![]() | | #1601 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score OH! DUDE! I found an E85 station 5 miles from me!!! On Fort Benning. Fuck yeah.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() | | #1602 | ![]() |
Tappin
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
![]() | | #1603 | ![]() |
![]() Join Date: Apr 2011 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,478
| Not Ranked : 0 score What about the knock tables? Have you been matching it to the no knock tables for consistency's sake? Or is your No Knock table slightly more advanced than the Knock table? The ECU pulls timing when KR is reported, so I don't really see the need for the no knock table, TBH. Correct my logic if I'm wrong, though. I'm seeing less than 1 count of knock in my logs now, I had to pull an extra 2-3 degrees of timing in the areas that I bumped the AFRs up to 11.8. I just ordered SURE's IM/TB TIGs, contemplating the EGR delete, and I think I'll be done with engine mods (for now). I'm tempted to dyno now lol.
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // |
![]() | | #1604 | ![]() |
| Not Ranked : 0 score Knock tables are v102 OTS so I haven't touched them....I rarely see KR so there's no need spending time tweaking them. did you happen to log g/s and load before and after the AFR shift at the same AMB temps? It'd be interesting to see if they dropped or went up with less timing but leaner AF. This would be evidence to support which method of knock reduction nets the most power. Richer AFR and more timing Leaner AFR and less timing. you pulled 2* so that's quite a bit I would think. You may want to find some middle ground and pull 1* and shift AFR to 11.6-11.7. I've tuned 3 guys now from cali with shitty 91 oct and it does suck for you guys...had to run less than Cobb OTS timing in some areas. You just have to see what makes YOUR car happy
![]() | | #1605 | ![]() |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. | |
![]() | | #1606 | ![]() |
| Not Ranked : 0 score Or hose it down w WMI. Lol Tappin
![]() | | #1607 | ![]() |
| Not Ranked : 0 score i actually chuckled out loud reading that lol. Anyways, I'm not seeing much KR anymore with my current map, but I'm going to backtrack a little bit in the interest of seeing if a slightly richer AFR (11.6:1) across the board combined with slightly more advanced timing will net me more MAF g/s than running leaner with less timing. I'm setting the areas above 1.38 (a little higher than my CL-OL transition point) back to OTS timing, and pull/retard from there. I'll also be changing the Ign BAT vs ECT tables back to OTS. I hope I can get this done in 2-3 map revisions, as I was mostly content with the current map, but the idea of richer AFRs + more timing was bugging me.
![]() | | #1608 | ![]() |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
__________________ www.MOTOIQ.com Beater Titan | |
![]() | | #1609 | ![]() |
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // | |
![]() | | #1610 | ![]() |
| Not Ranked : 0 score if you perform the runs on level ground, similar locations you can use Virtual Dyno to quantify the results...IIRC its basically using a time to distance calculation to generate the HP numbers. Virtual Dyno Program
![]() | | #1611 | ![]() |
![]() | | #1612 | ![]() |
Dano does have a point that too rich of an AF can cause knock. However, the OTS maps have AFRs richer than 11.x, and COBB deemed those maps "safe", so take that for what you will.
![]() | | #1613 | ![]() |
| Not Ranked : 0 score Yeah I wish we had a definitive AFR that we shouldn't go "under" but that would be too easy right. Not sure how hot if has been in your area but down in San Diego I get zero KR in the morning and then easily over 2 in the afternoon depending in how long the intercooler soaks. I'm considering trying ITV24's to see if they change anything, I can always switch back to 22's when things cool off.
![]() | | #1614 | ![]() |
not hating on Cobb at all but they have to take many things into consideration when they create their canned tunes. if you don't have your MAF just right that 10.x AFR could end up being 12.x. So they build in buffers throughout the tune. When your MAF if spot on, thus the ECU knows exactly how much air is entering the engine, you can tune closer to exactly what you want to see. For 93 + WMI at least a 12-12.4 AFR is becoming the norm. When we get a real upgraded IM with a better flow balance even leaner AFR will follow. I run 12.0 and need to go leaner but will wait for these 100+ temps to subside. Keep at it and you'll get it dialed in.
![]() | | #1615 | ![]() |
Here are the logs. They were done on a small incline, but I did my best to make sure the pulls were started at the same point on the road and RPM. From the looks of it, the v205 logs (11.8 AF + retard timing) net much higher MAF g/s than the v206 logs (11.6 AF + OTS timing). Granted, there's a fair amount of of KR in the v206 log, but even comparing the no-knock sections of the logs, the 11.6 map pushes out less g/s than the 11.8 map, and the 11.6 map is running more timing. I may just end up sticking with the v205 map, unless you guys see a glimpse of hope for the v206 map.
![]() | | #1616 | ![]() |
Have I said WMI yet today? It truly is a godsend.
![]() | | #1617 | ![]() |
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
![]() | | #1618 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score Can't wait to get moved to IL to get some sweet sweet 93! I am tired of this 91 and having to run weak timing & afr. |
![]() | | #1619 | ![]() |
| Not Ranked : 0 score don't you have E85 in NE? Just throw 3 gallons per tank in there and call it a day.
