 Old 07-28-2011, 11:50 AM   #1441
bewsted's Avatar
Posts: 2,456   (View Stats)
Originally Posted by Bucker View Post
I do see more load at night. Usually in the heat it is ~ 2.13-2.15 peak. I have seen up to 2.23 at night when it is almost 20º cooler. That's fine with me, because that load number would be unachievable for me in the heat. Load tuning or not I wouldn't make that power.
Also, I have no DP yet.
I only see 2.7-2.9 in the heat lol
EWG K04...GETSUM!
bewsted is offline
 Old 07-28-2011, 11:54 AM   #1442
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Yeah, "only"... fucker.
DP goes on today if UPS ever shows up... This is retarded. How can it be "out for delivery" since 4:30 AM? Ugh.
403whp/451ft/lb Dry Shot
Bucker is offline
 Old 07-28-2011, 12:10 PM   #1443
bewsted's Avatar
Your prolly the last stop HAHA
EWG K04...GETSUM!
bewsted is offline
 Old 07-28-2011, 12:12 PM   #1444
Bucker's Avatar
Groans: 451
Yeah, typical. I hate shipping companies.
Bucker is offline
 Old 07-28-2011, 12:50 PM   #1445
What company's TP did you go with Bucker?
rfinkle2 is offline
 Old 07-28-2011, 01:07 PM   #1446
Bucker's Avatar
Groans: 451
I've had a CS test pipe on for a while now, just waiting on the DP that was supposed to be here ~ noon... I have the stock one off and the car torn apart just waiting.
Bucker is offline
 Old 07-28-2011, 01:09 PM   #1447
Totally catless?
Todd98se pointed out the unique divorced design of the Corksport DP to me. Quality stuff.
rfinkle2 is offline
 Old 07-28-2011, 01:13 PM   #1448
Bucker's Avatar
Groans: 451
Totally catless?
Yes, Catless. If I don't like it it shouldn't be too hard to sell the TP and get a catted one or put the stocker on, but I think catless should be ok.
Bucker is offline
 Old 07-28-2011, 01:16 PM   #1449
I think it will too. I think you'll definitely be able to tweak your map for better results with that set-up for sure.
The only reason I don't run catless is the occasional smell, but Bewsted mentioned he gets no smell @ all.
rfinkle2 is offline
 Old 07-28-2011, 01:19 PM   #1450
Bucker's Avatar
Groans: 451
Yeah, not too concerned about that, I've had MUCH worse exhaust smell wise (had a car with blown rings that spit oil globs as I would drive). Ill keep my thread updated with results.
Bucker is offline
 Old 07-28-2011, 01:21 PM   #1451
I like the smell of gasoline anyway. I don't think you'll have an issue. There are a ton of guys on here that don't seem to have a problem.
Looking forward to your results.
rfinkle2 is offline
 Old 07-28-2011, 05:05 PM   #1452
bewsted's Avatar
Tuned in for buckers dp was for a ms6.
You best be making a new map. I want to see some numbers out your GUY!
EWG K04...GETSUM!
bewsted is offline
 Old 07-28-2011, 06:48 PM   #1453
Bucker's Avatar
Groans: 451
DP is on. Drove it for 10 miles, felt the same as before except a little louder and lots of PB smoke. I have a log, will post in my thread.
Bucker is offline
 Old 07-28-2011, 07:55 PM   #1454
bewsted's Avatar
Trust me it will be better once you get a lil more aggressive
EWG K04...GETSUM!
bewsted is offline
 Old 07-28-2011, 08:07 PM   #1455
Bucker's Avatar
Groans: 451
Another "First Log" post
Bucker is offline
 Old 07-29-2011, 07:19 AM   #1456
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Despite my love for load-based tunes, I'm really considering going back to boost-tuning. My car has no problem hitting whatever boost targets that I want. Likewise, while load-tuning, I can hit my 3rd gear load targets, but my 4th gear loads still aren't being met.
So tell me again MSF, when going from a load-based tune to a boost-based tune, what tables should I be changing? I figure the following should be changed/zeroed out:
- Boost Targets (set to desired boost)
- TRL x gear (leave the same or zero out, shouldn't matter on boost tuning?)
