![]() | | #1561 | ![]() |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
| Not Ranked : 0 score Then double check that you have your o2 sensors plugged in....As in they have clicked. Does the ap function as normal besides the AFR reading? I wouldn't do anymore WOT till you get that working. e85 waa waa?
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. |
![]() | | #1562 | ![]() |
![]() Join Date: Apr 2011 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,478
![]() I will double check my connections, though. Is the O2 sensor easy to mess up? I didn't strip it, but I wonder if all that PB Blaster did something to the sensors. Is it possible to clean them? I also suspect it might be the defouler on the secondary O2 sensor...
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // | ||
![]() | | #1563 | ![]() |
| Not Ranked : 0 score No the defouler wouldn't cause the wideband to readout funny. I ran without a rear o2 for a couple months and never had this sort of issue. Double check your connections. I dunno bout o2 cleaner
![]() | | #1564 | ![]() |
Sent from my MB300 using Tapatalk
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() | | #1565 | ![]() |
| Not Ranked : 0 score Here it is. Genpu w/UR downpipe and P0139
![]() | | #1566 | ![]() |
I'm going to jack the car up right now and make sure my primary O2 is ok, though. That, and I'll remove the defouler (it's a screw-on L-adapter) and see if I can at least get rid of some of the trouble codes.
![]() | | #1567 | ![]() |
You do want the o2 in the stream though.... You will get the pre cat warm cel....Which you can turn off in atr....
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. | |
![]() | | #1568 | ![]() |
The AFRs holding at 14.7... I hope my primary O2 sensor is ok. I want to disable the least amount of CELs possible, for emissions purposes in the future. Has anyone had trouble with re-enabling the P0101 code in ATR? The OTS maps (stage 1 and 2) have it disabled by default, but it seems that it will only throw the code if your MAF is bad or mis-calibrated.
![]() | | #1569 | ![]() |
| Not Ranked : 0 score You can always pm Darryl @ UR. He is ultra helpful if you can't get things figured out. FWIW, I haven't gotten a cel with my UR DP, and I was under the impression that they have fixed all of their latest DP's after there was a cel issue a while ago. |
![]() | | #1570 | ![]() |
| Not Ranked : 0 score If you have a defouler it will literally set a ton of different codes, all related to secondary O2 slow response, no respense,and bank1 sensor 2 lean, Bank1 sensor 2 stuck lean.... The list goes on. These cars use that sensor for a lot more than just a catalyst montitor. Unfortunatly the only way that I know of to get around it is delete the P0421 code, or take your chances and maybe the cat code won't pop up.
![]() | | #1571 | ![]() |
| Not Ranked : 0 score So I went and checked on all my O2 connections... The black harness for the primary O2 was unclipped . Plugged the sensor harness in, and now my primary O2 and AFR problems should be solved lol.I removed the defouler from the second O2 sensor and plugged the O2 sensor straight into the bung. I'll leave the P0421 DTC disabled, as is by default, and hopefully that will all that needs to be fixed. Thanks for the helpful info guys. Sorry for the partial-thread derail lol.
![]() | | #1572 | ![]() |
| Not Ranked : 0 score Your lucky yoour shit didnt deceide to pop on you.....that means you were running with no fueling adjustments whatsoever unless you knock lol
![]() | | #1573 | ![]() |
Sent from my Thunderbolt (Tapatalk)
![]() | | #1574 | ![]() |
| Not Ranked : 0 score Got my first batch of Stage2 datalogs finally, now with the O2 sensor problems out of the way lol. Here's a 3rd gear and 4th gear WOT pull from earlier tonight. There's a hefty amount of KR from 4800 to redline. I'm trying to decide whether or not I want to pull timing (probably 1 to 1.5 degrees in the affected load points and up), or run richer AFRs in the upper RPMs. What would be the more effective solution? BTW, I adjusted my Knock Offset tables from 5500-RL to slightly higher value to rule out false KR/engine noise from the stiffer RMM. The fact that I'm still getting bad amounts of KR up high signifies that I do have some real knocking problems. Damn pump 91 gas in Cali. A snapshot of my WOT fueling tables is also attached, for reference. This was done at 60F ambient temps at night.
