![]() | | #281 | ![]() |
| Not Ranked : 0 score
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost | |
![]() | | #282 | ![]() |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score On a Ko4, yep. Although I wanted more of course, it had been mentioned earlier by wiser members not to expect too much.... The gains off of a bigger turbo will of course be greater, but I'm not sure if we are going to take the time to remove, dyno, reinstall, because it's a pita... once the 2871 is on, that is. Now, I did not manipulate the tune to be more biased. This is ots tune (not designed for ex mani) with manipulation of wgdc, req load (to hit desired boost) and leaned out by like .5 (which I'm told does very little w/o timing). Timing and other more complicated parameters were not touched... who knows, maybe if I had worked with timing and other things before adding the ex mani, it would have had more effect on the redyno after the mani. I have no idea if adding an ex mani would have given me more room to add power in other areas of the tune??? ... sorry for the thread jack. |
![]() | | #283 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score When the flow restriction is the turbo, improving things like the ex mani is not going to make much of a difference.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
![]() | | #284 | ![]() |
I wish you nothing but the best of luck with your turbo swap. I am really interested in seeing your new numbers and impressions. | |
![]() | | #285 | ![]() |
| Banned ![]() Join Date: Nov 2010 Location: Valley Park, Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,461
Groans: 126
![]() | | #286 | ![]() |
First, I apologize for using the wrong terminology (I should have used "limit" rather than "cap") (this is not in the interest of saying I told you so, but I feel like this point may be missed by gen2 guys who are using ots values in their throttle req load -x gear tables.) YOU WILL have an easier time tuning your boost curve if you set the table values to either 2.3 or 3. (depending on your setup and observed calculated load.) PLEASE LOWER YOUR WGDC TABLES AND TAKE THE NECESSARY PRECAUTIONS WHEN DOING THIS. IT WILL INCREASE YOUR BOOST LEVELS ON MANY CARS. Some of you have already done this, and others have not. IMO, there is now solid evidence that the throttle requested load x gear values ARE affecting your boost levels if left OTS. Please hear this out... Above is a post from arguably THE most respected tuner on the forum. Below is a collection of posts and data that back this up from the likes of Forzda, Fobio, DJ, Bluestreak etc. http://www.mazdaspeedforum.org/forum/foru...tml#post817485 Gen 2 Cobb ATR discussion Gen 2 Cobb ATR discussion http://www.mazdaspeedforum.org/forum/foru...tml#post820752 http://www.mazdaspeedforum.org/forum/foru...tml#post820330 http://www.mazdaspeedforum.org/forum/foru...tml#post817576 @Ckmazdaspeed3 was able to solve his problems after changing his throttle - req load x gear tables also. Happy boosting! | |
![]() | | #287 | ![]() |
![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,323
| Not Ranked : 0 score Did you go to 2.3 load from 3k-7k in all the gears or just 2-5 or something? What about the high BAT TRL X gear tables, did you keep them OTS? Thanks,
__________________ www.MOTOIQ.com Beater Titan |
![]() | | #288 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score I changed mine from 3rd up. Traction issues in 1 - 2, don't need more power there. Leave the high BAT tables alone, they are to keep your car safe in hot weather. If you have some really hot days, you may be able to fine tune those though. |
![]() | | #289 | ![]() |
| Not Ranked : 0 score Thanks Wolly, I'm in the east county of San Diego, it can get to 100+ on the worst days in the summer.
![]() | | #290 | ![]() |
![]() | | #291 | ![]() |
Groans: 134
For all gears that I changed, I raised 3000rpm-6500rpm up to 3. I did not change 7000, but I'm guessing that wouldn't really matter either way. | |
![]() | | #292 | ![]() |
| Not Ranked : 0 score i also changed 2-6 from 3000 rpm on. I should have some logs tonight sometime, i still think im going to have to tweak my WGDC a little. Maybe ill get lucky with my first revision. haha
![]() | | #293 | ![]() |
| Not Ranked : 0 score If you change all to the same values, you can get your boost dialed in perfect. changing those values will allow you to have an easier time hitting targets. @Nataphen has used the APP translation to then limit his boost per gear. |
![]() | | #294 | ![]() |
This I know ive only tweaked 5500 rpm up since it was targeting 50 from the OTS map, I now have it down to 40 and slowly decreasing with less throttle position. I think i might need to lower it some more, but well see.
![]() | | #295 | ![]() |
Then, I would get your boost dialed in 3rd and 4th gear. After that I would use the APP translation tables to limit boost in first and second gear (if you choose). | |
![]() | | #296 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
(Thread Starter) | Not Ranked : 0 score Make sure that your CL max throttle is a little lower than what you set your APP to in 1-2, or your car will never enter OL fueling and you will be very rich. Also make sure that your AFR targets are where you want them in those ranges.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
![]() | | #297 | ![]() |
| Not Ranked : 0 score Nate, how do you have your first and 2nd gear app tables set up? |
![]() | | #298 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score I'm not at that point now because I sort of started over on my tune. I tried 50 max for 1st and 75 max for 2nd. I went from right at 20psi max to ~14 in 1st and ~17 in 2nd. I wanted to play with it some more, but I switched focus. At the drag strip, I'd probably go 100% in 2nd because I did fairly well with traction there. For the street, I may go even lower than 75% in 2nd.
