![]() | | #1401 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
![]() | | #1402 | ![]() |
![]() Join Date: Apr 2011 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,478
Sent from my Thunderbolt (Tapatalk)
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // | |
![]() | | #1403 | ![]() |
| Not Ranked : 0 score I am much like you (I like to know the who, why, what and where all while maintaining 100% consistency) LOL. After all is said and done though, it is a combination of all of the tables working in unison to get desired results that is the goal. |
![]() | | #1404 | ![]() |
Groans: 451
| Not Ranked : 0 score I would think that it would require more power to maintain an equal load in a higher gear, but I could be wrong. I dont know shit about mechanics.
![]() | | #1405 | ![]() |
The car actually reacts to changes in the TRL 4th gear table. But it's like it achieves targets up to a certain point, at which the ECU says "OK, close enough" when its still quite far off. I can target 2.15, car will achieve 2.04; I'll target 2.0, car will reach 1.9; I can target 1.88, but it may only achieve 1.77. All with plenty of WGDC still left on the table. If the ECU is truly trying to hit 4th gear targets, I should be seeing WGDC at or near 100% for target loads in 4th gear, since my 3rd gear targets are a touch lower than my 4th gear targets and those settings already result in 80-90% logged WGDC Sent from my Thunderbolt (Tapatalk)
![]() | | #1406 | ![]() |
![]() Join Date: Sep 2009 Location: Los Angeles, California
Rep Power: 442 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,334
Groaned at 72 Times in 51 Posts
| Not Ranked : 0 score After some revision on the map.. I think it's my first time breaking off that 250 g/s wall.. the car feels pretty damn good these days at night. It's targeting 18.5 from like 3500-5500rpm and tapering down to 16.5.
__________________ 2010 Mazdaspeed3 Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18) |
![]() | | #1407 | ![]() |
| Not Ranked : 0 score Hey guys, so my Corksport TMIC is coming in sometime today. Is it safe to say that I can run the TMIC without changing the current tune, and expect it to run slightly less boost for the loads I've been targeting?
![]() | | #1408 | ![]() |
| Not Ranked : 0 score I don't think that it will affect your tune all that much (besides cooling your bat's some and for longer periods of time). |
![]() | | #1409 | ![]() |
![]() So Braden @ COBB had me email him my map last night. He's gonna take a look at it to see if he can figure out the issue I'm having with the car not meeting 4th gear load targets.
![]() | | #1410 | ![]() |
Good luck with the tmic btw. | |
![]() | | #1411 | ![]() |
Groans: 451
| Not Ranked : 0 score I have one installed. I had to tweak my WGDC a minor bit (required less WGDC to meet my boost targets) and I added a very little bit of timing (lower BATs). Just put it on, get a log, and youll see. All my adjustments were within the error comp tables ability to compensate, so they weren't "necessary".
![]() | | #1412 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score I'd keep an eye on WGDC. The stock TMIC is quite restrictive at higher boost levels. Throwing on a higher flowing TMIC will require less WGDC to maintain the same level of boost.
__________________ '07 CWP MS3 Forged. |
![]() | | #1413 | ![]() |
Question: would I feel the Boost Limits - Fuel Cut and Throttle Close tables kick in? I mean, would it be an obvious "hitting a wall" feeling, or does the car just stop trying to make power? I ask because my Fuel Cut and Throttle Close tables are pegged at 21psi and 22psi, respectively. I don't feel any sudden halt in power, but I wonder if they're the limiting factor in the ECU not trying to hit 4th gear targets?
![]() | | #1414 | ![]() |
| Not Ranked : 0 score If you hit the boost cut, it'll feel like you blew your motor up. LOL. I almost crapped my pants the first few times I hit "boost cut". I don't think you are going to overboost that much with your new tmic, if @ all. |
![]() | | #1415 | ![]() |
| Not Ranked : 0 score Nataphen said I'm now done with fueling and boosting. Finally, it's time for timing! Can't wait to learn more about this. ![]() The car's been running really well lately. Probably because I don't drive during the day. LOL The heat just kills the power and gives me KR.. I'm a full time work + full time student, so that solves the problem.