![]() | | #1575 | ![]() |
| Not Ranked : 0 score I see no log LOL.
![]() | | #1576 | ![]() |
| Not Ranked : 0 score Holy shit, good find lol. Here's the two logs...really, this time.
![]() | | #1577 | ![]() |
| Not Ranked : 0 score I see 2 things going on here... 1st of all your getting some real knock from something....Check your Shroud on TMIC and check for anything else flopping around. Did you regap your plugs when installing them? Maybe your getting knock from this if not. Also I think your maf cal from 80 maf g/s up could use a 1.02 to clean up that WOT LTFT your getting.
![]() | | #1578 | ![]() |
| Not Ranked : 0 score I checked my plugs for proper gap, and they were all a .028" upon install. The shroud on the TMIC is held down as tight as I'm comfortable with (read: fairly tight), any more and the trim on the shroud will eat into the fins. I guess there's been a fitment problem with everyone's Corksport TMIC and the stock shroud. I don't think it would be causing the knock, but I could remove the shroud for a day and see how the car fares. I'll get around to the MAF cal sometime, although I copied my last Stage1 MAF cal over. Did the installation of a new downpipe necessitate a new MAF cal? Or does the improved exhaust flow not affect the calibrations?
![]() | | #1579 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score @bewsted FYI, here is a log. I added a bit more timing from the table you shared with me so I do have a bit of minor KR but I am fine with that. After 10 hours of driving yesterday (HARD DRIVING) on the tail of the dragon and a few races I got no more than 1.5 KR and it ran great.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() | | #1580 | ![]() |
| Not Ranked : 0 score Any mod you add can cause your maf cal to change a hair....
![]() | | #1581 | ![]() |
Groans: 451
| Not Ranked : 0 score Yeah, I think my turbo is a turd lol. I did get to run a similarly modded gen1 with a perm tune and we were pretty damn close. He pulled me by a little bit but he started in 3rd and I was in 4th. That tells me everything is normal and its running strong. Fuck the g/s and load #'s they don't seem to tell the whole story.
![]() | | #1582 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
Groaned at 53 Times in 27 Posts
Because you are running 91 octane gas, you should decrease your AFR's to run more rich. This will keep your pistons and cyclinders cooler and prevent/reduce detonation. This will also result in a lower power loss compared to reducing timing. I would also recommend getting a DO stage 2 water/meth kit, which will allow you to run higher AFR's and increase timing safely without detonation/knock. I am running 91 gas (max i can get here in Canada), and my AFR's are 11.3. When I do have KR, it is always less than 0.5%. Installing my kit next week and will be running 11.8 AFR's eventually w/ increased timing. Willy.
__________________ Current Mods: K&N SRI, UR downpipe, UR testpipe, Magnaflow CBE, 3.5" ETS TMIC, Cobb AP(Stage 2 91), cp-e 75 RMM, JBR HSK/SSP/bushings, RA mudflaps, EGR delete, Autotech HPFP Internals, DO stage 2 meth/water kit 50/50 mix,Ford Motorcraft Tranny Fluid | |
![]() | | #1583 | ![]() |
I'm gonna redo my MAF cal and check for any excess movement of the TMIC shroud to eliminate any potential problems. I re-torqued my JBR rear motor mount to install specs yesterday, so that may be a cause for more KR as well.
![]() | | #1584 | ![]() |
| Not Ranked : 0 score So it's been a few days running on my latest map, and after an earnest attempt at hypermiling this tank of gas, I got the urge to do a 3rd and 4th gear WOT pull to see how the map was holding up. This map still uses the same old timing and fuel tables, but the MAF tables were re-calibrated. They were off only by 3% at the most, but I redid the calibration anyway, though I'm probably chasing my tail at this point. I wanted to see if the KR I saw last week was just as bad/better/worse in slightly warmer ambient temps (75F). KR looks more or less the same. I think I may end up following through with the plan of pulling 1.5 degrees of timing or so from 4500 or 5000 to redline. I'm just in denial of it all, since the logs show I'm flowing ~250 g/s, and I'm worried that pulling timing will significantly lower that number ![]() Anyways, I guess it was expected. These timing tables ran great when I was targeting 17-18psi, but I guess it's asking a bit much now that I'm targeting 18-19 psi.
