![]() | | #1481 | ![]() |
| Not Ranked : 0 score Also, what is your wgdc boost ramp high limiter set to? |
![]() | | #1482 | ![]() |
Also, changes in temperature will have less affect on the tune if you allow the error comp tables more authority. Another interesting observation... If you have a value of 90 in your wgdc table, and you want to see less than 100%, you will have to set your wgdc boost error ramp limiter <10. | |
![]() | | #1483 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
![]() | | #1484 | ![]() |
![]() Join Date: Apr 2011 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,478
I'm going to try rebuilding my map from scratch by pasting my tables into the v102a maps like mentioned earlier. Perhaps there was some kind of mixup in non-table data that might be messing with my map's ability to do anything.
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // | |
![]() | | #1485 | ![]() |
Groans: 451
| Not Ranked : 0 score Why do you want WGDC maxed at 85? There is no negative to letting it go higher.
![]() | | #1486 | ![]() |
| Not Ranked : 0 score I'm considering allowing it to max at 90 or 95%, but it helps me sleep easier at night knowing that my little k04 isn't going to melt by being exposed to face-melting exhaust temps from allowing 100% WGDC.
![]() | | #1487 | ![]() |
| Not Ranked : 0 score When tuning via boost-targeting, I know we're supposed to zero out the Load Dynamics and WG Duty Load Error Comp tables. However, are we supposed to zero the Load Error High/Low Limits tables as well? Or leave them stock? I have this gut feeling that I shouldn't be leaving the Load Error high/low limits zeroed out, but rather match them to the Boost Error Comp High/Low limits. If that flowsheet of the new Wastegate tables is anything to go by, it seems that the Load Error High/Low Limits are still being factored into boost comp calculations, regardless whether or not the WG Duty Load Error Comp table is zeroed out or not.
![]() | | #1488 | ![]() |
The wastegate duty boost error comp table is added to the load limiter to give the final wgdc calculation. Without any load adjustments due to the load comp and dynamics tables being set to 0, the load limiter calc. should be zero. You could leave the values as is, or zero them. | |
![]() | | #1489 | ![]() |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
| Not Ranked : 0 score Werd....really not much too boost tuning....Dial in your Boost....Dial in your Fueling...Dial in your timing your done.
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. |
![]() | | #1490 | ![]() |
Try setting your Load Error ramp limiters to zero, and you should see logged WGDC hold to commanded values, nothing more, nothing less. After an unsuccessful load tune and having trouble with boost tuning, I finally figured out how to make the ECU do what I expected ![]() Sent from my Thunderbolt (Tapatalk)
![]() | | #1491 | ![]() |
| Not Ranked : 0 score Great news!. That is some great detective work. And NO, you can't make me set my load ramp limiters to zero. ![]() (I stand corrected, btw) |
![]() | | #1492 | ![]() |
| Not Ranked : 0 score Now I wish I could figure out that issue I had with load targeting. Although I do like being able to target x.xx paid and be done with it. I'm considering upping my targets to 19 psi in the meat of it, and tapering down to 17 psi by redline. I might be able to get away with it with my current mods Sent from my Thunderbolt (Tapatalk)
![]() | | #1493 | ![]() |
![]() | | #1494 | ![]() |
| Not Ranked : 0 score i dynoed 302whp 322wtq (mustang dyno) on pump gas and no meth. 20psi tapering to 17.5.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #1495 | ![]() |
![]() | | #1496 | ![]() |
| Not Ranked : 0 score Happy mustangs are happy Rob @MicaBlueMS3!
![]() | | #1497 | ![]() |
| Not Ranked : 0 score Hater e85 nubs are hating hahahman that dyno in infamous for reading low so IDGAF!!! is till made over 300whp on the k04 without meth ![]() oh and we will find out how happy that dyno was on the 12th, jumping on the dyno here with dustin. Tuning for my water/meth and than im going to throw in some e85 and tune for that. be on the look out for a thread. im guessing at least 320whp since i romp on a gen1 that puts those numbers down on the local dyno here. hahaha
![]() | | #1498 | ![]() |
| Not Ranked : 0 score I'm jealous of the e-85 availability in other states. The stations are so far away from me here in NJ, that I'd have to fill up again by the time I got home FML. |
![]() | | #1499 | ![]() |
After the FMIC goes on I will be hitting teh dyno as well...But I dont anticipate anything but maybe 300/350-360
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. | |
![]() | | #1500 | ![]() |
| Not Ranked : 0 score You need a core? I'd sell you my UR core, debating to pick up the Mishimoto limited edition gold core.
