![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
(Thread Starter) | Not Ranked : 0 score Some very helpful tuning threads. I recommend spending some time studying these in conjunction with the ATR help file before you go all in on your tuning. HOW TO CALIBRATE YOUR MAF! With An Example http://www.mazdaspeedforum.org/forum/foru...l-stuff-68239/ aka danos-boost-tuning-101-cool-stuff http://www.mazdaspeedforum.org/forum/foru...-thread-75524/ aka ziggos-boost-tuning-thread Should we increase timing?
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
Good idea Nate... As far as WGDC and the BCS maxing, please see this link... and ignore the bickering between me and some trolls. (post#35 if permalink fails) the grimmspeed 3 port boost solenoid (EBC) | |
Groans: 31
(Thread Starter) | Not Ranked : 0 score I've been thinking about making the switch to a 3 port, so that's some good info. I wonder why we have so much trouble with the BCS going to high WGDC, and gen 1s don't. I would assume that it's the same part. I guess that they could have changed it to a more finicky one along with the more picky fueling ECU logic that causes us to max out pumps more easily on gen 2. Gen 1 seems easier to tune, but gen 2 appears to have a little better airflow. Someone needs to tear both motors apart side-by-side, and measure/test/examine every part, then record all the differences so that some of these mysteries may be solved. Any takers?
![]() Join Date: Sep 2009 Location: Los Angeles, California
Rep Power: 442 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,334
Groaned at 72 Times in 51 Posts
| Not Ranked : 0 score Great! I'm still in the process of reading that helpfile.. I'm starting to get it a little though I recommend every ms3 owner to read it since it's really interesting and informative.The only thing I'm a little confused about is how to data log with ATR in the car properly. :hide:
__________________ 2010 Mazdaspeed3 Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18) |
Groans: 31
(Thread Starter) | Not Ranked : 0 score I have to order the dongle connector before I can DL with ATR. I've just be doing it with the AP and transferring, so actually using ATR will make it much easier.
LOL @ hiding... not from me or Nate... THE BELOW MAY HAVE JUST BEEN MY LAPTOP FML: Anyway, there are some bugs using the "pass thru", and it isn't very easy to stay connected right now, so I might wait. I've used it, and it will be great when you can log to your hard drive, but I've been logging to the AP because of the bugs. | |
| Not Ranked : 0 score Hahaha.. yeah I wanted to hide from members who will flame me saying "search you noob"! Anyway, so I guess I just do the data logging with my AP and transfer it to my home computer and work from there? I read in the helpfile that I need to do the data logging from certain RPM to certain RPM for MAF Calibration and other things. Can you guys help me out how to do on that? OR is it just like doing regular datalogging like 3rd gear 2500 to redline?
Groans: 31
(Thread Starter) | Not Ranked : 0 score You don't need to calibrate your MAF unless the STFTs and LTFTs are further off than the margin of error given in the help file. If they are, there is a great how-to sticky on MSF in the Cobb ATR support section. If you want to calibrate your WOT AFR, DJ made a post that finkle linked to a couple of days ago about that. I'm sure he can dig it up for you quickly if you need it. On a power pull, I usually pull from 3k in 3rd or 4th. 4th is the best, but there aren't many times around here that I can safely accelerate to 110+MPH. Log with the AP, plug the AP to the PC, and transfer your datalogs to your PC with AP manager. Use Xcel, Open Office, or ATR to view the datalog.
