 Old 12-01-2009, 12:02 PM   #241
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Well looks like the stock orifice is roughly 3/16" (0.1875") from this pic and ignoring parallax and lens distortion lol:
If i used a 1/8" (0.125) hole, it would reduce the area by just over half. I guess i'll try that first.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
djuosnteisn is offline
 Old 12-01-2009, 12:24 PM   #242
Realgib3's Avatar
Posts: 2,443   (View Stats)
Good work as always! How ironic that we were just talking about the intake mani and uneven flow yesterday...
Realgib3 is offline
 Old 12-01-2009, 12:34 PM   #243
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
3/32" or 3/16"?
3/32" or 3/16"?
I'd go for 1/16th, thats the smallest bit i have in my set.
socks is offline
 Old 12-01-2009, 12:38 PM   #244
Deadman's Avatar
Posts: 868   (View Stats)
i think the pic is deceiving... dustin did you measure the orifice with calipers by any chance? Or just guessing off the tape? If you have a set of calipers they may reach in there (from the reverse side) and give you exact measurement
Deadman is offline
 Old 12-01-2009, 12:42 PM   #245
Captain
LOL, i can't even count tick marks on a measuring tape, much less use calipers, haha.
definitely 3/32, and yeah, 1/16" would probably work fine, lol.
Oh and 1/16" is down to 62 thousandths, so were approaching the 50 thou mark i originally mentioned, which hopefully isn't too small to function.
3/32 to 1/16 results in an area reduction of .006903 to .00306, or again, just over half.
www.permtuning.com
 Old 12-01-2009, 02:39 PM   #246
dan7225's Avatar
Posts: 511   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
Groaned at 20 Times in 11 Posts
looks like 3/8" to me.
oops, you were talking about the hole inside the hole!
dan7225 is offline
 Old 12-01-2009, 04:17 PM   #247
socks's Avatar
Groans: 125
dustin, did you see any markings on that valve?
I'm really hoping as a permanent solution we can find a suitable replacement. I dont like ghetto as far as permanent goes.
socks is offline
 Old 12-01-2009, 04:19 PM   #248
Captain
I'll check when i get home.
www.permtuning.com
 Old 12-01-2009, 05:15 PM   #249
Deadman's Avatar
Relief Valves, Thermal Relief Valves, Safety Relief Valves, Cryogenic Relief Valves, Pressure Relief Valves, Needle Valves, Control Valves, Cryogenic Relief Valves, Check Valves, Releif Valves, Bi-Lok Tube Fittings, Needle Valves, Thermal Relief Valv
Im sure dustin can find a number on it somewhere...
"UPDATE (11/10/09) Even MORE LNF Goodies
Another Trifecta first, last week we unlocked the fuel rail pressure tables in the LNF ECM so customers requiring raised fuel rail pressure for upgraded turbos can get all the fuel they need! "
Unlocked By djuosnteisn kthx
http://www.carsponsors.com/420576
^another direct injection car (GT35r) stuck @ 400whp... hrmm i see a trend here lol. trifecta is working with the sky to unlock fuel tables and rail pressures etc i do believe
Deadman is offline
 Old 12-01-2009, 05:26 PM   #250
Captain
That inline one looks awesome, but our relief valve isn't NPT. Doesn't mean we can't use adapters tho.
www.permtuning.com
 Old 12-01-2009, 05:57 PM   #251
Deadman's Avatar
dustin does the valve come off the line or is it 1 piece with the line itself? It looks as if the inline valve could possibly work.. That is if you cant find a part number on the oem.
Deadman is offline
 Old 12-01-2009, 06:48 PM   #252
Captain
It's not attached to the line. I posted some pics of it a few pages back. It threads into the fuel rail with like a 10mm x 1mm pitch (or 1.25mm), and has a line that connects to it similar to the connections on the hpfp low pressure side.
Here's the only writing on the valve:
7.G9.
www.permtuning.com
 Old 12-01-2009, 06:57 PM   #253
Deadman's Avatar
need to check mcmastercarr or someone i suppose... im sure this valve is out there somewhere
Deadman is offline
 Old 12-01-2009, 07:04 PM   #254
Captain
We have a McMaster carr at work, i can check tomorrow i guess. That book is huge though... might take a few years.
I'm gonna play with disks tonight maybe.
www.permtuning.com
 Old 12-01-2009, 07:09 PM   #255
Deadman's Avatar
ya... i mean i wish i had the piece in hand, i think modifying it is gonna be the easiest thing to do at this time.
I checked mcmasters website and did not see anything, and yea i have the book @ work and its huge haha
Deadman is offline
 Old 12-01-2009, 09:36 PM   #256
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
why cant we just machine something that threads into the rail (male end), with a 50thou hole in it and then the female end threads into the stock spill valve. kinda like a spark plug non fouler but with a tiny tiney(sp?) hole in it.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
 Old 12-01-2009, 09:38 PM   #257
You don't want it to bleed pressure all the time.
Lex is offline
 Old 12-01-2009, 09:39 PM   #258
Must Have Teh 10's!
well this wouldent bleed pressure all the time it would only slow down how fast the spill valve saw the actual pressure right?
 Old 12-01-2009, 10:17 PM   #259
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
The angles on the fitting look like the custom threads I used to cut on oil field tools. The threads we cut were on more of an angle through.
We used the angles as sealing surfaces.
Ive been looking at the profiles of various fittings, but I can find one that matches this.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline
 Old 12-01-2009, 10:23 PM   #260
Captain
I don't think this valve is the "spill valve". It's a pressure over load relief valve, most likely used for safety, not proper functionality.
I think an adapter like this would be okay, right lex? No different that me shoving a custom restrictor in the hole?
Or do you have a change of heart about this approach.