![]() | | #299 | ![]() |
![]() | | #300 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score The only thing that I know for sure so far is that the CL max throttle has to be set right. I'll post up when I start to mess with it again.
![]() | | #301 | ![]() |
![]() Join Date: Mar 2010 Location: Fall River, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
__________________ -- 2010 MS3 Black Mica -- Ultimate Racing TP w/ Res delete, Corksport SRI+TIP, Turbosmart DP BOV, Autotech Fuel Pump Internals, Denso ITV22's, AP Tuned StagePu, custom painted headlights & decals. From Southern New England? Check out our local club! www.nescc.net | |
![]() | | #302 | ![]() |
| Not Ranked : 0 score Ok so i feel like im hitting boost cut in first gear now, but i did not change my req load first gear norm table... thoughts?
![]() | | #303 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Is your boost spiking above your fuel cut boost limit in 1st? EDIT: I gotta get to sleep, man. If someone else doesn't help you resolve the issue first, I'll get back with you tomorrow sometime.
![]() | | #304 | ![]() |
What values do you have in your boost limit- fuel cut tables? The fuel cut limits are usually about 2 psi above target boost, and if you have upped the boost target, you may be near the threshold. One thing to try is to give the right hand side of your boost dynamics table in the 1-3 psi overboost region (MAKE SURE TO RE-ENTER NEGATIVE SIGNS) a few % more authority. | |
![]() | | #305 | ![]() |
I had a feeling when ATR first came out that requested load per gear was affecting boost. Looks like it really is that way. AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3!
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
![]() | | #306 | ![]() |
The one time I hit fuel cut was @ 4 consecutive data points of around 20.43 psi, with a 20 psi boost fuel cut in the tables. | |
![]() | | #307 | ![]() |
| Not Ranked : 0 score After changing to 2.3 in the TRL X gear tables my problem with slowly building boost completely disappeared. I'm almost finished tweaking my WGDC table to hit boost targets with the BD table zero'd out. When that's done I am going to experiment and bring the TRL X gear loads back down to what I am logging calc. load at and see what effect it has. Thanks to rfinkle2 and everyone else for this tip, it worked perfectly on my car.
![]() | | #308 | ![]() |
I'm just glad to see that everyone's car is running well. | |
![]() | | #309 | ![]() |
| Not Ranked : 0 score Hey guys, A heads up. When I go to download the Cobb SF intake 93 octane map (stage 2), the 91 octane map downloads. |
![]() | | #310 | ![]() |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score Gay. Thanks for the heads up.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
![]() | | #311 | ![]() |
| Not Ranked : 0 score Ok so thanks to @rfinkle2 my fuel cut problem is fixed, just a little boost dynamic tweaking. But here are my latest logs a 3rd and 4th gear pull. The map Targets 20psi and drops to 17.50 by redline, my boost is literally spot on and my WGDC isnt pegging 100, i think the highest it got was 94, which i could lower but im content with where its at. enjoy! Ambient temp was around 85.
![]() | | #312 | ![]() |
| Not Ranked : 0 score I couldn't find my solenoid. I found an evo 8 one, but then gave it away to a guy with an evo 8 who i was mounting an ic core for. I'll look more this week, and try to kill it.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #313 | ![]() |
I have a ton of stuff to install this weekend, and when I put my Grimmspeed in, I'll send you my stocker. | |
![]() | | #314 | ![]() |
| Not Ranked : 0 score And then i will kill it, muhahahahaha. If i find mine before then, i'll let you know i don't need it.
![]() | | #315 | ![]() |
![]() | | #316 | ![]() |
| Not Ranked : 0 score i actually have one with a broken nipple, id just have to find it.
![]() | | #317 | ![]() |
| Not Ranked : 0 score Does anybody know how Ck made out this weekend installing his turbo? @Ckmazdaspeed3 , where are you???? We need impressions dammit! |
![]() | | #318 | ![]() |
Groans: 126
| Not Ranked : 0 score We were met with fail. His car is still in my garage on jack stands. I couldn't get the shit that I needed because of the fucking fail ass holiday known as Easter. Basically, we ran into some fucking issues with the install. I'm hoping that we can resolve them tonight. The install was slightly more retarded than I had anticipated. I'm almost starting to think that the genpu oil feed line is slightly larger than the gen 1s |
![]() | | #319 | ![]() |
![]() | | #320 | ![]() |
| Not Ranked : 0 score Oil feed? Are you talking about the banjo bolt? Or the line itself? You need a different banjo bolt for the Garret chra, but it would have come with the turbo likely. And depending on how everything is clocked, you may need to grind down one of the bolts that holds the compressor on (or hotside, i don't remember), in order for it to clear the banjo bolt. This is all from memory though, so take it with a grain of salt.
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