![]() Join Date: Apr 2010 Location: Kansas City, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 585
Groans: 39
For now I would just do some normal datalogging from 3k to redline or just before redline. Post your logs here and we'll help you decipher them and help you know what to look for. For now, I would follow this simple guideline: http://accessecu.com/support/docs/su...0Guidance.html This is pretty basic, but it's a good place to start. | |
| Not Ranked : 0 score @ your service sir...link from dj to come... italics from atr helpfile: This comparison only relates if you have an intake system that is other than stock; if your dictated A/F is 11.0 and you measure 12.0 in the exhaust stream, then you will want to add (+) grams/sec for the MAF voltage that corresponds for that RPM and load point. The specific adjustment for the above situation should be multiplying the corresponding MAF flow grams/sec by 1.0909 = 12/11. You should be measuring very close to the same Lambda (A/F Ratio) in your exhaust stream that you have dictated in your Fuel OL/WOT Commanded EQ (No Knock) table. Your trim values will always adjust back and forth (+/-); let them, that is what they are supposed to do. You should not have to modify the MAF Calibration table if you have a stock vehicle. We highly suggest you do not spend excessive time tuning your MAF Calibration table just so the A/F output matches exactly what is dictated in the Primary Fuel table. You will chase your tail getting it spot on then you will fill up at a different gas station that will have a different quality fuel and the targets may be slightly off. Could not find exact post from DJ (aka dustin) but, thanks to @dougefresh_ for this great thread... HOW TO CALIBRATE YOUR MAF! With An Example |
![]() Join Date: Jun 2010 Location: Toronto, Ontario, Canada
Rep Power: 297 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 899
| Not Ranked : 0 score Do you guys use a laptop to log or play around w/ ATR? I usually take my logs home to my desktop before messing around w/ stuff. Would a netbook work or is that too weak? |
| Not Ranked : 0 score ^ They just said there's a bug with using ATR in the car or something. Just do the log with your AP and transfer it to your home computer.
Thank you very much guys!! Will do a proper data logging this weekend and post it here to see if I need to calibrate anything with ATR. I am waiting for that autotech internal to be available again on April 30th... so it should be more fun after I get that baby in.
__________________ 2010 Mazdaspeed3 Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18) | ||
| Not Ranked : 0 score As far as the bug, it may have been just my laptop. I thought I remembered reading about a bug, but cannot find the thread now. I COULD HAVE BEEN MISTAKEN, AND THERE MAY BE NO BUG IN THE PASS THRU COMMUNICATION...sorry You guys can always try logging to the laptop and lmk how you make out. MAKE SURE YOU LOG 1st, and not flash. You don't want to get .5 way through a reflash and lose ecu communication. |
| Not Ranked : 0 score Just did two datalogging during my lunchtime lol im currently running Stage2+cpN+TIH 91 v100 BT Safe Mode map. My mods are in my sig. It was 3rd gear pull from around 3000rpm to almost redline.
| Not Ranked : 0 score I'm seeing consistent KR from 5000rpm to 6000rpm in datalog21.. Isn't this really dangerous?? And I'm only getting 14 psi when its targeting 15 psi.. hmm
Groans: 39
| Not Ranked : 0 score Your KR is under 2, so it's nothing to be too concerned about. Your AFR looks like it's following the fuel curve on the 91 OTS maps like it should. Your LTFT's are 3.91, so they're within the +/- 8%. It doesn't hurt to do a MAF calibration though. You might consider doing that as your next step. IIRC the safe maps target 12-14 psi. If you are actually targeting 15, you're not far from it. When you're ready to start using ATR to make adjustments to your map, you can bump up the WGDC% to help you hit your boost targets. I would suggest doing a Maf calibration next. Take a look at the link that @rfinkle2 posted above and let us know if you need any help. |
One question though, now with the safe mode, am I really SAFE to do a lot of spirited driving with many WOT? or should I take it easy until I get the fuel pump internal? Just curious. Because I can't stop driving my car hard now with the AP.
Groans: 39
| Not Ranked : 0 score I would continue to drive it hard until see the FP drop. You'll feel it if it drops too low. It's not a huge deal. It just means you need to adjust your map or go back to the stock tune. So yes, you're safe driving it hard. I doubt that you'll see the FP drop on the safe map. I would continue to drive the piss out of your car on the safe map until you feel comfortable getting into ATR and making changes to one of the maps. Personally, I started with the stage1 map, and "detuned" from there. You could do it that way, or you could take your stage2 safe map and increase the boost in small increments. |
![]() | | #19 | ![]() |
| Not Ranked : 0 score man you make so much sense. thank you so much! lol I think I'll start playing with the safe mode, just to be safe. :hide: I'll ask some questions on this Saturday when I start playing with the map.. I'm gonna try to read the helpfile and other ATR related threads couple more times before I mess it up.
![]() | | #20 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score Make sure your fp is fine before you start romping on it all the time though. I had fail fp even on the safe mode map. I was only "safe" after I leaned out the map a little in ATR. Even then, I couldn't go WOT in 2nd. |
![]() | | #21 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Start by leaning out your AFR targets to about 11.9 from 3k+, this will help with power and fuel pressure. It's the single most helpful thing that you can do to keep your stock pump in check.
