![]() | | #201 | ![]() |
| Not Ranked : 0 score
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #202 | ![]() |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
![]() | | #203 | ![]() |
| Not Ranked : 0 score what exactly does putting the req loads at an unatainble target do?
![]() | | #204 | ![]() |
Groans: 134
| Not Ranked : 0 score Ok, I'm at a bar, so I may not say this perfectly, but it keeps the ecu from being satisfied by meeting load... So if boost is X, and load >x, the ecu will hit X. However, if the load value is close to x, it may be met before boost is. If that happens, target boost will not be met because the load target is satisfied... Boost tuning is not perfect, probably because the ecu is programed by Mazda to work off load. |
![]() | | #205 | ![]() |
same as you posted above? One more thing, how did you come up with those WGDC targets? Just kinda played with them untill u werent pegging 100 past 5500?
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost | |
![]() | | #206 | ![]() |
Groans: 134
| Not Ranked : 0 score He mentions them a bit earlier. If I were not on my phone, I would quote them. I know that he lowered them from 2.31 to around 2.1-2.2... Its listed not too far back. |
![]() | | #207 | ![]() |
| Not Ranked : 0 score brought my laptop to work and im working on a revision to the map I have now. Will post up some logs tomorrow afternoon most likely but im trying this shit out. I also have my timing tweaked from some other shit i read, so hopefully my maf g's be flying high! haha
![]() | | #208 | ![]() |
If you look I added 10's in the top of each of the rpm's so i could try to keep the vertical interpolation straight in my mind. I wanted to gradually hit the boost targets until I'm comfortable that the final row in the 75 position wont cause a spike when I mash the throttle. I noticed after I shifted, that rpms were in the range where most of the 10's are placed. In the lower part of the rev band, I wanted to keep the wastegate duty cycle @ 0, so I started most of the interpolation up to the throttle points near peak boost (around 4000 rpm). Here is my latest 3rd gear log. No 4th gear logs due to so many police in my area yesterday. (note logs do not represent changes made to throttle - req load x tables, i.e. changes made after log) | |
![]() | | #209 | ![]() |
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() | | #210 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
(Thread Starter) | Not Ranked : 0 score My car must be one of those that isn't really affected by load. My low airflow numbers didn't change much, if any, when I went from OTS load targets to 3.00 in all tables at 3k+ RPM. I'm guessing that the reason that I was registering more air before my mods was because I had advanced timing by a fair amount. Some say timing doesn't affect g/s, some say it does. I just won't know until after I get a CDFP though, I'm safe right now, but I had to pull back my max boost by 1psi to keep it that way all the time. Timing will come at a later date.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
![]() | | #211 | ![]() |
| Not Ranked : 0 score First thing I want to say is PLEASE be careful if you decide to set your per gear tables @ 2.3. I don't think it will kill you or the motor, but you may hit boost cut and possibly poop your pants. You also may want to richen your fuel up a tad in the case you start to see increased boost levels. I almost did LOL. @BlueStreak did some testing and posted his results below.... |
![]() | | #212 | ![]() |
Groans: 134
![]() | | #213 | ![]() |
This is one of the reasons I even bothered to "stir the pot" so to speak with the load tables. I may still have the log, and if I do, I'll post it after I get home from work. I have my boost cut limit set @ 20 (on an 18.5 psi map), and saw 4 data points above before "cutting" . @bmorrisj hit cut also. (his post copied and pasted from Dano's thread) "I upped all my req load tables above OL and hit boost cut for the first time since installing my ap" | |
![]() | | #214 | ![]() |
Groans: 134
| Not Ranked : 0 score Well then I guess it really must depend on the car, or maybe things change when an ebcs is installed? I guess we will find out when u install yours. And I thought that maybe because you have your boost cut at 20, and mine is at 22, that maybe it was working for me because my boost is already at the upper limits (probably past) of what the ko4 can do, but yesterday when I was getting this map dialed in, I started with lower wgdc and was hitting only 16psi or so, and holding it perfectly. So, FOR MY SET UP (so proceed carefully if deciding to try this), it appears that regardless of what boost I am targeting, setting my req load to 3 does not create any spikes or excess boost, weather I am aiming for 16 or 20 psi... God these cars are weird! |
![]() | | #215 | ![]() |
Needless to say, I had to check my underwear when I got home. I'm glad to see that you are getting you're tune ironed out the way you want it. | |
![]() | | #216 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score There was some discussion around the TRL X Gear Tables being active when using boost based tuning. By the looks of it, the TRL X Gear Tables are active in some MS3s and not in others. It is not yet known as to why this inconsistency exists. At any rate, I did some sensitivity testing on my '07 and found that the TRL X Gear Tables do affect the behaviour of the (my) engine. My findings are quoted below from another thread.
