| LinkBack | Thread Tools | Search this Thread | Display Modes |
11-14-2009, 06:41 PM | #1 |
Captain Join Date: May 2008 Location: Rio Rancho, NM
Rep Power: 15759 Thanks: 33,656
(Thread Starter) | Not Ranked : 0 score How to scale the HPFP pressure sensor Resistors don't work cause all they really do is alter how much current the sensor is sinking. . . . Long story short, you need to supply a scaled voltage to the ecu, and for this, we use an op-amp. I noticed that there was more than just a pull up on the ecu side, but also a significant resistance to ground as well, basically a voltage divider. I figured that this could be some sort of fail safe for a failed sensor. It's about 4.6k to the supply and 6.8k to gnd, which would result in a voltage of 2.92V reported to the ecu if the sensor were "disconnected". I figure this was put there for a reason, so i mimiced it in my circuit. There's not much to the circuit, for those DIY types, just a non-inverting op-amp with a adjustable voltage divider on the input. The circuit limits the amount of adjustment you have. So you can turn the scaling all the way off, basically running normal. Or you can turn it all the way up, but it won't let you turn it into the danger zone, lol. That's what the "limiting resistor" does. Here's a plot of the voltage output with the pot set to minimum (no scaling): You can see that Vout clips at just over 4V. This isn't an issue cause the ecu will never command more than 4V. Here's a plot of the voltage output with the pot set to maximum (full scaling): The full scaling is roughly 22% increase across the board.
Here's a vid of the circuit working on a bench, with a power supply acting as the sensor input: This is when i was about to put it on the car: And it on the car: Here's a vid with minimum setting and an idle injection pulse width: Here's a vid with maximum setting and an idle injection pulse width, you can see that the injection duration is indeed brought in. I'll do much more testing when i get my upgraded internals in and can actually drive the car without worry . I mentioned in the other thread, if it proves to be safe on my car, and enough people want to do it, but don't want to build their own, i can order some pcb's and parts and stuff. *disclaimer*: Don't do this to your car unless your willing to assume all responsibility of damage incurred from this "mod". This is thread is not intended to be an instructional "how-to". But... if you do choose to do it, GL and let us know how it works
__________________ 500awhp 440awtq uncorrected EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
11-14-2009, 06:52 PM | #2 |
Rep Power: 1087 Thanks: 2,958
Groans: 27
| Not Ranked : 0 score or you could just use the standback - awesome work tho - you're a really smart dude! - you think someone could use your chart there to help interpret what they would need to scale w/ the sb
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
11-14-2009, 06:58 PM | #3 |
(Thread Starter) | Not Ranked : 0 score Possibly. The charts are just simulations. Easiest to just use the fuel trims and re-cal the maf. Amazing how the standback had this feature all along, lol. When i get my upgraded fp, i'll do a couple dyno pulls comparing with and without the higher pressure. I'll also be doing alot more injector logging.
11-14-2009, 07:06 PM | #4 |
Rep Power: 0 Thanks: 9,229
Groans: 78
| Not Ranked : 0 score awesome work man, much respect for you
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
11-14-2009, 07:28 PM | #5 |
Rep Power: 2705 Thanks: 766
| Not Ranked : 0 score put me down for one
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
11-14-2009, 07:30 PM | #6 |
Rep Power: 0 Thanks: 27
| Not Ranked : 0 score That looks super legit man. Awesome job. How ironic that you figure out how to juice the fuel pump when yours is down for the count. I'm looking forward to seeing how far this can take the car. I've got a boost gauge you can have if you want to tune for 26 psi when your ish is back together. |
11-14-2009, 07:38 PM | #7 |
(Thread Starter) | Not Ranked : 0 score Let me test it out to completion first, and then maybe i'll be willing to order some boards and stuff. Or i may decide to change the circuit up depending on tuning etc. May be nice to use things like boost, rpm, maf etc along with the scaling, kinda like a slimmed down SB. We'll see.
11-14-2009, 08:25 PM | #8 |
Rep Power: 0 Thanks: 343
| Not Ranked : 0 score I vote we have mark test this out, I think he needs it the most |
11-14-2009, 11:06 PM | #9 |
(Thread Starter) | Not Ranked : 0 score I think he has the standback, right? Which is actually probably more capable than this circuit, but then again, this circuit is much cheaper than a sb, lol. I agree though, next step is a dyno A-B comparison with increased fuel pressure as only change. I'll def give it a go if nobody else does in the next couple weeks.