![]() | | #1585 | ![]() |
![]() | | #1586 | ![]() |
500-4000 RPM: 11.8 4500-6000 RPM: 11.6 6500 RPM: 11.4 7000 RPM: 11.1 I'm thinking of lowering my 4500-RL fueling targets to 11.3. If I still get terrible KR, then I'll probably start pulling timing. Good strategy? I've read some people are running 12:1-12.5 AFRs, I wish our fuel qualities here would let me do that lol.
![]() | | #1587 | ![]() |
| Not Ranked : 0 score Ya you can try that first. Whats your timing at, it's not logged in those datalogs.
![]() | | #1588 | ![]() |
I'm going to test with the v203 map tonight on the way to work, hopefully ambient temps are close to what I saw earlier this afternoon.
![]() | | #1589 | ![]() |
![]() Join Date: Nov 2010 Location: Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 187
| Not Ranked : 0 score Pull timing. My timing is lower than yours and I'm on high quality 93octane. I am going to start making some adjustments but I would rather lose the knock and a couple HP rather than knock like crazy.
__________________ -2010 Mazdaspeed 3 - DD CorkSport Intake/TIH - CobbAP - JBR RSB + Brackets, Endlinks - Weinerdog Co-Driver -Acura Integra Track Whore Mods: Driver Mod, Teal -SCCA F-Production Triumph Spitfire #46 - Race Kah |
![]() | | #1590 | ![]() |
For me, I'd pull timing and run 11.8 AF across the board Time for WMI Also, don't know if you have performed the checks to see if the KR is real above 5.7K. Add octane or pull timing to see if it goes away. If not its false and you can change the sensor offset.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
![]() | | #1591 | ![]() |
I looked at the logs from last night's WOT pulls on the way to work, and found I had to pull another 1 degree at 5000, and 1.5 degrees by 6500. I've also done as you suggested and will run 11.8 AF all the way. I'll run the car later this afternoon with the revised ignition timing and fueling tables and see what happens. As for WMI, I want to push the car as far as it will reliably go without meth. My original goal was to make more power, but not max power, and I know that by avoiding WMI, I'm leaving quite a bit on the table. Still, the mod/power bug will bite eventually, and I'll may change my stance on WMI later.
![]() | | #1592 | ![]() |
It may/may not help your map, but it seems to have controlled the small bits of kr, when pulling away from a stop light etc. in my car. | |
![]() | | #1593 | ![]() |
![]() | | #1594 | ![]() |
You will of course need to pull more ign advance to run the leaner AFR up top. Just see how it reacts first and watch KR while logging. Once u go meth u can't go back so make sure you want it. ![]() Tappin
![]() | | #1595 | ![]() |
| Not Ranked : 0 score How have you guys been tweaking the higher load sections of the Max Ign A/B tables? Did you match it to the High throttle/OL tables, or did you make the Max tables a little more advanced than the High Throttle/OL tables to allow the ECU to advance timing further in cooler temps?
![]() | | #1596 | ![]() |
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
![]() | | #1597 | ![]() |
![]() | | #1598 | ![]() |
Groans: 451
| Not Ranked : 0 score @bewsted I got my ITV22s in today. I am about to go log a new run with slightly advanced timing over the table you shared. Will report back later!
![]() | | #1599 | ![]() |
| Not Ranked : 0 score I've been matching the Max Ign tables to my High Throttle table, so that the ECU wouldn't try to advance timing too much in warmer weather, thereby preventing knock in hot temps, while maintaining decent power output in cooler weather Sent from my Thunderbolt (Tapatalk)
![]() | | #1600 | ![]() |
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