![]() | | #22 | ![]() |
![]() Join Date: Nov 2010 Location: Ronkonkoma, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 917
Groans: 30
| Not Ranked : 0 score Subbed... Sent from my PC36100 using Tapatalk
__________________ I haz Partz!!!!!!!!!! [SIGPIC][/SIGPIC] |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Good stuff so far guys. I too am completely addicted to ATR. Looking forward to learning tons more. haha
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() | | #24 | ![]() |
| Not Ranked : 0 score I'd like to add essential links to using ATR if the guys and girls haven't already seen them... http://www.mazdaspeedforum.org/forum/foru...l-stuff-68239/ aka danos-boost-tuning-101-cool-stuff http://www.mazdaspeedforum.org/forum/foru...-thread-75524/ aka ziggos-boost-tuning-thread Should we increase timing? |
![]() | | #25 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score Very helpful links there, guys. I've picked up much information from those threads.
![]() | | #26 | ![]() |
Groans: 386
| Not Ranked : 0 score @rfinkle2 - Thanks for the timing thread, that was next on my research list... |
![]() | | #27 | ![]() |
Groans: 39
| Not Ranked : 0 score Guys, do you think it would be beneficial to add all of these links to the op? Or maybe create a sticky listing them? |
![]() | | #28 | ![]() |
Groans: 31
(Thread Starter) | Not Ranked : 0 score ^Good idea. Thank you, sir.
![]() | | #29 | ![]() |
| Not Ranked : 0 score @FORZDA 1 replied to this thread and I trust his judgement for anyone interested in methanol injection. I know some guys alreay have planned setups, but I think this link may help. Meth Injection: What is Really Needed? |
![]() | | #30 | ![]() |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
Groaned at 114 Times in 83 Posts
| Not Ranked : 0 score Forzda? Oh yea, the guy that just popped his motor
__________________ |
![]() | | #31 | ![]() |
| Not Ranked : 0 score I'll let others decide whether his recommendations are valid or not. He explains his catastrophic failure in the thread. http://www.mazdaspeedforum.org/forum/foru...nt-rods-77027/ |
![]() | | #32 | ![]() |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
![]() | | #33 | ![]() |
| Not Ranked : 0 score for reference, @djuosnteisn also blew his motor, and he is likely considered to be the best msf tuner. EDIT: this was in no way, shape or form an effort to disparage DJ (Dustins) ability to tune the DISI motor. It was simply an effort to note that things happen when pushing the limits of any platform, and to try and bring into context the shot taken @ Forzda earlier in the thread. |
![]() | | #34 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
![]() | | #35 | ![]() |
Groans: 386
| Not Ranked : 0 score Last night I raised the knock sensor max to 7k, and thought I would report my results. I have done 4 logs so far, and I get KR above 5900 rpm in all of them now. I had a few hits right at 1 - 1.2, and the rest is all <1 FWIW I was getting some KR in the 3 - 5k range before (usually <.8). I wonder if this is all false KE (hopefully)... To check this I should just pull a few * of timing from 3k up and log right? |
![]() | | #36 | ![]() |
Please note the edit to my post concerning DJ above. | |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Question, when I open up my stage2 safe mode map on ATR and look at the Boost Target table, the highest number is in the 100s. Did I do something wrong? Isn't my boost target ~15? lol
![]() | | #38 | ![]() |
Groans: 386
| Not Ranked : 0 score You need to enable standard units in ATR Edit -> Configure Options -> Display -> standard units should be checked. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Done. Thank you.
![]() | | #40 | ![]() |
Groans: 214
| Not Ranked : 0 score My bad, I walked into the lady's bathroom on accident
| Display Modes | |
| Gen 2 Cobb ATR discussion | Nataphen | 2010 MS3 - ECU Computer Tuning | 2261 | 05-12-2015 12:09 PM |
| Cobb Tuning Inlet Review Discussion | Haltech | Review Discussion | 62 | 06-03-2011 06:16 AM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Cobb AP Dyno Graph/Discussion | NYpest | MazdaSpeed 3/6 - ECU Computer Tuning | 212 | 05-13-2008 02:13 PM |
