| LinkBack | Thread Tools | Search this Thread | Display Modes |
01-06-2010, 07:30 PM | #481 |
Rep Power: 0 Thanks: 761
Groans: 190
| Not Ranked : 0 score The PLC series auxiliary valves are direct acting, factory-set pressure relief valves of the cartridge type that can be supplied with or without a threaded plug. They can also be supplied with housings to facilitate in-line installation. PLC valves are intended primarily to act as combined pressure-relief and anticavitation valves - otherwise known as port relief valves - in the service ports of our directional valves. However, they can also be used to advantage in other situations where pressure relief valves in this size range are required. Features * Small dimensions - easy to install * Single unit - facilitates installation * Very tight - no unnecessary leakage losses * Small pressure change between different flows * Low hysteresis - good precision in pressure maintenance * Fast acting - reacts quickly to pressure surges * Setting locked by welding - prevents undesirable changing of pressure setting
__________________ My mission is to go fast. Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
01-06-2010, 07:42 PM | #482 |
Captain Join Date: May 2008 Location: Rio Rancho, NM
Rep Power: 15759 Thanks: 33,656
(Thread Starter) | Not Ranked : 0 score One thing to keep in mind while valve huntin, is that the valve must be gasoline tolerant. Also, some manufacturers cringe when you mention gasoline or automotive, mainly for liability reasons.
__________________ 500awhp 440awtq uncorrected EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
01-06-2010, 07:54 PM | #483 |
Rep Power: 4725 Thanks: 5,721
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
01-06-2010, 08:10 PM | #484 |
Groans: 190
| Not Ranked : 0 score The guy at Parker said they have an adapter for it and it will thread right into the old spot. He's gonna look for it while I'm on holidays.
01-07-2010, 03:10 AM | #485 |
| Not Ranked : 0 score Cool!!! Thanks for taking the time to look around.
01-07-2010, 05:19 AM | #486 |
Rep Power: 334 Thanks: 247
| Not Ranked : 0 score I don't know how hard it would be but would converting the fuel system to a return style setup eliminate this relief valve? Once the valve is gone then some tuning would be needed to tell the ECU to stop looking for it. Nevertheless this is really interesting to follow and I hope you guys get this figured out. |
01-07-2010, 06:58 AM | #487 |
Groans: 190
EDIT: I think you would still need a relief valve to relieve the pressure in the rail.
__________________ My mission is to go fast. Currently Designing: The golden girdle of the gods The CF "fuck your face" IM | |
01-07-2010, 08:15 AM | #488 |
01-07-2010, 08:26 AM | #489 |
Groans: 190
*edit: sorry I got valves mixed up.
01-07-2010, 08:47 AM | #490 |
(Thread Starter) | Not Ranked : 0 score Phantom nailed it. Even on my pre-ckt logs i've seen 2100psi during throttle lifts. And 25psi is fucking nuts.
01-07-2010, 08:51 AM | #491 |
Groans: 190
| Not Ranked : 0 score CUZ KNOWLEDGE IS POWER!
01-10-2010, 07:36 PM | #492 |
Rep Power: 2705 Thanks: 766
| Not Ranked : 0 score soooo wait for you, or get a ptp relief valve...
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
01-10-2010, 07:41 PM | #493 |
Approved MSF Vendor Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 Thanks: 425
| Not Ranked : 0 score Not sure what you guys need this for? We aren't modifying the relief pressure at all. |
01-10-2010, 07:47 PM | #494 |
(Thread Starter) | Not Ranked : 0 score Yup, that's what sean told me. Great news IMO!
01-10-2010, 07:48 PM | #495 |
Rep Power: 1087 Thanks: 2,958
Groans: 27
| Not Ranked : 0 score so, is the speed6 different? or does the relief valve just not come into play?? just how far can the stanback scale the fps vs. dj's ckt?