![]() | | #1620 | ![]() |
![]() | | #1621 | ![]() |
| Not Ranked : 0 score Has anybody successfully re-enabled the P0101 CEL in ATR? I don't want to have more than two DTCs disabled for emissions reasons. I have p0101 and the inefficient cat DTCs disabled, but I'm considering doing the EGR block off, which will require me to disable another CEL. If I understand it right, P0101 is only thrown when the MAF readings are off for more than 8 secs, a problem we shouldn't encounter with a proper MAF calibration, correct? Sent from my Thunderbolt (Tapatalk)
![]() | | #1622 | ![]() |
| Not Ranked : 0 score Gonna try the 11.8 AFRs along with the OTS ign timing tables. Hope it's not too suicidal. This time, I'll try pulling from the BAT vs ECT tables before pulling the main timing tables. The car seems to hate BATs of ~114F and up.
![]() | | #1623 | ![]() |
| Not Ranked : 0 score Did dano suggest w/m lol. That and ebcs are my next to do's Sent from my MB300 using Tapatalk
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() | | #1624 | ![]() |
![]() Join Date: Jan 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 118
| Not Ranked : 0 score Dumb question - is there a unit of measure conversion for the fuel tables in ATR? For example, I got some fuel table data from a forum member who will be helping me tune...his target AFR for one cell would be 14.680 (stoich) but my ATR is formatted differently. Mine reads as 1.000 for that cell... So I assume I have to divide all of his AFR table data by 14.680 to put it in the proper format. Make sense to anyone? My ATR is for a 2011 MS3. Is it different than 2010?
__________________ pedal2plastic.wordpress.com The driving game blog Liquid Silver 2011 Mazdaspeed 3 w/ Tech Package Cobb: AP, SRI & RMM Corksport: TIP, TMIC, RP,SSP Autotech Internals Bilstein PSS Coilovers SPC Rear Camber Arms JBR RSB Gram Lights 57F - 18x8.5 +45 Rfinkle2 tuned @21psi |
![]() | | #1625 | ![]() |
![]() | | #1626 | ![]() |
![]() Sent from my Thunderbolt (Tapatalk)
![]() | | #1627 | ![]() |
Groans: 386
My meth setup is almost operational now! Aurora
![]() | | #1628 | ![]() |
| Not Ranked : 0 score I se the unit conversion in the accessport menu but not in ATR. Confused
![]() | | #1629 | ![]() |
Sent from my SCH-I500 using Tapatalk
![]() | | #1630 | ![]() |
Good to know your CEL went away with a quick cleaning, though. How many miles did you wait to clean it? Sent from my Thunderbolt (Tapatalk)
![]() | | #1631 | ![]() |
Groans: 386
![]() | | #1632 | ![]() |
| Not Ranked : 0 score Alright guys, here's a 3rd and 4th gear log from the latest map (11.8 AFRs targeted across the board, OTS Stage2 CS+TIH+IC timing from 1.38 load and up). As expected, there's a fair amount of KR here; the 3rd gear log averages ~2.5 KR all around, while the 4th gear log starts off alright, but starts developing some massive KR by 5500-6000 RPM. Normally, one would say to pull timing and call it a day. But now I want to try a balancing act of altering the "Ign BAT vs ECT % used", "Ign BAT vs ECT A/B", "High Throttle/OL", and the "Max Ign" tables. I'm getting ready for work, so I don't have time to make any immediate changes to the map. But I figured I'd post here in hopes that someone could chime in on what tables would be good to start from first. I've pulled a ton of timing in the past, and altered the Ign BAT vs ECT tables much later, so I want to start from scratch and do things in a more orderly fashion. Any takers? I'll be up most of the night lol
![]() | | #1633 | ![]() |
![]() | | #1634 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score Quick question...I can't seem to make the "search" function search anything 3 letters or less...maybe i'm missing something...anyway, question is what is everyone using for the Max Load D table settings? I read Abilor's guide but my OTS settings are already lower from 0-4500. 5000-7000 are higher than the guide. Just curious what everyone was doing for this table, and if anyone was editing any of the other Max Load tables.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #1635 | ![]() |
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // | ||
![]() | | #1636 | ![]() |
![]() | | #1637 | ![]() |
| Not Ranked : 0 score f-castrillo thanks for the response. So basically you increased the stock values from 1.10 and 1.0 to 1.25? Did you also decrease the values from 1.0 to .40 in the 5k+ range?
![]() | | #1638 | ![]() |
Have you had any success with the IAT table, at all? Sent from my Thunderbolt (Tapatalk)
![]() | | #1639 | ![]() |
Groans: 451
![]() | | #1640 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
Groaned at 53 Times in 27 Posts
My thinking is that the more fuel you put into the cylinders, the bigger the temperature drop and the less likely there will be pre-detonation due to hot spots, but lower than 11 AFR will leave leftover fuel that is unburned and reduce power, and even richer < 10 AFR can possibly not ignite (assumption). I know that optimum AFR is around 12.5, and timing @ BTDC is ~ 25, but with having a turbo, running richer (without meth) due to the added heat, will keep things relatively cool. We have to also keep in mind that running 91 octane gas is less than ideal for running higher timing and AFR's. To be safe, I think it would be best if f-castrillo left the timing alone and reduced his AFR's to ~11.4. The reduction of timing will have a larger negative effect on power band than dropping AFR's, and the episodes of KR will be reduced. Also.......f-castrillo needs meth. From what i've read about meth, you can run crazy timing and AFR's close to 12.5. My stage 2 kit is going in sunday.
__________________ Current Mods: K&N SRI, UR downpipe, UR testpipe, Magnaflow CBE, 3.5" ETS TMIC, Cobb AP(Stage 2 91), cp-e 75 RMM, JBR HSK/SSP/bushings, RA mudflaps, EGR delete, Autotech HPFP Internals, DO stage 2 meth/water kit 50/50 mix,Ford Motorcraft Tranny Fluid | |
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