![]() | | #1416 | ![]() |
| Not Ranked : 0 score Yeah, boost limit fuel cut is like hitting a brick wall. You'll know it when it hits it. The throttle close limit is a much softer limiter. I can typically feel a short lull in power when it happens. In a datalog, you should see a short dip in airflow where the throttle is closing, then it will open back up when targets have been met. |
![]() | | #1417 | ![]() |
When you hit cut, you'll know. It'll scare the crap out of you the first time :-P EDIT: You'll only hit boost limit fuel cut if the car is boosting above your set threshold for a good few seconds (less than 5, I believe). After that, it cuts and you'll hear a "thunk". It feels like you just jabbed the brakes really hard as you get launched forward in your seat but the car will keep accelerating if you keep going WOT.
__________________ '07 CWP MS3 Forged. | |
![]() | | #1418 | ![]() |
| Not Ranked : 0 score Anyone in SoCal area running intake/racepipe/hpfp/AP? I would love to see the logs just to compare!
![]() | | #1419 | ![]() |
![]() Join Date: Jan 2011 Location: Wildomar, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 375
No hpfp or rp, but intake/tip. Im also sad. Due to FP issue I dropped down to 15 psi, still needs some work, but logs attached.
__________________ 2011 Liquid Silver Corksport SRI/TIP/AIRBOX Ultimate Racing catback JBR stage 2 shift kit SURE RMM | |
![]() | | #1420 | ![]() |
Clean logs man, let me know if you need anything since we are both using the most shitty gas in the US. LOL I think 18.5psi is about the maximum that we can pull off without getting KR. And this is only for the ambient temp under like 70degrees. Once we play with the timing, I'll let you know here!
__________________ 2010 Mazdaspeed3 Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18) | |
![]() | | #1421 | ![]() |
| Not Ranked : 0 score One thing to note is that I did another datalog after hitting up the Angeles Crest Highway for 20 minutes... My poor stock turbo was so heatsoaked that it only pulled like 16.5-17psi throughout the run. :pofl:
![]() | | #1422 | ![]() |
However, since I installed the CS TMIC, I will get around to adjusting WGDC to account for the extra efficiency of the new TMIC. I need to get a warm-weather datalog and see what kind of WGDC the ECU wants to make to hit load targets, and adjust accordingly.
![]() | | #1423 | ![]() |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
| Not Ranked : 0 score You guys and your load tuning...lol JK
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. |
![]() | | #1424 | ![]() |
Groans: 451
| Not Ranked : 0 score Lolz bewsted. You homos and your E85...
![]() | | #1425 | ![]() |
| Not Ranked : 0 score This may be a long long long shot....I am curious to as if of you boost tuning guys have had a issue. Since the new wg tables have come out supposely the use of load tables effecting the boost tuning was removed....well i've been battling this slight blip of KR since this the new tables were brought out....and i'll be completely honest I hadn't been paying much attention to any of the "old" load tables shit since it should have no effect on anything boost tuning related. Well i just thought....maybe this old table is still in some sort of control. Sure enough prior to my slight blip of KR I'm exceeding the old Req load number just slightly. I had them set @ 2.85 and I hit 2.87. I have yet to test the new map yet and I may just be ranting but any input would be NICE.
![]() | | #1426 | ![]() |
| Not Ranked : 0 score I was looking @ a guys map and logs earlier, and although his wgdc load error comp table was 0's, his load dynamics table was still populated. I think that the KR @ spool may be @ least partially related to the time it takes for the intercooler to cool the bat's down. Now that we have max boost @ 3,000 or so rpm, rather than a slow onset like the ots maps, it may just be a matter of some of the remaining high bat air entering the engine. |
![]() | | #1427 | ![]() |
| Not Ranked : 0 score I was no where near the high bat flag.....which supposely does nothing anymore for boost tuning..
![]() | | #1428 | ![]() |
| Not Ranked : 0 score No cigar on the previous idea.....