Side Note I'm wondering if this is a hidden gem for those still affected by the TRL X Gear Tables. I'm thinking they could be used to tame boost in colder weather therefore negating the need for a "cold weather" boost tuned map. It would work something like this: - Create a boost based tune that works well on your average hot day. - Modify the TRL X Gear Tables accordingly to fit the calculated load curve. - In colder weather, the ECU will cut boost in an attempt to meet the TRL X Gear Table values assuming it doesn't have to reduce boost by more than ~1.5PSI or so.
__________________ '07 CWP MS3 Forged. | ||
![]() | | #217 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score Just use the max load tables to keep the loads from getting too high if that is what you are concerned about. My "cold weather map" would consist of increased boost targets in the high rpm range and readjusted WGDC. You can make the WGDC adjust automatically for colder temps with the IAT compensation table, but you can't make your boost targets go up.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
![]() | | #218 | ![]() |
Maybe I'll need 3 maps. One "hot weather", one "cold weather" and one "below freezing weather". Haha.
![]() | | #219 | ![]() |
| Not Ranked : 0 score Below 50f probably. It depends on what temperature I start to see my WGDC below 70 in the upper rpm range.
![]() | | #220 | ![]() |
![]() Join Date: Apr 2010 Location: Kansas City, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 585
Groans: 39
| Not Ranked : 0 score Is there a good place on the WGDC Table to start populating numbers? Currently I've just been adjusting the numbers from throttle position 68.75 and up and then doing a vertical interpolation to the the lowest number that was copied over from the OTS map. What's the best practice here? @rfinkle2 , you did a vertical interpolation to 5's and 10's. How did you decide what throttle position to put these values at?
__________________ 2010 Silver Mazdaspeed3 |
![]() | | #221 | ![]() |
![]() | | #222 | ![]() |
I chose to put the max numbers in the 75 throttle position, although the 68.75 would be fine also, imo. I logged some data while shifting, and wanting to get as smooth a transition as possible into boost after shifts. I also wanted to keep the car from part throttle boosting in low throttle positions, and I never shift after 3000-4000 if I'm driving around town. ( you can see me trying to close the wastegate earlier in low throttle positions after 4000 rpms's ) I used the 10's @ top of each rpm to vertically interpolate from the largest to smallest (10) values, and to try and create a smooth onset of boost in the case I just decide to punch the throttle in any gear. | |
![]() | | #223 | ![]() |
IMO, i've seen alot of inconsistencies with boost based tuning in the car's i've been tuning. On quite a few, the TRL gear tables were indeed "limiting" the boost, and when set to 3's, all was well. Other cars, like many have said, have had no problems at all. Another thing i've noticed on a few cars is lagging AFRs when initially going wot. They seem to linger around mid 12's before finally hitting target. I've even bumped that portion of the maf curve up twice on guy's map to help get them down faster, but it made no difference. For what it's worth, i've returned to load based tuning, cause honestly, it was never really that difficult for me, and always much much more consistent.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
![]() | | #224 | ![]() |
Groans: 39
__________________ 2010 Silver Mazdaspeed3 | |
![]() | | #225 | ![]() |
Gen2 (@ least) me, has never been through load based tuning, and we all have ots values in our load tables (much lower than 3 lol). I believe this difference is THE main factor that caused all of our boost target and control issues (not achieving boost targets etc), although some have not had any issues. @Ckmazdaspeed3 made this change and it solved all of his issues. I believe he, you and Joel are collaborating (lucky bastard) | |
![]() | | #226 | ![]() |
Groans: 39
![]() | | #227 | ![]() |
![]() | | #228 | ![]() |
IMO, load cap was the leading cause of blown motors back in the day. The max load values should be set to something very high, like 3, 4 or 5. Something unachievable. If a person is worried about hitting too high of a load, he needs to use proper WGDC values, and boost dynamics / load dynamics to keep it low.