- WGDC (match to logged values)
- Load Dynamics (zeroed out)
- WG Duty Load Error Comp (zeroed out)
Should I be changing anything else? Will my ignition tables be affected at all?
If my load-based tune was hitting 19-20psi in order to hit 2.x load, can I set my boost targets to 19-20psi and expect to hit in the ballpark of 2.x load still? I wonder if matching my boost targets to my last datalogged Load tune log will suffice
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline
 Old 07-29-2011, 07:36 AM   #1457
Don't zero out the trl-x gear tables because the throttle plate will still try to close if you limit those tables (see important post here: ATR Resolution to Oddities Reported with the Pressure-Based Boost Tuning Calibrations - Page 3)
I also copied and pasted a quote from Cobb here:
The throttle load tables are still active during boost tuning. If you set them to 1.0, the throttle will close to a point where it can try to achieve 1.0g load. Since most vehicles will likely breathe better with Stage2 modifications, it will be hard for the car to limit load down to 1.0g at WOT even with a partially opened throttle plate. It would be best to target a higher load and zero out the load dynamics & boost comp rpm tables to allow the system to work properly.
Otherwise, the table questions you have are spot on.
Your ignition tables may need tweaking because they are referenced by load, and until you get your boost dialed in, you won't be sure of the load you will hit @ your desired boost.
rfinkle2 is offline
 Old 07-29-2011, 07:43 AM   #1458
Bucker's Avatar
Groans: 451
Isn't this what the Beta ATR was supposed to fix?
That is, the WGDC load error table can now be zeroed in order to completely sever the load tables so they will not step in now. I could be entirely wrong though. Despite that I would still set the load req gear x tables a bit higher than the load you expect to see.
Bucker is offline
 Old 07-29-2011, 07:46 AM   #1459
It did to a large extent.
The throttle plate will still try to limit the load you have entered into the trl-x gear tables.
I just try to remember that the car is load tuned from the factory, and getting the car to where you want it to be is a juggle between many of the tables.
@Bucker The quote I posted above is from yesterday, btw.
rfinkle2 is offline
 Old 07-29-2011, 08:01 AM   #1460
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
You don't want to zero out any load tables, quite the opposite, put them at values that are out of reach like 3.0.
Dano is offline
 Old 07-29-2011, 08:09 AM   #1461
Bucker's Avatar
Groans: 451
Thanks! I was unaware they had put out new guidance on that. Thanks, you rock.
Bucker is offline
 Old 07-29-2011, 09:27 AM   #1462
bewsted's Avatar
So that means that my theory about TRL affecting boost tuning still was correct?
I was under the impression that the new WG duty tables were taking them out of the loop until i started having what I felt was AFR drop due to exceeding the TRL. I raised the TRL but didn't see a MASSIVE difference in the odd AFR's but some slight improvement.
EWG K04...GETSUM!
bewsted is offline
 Old 07-29-2011, 09:33 AM   #1463
atvfreek's Avatar
Posts: 7,787   (View Stats)
Yup, TRL req per gear does still affect a boost tune, I have mine set to 2.3, and this morning when it was near 2.3, throttle plate closed to 70% rather than staying at 76%.
But they shouldn't affect your afr. Only boost and the throttle plate should be affected. That's kind of odd.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
atvfreek is offline
 Old 07-29-2011, 10:14 AM   #1464
bewsted's Avatar
Well anything that is related to throttle position would be effected.
EWG K04...GETSUM!
bewsted is offline
 Old 07-29-2011, 11:43 AM   #1465
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Agreed.
OL AFR targets are determined by RPM, and fuel is added based on MAF g/s, so TP% should not affect them.
Even on the new Beta maps I would still see my TP close when I got above my TRLxgear values, which confirms what COBB is saying.
Tapadatass
silvapain is offline
 Old 07-29-2011, 01:25 PM   #1466
bewsted's Avatar
Meh....
I did find out my maf cal was off. Imagine that was the reason for the afr flucuation rather then the TRL.
EWG K04...GETSUM!
bewsted is offline
 Old 07-29-2011, 06:13 PM   #1467
Just curious, what's the logic behind setting TRL x gear tables to 3.0 on a boost tune? Is this just to prevent throttle closure when/if my desired boost levels start netting me higher calc. loads?