![]() | | #1501 | ![]() |
| Not Ranked : 0 score No i dont need a core...and if you buy a gold IC your such a homo.
![]() | | #1502 | ![]() |
| Not Ranked : 0 score Instead of upping boost, maybe I'll try to further advance ignition timing. I don't want to go the meth route yet, though. Truthfully, I don't want to deal with remembering to fill up the reservoir lol. How have you guys adjusted your maps to accomodate a downpipe? I will be ordering one soon, and I just want to know how to prep my map for when it gets installed. Lower WGDC a few ticks? Advance/retard timing by x degrees?
![]() | | #1503 | ![]() |
| Not Ranked : 0 score Dude it matches my wheels perfect and its like 3 inches taller and 2 inches wider. Ill need that when im running 30 psi haha
![]() | | #1504 | ![]() |
| Not Ranked : 0 score N before you run 18 psi
![]() | | #1505 | ![]() |
But ya you would need lower wgdc's, and can run boost earlier in the rpm range, also more timing.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() | | #1506 | ![]() |
Have you altered your knock offset tables to compensate for engine noise @ high revs? | |
![]() | | #1507 | ![]() |
Did you adjust yours, and if so, to what?
![]() | | #1508 | ![]() |
Could also have to do with being fully mounted me thinks.
![]() | | #1509 | ![]() |
cld12pk2go recommends these settings: hyperliked to a good thread concerning timing. http://www.mazdaspeedforum.org/forum/foru...tml#post937739 | |
![]() | | #1510 | ![]() |
| Not Ranked : 0 score 1.1 from 6K up and 1.5 load up is a good place to start. then IP horizontally and vertically by 1 row.
![]() | | #1511 | ![]() |
Sent from my MB300 using Tapatalk
![]() | | #1512 | ![]() |
| Not Ranked : 0 score just looked at 12pk code which is about the same but looks like he IPed or at least altered the offset further down the RPM range.
![]() | | #1513 | ![]() |
![]() Join Date: Nov 2010 Location: Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 187
Anyways, always fun to learn something new on here and then spend a week playing with it :-) ![]()
__________________ -2010 Mazdaspeed 3 - DD CorkSport Intake/TIH - CobbAP - JBR RSB + Brackets, Endlinks - Weinerdog Co-Driver -Acura Integra Track Whore Mods: Driver Mod, Teal -SCCA F-Production Triumph Spitfire #46 - Race Kah | |
![]() | | #1514 | ![]() |
![]() | | #1515 | ![]() |
Groans: 451
Remember that your WGDC settings in the heat will net significantly higher boost pressure when it cools off, so I personally think it is better to undershoot targets on WGDC and allow the compensation table to correct it for you in the heat so that you are less likely to be overboosting in a couple months.
![]() | | #1516 | ![]() |
From the point should I bother adjusting my WGDC table as is or should I reduce all my values to about 20 and then retune from there? Or OTS? I guess I'm getting a bit indecisive as to what to adjust first. I guess I could set my underboost error table values to zero and then tune the WGDC from scratch? Just be very conservative and then stick in my boost error comp values. (.2 to 0.0 interpolated, a tad higher at -1.0psi if needed)?
![]() | | #1517 | ![]() |
Groans: 451
![]() | | #1518 | ![]() |
| Not Ranked : 0 score Right. But from where I sit now, my WGDC tables are going to be a bit high for the targeted boost. If I reduce the tables I have right now, should I zero out the error comp and use those values? Or keep error comp at the OTS point and let it do its thing? I am hitting my gargets but not until after a slow spike on spool up (close to 19psi then slowly it finds 17.2 by 5k rpm or so). I have lots of things I'd like to try and might try, just looking to see how others are going about it.
![]() | | #1519 | ![]() |
Groans: 451
![]() | | #1520 | ![]() |
^^^^^^ This. IMO its always better to undeshoot WGDC and allow the comp tables to increase it than to overshoot and overboost or have WGDC cut which loses all that built up pressure. You then have to start over building PSI which causes more boost oscillation. The system is very fast and a great system but it can't make lost pressure, via the wastgate, re-appear instantly.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
