || JBR 3.5" WP SRI + 80 Duro Trilogy Mounts + RSB + IM TIG + TB Coolant Bypass & TIG + SSP + Bushings + Heavy Shift Knob || HKS SSQV III VTA || Denso ITV-22 || Ultimate Racing V2 Catted DP+Resonated TP || Ported IM || GT3071 Mods to come: Driver Mod || Snow Performance Meth Kit | |
![]() | | #1384 | ![]() |
Groans: 451
| Not Ranked : 0 score Ok so I have attached a first gear log. The grey area is where I have a problem. It seems that if I punch it in first ~3500 from a roll I get this crazy cut type feeling during the run. Its like before I even start spinning I get slammed forward, then before I can respond it will take off just fine. Scares the crap outta me. Log attached. The first (white cells) area was fine, no cut. The second (grey) area was where it cut.
![]() | | #1385 | ![]() |
| Not Ranked : 0 score I take it you noticed the afr's in your log in the grey area? That is plug blow-out Bucker. Note your rpm's go backward, and the AFR's go crazy rich. (sign of blowout) |
![]() | | #1386 | ![]() |
Groans: 451
| Not Ranked : 0 score Yessir. Stupid rich right? Any idea what would cause it though? Awesome, thank! Only getting it in first so Ill leave it alone for now. Hopefully adding the DP next week wont screw me too bad.
![]() | | #1387 | ![]() |
| Not Ranked : 0 score See above. Close the gap down on your plugs if you can. |
![]() | | #1388 | ![]() |
Groans: 451
| Not Ranked : 0 score Yup, will do later on. Gotta do an oil change ASAP too. Whats the reccomended gap? .028 or something?
![]() | | #1389 | ![]() |
| Not Ranked : 0 score I have mine @ .026 (ITV22). Also, if you are getting mad torque steer, I've been reading up on the "steering wheel angle sensor" here: I need SWAS pictures! |
![]() | | #1390 | ![]() |
Groans: 451
![]() | | #1391 | ![]() |
| Not Ranked : 0 score When your rpm's go backward in the log, that is tell tale blowout. |
![]() | | #1392 | ![]() |
![]() Join Date: Nov 2010 Location: Rutherfordton, NC
Rep Power: 312 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
Groans: 31
Groaned at 28 Times in 15 Posts
| Not Ranked : 0 score Unless you only drive straight, you should disconnect swas. |
![]() | | #1393 | ![]() |
| Not Ranked : 0 score I've been on this forum for a while, and read like a madman, and today and yesterday were the first mentions I've ever seen of disconnecting SWAS. Those using the new wgdc table by Cobb are likely getting a lot more part throttle boost than they were previously. The new wgdc tables are populated in throttle position areas that were left blank in older ots maps. I don't know this is the whole problem, but maybe a start. |
![]() | | #1394 | ![]() |
Groans: 31
![]() | | #1395 | ![]() |
| Not Ranked : 0 score Well, that explains one of the issues Ive been having. May have to give this a shot.(SWAS disconnect)
![]() | | #1396 | ![]() |
Holy shit, I'm looking at the dyno logs again, and I noticed that as early as 3500RPM, my calc. loads are off by over .20 now ![]() Here's a little excel graph I did to illustrate the discrepancies between my target load and actual load. For kicks, I threw in a slightly older 3rd gear comparison to show how well the ECU tries to meet 3rd gear targets vs 4th gear. I truly believe there is a bug somewhere that is preventing the ECU from really trying to meet target loads. I've double checked all my tables, and I don't see anything that could be limiting the ECU from achieving target loads. I don't see how making the Load Dynamics tables and the WG Duty Load Error Comp table more aggressive would help, seeing as it hits 3rd gear targets just fine with those settings. I'll try PMing someone at COBB and post on the forums there and see what they say.
![]() | | #1397 | ![]() |
| Not Ranked : 0 score @f-castrillo and @Bucker... I am starting to believe there is a bug somewhere also. Bucker, did you highlight from a calculated load of 1.13 for a specific reason? |
![]() | | #1398 | ![]() |
Groans: 451
![]() | | #1399 | ![]() |
| Not Ranked : 0 score So far, this is 2010 specific I think (Bucker and another person). i.e. dipping into the 9 afr's. |
![]() | | #1400 | ![]() |
| Not Ranked : 0 score I shot another PM to Braden @ COBB outlining my 4th gear problem in detail. It's essentially a cut and paste of the post and graph I did here. The other day, I sent him a PM about the same problem, but in less detail. Here's the original PM and his reply.
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