11-14-2009, 11:07 PM | #10 |
mark...you know you want to! | |
11-14-2009, 11:23 PM | #11 |
Groans: 27
| Not Ranked : 0 score silverdemon already did some real world testing - in the other thread - he got his car to dip down to 8 afr - scary stuff! - it just needs the hand of tuner - even tho i'm bailing on the car i'm still pumped to see what mark can do with way more fuel and the massive air coming form the freggin gt40- can't help but plug - i haz sb for sale cheap - see part out thread
11-15-2009, 12:46 AM | #12 |
Engineered Tuning Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 12034 Thanks: 6,485
| Not Ranked : 0 score Excellent work Dustin - glad you can get the circuit together in 1 day. EDIT - couple of notes: I like that you used a high limiting resistor to not load the output of the sensor. In terms of mimic-ing the 4.6k - 6.8k divider for some sort of failsafe (the 2.92V) - it's probably not necessary as that will be scaled if the pot is anything but 0 and the ECU won't see that voltage value even if the sensor is disconnected. |
11-15-2009, 02:03 AM | #13 |
Rep Power: 0 Thanks: 761
Groans: 190
| Not Ranked : 0 score +1 on the nice work. I would like to see how much the injector pulse width changes in the high RPMs.
__________________ My mission is to go fast. Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
11-15-2009, 06:21 AM | #14 |
Rep Power: 4725 Thanks: 5,721
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
11-15-2009, 08:30 AM | #15 |
| Not Ranked : 0 score SilverDemon, we're all aware, especially djuosnteisn, that the increased pressure needs to be tuned for, and that, by itself, it may not lead to any increase in power. But, if it works as expected, with no surprises, it's the the answer to increasing fueling needs to make big power on the MZR. Dustin, I was just thinking of the tour of your shop you gave me a while back. You need to hijack some resources to build some slick as shit, plug and play HPFP scalers. You're perfectly set up to do it. First one to do it makes the big bucks. |
11-15-2009, 08:45 AM | #16 |
Rep Power: 0 Thanks: 2,896
11-15-2009, 09:10 AM | #17 |
Speeeeeed Join Date: Mar 2008 Location: Corpus Christi, Tx
Rep Power: 7490 Thanks: 6,190
| Not Ranked : 0 score There isnt a vid of this, but supposing that the 22% pressure increase does corrilate to ~11 lower injector PW, then we should get 11% more power. Our injectors max around 420 crank hp, so 420*1.11=466 crank hp *.8 = 372whp @ 7000rpm. Or, if we lower the rpm peak to 4500rpm with the formula 4500/7000=.642, 1 -.642 = .358 + 1 = 1.358 * 372whp = 505whp @ 4500rpm. Or, if we lower the rpm peak to 5500rpm with the formule 5500/7000=.785, 1 -.785 = .215 + 1 = 1.215 * 372whp = 451whp @ 5500rpm.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
11-15-2009, 10:07 AM | #18 |
Rep Power: 2468 Thanks: 810
Groans: 60
| Not Ranked : 0 score That is rather convienient..
11-15-2009, 10:38 AM | #19 |
I'm stoked that it seems to work. Wish i could drive around with adam and the scope now, lol, but we will as soon as i get my new pump. In the mean time, i was thinking of building up like 5 or so, and letting some people beta test if they want, at their own risk! Haha, can't add enough disclaimer to this, cause it's definitely experimental research at this point. The 5 wouldn't be beautiful PnP units, they'd be ugly like mine, haha, and require soldering probably. And i honestly think they should go to some people pushing the limits of our power thus far, like socks, and definitely mark if he wants to try. And anyone else really. I may ask for some money for the time to build them and parts and shit.
11-15-2009, 11:05 AM | #20 |
Rep Power: 573 Thanks: 120
| Not Ranked : 0 score I'll take one. |
11-15-2009, 11:29 AM | #21 |
Rep Power: 3292 Thanks: 5,280
| Not Ranked : 0 score This is not true. Hence, why people (like me right now) are running a stock FP and dropping to 400psi or less WOT but, still holding AFR's in the low 11's and even 10's. There is a table that we can't see yet with ATR that must control this compensation, it's been talked about some in a couple other threads. |
11-15-2009, 11:34 AM | #22 |
| Not Ranked : 0 score Sorry, I have done a little testing where all I did was increase pressure and the AFR went to 8.xx
11-15-2009, 11:36 AM | #23 |
| Not Ranked : 0 score A couple of things to keep in mind. The car will target certain AFRs using more variables than just pressure, MAF, and boost. It's a little more complicated than that. The AFR you read from the O2 sensor does not tell you the whole story about what is going on in the combustion chamber. |
11-15-2009, 11:41 AM | #24 |
| Not Ranked : 0 score Exactly, but how else are you going to measure what is going on inside the combustion chamber?