Still though, i'm with sockerdoodles, best options is a complete replacement with a valve that opens at higher pressure, like 2300 or 2500 psi.
www.permtuning.com
 Old 12-02-2009, 06:11 AM   #261
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
It might be easier to drill out the valve and thread the rubber hose end for metal tubing and then find an inline valve.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 12-02-2009, 06:32 AM   #262
Must Have Teh 10's!
yah my idea was pretty much the same concept as the restrictor thingie but instead you thread it on both sides and you never have to worry about it moving around in there at 2200psi.
but +1 if we can find a replacement
 Old 12-02-2009, 06:49 AM   #263
socks's Avatar
Groans: 125
the probelm when you do that is your then going to have to deal with rail pressure in a rubber line.
Its fine when you have the relief valve there, because it doesnt pass rail pressure on. Thus it can pass into a rubber line (such as the stock one).
If you drill that valve out, your gonna have to make whatever you put past that capable of dealing with 2000psi of fuel.
socks is offline
 Old 12-02-2009, 08:25 AM   #264
An adapter with a hole drilled out will work - obviously you'd have to have the threads machined properly. If those are not sealing threads (NPT or similar) you will need whatever is sealing that valve on the rail duplicated.
Drilling out the valve is not the best idea as socks mentioned IMO.
I was thinking the disc with a hole against the flat end of the valve might be cheap/easy way to do it.
Lex is offline
 Old 12-02-2009, 08:39 AM   #265
Captain
This valve seems to seal on the surface, not on the threads. It's straight threaded.
I'll make a disc soon, and see if it fits in there, but if it's too thick the sealing surface may not touch. We'll see soon.
I feel sick as shit today tho. Swine flu. I'm fucked.
www.permtuning.com
 Old 12-02-2009, 08:58 AM   #266
Get better man, the Mazda can wait.
Lex is offline
 Old 12-02-2009, 01:20 PM   #267
masskaos's Avatar
Posts: 262   (View Stats)
masskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond repute
i think i might have found something that could work with an adapter fitting. the good thing about this is that it's adjustable.
relief valves - direct operated
part number 62299169 or 62299144
masskaos is offline
 Old 12-02-2009, 01:42 PM   #268
shook02's Avatar
Posts: 720   (View Stats)
shook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the world
Groaned at 20 Times in 10 Posts
oh man swine flu.... well it was fun while it lasted!
2010 Black Mica speed3]
Cobb SRI, Turbosmart BPV, Jbarone ssp, 6k lows, 20% tint all around, Corksport TP
shook02 is offline
 Old 12-02-2009, 04:35 PM   #269
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
3000psi
SpeedSixxx is offline
 Old 12-02-2009, 06:25 PM   #270
KoukiS14's Avatar
Posts: 146   (View Stats)
KoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond repute
Sure, that might work, but, umm, did you see the price? Fuck that!
KoukiS14 is offline
 Old 12-02-2009, 06:31 PM   #271
socks's Avatar
Groans: 125
thats a drop in the bucket bro, especially if it will open up the potential as much as we think it might.
socks is offline
 Old 12-02-2009, 06:42 PM   #272
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
$350 to get the extra 100~300 hp some of these turbo's and built motors have left in them, that's a bargan..
SSinstaller is offline
 Old 12-02-2009, 06:45 PM   #273
Must Have Teh 10's!
yah but that 350 dollar valve isent gona change shit if you cant scale the sensor more.
 Old 12-02-2009, 06:53 PM   #274
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
my dads brother died from swine flue on Saturday. he was 46 and in perfect health prior to getting sick. You should get checked out.
 Old 12-02-2009, 07:25 PM   #275
Captain
I really have no clue wtf i have. All the sudden this morning i just felt like i was 90 years old. Body so fucking achy, like sharp aches and dull pains and brain never really turned on.
I'm just gonna keep up on liquids and ride it out. I think i'll be fine, but yeah, if it gets worse i'll def get checked out.
As far as the valve goes, yeah, if we planned on running higher and higher pressures, eventually we'd have to upgrade to a higher pressure sensor, cause the stock is only good for 400~500 more psi. And honestly beyond that, i think the injector operation might become a lil iffy.
Personally i don't want to spend 350 on a new valve, i'll probably try the disk first. Still tho, great find Mass!
www.permtuning.com
 Old 12-02-2009, 09:54 PM   #276
Speeeeeed
06Speed6's Avatar
Ide buy that valve, that isnt a bad price for a valve if it is high enough quality to hold a consistent pressure for a few years etc, it would suck if it lost or gained pressure.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 12-02-2009, 10:51 PM   #277
In the end we might not need a valve at all. This is why starting with a cheap disk to test is best. You can also put a restrictor pill in the hose that is low pressure downstream of the valve. As long as you don't make the pill very small, it should restrict enough flow.
Lex is offline
 Old 12-03-2009, 06:46 AM   #278
masskaos's Avatar
i would not recommend putting in a restrictor pill downstream. that will increase pressure in the low pressure line and could make it burst.
masskaos is offline
 Old 12-03-2009, 08:03 AM   #279
Deadman's Avatar
somewhere someone has to make this exact piece... hrmmm
Deadman is offline
 Old 12-03-2009, 08:18 AM   #280
It's a matter of how large of a restrictor Ideally however it should be on the high pressure side, I agree. I don't think it would take much of a restriction to bump the rail pressure up.
Lex is offline
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 08-02-2019 11:09 PM
TIRE PRESSURE SENSOR... redneckrecon MazdaSpeed 3/6 - Wheels & Tires 12 01-21-2011 07:23 PM
How to scale the HPFP pressure sensor djuosnteisn MazdaSpeed 3/6 - ECU Computer Tuning 521 04-07-2010 08:39 AM
Page generated in 0.58670 seconds with 34 queries