![]() | | #1429 | ![]() |
| Not Ranked : 0 score Hey guys, so the TMIC definitely feels better to drive with (and it's pretty cold to the touch after parking and shutting the car off), but my gas mileage has dipped again. The cure-all to my gas mileage woes previously was to use the stock Boost Targets table. This doesn't appear to work much anymore, as it's taking everything I have just to get the car to stay above 24MPG on the MID (I hit 25.1 MPG for a minute) My assumption is that the dip in mileage has something to do with how different the Corksport TMIC flows vs. stock, and maybe some revised WGDC and Boost Target values for light TPS% is in order. Any suggestions on what could be causing the sudden MPG dip?
![]() | | #1430 | ![]() |
Groans: 451
![]() | | #1431 | ![]() |
I'm not sure if it's just the way the car calculates and displays gas mileage on the MID, though. I guess only a fill up from empty will tell. In an attempt to get better mileage, I've advanced timing a tad at cruise loads (<.8). I also upped the Ign Max A/B tables to accomodate the increased Low Throttle/CL table values. I'm also experimenting with adding timing at higher loads (1.44 and up) and see how high it'll let me go before I encounter consistent KR close to or above 2. I'd prefer to make all my power with ignition timing changes rather than boost. If I'm targeting the same loads as always, but timing is advanced to allow for more power, then I should be seeing slightly less logged boost, correct?
![]() | | #1432 | ![]() |
| Not Ranked : 0 score I feel like an idiot. I checked my dipstick and the oil level was below the MIN mark. Got an oil change, and guess what? Fuel economy issues resolved LOL. I guess the constant datalogging and last month's SoCal road trip really burned up a lot of oil. It lasted 5k miles, through all those WOT runs and long non-stop cruises. Anyways, I've begun working on my timing tables. I've been advancing my Low Throttle/CL tables in cruise loads by 1 degree per map revision (to aid gas mileage), until I start seeing consistent KR reports. Similarly, I've been advancing the High Throttle/OL tables in the higher loads and RPMs (4000+ RPM, 1.25 load and up), but retarding lower RPM/load timing to aid with spool up (2000-3500 RPM, .81 load and up). Attached is my current High Throttle/OL table. It's still a work in progress, as I'm barely seeing KR over .5 (sometimes a little blip or two of KR above 1.0), but does this look half-decent to you guys? I know it's kind of hard to critique a timing table since every car behaves differently, but enlighten me if I did something terribly wrong here.
![]() | | #1433 | ![]() |
| Not Ranked : 0 score Nothing wrong, but retarding timing early will heat up exhaust gas temps and spool the turbo quicker. |
![]() | | #1434 | ![]() |
| Not Ranked : 0 score Got a reply from Braden @ COBB regarding my 4th gear load tuning issues:
![]() | | #1435 | ![]() |
Groans: 451
![]() | | #1436 | ![]() |
| Not Ranked : 0 score I am boost tuning, and it seems very consistent. Even on hot days my car pulls hard and will burn the tires off 2nd gear. And when cruizing get my MID to show an average of 27 mpg on the highway. No reason for me to try load tuning at this point. Sent from my MB300 using Tapatalk
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() | | #1437 | ![]() |
Part of me is considering switching over to boost tuning again, but I'm so far into my load-targeting map that I feel inclined to just stick with it. The 4th gear underachieving load issue aside, load tuning isn't too terrible.
![]() | | #1438 | ![]() |
The more important thing to me though is how consistent it gets through a gear. In 3rd I can usually go from 40-80 in 5.5-6 sec. And 4th gear roll go from 60-100 in about 6 sec as well. I have made some slight changes since it got really hot out, added a little wdgc to hit my target and reduced timing by about .5 deg. at 4k to keep my kr min to non existent. But i'll always tinker and never by 100% satisfied. Lol Sent from my MB300 using Tapatalk
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() | | #1439 | ![]() |
Groans: 451
| Not Ranked : 0 score I do see more load at night. Usually in the heat it is ~ 2.13-2.15 peak. I have seen up to 2.23 at night when it is almost 20º cooler. That's fine with me, because that load number would be unachievable for me in the heat. Load tuning or not I wouldn't make that power. Also, I have no DP yet.
![]() | | #1440 | ![]() |
| Not Ranked : 0 score Did a 3rd gear log on the way to work this morning.
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
