![]() | | #1681 | ![]() |
![]() | | #1682 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
__________________ '07 CWP MS3 Forged. | |
![]() | | #1683 | ![]() |
| Not Ranked : 0 score @BlueStreak... I totally agree with the above. With the D07 and a 50/50 mix, I see no afr shift whatsoever. I will be spraying 100% meth with a D05 first, and then if necessary, move up to a D07. It almost seems that the manufacturers of the kits are covering there asses when suggesting nozzle size and overall mixture. I have seen many people spray with large nozzles, and see no afr shift. The only guys that I see with any appreciable afr shift and drop in bat's (below intake temp) are spraying 100% meth with a D07 or greater. In short, agreed with the above (how can anyone argue with datalogs lol), but it seems to achieve the tuning method that the manufacturers recommend, one would need to spray 100% meth with a much larger nozzle than specified in the recommended nozzle / horespower charts. |
![]() | | #1684 | ![]() |
| Not Ranked : 0 score In order to maintain the AFR shift, you would need to control based on MAF voltage, not pressure. You would also need to spray a ton of meth since the stoich ratio is so much richer than gas. |
![]() | | #1685 | ![]() |
| Not Ranked : 0 score I hear you, phate. You still require enough flow (i.e. nozzle size) in the system to keep spraying an increasing volume of meth to match the increased airflow.
![]() | | #1686 | ![]() |
He and Abilor put a meth tune together for Abilors car spraying 100% meth w/ a D07 nozzle, and I am pretty sure they were able to keep a constant afr shift to redline, but I am going from memory of the logs. TBH, I wish I had done a bit more research before buying my kit, and may eventually convert to an maf based controller. I have already had to spend a ton of additional $ on my DO kit, from bungs, nozzles etc. The only thing that I'm using from the DO stage 2 kit at the moment is the pump and controller. My nozzles are now Snow, as well as the bung itself and nozzle holder. I would've purchased a Labonte kit, but believe the Tsunami put a cramp in his supply chain, and effectively put him out of business. | |
![]() | | #1687 | ![]() |
| Not Ranked : 0 score Agreed. MAF based or IPW based is far superior to MAP based for controlling meth spray. EDIT: Actually, I have successfully converted my MAP based controller to MAF based but I find its a tad risky. I'll post a write up on it and will outline the risks involved if poop hits the fan.
![]() | | #1688 | ![]() |
| Not Ranked : 0 score MAF FTW...I have MAP and wish I had MAF. once the spray is started and levels out MAP works great but you go rich when the spray first starts if you are using a honking nozzle. If you base off of MAF you can scale the MAF right at the trigger point which will never change, so you stay at target AF. MAP based trigger can be at different MAF voltages so it doesn't work as well. Coolingmist has the coolest controller. its a digital boost gauge/controller/flow meter. [52mm] I believe it is can be either MAP or MAF. something like a CMG2 pro
![]() | | #1689 | ![]() |
![]() Join Date: Apr 2011 Location: Vallejo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,478
| Not Ranked : 0 score Thanks for all the info, guys. About making a safer meth tune, wouldn't a mechanical failsafe solve our worries here? aka nozzle stops spraying, failsafe cuts boost to spring pressure, meanwhile there's probably been a few counts of KR, and AFRs are richened and/or timing is automatically pulled? On that note, do such failsafes exist for MAF-based WMI setups?
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // |
![]() | | #1690 | ![]() |
Snow Performance comes to mind: Snow Performance: SafeInjection? Wastegate Solenoid | |
![]() | | #1691 | ![]() |
| Not Ranked : 0 score Mechanical FS sols don't work that great. They slow spool time by allowing boost pressure to act on the WG Until the flow sensor detects enough flow. Snow does have one that connects to your EBC wiring which may work better. So your FS controller is set to say 350ml/hr which is your max flow rate. Well when flow starts it is not at max rate yet so pressure goes to the WG until you reach that flow rate If you lower the set point enough you get the opposite and the controller detects an overflow condition and again trips the sol. That has been my experience with the labonte equipment When shopping for WMI FS controllers be careful as only a few support 100% meth. Coolingmist does not support it on their normal controller but do on their auto learning FS controller. Tappin
![]() | | #1692 | ![]() |
| Not Ranked : 0 score Thanks, I guess I have quite a bit more research to do before diving into the meth pool. I'm still trying to wrap my head around how to set up a meth kit that would net me some extra power, while remaining reasonable enough so that if the kit were to fail, that my engine wouldn't epic fail afterwards.
![]() | | #1693 | ![]() |
| Not Ranked : 0 score That's easy...I can help you out and how I run my WMI. If it fails I will only be .2 leaner than target and if KR does show up the ECU will add fuel and pull timing to quell it. I also have conservative timing. My FS is actually just lights in my dash which you can see in my WMI thread. I removed the actual FS solenoid months ago. When you get into trouble is when you completely rely on WMI with a very aggressively lean target AF and aggressive timing. so you can have a DD map that won't blow the motor up if WMI fails and if you want some killer dyno plot make another "ragged edge" map. I would actually like to try their FS boost cut controller that interrupts the electrical signal to an EBC. It probably reacts much faster than a mechanical one but then again you would need to run the OE BC or any aftermarket EBC. MBC would still need a mechanical boost cut device.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
![]() | | #1694 | ![]() |
| Not Ranked : 0 score rpm comp A and B tables (beta ATR) explained here: http://www.mazdaspeedforum.org/forum/foru...ml#post1009814 |
![]() | | #1695 | ![]() |
![]() Join Date: Feb 2010 Location: Tiburon, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
| Not Ranked : 0 score I received notification in AP Manager today that new firmware is available for the AP: 1.6.4.2-2553, and it comes with V200 maps. It references a new build of ATR: 1.8.6.0-2517. However, my version of ATR still shows 1760 as the most recent released ATR build, and 2212 as the most recent beta build. Has anyone else been able to download the new 2517 build of ATR yet? |
![]() | | #1696 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score My AP also shows update available...ATR shows nothing. So basically this update will not work with the current Beta ATR correct? Also, per release notes, the update doesn't seem to be anything different than the current beta tables...so no real need to update for those running beta correct?