 Old 07-29-2011, 06:30 PM   #1468
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Setting them to something unattainable just helps ensure that they aren't messing with your results at all.
These tables affect only some cars it seems, so the best way to deal with them is to make them unreachable.
However, once your tune is dialed in, it wouldn't hurt to set these to just slightly higher than what you typically see as a safegaurd.
wolly6973 is offline
 Old 07-29-2011, 07:50 PM   #1469
And this applies to all the throttle req. load tables, correct? Not just the TRL x Gear, but the TRL A-C and Baro vs RPM tables as well?
Sorry, last time I was targeting boost, the new tables weren't available yet, so I don't know how much tuning via boost targets has changed since I've been on a load-based tune.
 Old 07-29-2011, 09:28 PM   #1470
wolly6973's Avatar
Groans: 386
TRL A-C yes, not sure about the baro. I don't think you would need to touch it if your target loads are all way high.
 Old 07-30-2011, 01:52 AM   #1471
How accurate is the live data/current parameter screen on the AP? I drove to work on my latest map revision (went back to boost-target strategy), and the highest boost I hit during a 3rd gear WOT pull was 16.5 psi; my targets for most of the RPM range is 18psi, tapering down to 16psi by redline. So if the monitor is accurate, then I'm off by quite a bit.
I upped my WG Duty Boost Error Comp High Limiter to 45% (my base WGDC is currently at 40% across the board), and the Boost Error Comp table remains the same as OTS/stock. Load Dynamics and WG Duty Load Error Comp-related tables are zeroed out. I'm not sure how my logs look, I'll find out once I get off work tomorrow afternoon.
Question: is it unrealistic to tune the car safely for WOT runs in hot weather? It seems that some major overhaul of the Ign BAT vs ECT % used and Comp tables is needed in order to run WOT in 100F temps with KR < 2.0... I still have some more room to advance timing in cooler weather, but warmer IATs = higher BATs = tons of KR
I will leave my ignition tables where they're at for now though, until I can consistently hit my boost targets again.
 Old 07-30-2011, 07:52 AM   #1472
bewsted's Avatar
Ok so either you have your WGDC set too low and thats why you aren't hitting boost or you forgot to zero out the boost error comp....If your not load tuning anymore then you just zerod out the wrong table.
As long as you understand that zeroing out the boost error comp takes the ability of the ecu to adjust WGDC out of the equation LOL.
Oh and regarding tuning the car in hot weather. That is the downfall of boost tuning. It just doesn't adjust as easily as load tuning. So the best way I figure is finding a happy medium. Tune as far as you can in hot weather without seeing KR.
EWG K04...GETSUM!
bewsted is offline
 Old 07-30-2011, 08:15 AM   #1473
Bucker's Avatar
Groans: 451
And because tuning is so simple with ATR, make adjustments when it gets cooler out for more power.
Bucker is offline
 Old 07-30-2011, 08:47 AM   #1474
Did you mean zeroing out the load error comp tables? Hitting boost targets correctly by using the WG Boost Error Comp table is what we want, correct? Zeroing out the Boost Error comp table would negate the ECU's ability to compensate for under/overboost, but zeroing out the Load Error comp table would take load calculations out of the equation, if I remember right.
This is the reason why I wanted to stick to a load-based tune. More consistency in power output in a wide variance of ambient temperatures.
I'm gonna see how different the car feels in hot vs. cold weather on a boost tune. If it's too big a difference for me, I may just pick up from my last load tune and go from there.
 Old 07-30-2011, 09:05 AM   #1475
bewsted's Avatar
As the above math may be difficult for some to understand, we are able to modify a few tables withing the ECU to greatly simplify the boost tuning process. We can eliminate the ability of the ECU to modify WGDC based on a load error by setting the newly exposed WG Duty Load Error Comp. table to zero as pictured below.
Code:
0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
This will force the ECU to solely use feedback from the MAP sensor for all boost tuning strategies. Any errors in load targeting will have no influence on boost control. The values in the WG Duty Cycles table are used as a base for WGDC calculations then the WGDC can be modified by the ECU according to any Boost Error that is measured.
We have found that the below WG Duty Boost Error Comp. table settings are a great starting point for the closed-loop boost control feedback settings.