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
01-11-2010, 04:20 AM | #496 |
| Not Ranked : 0 score DJ's circuit doesnt do what our setup does. It is compeletely differrent. I wish it was that easy but the standback doesn't just scale FP as straight forward as you'd expect. We do a lot of other things behind the scenes as we play with pressure. Simply playin with the pressure with the circuit wont do whats required to make certain things happen. |
01-12-2010, 10:39 AM | #497 |
Rep Power: 0 Thanks: 305
| Not Ranked : 0 score It was my understanding that there are several variables to our fueling system. 1. Fuel Pressure 2. Injector Pulse Width 3. Injector Spray Pattern - My understanding, which I am not sure of, is that our fuel injectors are capable of not only controlling length of fueling, but also spray pattern for optimal combustion |
01-12-2010, 10:43 AM | #498 |
Rep Power: 0 Thanks: 120
__________________ Kriebs Speed and Power Development. AIM: KriebsSPD | |
01-13-2010, 05:37 PM | #499 |
| Not Ranked : 0 score I wanted to let you guys know that I have not forgot about the pressure relief valve....I talked to the vendor today to get an estimation of delivery for the first set up, he said he was going to contact them and me know. He said in the past that it takes about 2 weeks to get a custom RV from them. It is now been a week.....More to come!!
01-13-2010, 05:48 PM | #500 |
(Thread Starter) | Not Ranked : 0 score Cool. PTP has begun selling their valves. I'm curious how that all pans out, but it's still a real good idea to keep on your guys. Thanks again man!
01-13-2010, 05:54 PM | #501 |
| Not Ranked : 0 score I would like to see a pic of the ptp RV........There was only one company (that I could find) that would completely custom make a valve for our application......
01-13-2010, 06:22 PM | #502 |
Rep Power: 4481 Thanks: 16,850
Groans: 778
but tell him ty anyways =)
__________________ 2003 SilverStone Grey Honduh S2000 | |
01-13-2010, 08:57 PM | #503 |
Groans: 27
| Not Ranked : 0 score yeah because competition DECREASES productivity - RIGHT? Are you kiddin me - ZZP is nasty - take a stole thru their website and look at their accomplishments on the lnf & lsj platforms - not to mention do a little comparing to their staged kits compared to GM's for the lsj It would be sweet to get those guys working on MS3s and give CPE a run for their money...
01-14-2010, 04:59 PM | #504 |
Groans: 778
and pleaseeee can we stop all this MS3 shit and just say MZR or "speeds" not everyone has a speed 3. I hope they take on the 3's and 6's and we have more then a few good companies makin hard parts and tuning solutuons for us. =) love u my gizzard polly C wallE a lizards in tha wizards gizzards and blizzards!
01-22-2010, 02:36 PM | #505 |
| Not Ranked : 0 score Well, for what it's worth......Here is the pressure relief valve and block. I know the block is huge compared to the factory valve, but I bought the block so I could get the measurements to make one to fit my application.
01-22-2010, 02:48 PM | #506 |
(Thread Starter) | Not Ranked : 0 score Can't wait to see what you come up with!
01-22-2010, 05:38 PM | #507 |
Eth/Meth Junkie Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 Thanks: 1,846
| Not Ranked : 0 score Looks quite nice. Now install dem bitches and link the pics...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
01-22-2010, 05:55 PM | #508 |
| Not Ranked : 0 score Not a problem man!! I have the weekend off, and hopefully I will get the intake mani off so I can find out what type of adjustments I will need to make to the new valve block.
01-22-2010, 06:01 PM | #509 |
(Thread Starter) | Not Ranked : 0 score It's gonna be a tight fit with the fuel hardline wrapped around the valve, but i have no doubt in my mind you'll come up with something awesome!
01-22-2010, 06:09 PM | #510 |
| Not Ranked : 0 score Yeah, I figured it would be a bitch, and I hope it will be as easy as just milling off some of the extra material on the block. But, as everyone knows that working on this car is not easy!!
02-16-2010, 11:00 AM | #511 |
| Not Ranked : 0 score ok so what are we doing with this, will this have any bearing on scaling down the load plateau with the AP?