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #1697 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score DONT DO IT! I updated my AP a couple hours ago, went to flash a new map and it froze. My fucking ECU is bricked and I am 100 miles from fucking home. UGH! I left COBB a voicemail and shit but avoid this for now.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() | | #1698 | ![]() |
| Not Ranked : 0 score fuck I was afraid of that...the AP FW release notes specify a newer ATR version. Why would they release the FW before ATR????
![]() | | #1699 | ![]() |
| Not Ranked : 0 score Shit, thanks for letting us know. That sucks man I hope it gets fixed.
![]() | | #1700 | ![]() |
| Not Ranked : 0 score Just uncheck Beta in atr then u can update both atr and ap then have a happy day. Dont forget to resave existing maps. Tappin
![]() | | #1701 | ![]() |
| Not Ranked : 0 score But what is the point in us updating if we have the beta already? IT looks like nothing changed from current beta to the new non beta...seems like they just updated non beta to what us beta guys are running?
![]() | | #1702 | ![]() |
Groans: 451
| Not Ranked : 0 score Yeah, that was my error... working with Cobb now to make it work again haha.
![]() | | #1703 | ![]() |
__________________ (310whp, 341 ft/lb wtq) 91 octane + 100% methanol JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs // | |
![]() | | #1704 | ![]() |
![]() | | #1705 | ![]() |
| Not Ranked : 0 score Did you flash an OTS map, or a custom one? I was able to flash a stage 1 OTS map just fine with the new firmware. Maybe I just got lucky? |
![]() | | #1706 | ![]() |
Groans: 451
| Not Ranked : 0 score Ok, I have talked to Cobb. It wasn't the update, it was coincidental that my ECU got bricked when it did. I was just unlucky. They said they have seen "a few" have this happen, but it is not very widespread.
![]() | | #1707 | ![]() |
| Not Ranked : 0 score Yeah, that works now. Wasn't yesterday morning. Anyone know if there have been any changes since the beta? I'm guessing there may have been some bug fixes and improvements in the last 1.5 months. |
![]() | | #1708 | ![]() |
Good to see you Dachtler! Answer to your q. here: http://www.mazdaspeedforum.org/forum/foru...-lc-ffs-90471/ | |
![]() | | #1709 | ![]() |
| Not Ranked : 0 score Nice hefty update there, COBB! I wonder what use the new clutch in/out related tables are to us stock K04 guys, it seems like it'd only be really useful to people running BT. I'll probably just keep my current map as is, until the meth kit comes in, then I'll start tuning with the newest ATR and firmware.
![]() | | #1710 | ![]() |
| Not Ranked : 0 score For anyone that's installed a PMM (JBR or otherwise) after a RMM: Did you find you had to up the KR offset tables even more from when you first installed your RMM? I know the RMM was causing some false reports of knock, does the PMM require some KR offset changes as well? Sent from my Thunderbolt (Tapatalk)
![]() | | #1711 | ![]() |
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
![]() | | #1712 | ![]() |
| Not Ranked : 0 score I see, well I haven't heard anything terrible from the engine bay, and the car pulls more or less as expected. I'll probably re-evaluate my map once I rent a dyno for my meth tuning session... whenever it comes in lol.
![]() | | #1713 | ![]() |
| Not Ranked : 0 score I know I hear alot more noise with my PMM installed. Not sure if this will translate into kr readings or not. I did not modify my kr tables with my RMM...but I really wouldn't know how to see "real" vs "fake" knock in my logs.
![]() | | #1714 | ![]() |
| Not Ranked : 0 score only way to weed out the difference is to substantially increase the octane and see if the KR goes away. If it does it was real, if not the KR is false and you can proceed to tune the offset.
![]() | | #1715 | ![]() |
Has anybody bothered with the new clutch in/out ignition timing tables? I'm not too sure if they'll be useful for us that still have the stock K04 Sent from my Thunderbolt (Tapatalk)
![]() | | #1716 | ![]() |
| Not Ranked : 0 score haven't messed with the new clutch in/out tables but they could be beneficial for any car, not just BT. There are situations when the ECU will get confused after a FFS and even on a normal shift and pull timing/add fuel. I think these tables might be what we need to resolve this but haven't had time to test. My car would def fall on its face after a lift to shift IF I had FFS enabled so it will be an easy test once I get some time. I am talking like -15* advance after a shift LOL
![]() | | #1717 | ![]() |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
| Not Ranked : 0 score I have all 3 mounts and had to do a bit of tuning on the offsets to clean up some engine noise.
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. |
![]() | | #1718 | ![]() |
| Not Ranked : 0 score thanks Dano and Bewsted. I'll log and see what my KR looks like after my PMM and evaluate from there. Any tips on how to modify the offset table?
![]() | | #1719 | ![]() |
Hyperlink to post: http://www.mazdaspeedforum.org/forum/foru...tml#post937730 | |
![]() | | #1720 | ![]() |
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