Code:
0.04 0.02 0.02 0.00 0.00 0.00 -0.02 -0.07 -0.11 -0.16 -0.20
You can modify the settings from here if you would like to give the ECU more authority (values further from zero) to modify WGDC or less authority (values closer to zero).
By zeroing out the WG Duty Load Error Comp. table, you will also smooth out the part-throttle response as well by disallowing the ECU to modify WGDC based on any load errors. Below is a sample of a 2010 MS3 WGDC table that we've found to work very well for a linear part-throttle response for boost control, you are welcome to use this as a starting point for your WGDC table:
This the post from christian.
I zero out both tables. Use the throttle close and fuel cut tables as my fail safe for overboosting.
EWG K04...GETSUM!
bewsted is offline
 Old 07-30-2011, 01:16 PM   #1476
Code:
Code:
So as I understand it, the WG Duty Boost Error Comp table only works for closed-loop operations? How do you limit boost to x.xx psi without having the Boost Error Comp table do its thing? I haven't come home from work yet, so I can't read my logs, but I presumed that I could raise the base WGDC to hit close to my desired boost, and use the WG Duty Boost Error Comp table to fix any further deviations from target boost?
 Old 07-30-2011, 02:47 PM   #1477
The wgdc boost error comp table works under all conditions. It is a fine tune adjustment that the ecu performs for you so your wgdc table does not have to be perfect.
I'm using the following values and they are working well for me:
rfinkle2 is offline
 Old 07-30-2011, 05:46 PM   #1478
My log read 16psi and 40% WGDC throughout a 3rd gear pull. I imagine that's because my WG Duty Boost Error Comp value for being under 1 psi is set to 0... lol
I will try populating my table with your values, @rfinkle2
Sent from my Thunderbolt (Tapatalk)
 Old 07-30-2011, 08:11 PM   #1479
Bucker's Avatar
Groans: 451
holy crap you give that table a LOT of authority rob.
I run something like .07 .05 .04 .03 .02 0.0 -.04 -.11 -.20 -.45 ?? ??
I might have to give it some more power it increase WGDC...
Bucker is offline
 Old 07-30-2011, 10:47 PM   #1480
I'm having some trouble coming from load-based tuning to boost-targeting. It doesn't seem like the WG Duty Boost Error Comp tables are doing much of anything at all. I have it set a tad more aggressively from OTS with the following:
0.20 0.12 0.10 0.07 0.04 0.00 -0.02 -0.07 -0.12 -0.25 -0.80
Logged WGDC is holding to my commanded 55% throughout the entire 4th gear pull. Not once does the car even try to compensate for over/underboost conditions by modifying WGDC. Any takers?
EDIT: I'm at work, so I can't give exact boost targets, but to the best of my memory, I'm targeting 18psi from 3000 to 5500, then taper to 16psi from 6000-RL. What's the general consensus for acceptable boost error? .5 psi? On second inspection, pegging my WGDC at 55% seems to work well for keeping boost at 18 psi for the most part. However, logged boost starts to stray ~4500 RPM, falling under over 1.5 psi from targets, and WGDC still holding at 55. My Boost Error High Limiter is set to 30%, so the ECU has room to raise WGDC to 85% if need be. The problem is that it isn't doing it.
Is it possible that my map might have been screwed up from the numerous revisions, jumping between boost and load targeting, and saving between different ATR versions? My current maps originate from the Stage1 CS+TIH v101 BT OTS map. I wonder if rebuilding a map from the newer v102a maps and just pasting my old tablse back in would fix anything.
Also, I don't like that -4.5% LTFT during random points of the log. I will probably do a MAF cal run on the way home from work in the morning to make sure I'm still in acceptable limits.
Gen 2 Cobb ATR discussion Nataphen 2010 MS3 - ECU Computer Tuning 2261 05-12-2015 12:09 PM
Cobb Tuning Inlet Review Discussion Haltech Review Discussion 62 06-03-2011 06:16 AM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Cobb AP Dyno Graph/Discussion NYpest MazdaSpeed 3/6 - ECU Computer Tuning 212 05-13-2008 02:13 PM
Page generated in 0.61408 seconds with 28 queries