Is the boost lower on hotter days or colder days. If it's hotter days, then it's WGDC limiting you, if it's colder days, it's TRL tables holding you back.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |||
![]() | | #229 | ![]() |
if so, i expect my next map to be on point! ahahaah jk mang.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost | ||
![]() | | #230 | ![]() |
| Not Ranked : 0 score I believe, given this information, if people decide to do this, one should make appropriate changes, and adjust back to more aggressive wgdc, boost targets, and afr's etc. after seeing its effect on the car / tune and logs. e.g. I hit boost cut for the first time when I tried inserting values of 3. |
![]() | | #231 | ![]() |
| Not Ranked : 0 score Can't wait to do some WGDC analysis Soon enough i'll get you a couple maps for comparison sake.If that's the case, there's really no way to have higher boost in colder weather, and lower boost in warmer weather. The closest you could do is have 2 seasonal tunes, one that takes advantage of the more efficient turbo in colder temps, and runs more boost, and one that reduces boost in warmer temps to avoid over working the turbo (or at least what we currently believe to be over working the turbo, aka pegged wgdc). But with such drastic temp changes in a single day, you'd have to switch your maps at lunch time :-P Hahaha, or get an after market EBCS that you can adjust on the fly haha.
![]() | | #232 | ![]() |
![]() | | #233 | ![]() |
Very important note here. Go back to very conservative WGDC and boost target values before doing anything like this.
The better approach is to get a turbo that you don't have to baby sit so much. If your going BT, then i wouldnt' bother. You'll just simply run higher boost in warmer weather ![]() In fact, when a properly sized turbo is fitted to the car, that's when load based tuning really shines, cause you can tune the car to achieve a specific airflow (power level), and you'll get it regardless of temperature etc. Lower boost in winter, higher boost in summer, but the same airflow year around. I'm being overly simplistic, and nothing in life is truly that easy, but it's still food for thought
![]() | | #234 | ![]() |
![]() | | #235 | ![]() |
Groans: 134
| Not Ranked : 0 score DJ, is a 2871 considered a "proper sized turbo", to take advantage of load based tuning? |
![]() | | #236 | ![]() |
| Not Ranked : 0 score I think it's a great fit for our motors. It all depends on your goals. for 350-380whp, 2871 is perfect. You just don't want to end up with another turbo that your having to push as hard as you do the k04. So it's important to know your goal, and choose a turbo with a lil bit of head room.
![]() | | #237 | ![]() |
![]() | | #238 | ![]() |
![]() | | #239 | ![]() |
| Not Ranked : 0 score EDIT: I pm'd him and he said there is no appreciable difference in his opinion with the stock turbo 2 vs. 3 port solenoid. |
![]() | | #240 | ![]() |
| Not Ranked : 0 score well ive been sitting here all day being bored as shit so i decided to tweak my WGDC/Boost dynamics/Boost Targets and i did a little timing tweak. And what can i say, I think it worked extremely well. I only lowered my Boost targets by .25 from 5500rpm and up I lowered my WGDC tables by 5* from 6000rpm up. I also made my boost dynamics table look the same as finkles. attached are screen shots of my tables and a 4th gear log. How u like me now? Ambient temp according to my car was 74 degrees. Edit: After looking at my log again im maxing out my WGDC @ 94.01, I actually think i might be able to put my boost targets back up .25 from 5500rpm and up and still be under that 99% WGDC, thoughts?
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