11-15-2009, 11:48 AM | #25 |
Rep Power: 0 Thanks: 31
__________________ 2007 Mazdaspeed3 Sport, True Red | |
11-15-2009, 11:59 AM | #26 |
Rep Power: 4481 Thanks: 16,850
Groans: 778
| Not Ranked : 0 score i'll take when ur ready to build
__________________ 2003 SilverStone Grey Honduh S2000 |
11-15-2009, 12:05 PM | #27 |
11-15-2009, 12:17 PM | #28 |
Groans: 60
| Not Ranked : 0 score Watching EGT's as well as the wideband is the best method any of us are ever going to have... Unless you want to mortgage your house and buy some real testing equipment..
11-15-2009, 12:20 PM | #29 |
11-15-2009, 12:29 PM | #30 |
To be honest I'm way more interested in what dustin can come up with than p3. | |
11-15-2009, 12:38 PM | #31 |
11-15-2009, 01:11 PM | #32 |
Groans: 27
i think the answer is that jordan isn't with cpe anymore - from my understanding lou was the one that origionally cracked the ecu for the ms3 and developed the sb - that's not to say that he was the one that got into it's full capabilities - i think jordan had a hand in tuning that robbie guy's car in college park md w/the sb - and to date it believe it's still the record for most hp - like 410 w/out nos or meth - i would have like to have seen the tables on that tune - i think the real question is who has gone to cpe/p3 and really ponied up all money they want for all the stuff they can do - and what can they do now that jordan is gone and just the folks that are using what he developed are left? so is that all that's left at cpe/p3 tuners who don't know about di???? - if i'm wrong prove me wrong - somebody's gotta know what's going on there with all the rumors of what' s to come... when you show the average tuner around the sb (which i have done locally) - they think in terms of only what a piggy back can do, and they probably don't think in terms of the complex di system on the ms3 - they prob think in terms of what piggy backs do on port injected cars - which means stick to tricking the maf for fuel and tricking the cps/csps for timing, add fuel & if you get knock pull timing, and if you need more fuel just get bigger injectors - well the rules change with di - the injectors are already supposed to push tons of fuel - so then you have look at the complicated, most likely load based equation that is involved in fuel pressure and who really knows how to do that? why did lou put the table there if jordan didn't know how to use it? look this idea to me is like using a maf clamp instead of tuning - you can get the job done, but it's like a broad sword when you need a razor - no disrespect to dj here - he's way smarter then me to have come up with this, but i gotta say you have to be able to get further with the sb dialing in exactly what you need granted this is some serious speculation too, but when all the factors are presented to me, these are the conclusions i draw...
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) | |
11-15-2009, 01:44 PM | #33 |
Part of me almost thinks that having the capability to vary the pressure at different load points, or rpm or whatever, only complicates this approach. Sometimes simpler is better, imo.
11-15-2009, 02:57 PM | #34 |
Groans: 27
| Not Ranked : 0 score i think what's talked about here will prove to be superior to anything - the only other thing that could be as good is the mazdaedit software discussed here: MazdaEdit is available nobody is interested in this though... so many are cobb fanboys i have been researching cars in the hopes i will move to another platform - i think the real secret to the cobalt reaching over 500 is these guys HPTuners.com >> Performance At Your Fingertips piggybacks or flash devices are great - but i just don't see anything better then getting in there and really re-writing existing ecu tables - besides of course running all the sensors from a standalone
11-15-2009, 03:16 PM | #35 |
| Not Ranked : 0 score Yeah it would certainly be ideal if Christian / Cobb could find the parameter for the fuel pressure so we dont have to dance around it. But i think DJ's stuff will work just fine if tuned for. |
11-15-2009, 04:30 PM | #36 |
Groans: 60
He could not produce a screenshot, and then stopped responding to my PM's on his forum...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
11-15-2009, 04:37 PM | #37 |
| Not Ranked : 0 score cpolly and myself talked to him in person, I was all for doing it as well, but he wants a bone stock car to work with, I guess so he can see what can be done with it before any bolt-ons are added
11-16-2009, 11:38 AM | #38 |
Rep Power: 0 Thanks: 53
11-16-2009, 12:30 PM | #39 |
Rep Power: 0 Thanks: 263
Groans: 75
| Not Ranked : 0 score | |
11-16-2009, 12:39 PM | #40 |
| Not Ranked : 0 score Ohh and one more thing. Matt @ Zzp said "we are considering working with the mazdaspeed platform" |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread | Thread Starter | Forum | Replies | Last Post |
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? | AFcadet | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 08-02-2019 11:09 PM |
TIRE PRESSURE SENSOR... | redneckrecon | MazdaSpeed 3/6 - Wheels & Tires | 12 | 01-21-2011 07:23 PM |
How to scale the HPFP pressure sensor | djuosnteisn | MazdaSpeed 3/6 - ECU Computer Tuning | 521 | 04-07-2010 08:39 AM |