02-16-2010, 11:43 AM | #512 |
(Thread Starter) | Not Ranked : 0 score I'm glad you asked: Fits inside this box: http://www.hammondmfg.com/pdf/1593S.pdf The battery slider door will be used to access the buttons and leds for programming the unit. And all wires will go in and out the opposite side. I still haven't found oem connectors, but i haven't really tried. I'm sure it'll be easy to find something that will work without too much cutting and stripping wires. I know i dropped the ball for a while. Life has a tendency to catch up with me sometimes. But i'm 99% sure i'm done with the design (not really complicated at all), so i think i'll order some boards today or tomorrow. And then i can whip out some simple firmware and hopefully beta test on my own car at some point. I'll build up 5 at first i guess. We'll see how much they end up costing. Sorry for the lack of updates guys!
02-16-2010, 03:15 PM | #513 |
Rep Power: 1818 Thanks: 1,848
| Not Ranked : 0 score Holy shit that's awesome. |
02-19-2010, 12:05 PM | #514 |
(Thread Starter) | Not Ranked : 0 score Ordered 2 boards today, just to proof it all out and make sure it works like expected. If it does i'll order quite a few more. We'll cross that bridge when it comes. I ordered through BATCHPCB, for any of you who want cheap pcb boards. They take a lil longer to get (2-3wks typical), but are amazingly cheap. I think they wait til they get enough boards from a bunch of different people and then submit all at once to keep the price low (they have an arrangement with some chinese board house, works for me). Can't argue with $2.50 / sq inch. Once they come in i'll whip up some simple firmware and test it out on the bench. And i'll probably look into a way to hook up to the oem connectors without cutting splicing.
02-19-2010, 12:11 PM | #515 |
Rep Power: 3292 Thanks: 5,280
| Not Ranked : 0 score no cutting = I can test tooooo!!! |
04-06-2010, 07:54 PM | #516 |
Rep Power: 0 Thanks: 9,578
| Not Ranked : 0 score Holy McGuyver on Crystal Meth!! Brilliant work DJ!! ...too bad I was lost in the OP! lol I'm hoping this only necessary for people with larger injectors to communicate fueling properly with the ECU, and not for noobs like myself who just need an upgraded HPFP?! From what I read in ATR the hpfp will affect my FT's, and I thought a simple MAF recal would address that np. Is this just for larger injectors, or am I missing out on something here? Man, you're a lot smarter than you look! haha j/k
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
04-06-2010, 07:59 PM | #517 |
| Not Ranked : 0 score no such thing as larger injectors
04-06-2010, 08:09 PM | #518 |
Rep Power: 2468 Thanks: 810
Groans: 60
04-06-2010, 10:54 PM | #519 |
(Thread Starter) | Not Ranked : 0 score Only one such thing as bigger injectors, and SS has em.. For the rest of us... no such thing... Doug, the advantages are there for stock injectors as well. What this thread basically showed was that the stock injectors would actually flow more fuel with increased rail pressure. To some extent, it shows that fueling isn't quite yet an issue, but as we all know, we are getting fairly close. Many of us agree that the earlier you can get the fuel into the cylinder, the more time it will have to mix with the air and become homogeneous and provide a much better burn. It hasn't been quantified yet, power wise, but at least the fueling benefits have been shown.
04-07-2010, 03:38 AM | #520 |
Groans: 778
| Not Ranked : 0 score may I ask why whoosh or whoever else wont take on the task of doing the injector porting for others.???
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread | Thread Starter | Forum | Replies | Last Post |
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? | AFcadet | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 08-02-2019 11:09 PM |
TIRE PRESSURE SENSOR... | redneckrecon | MazdaSpeed 3/6 - Wheels & Tires | 12 | 01-21-2011 07:23 PM |
How to scale the HPFP pressure sensor | djuosnteisn | MazdaSpeed 3/6 - ECU Computer Tuning | 521 | 04-07-2010 08:39 AM |
